problem about AT%XCBAND=?
hi support team,
customer had one problem about "AT%XCBAND=? "
first. Customer try to set catm and catnb systemmode together as below, i could not see the band17 in list:
[16:43:53.099] AT%XFACTORYRESET=0
[16:48:21.233]
[16:48:21.233] OK
[16:48:21.233] AT%XFACTORYRESET=1
[16:48:23.659]
[16:48:23.659] OK
[16:48:23.659] AT%XBANDLOCK=1,"10001100000001010"
[16:48:26.335]
[16:48:26.335] OK
[16:48:26.335] AT%XBANDLOCK=2,"10001100000001010"
[16:48:29.173]
[16:48:29.173] OK
[16:48:29.173] AT%XCBAND=?
[16:48:32.368]
[16:48:32.368] %XCBAND: (2,4,12,13)
then we change systemmode to catnb only, it shows band17 as below:
[16:49:16.633] AT%XSYSTEMMODE=0,1,0,0
[16:49:21.557]
[16:49:21.557] OK
[16:49:21.557] AT%XCBAND=?
[16:49:26.089]
[16:49:26.089] %XCBAND: (2,4,12,13,17)
then. i start the modem as AT+CFUN=1, the band 17 show quite slow:
[16:49:56.018] AT+CFUN=1
[16:50:02.586]
[16:50:02.586] OK
[16:50:02.586] AT%XCBAND=?
[16:50:08.516]
[16:50:08.516] %XCBAND: (2,4,12,13)
[16:50:08.516]
[16:50:08.516] OK
[16:50:08.516] AT%XCBAND=?
[16:50:13.511]
[16:50:13.511] %XCBAND: (2,4,12,13)
[16:50:13.511]
[16:50:13.512] OK
[16:50:13.512] AT%XCBAND=?
[16:50:18.510]
[16:50:18.510] %XCBAND: (2,4,12,13)
[16:50:18.512]
[16:50:18.512] OK
[16:50:18.512] AT%XCBAND=?
[16:50:23.519]
[16:50:23.519] %XCBAND: (2,4,12,13,17)
[16:50:23.519]
[16:50:23.519] OK
the question is ,is there any reason for this command?
William.
  • Hi William,
    We do not support band 17 on LTE-M, as stated here in the release notes for the mfw v1.3.6:
    *** mfw_nrf9160_1.3.6
    The mfw_nrf9160 is the firmware for the modem subsystem of nRF9160. It supports 3GPP LTE release 13
    LTE-M and NB-IoT standards, selected optional 3GPP LTE release 14 features, GPS L1C/A and QZSS L1C/A
    positioning.
    LTE-M operation is enabled on E-UTRA Bands 1, 2, 3, 4, 5, 8, 12, 13, 18, 19, 20, 25, 26, 28 and 66.
    NB-IoT operation is enabled on E-UTRA Bands 1, 2, 3, 4, 5, 8, 12, 13, 17, 19, 20, 25, 26, 28 and 66.
    Also reflected here in the chart:
    https://www.nordicsemi.com/Products/Wireless/Low-power-cellular-IoT/nRF9160-Revision-1-global-and-regulatory-certifications
    Håkon
  • yes,Hakon
    i understand your meaning, my point is band 17 is not listed at the first moment, but shows at about 10 seconds later.
    we have any reason for this?
    [16:50:18.510]
    [16:50:18.512]
    [16:50:18.512] OK
    [16:50:23.519]
    William.
  • Hi William,
    My apologies for misunderstanding the scenario.
    I tried to recreate this locally, but was not able to do so:
    [2024-11-15 13:59:38] *** Using Zephyr OS v3.7.99-adcffa835a8e ***
    [2024-11-15 13:59:38] The AT host sample started
    [2024-11-15 13:59:38] Ready
    [2024-11-15 13:59:43] AT%XFACTORYRESET=1
    [2024-11-15 13:59:44] OK
    [2024-11-15 13:59:50] AT%XBANDLOCK=1,"10001100000001010"
    [2024-11-15 13:59:50] OK
    [2024-11-15 13:59:54] AT%XBANDLOCK=2,"10001100000001010"
    [2024-11-15 13:59:54] OK
    [2024-11-15 13:59:58] AT%XCBAND=?
    [2024-11-15 13:59:59] %XCBAND: (2,4,12,13)
    [2024-11-15 13:59:59] OK
    [2024-11-15 14:00:04] AT%XSYSTEMMODE=0,1,0,0
    [2024-11-15 14:00:09] OK
    [2024-11-15 14:00:10] AT%XCBAND=?
    [2024-11-15 14:00:10] %XCBAND: (2,4,12,13,17)
    [2024-11-15 14:00:10] OK
    [2024-11-15 14:00:19] at+cfun=1
    [2024-11-15 14:00:21] OK
    [2024-11-15 14:00:21] AT%XCBAND=?
    [2024-11-15 14:00:21] %XCBAND: (2,4,12,13,17)
    [2024-11-15 14:00:22] AT%XCBAND=?
    [2024-11-15 14:00:22] %XCBAND: (2,4,12,13,17)
    [2024-11-15 14:00:22] OK
    [2024-11-15 14:00:23] AT%XCBAND=?
    [2024-11-15 14:00:23] %XCBAND: (2,4,12,13,17)
    [2024-11-15 14:00:23] OK
    Which modem fw are you running? This can be read out using "at+cgmr"
    I was running this on mfw v1.3.6.
    Håkon
  • yes Hakon,
    the same mfm1.3.6 as you.
    You are reproducing my question, you can set AT%XSYSTEMMODE=1,1,0,0, and please try again.
    you can see that %XCBAND: (2,4,12,13,17) appears at about 15 seconds.
    William.
  • Hi William,
    If we look at the documentation for XSYSTEMMODE:
    https://docs.nordicsemi.com/bundle/ref_at_commands/page/REF/at_commands/mob_termination_ctrl_status/xsystemmode_set.html
    You are enabling both NB + LTE-M modes, then enabling the modem. It will start up with LTE-M and then switch over to NB-IoT. Could this be the reason why you're seeing this behavior?
    Try setting "at+cereg=5" and checking the return (at+cereg?) for each time you poll the %XCBAND to verify which mode is used.
    Håkon
