I want to change static_passkey from "000000" to "0000".
But It doesn't work when I update changed code to board.
I changed like below pictures.(000000 -> 0000)
And this is the code of PASSKEY
Please help me.
Please help me.
"Doesn't work" means I can't find this device when I scanned by app.
Setting the STATIC_PASSKEY value to "0000" is indeed the right way to do do. You might also need to adjust the following parameters for it:
#define SEC_PARAM_MITM 1
#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_DISPLAY_ONLY
This has been described in this ticket: (https://devzone.nordicsemi.com/f/nordic-q-a/101940/how-to-config-lesc?ReplyFilter=Answers&ReplySortBy=Answers&ReplySortOrder=Descending) and shows an example on how to implement these changes in the context of the ble_app_hrs example.
Hope this helps.
Best Regards,
Swathy
Oh, Sorry.
I didn't write that part.
I coded that part like this :
#define SEC_PARAM_BOND 1 /**< Perform bonding. */
#define SEC_PARAM_MITM 1 /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC 0 /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS 0 /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_DISPLAY_ONLY /**< Display only I/O capabilities. */
#define SEC_PARAM_OOB 0 /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE 7 /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE 16 /**< Maximum encryption key size. */
#define STATIC_PASSKEY "000000" /**< Paring pass-key */
But I found the reason of this issue.
The passkey must be 6 digits. So I can't change passkey to 4 digits.
I heard that this is related to Bluetooth, Android security regulations.
Is it right??
