Bricked PCA10056 52840 DK
I have a  PCA10056 (nRF52840 DK) and while programming it with a UART example from the nRF5_SDK_17.1.0_ddde560 using Segger Embedded Studio for Arm  5.42a, it will not show up on the COM anymore in Windows.
I do a RESET hold and power of/on and then LED5 flashes green, but only if I plug the USB in from the long side of the board (which suppsoed to be the USB application port).  If I plug in from the short side in the USB, I do not get LED5  to come on, even if I do a RESET and hold off/on.  If I plug one USB cable in the long end and do the RESET off/on to start LED5 flash green...and also plug in another USB cable in the short side USB port... then when I unplug the USB cable on re long side, the LED5 remains fleshing.
When I do the RESET and power off/on, the BOOTLOADER mass storage shows up for a few seconds.  I tired to drop previously good hex apps on it, but it does not have enough space, shows only 108KB of 128KB free.  So I cannot drop the 1MB  j-link-ob-sam3u128-v2-nordicsemi-170724.bin on it, not any hex files that are more than 100KB.  Also, the mass storage only stays active for a few seconds then disappears on its own while making the Windows sound of a USB port disconnect.  I cannot see any devices in NRF Connect for Desktop (latest version) Programmer and  Quick Start.
When I connect the J-Link Mini-Edu to the DK board's SWIO, SWCLK, GND, and separate 3-5V V-in, I can see a J-link device in Desktop Programmer and Quick Start.  But, the Programmer cannot identify it.  It says I should do a full erase to free up the protected memory. When I try a full erase, it says it's protected and will not let me do it.
I checked out these guides, but no avail.  I have not yet done a njprog- erase on comand line tool, I would need some guidance on that.  Or if I should use any other J-LINK programs/terminals..  Segger Studio also did not show any options to use for J-Link Connect and shows no COM ports.
Rebooted the laptop, and other MCU boards work, like an Nrf52840 dongle (PCA10059).
 nRf52840 unseen under Device Manager. How to restore?
 factory reset nrf52-dk
