I used sdk 2.6.1,
when performing FOTA, should we disable the watchdog timer? If so, how can we disable it?
I used sdk 2.6.1,
Some FOTA applications do disable watchdog, but it is an architectural choice that you can make. A code snippet on how to do it can be as below. Please use this as a reference only as I have not tested this to work.
#include <zephyr.h>
#include <drivers/watchdog.h>
#define WDT_TIMEOUT_MS 10000 // Watchdog timeout in milliseconds (adjust as needed)
#define WDT_DEVICE_NAME DT_LABEL(DT_NODELABEL(wdt0))
static const struct device *wdt_dev;
static int wdt_channel_id = -1;
// Set up the watchdog timer to ensure system stability by resetting on timeouts
void watchdog_init(void) {
// Get the watchdog device
wdt_dev = device_get_binding(WDT_DEVICE_NAME);
if (!wdt_dev) {
printk("Error: Cannot find watchdog device\n");
return;
// Configure the watchdog timer with the specified timeout and reset behavior
struct wdt_timeout_cfg wdt_config = {
.window = { .min = 0, .max = K_MSEC(WDT_TIMEOUT_MS) },
.callback = NULL, // We’re not using a callback for simplicity
.flags = WDT_FLAG_RESET_SOC // Trigger a full system reset on timeout
// Install the watchdog timeout with the configuration above
wdt_channel_id = wdt_install_timeout(wdt_dev, &wdt_config);
if (wdt_channel_id < 0) {
printk("Error: Failed to install watchdog timeout\n");
return;
// Start the watchdog timer
int err = wdt_setup(wdt_dev, 0);
if (err) {
printk("Error: Failed to set up watchdog\n");
return;
printk("Watchdog initialized with %d ms timeout\n", WDT_TIMEOUT_MS);
// Function to enable the watchdog, which starts the countdown
void watchdog_enable(void) {
if (wdt_channel_id >= 0) {
wdt_feed(wdt_dev, wdt_channel_id); // Feed the watchdog to start it
printk("Watchdog enabled\n");
} else {
printk("Error: Watchdog channel not initialized\n");
// Function to disable the watchdog, typically before long operations like FOTA
void watchdog_disable(void) {
int err = wdt_disable(wdt_dev); // Disables the watchdog, if supported by your SDK
if (err == 0) {
printk("Watchdog disabled\n");
} else {
printk("Error: Unable to disable watchdog\n");
} else {
// Call this function right before starting a FOTA update to avoid unexpected resets
void prepare_for_fota(void) {
watchdog_disable(); // Temporarily turn off watchdog for the update
// Any other FOTA preparation steps can go here
// Call this function after FOTA completes to re-enable the watchdog
void post_fota_cleanup(void) {
// Any necessary cleanup steps after FOTA can go here
watchdog_enable(); // Re-enable the watchdog to restore normal operation
// Function to regularly feed the watchdog to prevent unwanted resets
void watchdog_feed_periodic(void) {
wdt_feed(wdt_dev, wdt_channel_id); // Reset the watchdog timer countdown
