Serial LTE Modem IPV6 problem on PPP connection establishment
I'm using firmware 1.3.6 and SDK 2.7.
I have a ppp connection problem for IPV6. Tables below show connection status:
When I use SLM:
ISP / PDP + APN "IPV6" + "internet.v6.telekom" "IPV4V6" + "internet.telekom"
Congstar
No Yes
Telefonica
Yes Yes
When I use MOSH:
Congstar
Yes Yes
Telefonica
Yes Yes
Here is our ppp conf:
/dev/ttymxc0
921600
-detach
noauth
crtscts
#noccp
#novj
#nodeflate
#nobsdcomp
#nomagic
local
debug
+ipv6
#ipv6cp-use-ipaddr
# currently we just use the default resolv.conf entries
# because of the read-only file-system
#usepeerdns
noipdefault
defaultroute
ipv6cp-restart 5
ipcp-restart 5
#lcp-echo-interval 0
I tried lots of combinations to comment out / uncomment options on ppp but nothing changed.
Question is why MOSH was working fine with several combinations of ppp conf and given pdp + apn and different ISP, on the other hand, SLM doesn't work with any combination of ppp conf and "IPV6" + "internet.v6.telekom" on Congstar?
What might be the reason? Where can I take a look first?
By the way: Connection problem doesn't mean getting IP from ISP. In any cases, modem is able to get IP address (v4 or v6) without any problem and we can see it with AT+CGDCONT? command. The problem was pppd is not able to establish network interface only combination on SLM + "IPV6" + "internet.v6.telekom" + Congstar.
Modem side:
+CEREG: 0,1,"05D7","01B6DA0F",7
+CGDCONT: 0,"IPV6","internet.v6.telekom","2A01:0599:0112:8997:555E:3F0D:3B4C:3F52",0,0
pppd side:
Nov 15 09:21:35 mosdon-rev-a4 pppd[21279]: pppd 2.4.9 started by root, uid 0
Nov 15 09:21:35 mosdon-rev-a4 pppd[21279]: using channel 21
Nov 15 09:21:35 mosdon-rev-a4 pppd[21279]: Using interface ppp0
Nov 15 09:21:35 mosdon-rev-a4 pppd[21279]: Connect: ppp0 <--> /dev/ttymxc0
Nov 15 09:21:35 mosdon-rev-a4 pppd[21279]: sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0x5c79b0a6> <pcomp> <accomp>]
Nov 15 09:21:38 mosdon-rev-a4 pppd[21279]: sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0x5c79b0a6> <pcomp> <accomp>]
Nov 15 09:21:41 mosdon-rev-a4 pppd[21279]: sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0x5c79b0a6> <pcomp> <accomp>]
Nov 15 09:21:44 mosdon-rev-a4 pppd[21279]: sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0x5c79b0a6> <pcomp> <accomp>]
Nov 15 09:21:47 mosdon-rev-a4 pppd[21279]: sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0x5c79b0a6> <pcomp> <accomp>]
Nov 15 09:21:50 mosdon-rev-a4 pppd[21279]: sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0x5c79b0a6> <pcomp> <accomp>]
Nov 15 09:21:53 mosdon-rev-a4 pppd[21279]: sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0x5c79b0a6> <pcomp> <accomp>]
Nov 15 09:21:56 mosdon-rev-a4 pppd[21279]: sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0x5c79b0a6> <pcomp> <accomp>]
Nov 15 09:21:59 mosdon-rev-a4 pppd[21279]: sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0x5c79b0a6> <pcomp> <accomp>]
Nov 15 09:22:02 mosdon-rev-a4 pppd[21279]: sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0x5c79b0a6> <pcomp> <accomp>]
Nov 15 09:22:05 mosdon-rev-a4 pppd[21279]: LCP: timeout sending Config-Requests
Nov 15 09:22:05 mosdon-rev-a4 pppd[21279]: Connection terminated.
Nov 15 09:22:05 mosdon-rev-a4 pppd[21279]: Receive serial link is not 8-bit clean:
Nov 15 09:22:05 mosdon-rev-a4 pppd[21279]: Problem: all had bit 7 set to 0
Nov 15 09:22:05 mosdon-rev-a4 pppd[21279]: Modem hangup
Nov 15 09:22:05 mosdon-rev-a4 pppd[21279]: Exit.
  • And normally I'm building SLM locally with ppp now I wanted to test its trace as well wih adding "CONFIG_NRF_MODEM_LIB_TRACE=y" but code is not able to built:
    /home/o.tuerk/ncs/v2.7.0/zephyr/include/zephyr/device.h:91:41: error: '__device_dts_ord_DT_CHOSEN_nordic_modem_trace_uart_ORD' undeclared here (not in a function)
    91 | #define DEVICE_NAME_GET(dev_id) _CONCAT(__device_, dev_id)
    /home/o.tuerk/ncs/v2.7.0/zephyr/include/zephyr/toolchain/common.h:137:26: note: in definition of macro '_DO_CONCAT'
    137 | #define _DO_CONCAT(x, y) x ## y
    /home/o.tuerk/ncs/v2.7.0/zephyr/include/zephyr/device.h:91:33: note: in expansion of macro '_CONCAT'
    /home/o.tuerk/ncs/v2.7.0/zephyr/include/zephyr/device.h:228:37: note: in expansion of macro 'DEVICE_NAME_GET'
    228 | #define DEVICE_DT_NAME_GET(node_id) DEVICE_NAME_GET(Z_DEVICE_DT_DEV_ID(node_id))
    /home/o.tuerk/ncs/v2.7.0/zephyr/include/zephyr/device.h:245:34: note: in expansion of macro 'DEVICE_DT_NAME_GET'
    245 | #define DEVICE_DT_GET(node_id) (&DEVICE_DT_NAME_GET(node_id))
    /home/o.tuerk/ncs/v2.7.0/nrf/lib/nrf_modem_lib/trace_backends/uart/uart.c:19:46: note: in expansion of macro 'DEVICE_DT_GET'
    19 | static const struct device *const uart_dev = DEVICE_DT_GET(UART_DEVICE_NODE);
  • How can enable tracing in SLM but at the same time with using ppp as well? Which extra overlay or code snippet etc. should I select?
  • Now I sleect nrf91-modem-trace-uart as Snippet on the Build Configuration. And here is my overlay-ppp-without-cmux.overlay:
    &uart0 {
    status = "okay";
    hw-flow-control;
    current-speed = <921600>;
    &uart1 {
    status = "okay";
    current-speed = <115200>;
    &uart2 {
    status = "okay";
    chosen {
    ncs,slm-ppp-uart = &uart0;
    ncs,slm-uart = &uart1;
    nordic,modem-trace-uart = &uart2;
    And I tried ACM0, ACM1, ACM2 on Cellular Monitor. Nothing worked again.
  • Normally I was building for our custom board but I also tested these on the dev board (https://www.nordicsemi.com/Products/Development-hardware/nRF9160-DK) Especially testing with "Cellular Monitor" was only available with DK. It was not working with Jlink which can be connected to our custom board.
