nrf52811 bluetooth SES code
Hi
I am trying to use nrf52811 using nrf52840 DK board.
First, I check simple GPIO example working on my nrf52811 based custom boards
Second, I checked the Bluetooth example for my boards and I have an issue.
I follow below step
0. My hardware configuration is following below document "Schematic CAAA WLCSP with two layers" (32mHz crystals)
https://docs.nordicsemi.com/bundle/ps_nrf52811/page/ref_circuitry.html
1. Use main code from below Bluetooth peripheral template.
https://www.youtube.com/watch?v=sMXkbtEMgy4&list=PLiKJljyEUlZj4z8RqJKTaoMpSqjLdBGO4&index=57
2. Modify the project.emproject file to match with nrf52811 setting from nrf52840 dk  .emproject setting.
Actually I didn't understand what I have to do in this step. So I just used the code that given from below link "vidar berg" pca10056e.zip file and an additional library and header file for my project.
https://devzone.nordicsemi.com/f/nordic-q-a/75481/porting-an-example-from-pca10056-to-pca10056e-segger-embedded-studio
<!DOCTYPE CrossStudio_Project_File>
<solution Name="ble_app_bluetooth_nrf5281 ongoing" target="8" version="2">
  <configuration
    Name="Debug"
    c_preprocessor_definitions="DEBUG; DEBUG_NRF"
    gcc_optimization_level="None" />
  <configuration
    Name="Release"
    c_preprocessor_definitions="NDEBUG"
    gcc_optimization_level="Optimize For Size"
    link_time_optimization="No" />
  <project Name="ble_app_uart_c_pca10056e_s140">
    <configuration
      Name="Common"
      arm_architecture="v7EM"
      arm_core_type="Cortex-M4"
      arm_endian="Little"
      arm_fp_abi="Soft"
      arm_fpu_type="Soft"
      arm_linker_heap_size="2048"
      arm_linker_process_stack_size="0"
      arm_linker_stack_size="2048"
      arm_linker_treat_warnings_as_errors="No"
      arm_simulator_memory_simulation_parameter="RWX 00000000,00100000,FFFFFFFF;RWX 20000000,00010000,CDCDCDCD"
      arm_target_device_name="nRF52811_xxAA"
      arm_target_interface_type="SWD"
      c_preprocessor_definitions="APP_TIMER_V2;APP_TIMER_V2_RTC1_ENABLED;BOARD_PCA10056;DEVELOP_IN_NRF52840;NRFX_COREDEP_DELAY_US_LOOP_CYCLES=3;CONFIG_GPIO_AS_PINRESET;FLOAT_ABI_SOFT;INITIALIZE_USER_SECTIONS;NO_VTOR_CONFIG;NRF52811_XXAA;NRF_SD_BLE_API_VERSION=7;S140;SOFTDEVICE_PRESENT;"
      c_user_include_directories="../../../config;../../../../../../components;../../../../../../components/ble/ble_advertising;../../../../../../components/ble/ble_db_discovery;../../../../../../components/ble/ble_dtm;../../../../../../components/ble/ble_racp;../../../../../../components/ble/ble_services/ble_ancs_c;../../../../../../components/ble/ble_services/ble_ans_c;../../../../../../components/ble/ble_services/ble_bas;../../../../../../components/ble/ble_services/ble_bas_c;../../../../../../components/ble/ble_services/ble_cscs;../../../../../../components/ble/ble_services/ble_cts_c;../../../../../../components/ble/ble_services/ble_dfu;../../../../../../components/ble/ble_services/ble_dis;../../../../../../components/ble/ble_services/ble_gls;../../../../../../components/ble/ble_services/ble_hids;../../../../../../components/ble/ble_services/ble_hrs;../../../../../../components/ble/ble_services/ble_hrs_c;../../../../../../components/ble/ble_services/ble_hts;../../../../../../components/ble/ble_services/ble_ias;../../../../../../components/ble/ble_services/ble_ias_c;../../../../../../components/ble/ble_services/ble_lbs;../../../../../../components/ble/ble_services/ble_lbs_c;../../../../../../components/ble/ble_services/ble_lls;../../../../../../components/ble/ble_services/ble_nus;../../../../../../components/ble/ble_services/ble_nus_c;../../../../../../components/ble/ble_services/ble_rscs;../../../../../../components/ble/ble_services/ble_rscs_c;../../../../../../components/ble/ble_services/ble_tps;../../../../../../components/ble/common;../../../../../../components/ble/nrf_ble_gatt;../../../../../../components/ble/nrf_ble_gq;../../../../../../components/ble/nrf_ble_qwr;../../../../../../components/ble/nrf_ble_scan;../../../../../../components/ble/peer_manager;../../../../../../components/boards;../../../../../../components/libraries/atomic;../../../../../../components/libraries/atomic_fifo;../../../../../../components/libraries/atomic_flags;../../../../../../components/libraries/balloc;../../../../../../components/libraries/bootloader/ble_dfu;../../../../../../components/libraries/bsp;../../../../../../components/libraries/button;../../../../../../components/libraries/cli;../../../../../../components/libraries/crc16;../../../../../../components/libraries/crc32;../../../../../../components/libraries/crypto;../../../../../../components/libraries/csense;../../../../../../components/libraries/csense_drv;../../../../../../components/libraries/delay;../../../../../../components/libraries/ecc;../../../../../../components/libraries/experimental_section_vars;../../../../../../components/libraries/experimental_task_manager;../../../../../../components/libraries/fds;../../../../../../components/libraries/fifo;../../../../../../components/libraries/fstorage;../../../../../../components/libraries/gfx;../../../../../../components/libraries/gpiote;../../../../../../components/libraries/hardfault;../../../../../../components/libraries/hci;../../../../../../components/libraries/led_softblink;../../../../../../components/libraries/log;../../../../../../components/libraries/log/src;../../../../../../components/libraries/low_power_pwm;../../../../../../components/libraries/mem_manager;../../../../../../components/libraries/memobj;../../../../../../components/libraries/mpu;../../../../../../components/libraries/mutex;../../../../../../components/libraries/pwm;../../../../../../components/libraries/pwr_mgmt;../../../../../../components/libraries/queue;../../../../../../components/libraries/ringbuf;../../../../../../components/libraries/scheduler;../../../../../../components/libraries/sdcard;../../../../../../components/libraries/slip;../../../../../../components/libraries/sortlist;../../../../../../components/libraries/spi_mngr;../../../../../../components/libraries/stack_guard;../../../../../../components/libraries/strerror;../../../../../../components/libraries/svc;../../../../../../components/libraries/timer;../../../../../../components/libraries/twi_mngr;../../../../../../components/libraries/twi_sensor;../../../../../../components/libraries/uart;../../../../../../components/libraries/usbd;../../../../../../components/libraries/usbd/class/audio;../../../../../../components/libraries/usbd/class/cdc;../../../../../../components/libraries/usbd/class/cdc/acm;../../../../../../components/libraries/usbd/class/hid;../../../../../../components/libraries/usbd/class/hid/generic;../../../../../../components/libraries/usbd/class/hid/kbd;../../../../../../components/libraries/usbd/class/hid/mouse;../../../../../../components/libraries/usbd/class/msc;../../../../../../components/libraries/util;../../../../../../components/nfc/ndef/conn_hand_parser;../../../../../../components/nfc/ndef/conn_hand_parser/ac_rec_parser;../../../../../../components/nfc/ndef/conn_hand_parser/ble_oob_advdata_parser;../../../../../../components/nfc/ndef/conn_hand_parser/le_oob_rec_parser;../../../../../../components/nfc/ndef/connection_handover/ac_rec;../../../../../../components/nfc/ndef/connection_handover/ble_oob_advdata;../../../../../../components/nfc/ndef/connection_handover/ble_pair_lib;../../../../../../components/nfc/ndef/connection_handover/ble_pair_msg;../../../../../../components/nfc/ndef/connection_handover/common;../../../../../../components/nfc/ndef/connection_handover/ep_oob_rec;../../../../../../components/nfc/ndef/connection_handover/hs_rec;../../../../../../components/nfc/ndef/connection_handover/le_oob_rec;../../../../../../components/nfc/ndef/generic/message;../../../../../../components/nfc/ndef/generic/record;../../../../../../components/nfc/ndef/launchapp;../../../../../../components/nfc/ndef/parser/message;../../../../../../components/nfc/ndef/parser/record;../../../../../../components/nfc/ndef/text;../../../../../../components/nfc/ndef/uri;../../../../../../components/nfc/platform;../../../../../../components/nfc/t2t_lib;../../../../../../components/nfc/t2t_parser;../../../../../../components/nfc/t4t_lib;../../../../../../components/nfc/t4t_parser/apdu;../../../../../../components/nfc/t4t_parser/cc_file;../../../../../../components/nfc/t4t_parser/hl_detection_procedure;../../../../../../components/nfc/t4t_parser/tlv;../../../../../../components/softdevice/common;../../../../../../components/softdevice/s140/headers;../../../../../../components/softdevice/s140/headers/nrf52;../../../../../../components/toolchain/cmsis/include;../../../../../../external/fprintf;../../../../../../external/segger_rtt;../../../../../../external/utf_converter;../../../../../../integration/nrfx;../../../../../../integration/nrfx/legacy;../../../../../../modules/nrfx;../../../../../../modules/nrfx/drivers/include;../../../../../../modules/nrfx/hal;../../../../../../modules/nrfx/mdk;../config"
      debug_additional_load_file="../../../../../../components/softdevice/s140/hex/s140_nrf52_7.2.0_softdevice.hex"
      debug_register_definition_file="../../../../../../modules/nrfx/mdk/nrf52811.svd"
      debug_start_from_entry_point_symbol="No"
      debug_target_connection="J-Link"
      gcc_debugging_level="Level 3"
      gcc_entry_point="Reset_Handler"
      linker_output_format="hex"
      linker_printf_fmt_level="long"
      linker_printf_width_precision_supported="Yes"
      linker_scanf_fmt_level="long"
      linker_section_placement_file="flash_placement.xml"
      linker_section_placement_macros="FLASH_PH_START=0x0;FLASH_PH_SIZE=0x30000;RAM_PH_START=0x20000000;RAM_PH_SIZE=0x6000;FLASH_START=0x27000;FLASH_SIZE=0x9000;RAM_START=0x20002a38;RAM_SIZE=0x35c8"
      linker_section_placements_segments="FLASH RX 0x0 0x30000;RAM1 RWX 0x20000000 0x6000"
      macros="CMSIS_CONFIG_TOOL=../../../../../../external_tools/cmsisconfig/CMSIS_Configuration_Wizard.jar"
      project_directory=""
      project_type="Executable" />
    <folder Name="Application">
      <file file_name="../../../main.c" />
      <file file_name="../config/sdk_config.h" />
    </folder>
    <folder Name="Board Definition">
      <file file_name="../../../../../../components/boards/boards.c" />
    </folder>
    <folder Name="Board Support">
      <file file_name="../../../../../../components/libraries/bsp/bsp.c" />
      <file file_name="../../../../../../components/libraries/bsp/bsp_btn_ble.c" />
    </folder>
    <folder Name="None">
      <file file_name="../../../../../../modules/nrfx/mdk/ses_startup_nrf52811.s" />
      <file file_name="../../../../../../modules/nrfx/mdk/ses_startup_nrf_common.s" />
      <file file_name="../../../../../../modules/nrfx/mdk/system_nrf52811.c" />
    </folder>
    <folder Name="nRF_BLE">
      <file file_name="../../../../../../components/ble/common/ble_advdata.c" />
      <file file_name="../../../../../../components/ble/ble_advertising/ble_advertising.c" />
      <file file_name="../../../../../../components/ble/common/ble_conn_params.c" />
      <file file_name="../../../../../../components/ble/common/ble_conn_state.c" />
      <file file_name="../../../../../../components/ble/ble_db_discovery/ble_db_discovery.c" />
      <file file_name="../../../../../../components/ble/common/ble_srv_common.c" />
      <file file_name="../../../../../../components/ble/nrf_ble_gatt/nrf_ble_gatt.c" />
      <file file_name="../../../../../../components/ble/nrf_ble_gq/nrf_ble_gq.c" />
      <file file_name="../../../../../../components/ble/nrf_ble_qwr/nrf_ble_qwr.c" />
      <file file_name="../../../../../../components/ble/nrf_ble_scan/nrf_ble_scan.c" />
    </folder>
    <folder Name="nRF_BLE_Services">
      <file file_name="../../../../../../components/ble/ble_services/ble_nus_c/ble_nus_c.c" />
    </folder>
    <folder Name="nRF_Drivers">
      <file file_name="../../../../../../integration/nrfx/legacy/nrf_drv_clock.c" />
      <file file_name="../../../../../../integration/nrfx/legacy/nrf_drv_uart.c" />
      <file file_name="../../../../../../modules/nrfx/soc/nrfx_atomic.c" />
      <file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_clock.c" />
      <file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_gpiote.c" />
      <file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_uart.c" />
      <file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_uarte.c" />
    </folder>
    <folder Name="nRF_Libraries">
      <file file_name="../../../../../../components/libraries/button/app_button.c" />
      <file file_name="../../../../../../components/libraries/util/app_error.c" />
      <file file_name="../../../../../../components/libraries/util/app_error_handler_gcc.c" />
      <file file_name="../../../../../../components/libraries/util/app_error_weak.c" />
      <file file_name="../../../../../../components/libraries/fifo/app_fifo.c" />
      <file file_name="../../../../../../components/libraries/scheduler/app_scheduler.c" />
      <file file_name="../../../../../../components/libraries/timer/app_timer2.c" />
      <file file_name="../../../../../../components/libraries/uart/app_uart_fifo.c" />
      <file file_name="../../../../../../components/libraries/util/app_util_platform.c" />
      <file file_name="../../../../../../components/libraries/timer/drv_rtc.c" />
      <file file_name="../../../../../../components/libraries/hardfault/hardfault_implementation.c" />
      <file file_name="../../../../../../components/libraries/util/nrf_assert.c" />
      <file file_name="../../../../../../components/libraries/atomic_fifo/nrf_atfifo.c" />
      <file file_name="../../../../../../components/libraries/atomic_flags/nrf_atflags.c" />
      <file file_name="../../../../../../components/libraries/atomic/nrf_atomic.c" />
      <file file_name="../../../../../../components/libraries/balloc/nrf_balloc.c" />
      <file file_name="../../../../../../external/fprintf/nrf_fprintf.c" />
      <file file_name="../../../../../../external/fprintf/nrf_fprintf_format.c" />
      <file file_name="../../../../../../components/libraries/memobj/nrf_memobj.c" />
      <file file_name="../../../../../../components/libraries/pwr_mgmt/nrf_pwr_mgmt.c" />
      <file file_name="../../../../../../components/libraries/queue/nrf_queue.c" />
      <file file_name="../../../../../../components/libraries/ringbuf/nrf_ringbuf.c" />
      <file file_name="../../../../../../components/libraries/experimental_section_vars/nrf_section_iter.c" />
      <file file_name="../../../../../../components/libraries/sortlist/nrf_sortlist.c" />
      <file file_name="../../../../../../components/libraries/strerror/nrf_strerror.c" />
      <file file_name="../../../../../../components/libraries/uart/retarget.c" />
    </folder>
    <folder Name="nRF_Log">
      <file file_name="../../../../../../components/libraries/log/src/nrf_log_backend_rtt.c" />
      <file file_name="../../../../../../components/libraries/log/src/nrf_log_backend_serial.c" />
      <file file_name="../../../../../../components/libraries/log/src/nrf_log_default_backends.c" />
      <file file_name="../../../../../../components/libraries/log/src/nrf_log_frontend.c" />
      <file file_name="../../../../../../components/libraries/log/src/nrf_log_str_formatter.c" />
    </folder>
    <folder Name="nRF_Segger_RTT">
      <file file_name="../../../../../../external/segger_rtt/SEGGER_RTT.c" />
      <file file_name="../../../../../../external/segger_rtt/SEGGER_RTT_printf.c" />
      <file file_name="../../../../../../external/segger_rtt/SEGGER_RTT_Syscalls_SES.c" />
    </folder>
    <folder Name="nRF_SoftDevice">
      <file file_name="../../../../../../components/softdevice/common/nrf_sdh.c" />
      <file file_name="../../../../../../components/softdevice/common/nrf_sdh_ble.c" />
      <file file_name="../../../../../../components/softdevice/common/nrf_sdh_soc.c" />
    </folder>
    <folder Name="Segger Startup Files">
      <file file_name="$(StudioDir)/source/thumb_crt0.s" />
    </folder>
    <folder Name="UTF8/UTF16 converter">
      <file file_name="../../../../../../external/utf_converter/utf.c" />
    </folder>
  </project>
</solution>
3. There is no error while I building the project. But even though I upload it to my nrf52811 my phones nrf SDK app cannot find my device.
(Same main code work at nrf52840 dk board, and simple gpio main code is work at nrf52811)
My question is I want to fully understand step 2 and get the solution for my project.
I am using nRF5_SDK_17.1.0_ddde560.
Thank you for your any advice.
    Have you done any debugging in order to find out what is wrong? What did you learn from that? If not, pelase start by observing logs or just debug and see if an error handler is reached (which seems likely).
    The post you linked to give a good overview. Which particular steps do you need more information about? (I suggest focusing on debugging for now though, as you have followed a guide and are able to build without errors.)
  • Thanks for your answer. I solve it by following RTT logging Thank you!
