Hi
I want to run an epaper with the nRF52832 therefore is SPI needed.
Board file was generated from scratch. In the devicetree I added the SPI modul and a epaper modul, which connects to the SPI modul.
To send data to the epaper over SPI I use the spi_transceive_dt function.
void EPaper_Spi_WriteByte(uint8_t txData)
uint8_t tx_buffer = 0x88;
struct spi_buf tx_spi_buf = {
.buf = (void *)&tx_buffer,
.len = 1
struct spi_buf_set tx_spi_buf_set = {
.buffers = &tx_spi_buf,
.count = 1
struct spi_buf rx_spi_bufs = {
.buf = &txData,
.len = 1
struct spi_buf_set rx_spi_buf_set = {
.buffers = &rx_spi_bufs,
.count = 1
int err = spi_transceive_dt(&spiSpec, &tx_spi_buf_set, &rx_spi_buf_set);
if (err < 0) {
printk("SPI: spi_transceive_dt() failed, err: %d\n", err);
return err;
Chipselect and MOSI Signal ar working as requeried. But the SCL signal does nothing, it stays the whole time on low. Even when pin MOSI and SCL are swapped in devicetree, SCL is still low.
Do you have any idea why the SCL signal does not work? Hopfully I added all requeried files.
Project - Digitale Laufkarte
We reserve all rights in this document and in the information contained
therein. Reproduction, use or disclosure to third parties without express
authority is strictly forbidden.
(c) Copyright 2024 Marelcom AG
$HeadURL: $
$Id: epaper.c 145 2024-11-11 13:31:16Z mr $
// includes
#include "epaper.h"
#include "bsp.h"
#include <zephyr/drivers/spi.h>
// defines
#define EPAPER_WIDTH_PX 384
#define EPAPER_HEIGHT_PX 168
#define SPIOP SPI_WORD_SET(8) | SPI_TRANSFER_MSB
// typedef
// module static variable
//struct spi_dt_spec s_epaperSpispec = SPI_DT_SPEC_GET(DT_NODELABEL(gendev), SPIOP, 0);
static const struct gpio_dt_spec dcPin_spec = GPIO_DT_SPEC_GET(DT_NODELABEL(epaper_display), dc_gpios);
static const struct gpio_dt_spec rstPin_spec = GPIO_DT_SPEC_GET(DT_NODELABEL(epaper_display), reset_gpios);
static const struct gpio_dt_spec busyPin_spec = GPIO_DT_SPEC_GET(DT_NODELABEL(epaper_display), busy_gpios);
static const struct gpio_dt_spec csPin_spec = GPIO_DT_SPEC_GET(DT_NODELABEL(spi0), cs_gpios);
/*static const struct device *spi_dev;
static const struct spi_config spi_cfg = {
.frequency = 1000000, // Frequenz: 1 MHz
.operation = SPI_OP_MODE_MASTER | SPI_WORD_SET(8) | SPI_TRANSFER_MSB, // Full-Duplex
.slave = 0,
.cs = NULL,
struct spi_dt_spec spiSpec = SPI_DT_SPEC_GET(DT_NODELABEL(epaper_display), SPIOP, 0);
// macro
#define EPAPER_CS_CLEAR (gpio_pin_set_dt(&csPin_spec, 1))
#define EPAPER_CS_SET (gpio_pin_set_dt(&csPin_spec, 0))
#define EPAPER_COMMAND (gpio_pin_set_dt(&dcPin_spec, 0))
#define EPAPER_DATA (gpio_pin_set_dt(&dcPin_spec, 1))
// private function prototype
void EPaper_Reset(void);
void EPaper_Spi_WriteByte(uint8_t txData);
void EPaper_Write_Command(uint8_t cmd);
void EPaper_Write_Data(uint8_t data);
void EPaper_WaitForNotBusy(void);
// description:
// EPaper_Init
void EPaper_Init(void)
// SPI-Gerät abrufen
/*spi_dev = DEVICE_DT_GET(DT_NODELABEL(spi0));
if (!spi_dev) {
printk("SPI device not found\n");
return;
bool err = spi_is_ready_dt(&spiSpec);
if (!err) {
printk("Error: SPI device is not ready, err: %d\n", err);
return 0;
// GPIOs für DC, RST und BUSY einrichten und prüfen
if (!device_is_ready(dcPin_spec.port) || !device_is_ready(rstPin_spec.port) || !device_is_ready(busyPin_spec.port) || !device_is_ready(csPin_spec.port)) {
printk("GPIO device not ready\n");
return;
gpio_pin_configure_dt(&busyPin_spec, GPIO_INPUT);
gpio_pin_configure_dt(&csPin_spec, GPIO_OUTPUT_HIGH);
gpio_pin_configure_dt(&dcPin_spec, GPIO_OUTPUT_HIGH);
gpio_pin_configure_dt(&rstPin_spec, GPIO_OUTPUT_LOW);
EPAPER_CS_CLEAR;
EPAPER_DATA;
// init E-Paper
k_msleep(10);
EPaper_Reset();
EPaper_WaitForNotBusy(); //读busy信号
EPaper_Write_Command(0x12); // 软件复位 soft reset
Display_All_White();
gpio_pin_set_dt(&rstPin_spec, 0);
k_msleep(10);
gpio_pin_set_dt(&rstPin_spec, 1);
k_msleep(10);
while(1)
if (gpio_pin_get_dt(&busyPin_spec) == 0)
k_usleep(5);
k_usleep(100);
/*void EPaper_DisplayImage(const uint8_t *image_data, size_t len)
struct spi_buf tx_buf = {
.buf = image_data,
.len = len, // Bildgröße anpassen
struct spi_buf_set tx = {
.buffers = &tx_buf,
.count = 1,
// SPI-Konfiguration wird automatisch aus dem Device Tree übernommen
int ret = spi_write(spi_dev, &spi_cfg, &tx); // Die Konfiguration wird durch den Device Tree bestimmt
if (ret < 0) {
// Fehlerbehandlung
printk("SPI: Write Image Data failed");
return ret;
return 0;
void EPaper_Clear(void)
* Function name: EPaper_Spi_WriteByte
* Description: SPI writes a byte
* Input: TxData: byte to be written
* Output: None
/*struct spi_buf tx_buf = {
.buf = &txData,
.len = 1,
.buffers = &tx_buf,
.count = 1,
if (ret < 0) {
return ret;
.len = 1
.count = 1
.buf = &txData,
.len = 1
.count = 1
if (err < 0) {
return err;
* Function name: EPaper_Write_Command
* Description: Write command
* Input: cmd
* Output: None
EPAPER_CS_SET;
EPAPER_COMMAND;
k_usleep(5) ;
EPaper_Spi_WriteByte(cmd);
k_usleep(5) ;
EPAPER_CS_CLEAR;
* Function name: EPaper_Write_Data
* Description: Write data
* Input: data
* Output: None
EPAPER_CS_SET;
EPAPER_DATA;
k_usleep(5) ;
EPaper_Spi_WriteByte(data);
k_usleep(5) ;
EPAPER_CS_CLEAR;
* Function name: Epaper_Update_and_Deepsleep
* Description: Update & enter deep sleep
* Input: None
* Output: None
void EPaper_UpdateAndDeepsleep(void)
EPaper_Write_Command(0x20);
EPaper_Write_Command(0x10);
EPaper_Write_Data(0x01);
k_msleep(100);
* Function name: Display_All_White
* Description: Refresh the display to all white
* Input: None
* Output: None
void Display_All_White(void)
uint32_t col = 0;
uint32_t row = 0;
EPaper_Write_Command(0x24);
for (col = 0; col < EPAPER_WIDTH_PX; col++)
for (row = 0; row < EPAPER_HEIGHT_PX / 8; row++)
EPaper_Write_Data(0xFF);
EPaper_Write_Command(0x26);
EPaper_Write_Data(0x00);
* Function name: Display_All_Black
* Description: Refresh the display to all black
* Input: None
* Output: None
void Display_All_Black(void)
uint32_t col = 0;
uint32_t row = 0;
* Function name: Display_All_Red
* Description: Refresh the display to all red
* Input: None
* Output: None
void Display_All_Red(void)
uint32_t col = 0;
uint32_t row = 0;
Thanks & best regards
Markus
