I am encountering difficulties connecting to and recovering my nRF52840 board with J-Link on macOS, both via nRF Connect and using nrfjprog
in the terminal. Below are the details of the situation and the errors I’ve encountered.
Context:
- Target Board: nRF52840
- Programming Tool: J-Link
- Environment: macOS, with J-Link and nRF Connect installed
- Objective: Unlock and erase the board to flash new firmware
Problem Encountered:
When I try to connect to the board and flash it, I receive errors both with nrfjprog
and J-Link Commander. Below are the specific errors observed.
Additionally, I am able to successfully flash other Nordic microcontrollers and use the J-Link for different applications, boards, and firmware. This suggests that the J-Link itself is functioning correctly with other setups.
Logs and Error Messages:
1. Error with nrfjprog --recover --family nRF52
When using the nrfjprog --recover --family nRF52
command, I receive the following messages:
Recovering device. This operation might take 30s.
[error] [ Client] - Encountered error -21: Command recover executed for 115 milliseconds with result -21
[error] [ Worker] - Encountered unexpected debug port ID 0, expected 2
ERROR: Recover failed. Please make sure that the correct device family is given
ERROR: and try again.
NOTE: For additional output, try running again with logging enabled (--log).
NOTE: Any generated log error messages will be displayed
2. Attempted Connection via J-Link Commander:
When launching J-Link Commander with the following parameters: JLinkExe -device nRF52840_xxAA -if SWD -speed 4000
, I receive the error message:
Connecting to target via SWD
InitTarget() start
InitTarget() end - Took 3.14ms
Failed to attach to CPU. Trying connect under reset.
InitTarget() start
InitTarget() end - Took 106ms
Error occurred: Could not connect to the target device.
For troubleshooting steps visit: https://wiki.segger.com/J-Link_Troubleshooting
3. Library Error When Using nRF Connect:When trying to flash via nRF Connect, another error related to the `libjlinkarm.dylib` library appears, suggesting a problem loading the library. Here’s the full message:
Failed "reading readback protection status for application core". Error: code: 1, description: Generic, message: Batch task protection-get failed, [Probe] Emulator error: Unable to load J-Link DLL: DlOpen { desc: "dlopen(/Applications/SEGGER/JLink/libjlinkarm.dylib, 0x0005): tried: '/Users/Engineering/Library/Application Support/nrfconnect/nrfutil-sandboxes/device/2.6.4/lib/nrfutil-device/libjlinka
Error: Failed with exit code 1. One or more batch tasks failed: - [Probe] Emulator error: Unable to load J-Link DLL: DlOpen { desc: "dlopen(/Applications/SEGGER/JLink/libjlinkarm.dylib, 0x0005): tried: '/Users/Engineering/Library/Application Support/nrfconnect/nrfutil-sandboxes/device/2.6.4/lib/nrfutil-device/libjlinka, code: Generic.
Steps Already Attempted to Resolve the Issue:
1. Reinstall the latest versions of J-Link and nRF Connect.
2. Use the command line with
nrfjprog
specifying--family nRF52
.3. Lower the debug speed with
--clk 125kHz
to see if it improves the connection.4. Verify that `libjlinkarm.dylib` is present in `/Applications/SEGGER/JLink/`.
5. Try launching nRF Connect with the library path `
DYLD_LIBRARY_PATH
` set.Despite these attempts, the errors persist.
Do you have any additional suggestions for resolving this issue? The `nrfjprog` error with the unexpected "debug port ID" seems to indicate protection, but I am unable to perform a `recover`. Any help to diagnose and unblock the situation would be greatly appreciated!
Thank you in advance for your assistance.
