tx_rx_non_blocking sample fails to build
I'm trying to build the "tx_rx_non_blocking" sample (ncs2.70, nRF52840dk) but get the following error message  -
C:/devtools/nordic/ncs/v2.7.0/modules/hal/nordic/nrfx/drivers/include/nrfx_twis.h:71:33: error: 'NRFX_TWIS1_INST_IDX' undeclared here (not in a function); did you mean 'NRFX_TWIS_INSTANCE'?
The 'sister' sample app tx_rx_blocking builds like a charm...
What am I missing here?
Thanks
  • Try adding the below to your prj.conf
    # Enable the I2C peripheral driver
    CONFIG_I2C=y
    CONFIG_I2C_NRFX=y
    CONFIG_NRFX_TWIS=y
    CONFIG_NRFX_TWIS1=y
    CONFIG_I2C_NRFX_TWIS=y
    CONFIG_I2C_SLAVE=y
  • Problem solved.
    Apparently, the problem is in the file \boards\nrf52840dk_nrf52840.dtsi
    It has a wrong inclusion path hence when initially creating a build configuration something gets broken and creates the problem above.
    The way to fix:
    1. Copy the sample
    2. Add a build configuration (in my case it was nrf52840dk, -Og (debug optimization)). Click 'Build Configuration'
         Note that the initial build fails
    3. modify line #1 of \boards\nrf52840dk_nrf52840.dtsi  to :
    // #include "../../../common/common-pinctrl.dtsi" // BAD
    #include "../common/common-pinctrl.dtsi" // GOOD
    4. Run pristine build. Voila, it works
