Hi
for DFU is bluetooth used by default. Your DFU app suports only using bluetooth to do a DFU.
Do you have any tools to do a DFU over NFC? Or do I have to write a tool by myself?
Thanks and best regards
Markus
Hi
Markus
Hi Markus,
Could you give more information about your application ?
Usually NFC is not the best option to transfer DFU image file due to the slower throughput.
We don't have any example or tool that show casing transferring image with NFC. But I don't see any reason it can't be done.
Hi
yes shure:
The device is like a label. It has an e-paper and is driven by a button cell battery. User will send the display data over NFC to the device, while using a smartphone.
The main goal is that the DFU uses as less power as possible. As far as I can tell, NFC is more power efficient than Bluetooth, correct?
Hi Markus,
I don't think doing DFU via NFC is more power efficiency than BLE. The biggest challenge is that the NFC communication is slow, the buffer is small and you will have to wake up the CPU to receive and response on each packet. I think if you calculate the energy for the same process, NFC DFU may draw more current than BLE. With BLE the radio receive larger the data packet without waking up the CPU. The CPU then only wake up when the buffer is ready to write to flash.
You may want to do some test to verify that. So far I haven't seen any of our customers doing DFU over NFC.
I’m currently looking into implementing DFU over NFC for a similar low-power device.
Were you able to get it working in the end? Any lessons learned would be very helpful.
Best regards
David
Hi David
finaly I took the out of the box solution DFU over BLE. Since the development effort was to high of implementing DFU over NFC in comparision of power saving.
best regards
Markus
