Concurrent ble Central and Peripheral Implementation Problem in nrf528232
We are currently starting a project using the nRF52832 as our controller, Segger Embedded Studio 5.42a as our IDE, and nRF5 SDK version 17.0.2.
Project Requirement Explanation:
I want to create an nRF52832-based gateway module that can connect peripheral devices and the nRF Connect app simultaneously.
  1. Initial Connection: Nordic UART Service-based BLE peripheral devices automatically connect to the gateway device. In this stage, the gateway device acts as a central device.
  2. Gateway as Peripheral: After peripheral device connection, the gateway device acts as a peripheral, advertises, and connects to the nRF Connect app.
  3. Data Sharing: Once connected to the app, the gateway device shares the connected devices' MAC IDs, device names, and Nordic UART data received from peripheral devices.
  4. Command and Data Transmission: When the app sends data or commands along with a specific peripheral device's MAC ID, the data is sent to the corresponding device.
Steps Followed:
To meet these requirements, I examined the nRF5 SDK for a suitable concurrent central and peripheral example project. The ble_app_uart_hrs_rscs project seemed like a good starting point. I incorporated parts of the ble_app_uart_c project for central NUS data handling and the ble_app_uart project for peripheral data handling. I also modified the RAM start address to 0x20004718 in the section placement macros.
However, I'm encountering a fatal error after enabling the SoftDevice. I'm unsure about the cause and whether my NUS integration into the ble_app_uart_hrs_rscs project is correct. I'll attach the code for further clarification.
 * Copyright (c) 2014 - 2020, Nordic Semiconductor ASA
 * All rights reserved.
 * @brief BLE Heart Rate and Running Speed relay application main file.
 * @detail This application demonstrates a simple relay, which passes on the values it receives.
 * By combining a collector part on one end and a sensor part on the other,
 * the s130 can function simultaneously as a central and a peripheral device.
 * The following figure shows how the sensor ble_app_hrs connects and interacts with the relay
 * in the same manner it would connect to a Heart Rate Collector. In this case, the relay
 * application acts as a central.
 * On the other side, a collector (such as Master Control Panel or ble_app_hrs_c) connects
 * and interacts with the relay in the same manner it would connect to a heart rate sensor peripheral.
 * LED layout:
 * LED 1: Central side is scanning.       LED 2: Central side is connected to a peripheral.
 * LED 3: Peripheral side is advertising. LED 4: Peripheral side is connected to a central.
 * @note While testing, make sure that the Sensor and Collector are actually connecting to the relay,
 *       and not directly to each other!
 *    Peripheral                  Relay                    Central
 *    | Heart  |        | Heart     |   Heart  |        |           |
 *    | Rate   | -----> | Rate     -|-> Rate   | -----> | Collector |
 *    | Sensor |        | Collector |   Sensor |        |           |
 *    +--------+        +-----------|   and    |        +-----------+
 *                      | Running   |   Running|
 *    +--------+        | Speed    -|-> Speed  |
 *    | Running|------> | Collector |   Sensor |
 *    | Speed  |        +-----------|----------+
 *    | Sensor |
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "app_timer.h"
#include "bsp_btn_ble.h"
#include "ble.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "ble_db_discovery.h"
#include "ble_hrs.h"
#include "ble_rscs.h"
#include "ble_hrs_c.h"
#include "ble_rscs_c.h"
#include "ble_conn_state.h"
#include "ble_nus.h"
#include "ble_nus_c.h"
#include "nrf_fstorage.h"
#include "fds.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_ble_scan.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
char Bledatabuff[64];
#define PERIPHERAL_ADVERTISING_LED      BSP_BOARD_LED_2
#define PERIPHERAL_CONNECTED_LED        BSP_BOARD_LED_3
#define CENTRAL_SCANNING_LED            BSP_BOARD_LED_0
#define CENTRAL_CONNECTED_LED           BSP_BOARD_LED_1
#define DEVICE_NAME                     "nRF Relay"                                 /**< Name of device used for advertising. */
#define MANUFACTURER_NAME               "NordicSemiconductor"                       /**< Manufacturer. Passed to Device Information Service. */
#define APP_ADV_INTERVAL                300                                         /**< The advertising interval (in units of 0.625 ms). This value corresponds to 187.5 ms. */
#define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define APP_BLE_CONN_CFG_TAG            1                                           /**< Tag that identifies the SoftDevice BLE configuration. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to the first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_BOND                  1                                           /**< Perform bonding. */
#define SEC_PARAM_MITM                  0                                           /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC                  0                                           /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS              0                                           /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_NONE                        /**< No I/O capabilities. */
#define SEC_PARAM_OOB                   0                                           /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE          7                                           /**< Minimum encryption key size in octets. */
#define SEC_PARAM_MAX_KEY_SIZE          16                                          /**< Maximum encryption key size in octets. */
#define HART_RATE_SERVICE_UUID_IDX      0                                           /**< Hart Rate service UUID index in array. */
#define RSCS_SERVICE_UUID_IDX           1                                           /**< RSCS service UUID index in array. */
#define NUS_SERVICE_UUID_TYPE   BLE_UUID_TYPE_VENDOR_BEGIN              /**< UUID type for the Nordic UART Service (vendor specific). */
/**@brief   Priority of the application BLE event handler.
 * @note    You shouldn't need to modify this value.
#define APP_BLE_OBSERVER_PRIO           3
#define DB_DISCOVERY_INSTANCE_CNT       2  /**< Number of DB Discovery instances. */
static ble_hrs_t m_hrs;                                             /**< Heart Rate Service instance. */
static ble_rscs_t m_rscs;                                           /**< Running Speed and Cadence Service instance. */
static ble_hrs_c_t m_hrs_c;                                         /**< Heart Rate Service client instance. */
static ble_rscs_c_t m_rscs_c;
                                      /**< Running Speed and Cadence Service client instance. */
BLE_NUS_C_DEF(m_ble_nus_c);                                        /**< BLE Nordic UART Service (NUS) client instance. */
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                   // peripherel instance of NUS  ( modified )
NRF_BLE_GQ_DEF(m_ble_gatt_queue,                                    /**< BLE GATT Queue instance. */
               NRF_SDH_BLE_CENTRAL_LINK_COUNT,
               NRF_BLE_GQ_QUEUE_SIZE);
NRF_BLE_GATT_DEF(m_gatt);                                              /**< GATT module instance. */
NRF_BLE_QWRS_DEF(m_qwr, NRF_SDH_BLE_TOTAL_LINK_COUNT);                 /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                    /**< Advertising module instance. */
BLE_DB_DISCOVERY_ARRAY_DEF(m_db_discovery, 2);                         /**< Database discovery module instances. */
NRF_BLE_SCAN_DEF(m_scan);                                           /**< Scanning module instance. */
static uint16_t m_conn_handle_hrs_c  = BLE_CONN_HANDLE_INVALID;     /**< Connection handle for the HRS central application */
static uint16_t m_conn_handle_rscs_c = BLE_CONN_HANDLE_INVALID;     /**< Connection handle for the RSC central application */
static uint16_t m_conn_handle_nus_c  = BLE_CONN_HANDLE_INVALID;     /**< Handle of the current connection for the nus  */
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - OPCODE_LENGTH - HANDLE_LENGTH; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
/**@brief Names that the central application scans for, and that are advertised by the peripherals.
 *  If these are set to empty strings, the UUIDs defined below are used.
static char const m_target_periph_name[] = "";
/**@brief UUIDs that the central application scans for if the name above is set to an empty string,
 * and that are to be advertised by the peripherals.
static ble_uuid_t m_adv_uuids[] =
    {BLE_UUID_HEART_RATE_SERVICE,        BLE_UUID_TYPE_BLE},
    {BLE_UUID_RUNNING_SPEED_AND_CADENCE, BLE_UUID_TYPE_BLE}
/**@brief NUS UUID. */
static ble_uuid_t const m_nus_uuid =
    .uuid = BLE_UUID_NUS_SERVICE,
    .type = NUS_SERVICE_UUID_TYPE
static ble_gap_scan_params_t m_scan_param =                 /**< Scan parameters requested for scanning and connection. */
    .active        = 0x01,
    .interval      = NRF_BLE_SCAN_SCAN_INTERVAL,
    .window        = NRF_BLE_SCAN_SCAN_WINDOW,
    .filter_policy = BLE_GAP_SCAN_FP_ACCEPT_ALL,
    .timeout       = NRF_BLE_SCAN_SCAN_DURATION,
    .scan_phys     = BLE_GAP_PHY_1MBPS,
    .extended      = true,
/**@brief Function for handling asserts in the SoftDevice.
 * @details This function is called in case of an assert in the SoftDevice.
 * @warning This handler is an example only and is not meant for the final product. You need to analyze
 *          how your product is supposed to react in case of assert.
 * @param[in] line_num     Line number of the failing assert call.
 * @param[in] p_file_name  File name of the failing assert call.
    app_error_handler(0xDEADBEEF, line_num, p_file_name);
/**@brief Function for handling the Heart Rate Service Client
 *        Running Speed and Cadence Service Client.
static void service_error_handler(uint32_t nrf_error)
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling errors from the Connection Parameters module.
static void scan_evt_handler(scan_evt_t const * p_scan_evt)
    ret_code_t err_code;
    ble_gap_evt_adv_report_t const * p_adv =
                   p_scan_evt->params.filter_match.p_adv_report;
    ble_gap_scan_params_t    const * p_scan_param =
                   p_scan_evt->p_scan_params;
    switch(p_scan_evt->scan_evt_id)
        case NRF_BLE_SCAN_EVT_FILTER_MATCH:
            // Initiate connection.
            err_code = sd_ble_gap_connect(&p_adv->peer_addr,
                                          p_scan_param,
                                          &m_scan.conn_params,
                                          APP_BLE_CONN_CFG_TAG);
        } break;
        case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
            err_code = p_scan_evt->params.connecting_err.err_code;
        } break;
        case NRF_BLE_SCAN_EVT_CONNECTED:
            ble_gap_evt_connected_t const * p_connected = p_scan_evt->params.connected.p_connected;
            NRF_LOG_INFO("Connected to target %02x%02x%02x%02x%02x%02x",
                         p_connected->peer_addr.addr[0],
                         p_connected->peer_addr.addr[1],
                         p_connected->peer_addr.addr[2],
                         p_connected->peer_addr.addr[3],
                         p_connected->peer_addr.addr[4],
                         p_connected->peer_addr.addr[5]);
        } break;
/**@brief Function for initialization the scanning and setting the filters.
static void scan_init(void)
    nrf_ble_scan_init_t init_scan;
    memset(&init_scan, 0, sizeof(init_scan));
    init_scan.p_scan_param = &m_scan_param;
    init_scan.connect_if_match = true;
    init_scan.conn_cfg_tag     = APP_BLE_CONN_CFG_TAG;
    err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
    if (strlen(m_target_periph_name) != 0)
        err_code = nrf_ble_scan_filter_set(&m_scan,
                                           SCAN_NAME_FILTER,
                                           m_target_periph_name);
                                       SCAN_UUID_FILTER,
                                       &m_adv_uuids[HART_RATE_SERVICE_UUID_IDX]);
                                       SCAN_UUID_FILTER,
                                       &m_adv_uuids[RSCS_SERVICE_UUID_IDX]);
    err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_UUID_FILTER, &m_nus_uuid);
    err_code = nrf_ble_scan_filters_enable(&m_scan,
                                           NRF_BLE_SCAN_ALL_FILTER,
                                           false);
/**@brief Function for initializing the scanning.
static void scan_start(void)
    err_code = nrf_ble_scan_start(&m_scan);
    NRF_LOG_INFO("nrf_ble_scan_start : %d\n",err_code);
    NRF_LOG_INFO("SCAN START");
/**@brief Function for initializing the advertising and the scanning.
static void adv_scan_start(void)
    //check if there are no flash operations in progress
    if (!nrf_fstorage_is_busy(NULL))
        // Start scanning for peripherals and initiate connection to devices which
        // advertise Heart Rate or Running speed and cadence UUIDs.
        scan_start();
        // Turn on the LED to signal scanning.
        bsp_board_led_on(CENTRAL_SCANNING_LED);
        // Start advertising.
        err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
    pm_handler_on_pm_evt(p_evt);
    pm_handler_disconnect_on_sec_failure(p_evt);
    pm_handler_flash_clean(p_evt);
    switch (p_evt->evt_id)
            adv_scan_start();
/**@brief Function for changing filter settings after establishing the connection.
static void filter_settings_change(void)
    err_code = nrf_ble_scan_all_filter_remove(&m_scan);
                                           SCAN_NAME_FILTER,
    if ((m_conn_handle_hrs_c != BLE_CONN_HANDLE_INVALID) &&
        (m_conn_handle_rscs_c == BLE_CONN_HANDLE_INVALID))
                                           SCAN_UUID_FILTER,
    if ((m_conn_handle_rscs_c != BLE_CONN_HANDLE_INVALID) &&
         m_conn_handle_hrs_c == BLE_CONN_HANDLE_INVALID)
                                           SCAN_UUID_FILTER,
/**@brief Handles events coming from the Heart Rate central module.
static void hrs_c_evt_handler(ble_hrs_c_t * p_hrs_c, ble_hrs_c_evt_t * p_hrs_c_evt)
    switch (p_hrs_c_evt->evt_type)
        case BLE_HRS_C_EVT_DISCOVERY_COMPLETE:
            if (m_conn_handle_hrs_c == BLE_CONN_HANDLE_INVALID)
                m_conn_handle_hrs_c = p_hrs_c_evt->conn_handle;
                NRF_LOG_INFO("HRS discovered on conn_handle 0x%x", m_conn_handle_hrs_c);
                filter_settings_change();
                err_code = ble_hrs_c_handles_assign(p_hrs_c,
                                                    m_conn_handle_hrs_c,
                                                    &p_hrs_c_evt->params.peer_db);
                // Initiate bonding.
                err_code = pm_conn_secure(m_conn_handle_hrs_c, false);
                if (err_code != NRF_ERROR_BUSY)
                // Heart rate service discovered. Enable notification of Heart Rate Measurement.
                err_code = ble_hrs_c_hrm_notif_enable(p_hrs_c);
        } break; // BLE_HRS_C_EVT_DISCOVERY_COMPLETE
        case BLE_HRS_C_EVT_HRM_NOTIFICATION:
            NRF_LOG_INFO("Heart Rate = %d", p_hrs_c_evt->params.hrm.hr_value);
            err_code = ble_hrs_heart_rate_measurement_send(&m_hrs, p_hrs_c_evt->params.hrm.hr_value);
            if ((err_code != NRF_SUCCESS) &&
                (err_code != NRF_ERROR_INVALID_STATE) &&
                (err_code != NRF_ERROR_BUSY) &&
                (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
                APP_ERROR_HANDLER(err_code);
        } break; // BLE_HRS_C_EVT_HRM_NOTIFICATION
            // No implementation needed.
/**@brief Handles events coming from  Running Speed and Cadence central module.
static void rscs_c_evt_handler(ble_rscs_c_t * p_rscs_c, ble_rscs_c_evt_t * p_rscs_c_evt)
    switch (p_rscs_c_evt->evt_type)
        case BLE_RSCS_C_EVT_DISCOVERY_COMPLETE:
            if (m_conn_handle_rscs_c == BLE_CONN_HANDLE_INVALID)
                m_conn_handle_rscs_c = p_rscs_c_evt->conn_handle;
                NRF_LOG_INFO("Running Speed and Cadence service discovered on conn_handle 0x%x",
                             m_conn_handle_rscs_c);
                err_code = ble_rscs_c_handles_assign(p_rscs_c,
                                                    m_conn_handle_rscs_c,
                                                    &p_rscs_c_evt->params.rscs_db);
                err_code = pm_conn_secure(m_conn_handle_rscs_c, false);
                // Running Speed Cadence Service discovered. Enable notifications.
                err_code = ble_rscs_c_rsc_notif_enable(p_rscs_c);
        } break; // BLE_RSCS_C_EVT_DISCOVERY_COMPLETE:
        case BLE_RSCS_C_EVT_RSC_NOTIFICATION:
            ble_rscs_meas_t rscs_measurment;
            NRF_LOG_INFO("Speed      = %d", p_rscs_c_evt->params.rsc.inst_speed);
            rscs_measurment.is_running                  = p_rscs_c_evt->params.rsc.is_running;
            rscs_measurment.is_inst_stride_len_present  = p_rscs_c_evt->params.rsc.is_inst_stride_len_present;
            rscs_measurment.is_total_distance_present   = p_rscs_c_evt->params.rsc.is_total_distance_present;
            rscs_measurment.inst_stride_length = p_rscs_c_evt->params.rsc.inst_stride_length;
            rscs_measurment.inst_cadence       = p_rscs_c_evt->params.rsc.inst_cadence;
            rscs_measurment.inst_speed         = p_rscs_c_evt->params.rsc.inst_speed;
            rscs_measurment.total_distance     = p_rscs_c_evt->params.rsc.total_distance;
            err_code = ble_rscs_measurement_send(&m_rscs, &rscs_measurment);
        } break; // BLE_RSCS_C_EVT_RSC_NOTIFICATION
/**@brief Function for assigning new connection handle to available instance of QWR module.
 * @param[in] conn_handle New connection handle.
static void multi_qwr_conn_handle_assign(uint16_t conn_handle)
    for (uint32_t i = 0; i < NRF_SDH_BLE_TOTAL_LINK_COUNT; i++)
        if (m_qwr[i].conn_handle == BLE_CONN_HANDLE_INVALID)
            ret_code_t err_code = nrf_ble_qwr_conn_handle_assign(&m_qwr[i], conn_handle);
/**@brief   Function for handling BLE events from the central application.
 * @details This function parses scanning reports and initiates a connection to peripherals when a
 *          target UUID is found. It updates the status of LEDs used to report the central application
 *          activity.
static void on_ble_central_evt(ble_evt_t const * p_ble_evt)
    ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
        // Upon connection, check which peripheral is connected (HR or RSC), initiate DB
        // discovery, update LEDs status, and resume scanning, if necessary.
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Central connected");
            // If no Heart Rate sensor or RSC sensor is currently connected, try to find them on this peripheral.
            if (   (m_conn_handle_hrs_c  == BLE_CONN_HANDLE_INVALID)
                || (m_conn_handle_rscs_c == BLE_CONN_HANDLE_INVALID)||(m_conn_handle_nus_c==BLE_CONN_HANDLE_INVALID)) //added an nus or operator checking here .
                NRF_LOG_INFO("Attempt to find HRS or RSC or NUS conn_handle 0x%x", p_gap_evt->conn_handle);
                err_code = ble_db_discovery_start(&m_db_discovery[0], p_gap_evt->conn_handle);
                if (err_code == NRF_ERROR_BUSY)
                    err_code = ble_db_discovery_start(&m_db_discovery[1], p_gap_evt->conn_handle);
            // Assign connection handle to NUS Client
            err_code = ble_nus_c_handles_assign(&m_ble_nus_c, p_ble_evt->evt.gap_evt.conn_handle, NULL);  //added nus handle assigning
            // Assign connection handle to the QWR module.
            multi_qwr_conn_handle_assign(p_gap_evt->conn_handle);
            // Update LEDs status, and check whether to look for more peripherals to connect to.
            bsp_board_led_on(CENTRAL_CONNECTED_LED);
            if (ble_conn_state_central_conn_count() == NRF_SDH_BLE_CENTRAL_LINK_COUNT)
                bsp_board_led_off(CENTRAL_SCANNING_LED);
                // Resume scanning.
                scan_start();
        } break; // BLE_GAP_EVT_CONNECTED
        // Upon disconnection, reset the connection handle of the peer that disconnected,
        // update the LEDs status and start scanning again.
         NRF_LOG_INFO("Device disconnected, conn_handle: 0x%x, reason: 0x%x",
                         p_gap_evt->conn_handle,
                         p_gap_evt->params.disconnected.reason);
            if (p_gap_evt->conn_handle == m_conn_handle_hrs_c)
                NRF_LOG_INFO("HRS central disconnected (reason: %d)",
                                                   SCAN_UUID_FILTER,
                NRF_LOG_INFO("HRS service disconnected.");
            if (p_gap_evt->conn_handle == m_conn_handle_rscs_c)
                NRF_LOG_INFO("RSC central disconnected (reason: %d)",
                                                   SCAN_UUID_FILTER,
                NRF_LOG_INFO("RSCS service disconnected.");
            if (p_gap_evt->conn_handle == m_conn_handle_nus_c)
                NRF_LOG_INFO("NUS service disconnected.");
            if (   (m_conn_handle_rscs_c == BLE_CONN_HANDLE_INVALID)
                || (m_conn_handle_hrs_c  == BLE_CONN_HANDLE_INVALID)||(m_conn_handle_nus_c==BLE_CONN_HANDLE_INVALID)) //added nus connection handle checking
                // Start scanning.
                scan_start();
                // Update LEDs status.
            if (ble_conn_state_central_conn_count() == 0)
                bsp_board_led_off(CENTRAL_CONNECTED_LED);
        } break; // BLE_GAP_EVT_DISCONNECTED
        case BLE_GAP_EVT_TIMEOUT:
            // No timeout for scanning is specified, so only connection attemps can timeout.
            if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                NRF_LOG_INFO("Connection Request timed out.");
        } break;
        case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
            // Accept parameters requested by peer.
            err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                        &p_gap_evt->params.conn_param_update_request.conn_params);
        } break;
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
/**@brief   Function for handling BLE events from peripheral applications.
 * @details Updates the status LEDs used to report the activity of the peripheral applications.
static void on_ble_peripheral_evt(ble_evt_t const * p_ble_evt)
            NRF_LOG_INFO("Peripheral connected");
            bsp_board_led_off(PERIPHERAL_ADVERTISING_LED);
            bsp_board_led_on(PERIPHERAL_CONNECTED_LED);
            multi_qwr_conn_handle_assign(p_ble_evt->evt.gap_evt.conn_handle);
            NRF_LOG_INFO("Peripheral disconnected. conn_handle: 0x%x, reason: 0x%x",
            bsp_board_led_off(PERIPHERAL_CONNECTED_LED);
        } break;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
            NRF_LOG_INFO("Fast advertising.");
            bsp_board_led_on(PERIPHERAL_ADVERTISING_LED);
        } break;
        case BLE_ADV_EVT_IDLE:
            ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
        } break;
/**@brief Function for checking whether a bluetooth stack event is an advertising timeout.
 * @param[in] p_ble_evt Bluetooth stack event.
static bool ble_evt_is_advertising_timeout(ble_evt_t const * p_ble_evt)
    return (p_ble_evt->header.evt_id == BLE_GAP_EVT_ADV_SET_TERMINATED);
    uint16_t conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
    uint16_t role        = ble_conn_state_role(conn_handle);
    NRF_LOG_INFO("enter in ble evt handler \n ");
    // Based on the role this device plays in the connection, dispatch to the right handler.
    if (role == BLE_GAP_ROLE_PERIPH || ble_evt_is_advertising_timeout(p_ble_evt))
        NRF_LOG_INFO("ble gap role peripherel  \n ");
        ble_hrs_on_ble_evt(p_ble_evt, &m_hrs);
        ble_rscs_on_ble_evt(p_ble_evt, &m_rscs);
        ble_nus_on_ble_evt(p_ble_evt, &m_nus);  // Adding this line for NUS peripheral handling
        on_ble_peripheral_evt(p_ble_evt);
    else if ((role == BLE_GAP_ROLE_CENTRAL) || (p_ble_evt->header.evt_id == BLE_GAP_EVT_ADV_REPORT))
        NRF_LOG_INFO("ble gap role central   \n ");
        ble_hrs_c_on_ble_evt(p_ble_evt, &m_hrs_c);
        ble_rscs_c_on_ble_evt(p_ble_evt, &m_rscs_c);
        ble_nus_c_on_ble_evt(p_ble_evt,&m_ble_nus_c);   // need to check this operation is neccesssary
        on_ble_central_evt(p_ble_evt);
/**@brief Function for handling the Nordic UART Service Client errors.
static void nus_error_handler(uint32_t nrf_error)
static void ble_nus_chars_received_log_print(uint8_t * p_data, uint16_t data_len)
  ret_code_t ret_val;
  char received_str[64];
   memset(received_str,0,sizeof(received_str));
   NRF_LOG_DEBUG("Receiving data.");
   NRF_LOG_HEXDUMP_DEBUG(p_data, data_len);
   for (uint32_t i = 0; i < data_len; i++)
	 received_str[i]=p_data[i];
	NRF_LOG_INFO("received_str_from_peripherel  : %s\n",received_str);
static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
 switch (p_ble_nus_evt->evt_type)
     case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
          NRF_LOG_INFO("Discovery complete");
          err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
          err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
          NRF_LOG_INFO("Connected to device with Nordic UART Service.");
     case BLE_NUS_C_EVT_NUS_TX_EVT:
          ble_nus_chars_received_log_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
     case BLE_NUS_C_EVT_DISCONNECTED:
          NRF_LOG_INFO("Disconnected");
          scan_start();
/**@brief Function for initializing the Nordic UART Service (NUS) client. */
static void nus_c_init(void)
    ble_nus_c_init_t init;
    init.evt_handler   = ble_nus_c_evt_handler;
    init.error_handler = nus_error_handler;
    init.p_gatt_queue  = &m_ble_gatt_queue;
    err_code = ble_nus_c_init(&m_ble_nus_c, &init);
    NRF_LOG_INFO("ble_nus_c_init : %d\n",ble_nus_c_init);
/**@brief Heart Rate Collector initialization.
static void hrs_c_init(void)
    ble_hrs_c_init_t hrs_c_init_obj;
    hrs_c_init_obj.evt_handler   = hrs_c_evt_handler;
    hrs_c_init_obj.error_handler = service_error_handler;
    hrs_c_init_obj.p_gatt_queue  = &m_ble_gatt_queue;
    err_code = ble_hrs_c_init(&m_hrs_c, &hrs_c_init_obj);
    NRF_LOG_INFO("ble_hrs_c_init : %d\n",err_code);
/**@brief RSC collector initialization.
static void rscs_c_init(void)
    ble_rscs_c_init_t rscs_c_init_obj;
    rscs_c_init_obj.evt_handler   = rscs_c_evt_handler;
    rscs_c_init_obj.error_handler = service_error_handler;
    rscs_c_init_obj.p_gatt_queue  = &m_ble_gatt_queue;
    err_code = ble_rscs_c_init(&m_rscs_c, &rscs_c_init_obj);
    NRF_LOG_INFO("ble_rscs_c_init : %d\n",err_code);
 * @details Initializes the SoftDevice and the BLE event interrupts.
    NRF_LOG_INFO("nrf_sdh_enable_request : %d\n",err_code);
    uint32_t ram_start = 0;
    NRF_LOG_INFO("nrf_sdh_ble_default_cfg_set : %d\n",err_code);
    // Enable BLE stack.
    NRF_LOG_INFO("nrf_sdh_ble_enable : %d\n",err_code);
/**@brief Function for initializing the Peer Manager.
static void peer_manager_init(void)
    err_code = pm_init();
    NRF_LOG_INFO("pm_init : %d\n",err_code);
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.lesc           = SEC_PARAM_LESC;
    sec_param.keypress       = SEC_PARAM_KEYPRESS;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
    NRF_LOG_INFO("pm_sec_params_set : %d\n",err_code);
    NRF_LOG_INFO("pm_register : %d\n",err_code);
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void)
    NRF_LOG_INFO("Erase bonds!");
    err_code = pm_peers_delete();
/**@brief Function for initializing buttons and LEDs.
 * @param[out] p_erase_bonds  Will be true if the clear bonding button was pressed to
 *                            wake the application up.
    bsp_event_t startup_event;
    err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, NULL);
/**@brief Function for initializing the GAP.
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device, including the device name, appearance, and the preferred connection parameters.
                                          (const uint8_t *)DEVICE_NAME,
                                          strlen(DEVICE_NAME));
    gap_conn_params.min_conn_interval = m_scan.conn_params.min_conn_interval;
    gap_conn_params.max_conn_interval = m_scan.conn_params.max_conn_interval;
    gap_conn_params.slave_latency     = m_scan.conn_params.slave_latency;
    gap_conn_params.conn_sup_timeout  = m_scan.conn_params.conn_sup_timeout;
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)
        NRF_LOG_INFO("ATT MTU exchange completed.");
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        NRF_LOG_INFO("Ble NUS max data length set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    NRF_LOG_INFO("nrf_ble_gatt_init : %d\n",err_code);
    // Set the ATT MTU size for central role
    err_code = nrf_ble_gatt_att_mtu_central_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
    NRF_LOG_INFO("nrf_ble_gatt_att_mtu_central_set : %d\n",err_code);
    // Set the ATT MTU size for peripheral role
    err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
    NRF_LOG_INFO("nrf_ble_gatt_att_mtu_periph_set : %d\n",err_code);
    cp_init.start_on_notify_cccd_handle    = BLE_CONN_HANDLE_INVALID; // Start upon connection.
    cp_init.disconnect_on_fail             = true;
    cp_init.evt_handler                    = NULL;  // Ignore events.
/**@brief Function for handling database discovery events.
 * @details This function is a callback function to handle events from the database discovery module.
 *          Depending on the UUIDs that are discovered, this function forwards the events
 *          to their respective services.
 * @param[in] p_event  Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
    ble_db_discovery_t const * p_db = (ble_db_discovery_t *)p_evt->params.p_db_instance;
    ble_hrs_on_db_disc_evt(&m_hrs_c, p_evt);
    ble_rscs_on_db_disc_evt(&m_rscs_c, p_evt);
    ble_nus_c_on_db_disc_evt(&m_ble_nus_c, p_evt);     // nus central db disc evt handler .
    if (p_evt->evt_type == BLE_DB_DISCOVERY_AVAILABLE) {
        NRF_LOG_INFO("DB Discovery instance %p available on conn handle: %d",
                     p_db,
        NRF_LOG_INFO("Found %d services on conn_handle: %d",
                     p_db->srv_count,
 * @brief Database discovery initialization.
static void db_discovery_init(void)
    ble_db_discovery_init_t db_init;
    memset(&db_init, 0, sizeof(ble_db_discovery_init_t));
    db_init.evt_handler  = db_disc_handler;
    db_init.p_gatt_queue = &m_ble_gatt_queue;
    ret_code_t err_code = ble_db_discovery_init(&db_init);
    NRF_LOG_INFO("ble_db_discovery_init :%d\n",err_code);
/**@brief Function for handling Queued Write module errors.
 * @details A pointer to this function is passed to each service that may need to inform the
 * @param[in]   nrf_error   Error code that contains information about what went wrong.
  memset(Bledatabuff,0,sizeof(Bledatabuff));
  // write the code for nus data handling .
        NRF_LOG_DEBUG("Received data from BLE NUS.");
        // Copy received data to Bledatabuff array
        for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
            Bledatabuff[i] = p_evt->params.rx_data.p_data[i];
    NRF_LOG_INFO(" Received ble data : %s\n",Bledatabuff );
/**@brief Function for initializing services that are be used by the application.
 * @details Initialize the Heart Rate, Battery and Device Information services.
    ble_hrs_init_t     hrs_init;
    ble_rscs_init_t    rscs_init;
    ble_nus_init_t     nus_init;
    uint8_t            body_sensor_location;
    // Initialize Queued Write module instances.
        err_code = nrf_ble_qwr_init(&m_qwr[i], &qwr_init);
        NRF_LOG_INFO("nrf_ble_qwr_init : %d\n",err_code);
    // Initialize the Heart Rate Service.
    body_sensor_location = BLE_HRS_BODY_SENSOR_LOCATION_FINGER;
    memset(&hrs_init, 0, sizeof(hrs_init));
    hrs_init.evt_handler                 = NULL;
    hrs_init.is_sensor_contact_supported = true;
    hrs_init.p_body_sensor_location      = &body_sensor_location;
    // Here the sec level for the Heart Rate Service can be changed or increased.
    hrs_init.hrm_cccd_wr_sec = SEC_OPEN;
    hrs_init.bsl_rd_sec      = SEC_OPEN;
    err_code = ble_hrs_init(&m_hrs, &hrs_init);
    NRF_LOG_INFO("ble_hrs_init : %d\n",err_code);
    // Initialize the Running Speed and Cadence Service.
    memset(&rscs_init, 0, sizeof(rscs_init));
    rscs_init.evt_handler = NULL;
    rscs_init.feature     = BLE_RSCS_FEATURE_INSTANT_STRIDE_LEN_BIT |
                            BLE_RSCS_FEATURE_WALKING_OR_RUNNING_STATUS_BIT;
    // Here the sec level for the Running Speed and Cadence Service can be changed or increased.
    rscs_init.rsc_feature_rd_sec   = SEC_OPEN;
    rscs_init.rsc_meas_cccd_wr_sec = SEC_OPEN;
    err_code = ble_rscs_init(&m_rscs, &rscs_init);
    NRF_LOG_INFO("ble_rscs_init : %d\n ",err_code);
    nus_init.data_handler = nus_data_handler;    //intialisation parts for the nus
    NRF_LOG_INFO(" ble_nus_init : %d\n",err_code);
/**@brief Function for initializing the advertising functionality.
    ble_advertising_init_t init;
    init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance      = true;
    init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
/**@brief Function for initializing logging.
static void log_init(void)
/**@brief Function for handling the idle state (main loop). If there is no pending log operation,
          then sleeps until the next event occurs.
        nrf_pwr_mgmt_run();
/**@brief Function for initializing the timer.
static void timer_init(void)
/**@brief Function for initializing the application main entry.
    bool erase_bonds;
    // Initialize.
    log_init();
    timer_init();
    power_management_init();
    ble_stack_init();
    scan_init();
    gap_params_init();
    gatt_init();
    conn_params_init();
    db_discovery_init();
    peer_manager_init();
    hrs_c_init();
    rscs_c_init();
    nus_c_init();
    services_init();
    advertising_init();
    // Start execution.
    NRF_LOG_INFO("Relay example started.");
    if (erase_bonds == true)
        // Scanning and advertising is done upon PM_EVT_PEERS_DELETE_SUCCEEDED event.
        delete_bonds();
        adv_scan_start();
    // Enter main loop.
    for (;;)
        idle_state_handle();
the code is not completely modified as per our requirement . need some more additional modifications .
the log output shows this
 <info> app_timer: RTC: initialized.
 <info> app: nrf_sdh_enable_request : 0
 <info> app: nrf_sdh_ble_default_cfg_set : 0
 <info> app: nrf_sdh_ble_enable : 0
 <error> app: Fatal error
 <warning> app: System reset
I've been completely stuck here for days. Any response would be helpful for further development.
Are there any example projects available that are similar to my requirements? Thank you in advance
