I'm using
- the nRF52840 DK and the Matter light_bulb example, SDK v2.7.0.
- a raspberry pi with the nRF dongle as a thread border router
- the chip-tool running and compiled for macos (but with the repository version from the SDK)
When trying to pair directly after the device has been unpaired, meaning
- chip-tool pairing ble-thread <node-id> hex:<dataset active -x> 20202021 3840
- chip-tool pairing unpair <node-id>
then the pairing process takes significantly longer due to some reported mDNS error and a lookup for some address that doesn't seem to belong to my device (there are no other nodes on the fabric). The "offending" log in the chip-tool is the following (comparing compared to an OK pairing sequence):
[1731047068526] [4486:2075296] [DIS] Checking node lookup status after 202 ms [1731047071245] [4486:2075296] [DIS] Mdns: OnResolve flags: 0, interface: 11, fullname: BC457DD5B6258255-0000000000000045._matter._tcp.local., hostname: 1E6BC32C13681711.local., port: 5540 [1731047071245] [4486:2075296] [DIS] Mdns : OnNewInterface hostname:1E6BC32C13681711.local. fullname:BC457DD5B6258255-0000000000000045._matter._tcp.local. interface: 11 port: 5540 TXT:"SII=2000,SAI=2000,SAT=4000" [1731047073328] [4486:2075295] [DIS] Mdns: OnGetAddrInfo flags: 3, interface: 0, hostname: 0E38BB10063D903E.local. [1731047073328] [4486:2075295] [DIS] OnGetAddrInfo (kDNSServiceErr_Timeout) [1731047073328] [4486:2075295] [DIS] Mdns: OnGetAddrInfo flags: 2, interface: 0, hostname: 0E38BB10063D903E.local. [1731047073328] [4486:2075295] [DIS] OnGetAddrInfo (kDNSServiceErr_Timeout) [1731047073328] [4486:2075295] [DIS] Mdns: Resolve failure (kDNSServiceErr_BadState) [1731047113327] [4486:2075296] [DIS] Checking node lookup status after 45002 ms [1731047113327] [4486:2075296] [DIS] No longer need resolve for BC457DD5B6258255-0000000000000045 [1731047113327] [4486:2075296] [DIS] OperationalSessionSetup[1:0000000000000045]: operational discovery failed: src/lib/address_resolve/AddressResolve_DefaultImpl.cpp:119: CHIP Error 0x00000032: Timeout [1731047113327] [4486:2075296] [DIS] Retrying operational DNS-SD discovery. Attempts remaining: 2 [1731047113327] [4486:2075296] [DIS] Resolving BC457DD5B6258255:0000000000000045 ... [1731047113327] [4486:2075296] [DIS] Resolve type=_matter._tcp name=BC457DD5B6258255-0000000000000045 interface=0 [1731047113328] [4486:2075296] [CTL] Session establishment failed for <0000000000000045, 1>, error: src/lib/address_resolve/AddressResolve_DefaultImpl.cpp:119: CHIP Error 0x00000032: Timeout. Next retry expected to get a response to Sigma1 or fail within 60 seconds [1731047113328] [4486:2075296] [CTL] Arming failsafe (120 seconds) [1731047113328] [4486:2075296] [DMG] ICR moving to [AddingComm] [1731047113328] [4486:2075296] [DMG] ICR moving to [AddedComma] [1731047113329] [4486:2075296] [EM] <<< [E:10437i S:63980 M:221767263] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:08 (IM:InvokeCommandRequest) [1731047113329] [4486:2075296] [DMG] ICR moving to [AwaitingRe] [1731047113329] [4486:2075296] [DIS] Mdns: OnResolve flags: 0, interface: 11, fullname: BC457DD5B6258255-0000000000000045._matter._tcp.local., hostname: 1E6BC32C13681711.local., port: 5540 [1731047113329] [4486:2075296] [DIS] Mdns : OnNewInterface hostname:1E6BC32C13681711.local. fullname:BC457DD5B6258255-0000000000000045._matter._tcp.local. interface: 11 port: 5540 TXT:"SII=2000,SAI=2000,SAT=4000" [1731047113331] [4486:2075296] [DIS] Mdns: OnGetAddrInfo flags: 1073741826, interface: 11, hostname: 1E6BC32C13681711.local. [1731047113331] [4486:2075296] [DIS] Mdns: OnNewAddress interface: 11 ip:fd21:ad93:14a0:1:d117:fae1:8f33:f012 [1731047113331] [4486:2075296] [DIS] Mdns: Resolve success on interface 11 [1731047113331] [4486:2075296] [DIS] Node ID resolved for BC457DD5B6258255:0000000000000045 [1731047113331] [4486:2075296] [DIS] Hostname: 1E6BC32C13681711 [1731047113331] [4486:2075296] [DIS] IP Address #1: fd21:ad93:14a0:1:d117:fae1:8f33:f012 [1731047113331] [4486:2075296] [DIS] Port: 5540 [1731047113331] [4486:2075296] [DIS] Mrp Interval idle: 2000 ms [1731047113332] [4486:2075296] [DIS] Mrp Interval active: 2000 ms [1731047113332] [4486:2075296] [DIS] Mrp Active Threshold: 4000 ms [1731047113332] [4486:2075296] [DIS] TCP Supported: 0 [1731047113332] [4486:2075296] [DIS] ICD: not present [1731047113332] [4486:2075296] [DIS] Lookup clearing interface for non LL address [1731047113332] [4486:2075296] [DIS] UDP:[fd21:ad93:14a0:1:d117:fae1:8f33:f012%en0]:5540: new best score: 3 [1731047113332] [4486:2075296] [DIS] Checking node lookup status after 5 ms [1731047113332] [4486:2075296] [DIS] Keeping DNSSD lookup active [1731047113503] [4486:2075295] [EM] >>> [E:10437i S:63980 M:22159] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse) [1731047113503] [4486:2075295] [EM] Found matching exchange: 10437i, Delegate: 0x14b504258 [1731047113503] [4486:2075295] [DMG] ICR moving to [ResponseRe] [1731047113503] [4486:2075295] [DMG] InvokeResponseMessage = [1731047113503] [4486:2075295] [DMG] { [1731047113503] [4486:2075295] [DMG] suppressResponse = false, [1731047113503] [4486:2075295] [DMG] InvokeResponseIBs = [1731047113503] [4486:2075295] [DMG] [ [1731047113503] [4486:2075295] [DMG] InvokeResponseIB = [1731047113503] [4486:2075295] [DMG] { [1731047113503] [4486:2075295] [DMG] CommandDataIB = [1731047113503] [4486:2075295] [DMG] { [1731047113503] [4486:2075295] [DMG] CommandPathIB = [1731047113503] [4486:2075295] [DMG] { [1731047113503] [4486:2075295] [DMG] EndpointId = 0x0, [1731047113503] [4486:2075295] [DMG] ClusterId = 0x30, [1731047113503] [4486:2075295] [DMG] CommandId = 0x1, [1731047113503] [4486:2075295] [DMG] }, [1731047113503] [4486:2075295] [DMG] [1731047113503] [4486:2075295] [DMG] CommandFields = [1731047113503] [4486:2075295] [DMG] { [1731047113504] [4486:2075295] [DMG] 0x0 = 0 (unsigned), [1731047113504] [4486:2075295] [DMG] 0x1 = "" (0 chars), [1731047113504] [4486:2075295] [DMG] }, [1731047113504] [4486:2075295] [DMG] }, [1731047113504] [4486:2075295] [DMG] [1731047113504] [4486:2075295] [DMG] }, [1731047113504] [4486:2075295] [DMG] [1731047113504] [4486:2075295] [DMG] ], [1731047113504] [4486:2075295] [DMG] [1731047113504] [4486:2075295] [DMG] InteractionModelRevision = 11 [1731047113504] [4486:2075295] [DMG] }, [1731047113504] [4486:2075295] [DMG] Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001 [1731047113504] [4486:2075295] [CTL] Status of extending fail-safe for CASE retry: 0
The important parts seem to be
- OnGetAddrInfo (kDNSServiceErr_Timeout)
- Mdns: Resolve failure (kDNSServiceErr_BadState)
- OperationalSessionSetup[1:0000000000000045]: operational discovery failed: src/lib/address_resolve/AddressResolve_DefaultImpl.cpp:119: CHIP Error 0x00000032: Timeout
- Session establishment failed for <0000000000000045, 1>, error: src/lib/address_resolve/AddressResolve_DefaultImpl.cpp:119: CHIP Error 0x00000032: Timeout. Next retry expected to get a response to Sigma1 or fail within 60 seconds
I'm not an expert on how mDNS and the translation to DNS-SD works, so I'm really struggling to understand what goes wrong here. My best guess is that maybe a "goodbye" message went missing and therefore the mDNS cache at the border router keeps a now invalid entry. This would explain why the pairing works without problems if you wait for ~2 minutes after unpairing.
Even with the above error, the pairing itself is successful 90% of the time - it just takes significantly longer. Arbitrarily I observed that the sequence failed but (after a reboot of the nRF52840 DK) I could pair successfully.
Is there anything I'm missing? I only found the following tickets on the connectedhomeip project, but they didn't really seem to match my problem
- https://github.com/project-chip/connectedhomeip/issues/31582
- https://github.com/project-chip/connectedhomeip/issues/28568
I'm also attaching a screenshot where the left side is the log of an OK pairing sequence and the right side is a failed sequence.
