Disable interrupts to enter critical section on nRF5340
Hi!
I'm working on the firmware part that needs to perform operations on the same variables both inside GPIO IRQ and the software timer callback.
So, there is a need for a critical section to make sure they operate properly.
By looking through the documentation, I found that I can use "irq_lock()"/"irq_unlock()" to achieve this (software timer implementation also makes use of these under the hood), but I found that after calling irq_lock(), GPIO interrupts are not locked.
Diving deeper into the "lock()" implementation, I found the following:
So, BASEPRI register is set with the value 32 (_EXC_IRQ_DEFAULT_PRIO).
So, all priorities higher than 32 (numerically lower) can generate interrupts while the code is insiode this critical section.
According to the *.dts config, "NUM_IRQ_PRIO_BITS" is set to 3, so lowest IRQ priority possible should be 8.
With default configuration, the priority for the GPIO interrupts are 6 (got this value by calling "NVIC_GetPriority(GPIOTE0_IRQn").
Therefiore, it looks like "irq_lock()" does not disable any interrupts.
That is why I need to call something like "irq_disable(GPIOTE0_IRQn)" to explicitly disable GPIO interrupts for the time of processing.
Am I missing something here or is it correct behaviour for the "irq_lock()"?
Anton
