uint32_t ble_cus_sensor_state_update(ble_cus_t * p_cus, int8_t * p_buttons_states, int length, uint16_t conn_handle) { ble_gatts_hvx_params_t params; uint16_t len = length; uint32_t err_code; memset(¶ms, 0, sizeof(params)); params.type = BLE_GATT_HVX_NOTIFICATION;//BLE_GATT_HVX_NOTIFICATION; params.handle = p_cus->leds_states_char_handles.value_handle; params.p_data = p_buttons_states; params.p_len = &len; return sd_ble_gatts_hvx(conn_handle, ¶ms); } void ble_cus_send_sensor_data(uint8_t *data, uint16_t len) { ret_code_t err_code; uint32_t timer = millis(); do{ err_code = ble_cus_sensor_state_update(&m_cus, data, len, m_conn_handle); }while(err_code == BLE_ERROR_GATTS_SYS_ATTR_MISSING && millis() - timer < 3000 && (err_code == NRF_ERROR_RESOURCES)); if ( err_code != NRF_SUCCESS && err_code != BLE_ERROR_INVALID_CONN_HANDLE && err_code != NRF_ERROR_INVALID_STATE && /* (err_code != NRF_ERROR_RESOURCES) &&*/ err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING) { APP_ERROR_CHECK(err_code); } } void send_current_data(void) { printf("Sending current data \n"); for(int i=0;i<500;i++) { memset(lv_data_header,0,sizeof(lv_data_header)); lv_data_header[0] =0xFF; lv_data_header[0] =i; ble_cus_send_sensor_data(lv_data_header, 2); if( m_ble_cust_packet_sent == true) { printf("Sending current data packet %d \n",i); ble_cus_send_sensor_data(lv_data_header, 2); } } } void cus_evt_handler(ble_cus_t * p_cus, ble_cus_evt_t * p_evt) { uint8_t u8_cmd_id = 0; switch(p_evt->evt_type) { case BLE_LEDS_STATES_CHAR_EVT_COMMAND_RX: { if(p_evt->params_command.command_data.p_data[0] == 0XFD) { send_current_data(); } } }
Hi Nordic team
Currently I am trying to send a big chunk of data close to 100 KB from my nRF52832 to nRF connect for mobile app in Android phone. I am able to send few bytes in one shot. But when I kept a loop for sending more than 10 data packets, my code is getting stuck in while loop and sd_ble_gatts_hvx returns NRF_ERROR_RESOURCES error. After that my application is stuck until I restart the application. It is not accepting any new command and stops sending the data.
I already change hvn_tx_queue_size = 20 and NRF_SDH_BLE_GAP_EVENT_LENGTH to 20 even to larger number , but still it doesn't resolve the issue.
Also it is blocking BLE_GATTS_EVT_HVN_TX_COMPLETE event handler. So I am unable to understand if the queue buffer resource is empty or not.
