Add FOTA over BLE to nrf9151+nrf52840
I have a board which is nrf9151 with nrf52840 as BLE controller connected via hci_lpuart. This works fine so far, I am able to do simple AT commands as well as doing some BLE communication. I am using TF-M for nrf9151
Now I am trying to add FOTA over BLE and I just cannot get this to work. To not complicate it even more I am trying the old way - not using sysbuild, but it doesn't help.
So what I have tried:
1. Add child_image/mcu_boot.conf
2. Add configuration to proj.conf
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_SECURE_BOOT=y
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y
I am using ncs 2.7.0
Michal
  • Hi Michal,
    If you mean using BLE FOTA an nRF9151 with nRF52840, you can refer to a similar discussion here UART DFU of a nRF9160 in recovery mode via nRF5340. - Nordic Q&A - Nordic DevZone - Nordic DevZone
    Charlie
  • Hi Charlie. Thank you for the reply. Please note that the mentioned case is different - there the custom UART protocol is used to communicate nrf53<->nrf91. In my case I use HCI with lp_uart variant.
    Anyway I was able to get it all to compile, but I am just getting an MCU boot compilation error:
    [22/29] Building C object CMakeFiles/app.dir/home/michal/ncs/v2.7.0/bootloader/mcuboot/ext/nrf/cc310_glue.c.obj
    FAILED: CMakeFiles/app.dir/home/michal/ncs/v2.7.0/bootloader/mcuboot/ext/nrf/cc310_glue.c.obj
    ccache /home/michal/ncs/toolchains/e9dba88316/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DKERNEL -DK_HEAP_MEM_POOL_SIZE=0 -DMBEDTLS_CONFIG_FILE=\"/home/michal/ncs/v2.7.0/bootloader/mcuboot/boot/zephyr/include/mcuboot-mbedtls-cfg.h\" -DNCS_APPLICATION_BOOT_BANNER_GIT_REPO -DNRF9120_XXAA -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DUSE_PARTITION_MANAGER=1 -D__PROGRAM_START -D__ZEPHYR__=1 -I/home/michal/ncs/v2.7.0/bootloader/mcuboot/boot/zephyr/include -I/home/michal/ncs/v2.7.0/bootloader/mcuboot/boot/zephyr/targets -I/home/michal/ncs/v2.7.0/bootloader/mcuboot/boot/bootutil/include -I/home/michal/ncs/v2.7.0/bootloader/mcuboot/ext/mbedtls-asn1/include -I/home/michal/ncs/v2.7.0/bootloader/mcuboot/ext/nrf -I/home/michal/ncs/v2.7.0/zephyr/include -I/home/michal/repos/MG105/build/mcuboot/zephyr/include/generated -I/home/michal/ncs/v2.7.0/zephyr/soc/nordic -I/home/michal/ncs/v2.7.0/zephyr/soc/nordic/nrf91/. -I/home/michal/ncs/v2.7.0/zephyr/soc/nordic/common/. -I/home/michal/ncs/v2.7.0/nrf/include -I/home/michal/ncs/v2.7.0/nrf/tests/include -I/home/michal/ncs/v2.7.0/modules/hal/cmsis/CMSIS/Core/Include -I/home/michal/ncs/v2.7.0/zephyr/modules/cmsis/. -I/home/michal/ncs/v2.7.0/modules/hal/nordic/nrfx -I/home/michal/ncs/v2.7.0/modules/hal/nordic/nrfx/drivers/include -I/home/michal/ncs/v2.7.0/modules/hal/nordic/nrfx/mdk -I/home/michal/ncs/v2.7.0/zephyr/modules/hal_nordic/nrfx/. -I/home/michal/ncs/v2.7.0/bootloader/mcuboot/boot/bootutil/zephyr/.. -I/home/michal/ncs/v2.7.0/bootloader/mcuboot/boot/bootutil/zephyr/../include -I/home/michal/ncs/v2.7.0/bootloader/mcuboot/boot/bootutil/zephyr/../../zephyr/include -I/home/michal/ncs/v2.7.0/nrfxlib/crypto/nrf_cc310_bl/include -isystem /home/michal/ncs/v2.7.0/zephyr/lib/libc/minimal/include -isystem /home/michal/ncs/v2.7.0/zephyr/lib/libc/common/include -isystem /home/michal/ncs/toolchains/e9dba88316/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include -isystem /home/michal/ncs/toolchains/e9dba88316/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/include-fixed -isystem /home/michal/ncs/v2.7.0/nrfxlib/crypto/nrf_cc310_platform/include -fno-strict-aliasing -Os -imacros /home/michal/repos/MG105/build/mcuboot/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mfp16-format=ieee --sysroot=/home/michal/ncs/toolchains/e9dba88316/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros /home/michal/ncs/v2.7.0/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=/home/michal/ncs/v2.7.0/bootloader/mcuboot/boot/zephyr=CMAKE_SOURCE_DIR -fmacro-prefix-map=/home/michal/ncs/v2.7.0/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/home/michal/ncs/v2.7.0=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir/home/michal/ncs/v2.7.0/bootloader/mcuboot/ext/nrf/cc310_glue.c.obj -MF CMakeFiles/app.dir/home/michal/ncs/v2.7.0/bootloader/mcuboot/ext/nrf/cc310_glue.c.obj.d -o CMakeFiles/app.dir/home/michal/ncs/v2.7.0/bootloader/mcuboot/ext/nrf/cc310_glue.c.obj -c /home/michal/ncs/v2.7.0/bootloader/mcuboot/ext/nrf/cc310_glue.c
    In file included from /home/michal/ncs/v2.7.0/bootloader/mcuboot/ext/nrf/cc310_glue.c:18:
    /home/michal/ncs/v2.7.0/bootloader/mcuboot/ext/nrf/cc310_glue.h: In function 'nrf_cc310_enable':
    /home/michal/ncs/v2.7.0/bootloader/mcuboot/ext/nrf/cc310_glue.h:53:5: error: 'NRF_CRYPTOCELL' undeclared (first use in this function); did you mean 'NRF_CRYPTOCELL_S'?
    53 | NRF_CRYPTOCELL->ENABLE=1;
    | NRF_CRYPTOCELL_S
    /home/michal/ncs/v2.7.0/bootloader/mcuboot/ext/nrf/cc310_glue.h:53:5: note: each undeclared identifier is reported only once for each function it appears in
    /home/michal/ncs/v2.7.0/bootloader/mcuboot/ext/nrf/cc310_glue.h: In function 'nrf_cc310_disable':
    /home/michal/ncs/v2.7.0/bootloader/mcuboot/ext/nrf/cc310_glue.h:58:5: error: 'NRF_CRYPTOCELL' undeclared (first use in this function); did you mean 'NRF_CRYPTOCELL_S'?
    58 | NRF_CRYPTOCELL->ENABLE=0;
    | NRF_CRYPTOCELL_S
    FAILED: _sysbuild/sysbuild/images/bootloader/mcuboot-prefix/src/mcuboot-stamp/mcuboot-build /home/michal/repos/MG105/build/_sysbuild/sysbuild/images/bootloader/mcuboot-prefix/src/mcuboot-stamp/mcuboot-build
    cd /home/michal/repos/MG105/build/mcuboot && /home/michal/ncs/toolchains/e9dba88316/usr/local/bin/cmake --build .
    FATAL ERROR: command exited with status 1: /home/michal/ncs/toolchains/e9dba88316/usr/local/bin/cmake --build /home/michal/repos/MG105/build
    I don't think I am including cc310 and MCU boot doesn't use it as far as I read, so how do I disable this?
    Michal
  • Hi Michal,
    I have not seen anyone tried this before. If nRF9160 can receiving image over BLE, there shouldn't be any issue to do update.
    You may refer to the codes following exercies to implment a smp server on nRF9160 side, then test with uart to make sure there is no issue with mcuboot to do firmware udpate first.
    Exercise 3 - FOTA over Bluetooth Low Energy - Nordic Developer Academy
    Charlie
