Folks,
Am running VSC 1.95.1 on Mageia Linux.
I have a 52833 board that I have working in that I can write to and read from custom BLE characteristics and send data out on the UART, but receiving is proving impossible.
Issue 1
The biggest issue is that in the UART callback function I'm constantly getting calls with UART_RX_DISABLED being the evt->type
static void uart_callback(const struct device *dev, struct uart_event *evt, void *user_data){ uint8_t i; switch (evt->type) { case UART_TX_DONE: break; case UART_TX_ABORTED: break; case UART_RX_RDY: for (i=0; i<evt->data.rx.len; i++) { serial_mess_in[mess_in_index++] = evt->data.rx.buf[i]; if (mess_in_index >= MESS_IN_SIZE) mess_in_index = 0; } break; case UART_RX_BUF_REQUEST: set_uart_buffer(); break; case UART_RX_BUF_RELEASED: break; case UART_RX_DISABLED: printk("callback: RX Disabled \n"); rx_enabled = false; rx_enable(dev); break; case UART_RX_STOPPED: break; default: printk("callback: other, go investigate\n"); break; }}static void set_uart_buffer(void){ current_buffer ^= 0x01; uint16_t sof; sof = sizeof(rx_buff[current_buffer]); uart_rx_buf_rsp (cuteU, &rx_buff[current_buffer][0], RX_BUFF_SIZE); }"message": "cannot open source file \"stddef.h\" (dependency of \"zephyr/types.h\")",
"message": "ignoring malformed line 'CONFIG_ARM_MPU=y'",
# SPDX-License-Identifier: Apache-2.0# Enable MPUCONFIG_ARM_MPU=y# Enable hardware stack protectionCONFIG_HW_STACK_PROTECTION=y# Enable RTTCONFIG_USE_SEGGER_RTT=y# enable GPIOCONFIG_GPIO=y# enable uart driverCONFIG_SERIAL=y# enable consoleCONFIG_CONSOLE=yCONFIG_UART_CONSOLE=y"resource": "/home/XXXXX/ncs/v2.7.0/zephyr/boards/nordic/nrf52833dk/nrf52833dk_nrf52833_defconfig",
"owner": "Kconfig no context",
"severity": 4,
"message": "The active build context 'build/BLE_LBS' does not use this file.",
"startLineNumber": 1,
"startColumn": 1,
"endLineNumber": 1,
"endColumn": 1
What does this mean and is it an issue?
Issue 7
"resource": "/home/XXXXXX/ncs/v2.7.0/zephyr/CMakeLists.txt",
"owner": "nrf-connect",
"severity": 4,
"message": "CMake Warning at /home/robertw/ncs/v2.7.0/zephyr/CMakeLists.txt:2027 (message):",
"source": "cmake",
"startLineNumber": 2027,
"startColumn": 1,
"endLineNumber": 2027,
"endColumn": 2147483647
