Im a bit stuck here.
I have the following code, trying to communicate with a flash memory:
Overlay:
&spi1 { compatible = "nordic,nrf-spi"; status = "okay"; pinctrl-0 = <&spi1_default>; pinctrl-1 = <&spi1_sleep>; pinctrl-names = "default", "sleep"; cs-gpios = <&gpio0 21 GPIO_ACTIVE_LOW>; SST26VF032B: SST26VF032B@0 { compatible = "jedec,spi-nor"; reg = <0>; spi-max-frequency = <8000000>; requires-ulbpr; label = "SST26VF032B"; jedec-id = [BF 26 42]; size = <16777216>; //size = <67108864>; has-dpd; // t-enter-dpd = <10000>; // t-exit-dpd = <35000>; }; };
code:
#include "flash_memory.h" #include <zephyr/kernel.h> #include <zephyr/drivers/flash.h> typedef struct { uint8_t code[8]; uint8_t card[8]; uint8_t other[16]; } Slot; #define SLOTS_IN_PAGE 128 typedef struct { Slot slot[SLOTS_IN_PAGE]; } Page; #define ARRAY_SIZE 1024 #define FLASH_SLOT_ADDRESS 0x0000 #define SLOT_SIZE 32 #define MEMORY_PAGE_SIZE 4096 #define PAGE_SIZE SLOT_SIZE*SLOTS_IN_PAGE Slot arrayOfCodes[ARRAY_SIZE]; void test_flash_memory() { const struct device *flash_dev; flash_dev = device_get_binding(DT_LABEL(DT_INST(0, jedec_spi_nor))); if(!flash_dev) { printk("Failed to get flash dev\r\n"); } printk("Testing memory\r\n"); static Page toMemory; int page = 0; int position = 40960 + (PAGE_SIZE*page); int offset = 0 + (SLOTS_IN_PAGE * page); int err = flash_read(flash_dev, position, &toMemory, PAGE_SIZE); if(err) { printk("failed writing flash memory:"); } else { printk("Success reading memory"); } }
I get the following error message:
error: 'DT_N_S_soc_S_spi_40004000_S_sst26vf032b_0' undeclared (first use in this function); did you mean 'DT_N_S_soc_S_spi_40004000_S_sst26vf032b_0_BUS'?
Am I missing something in the overlay file, im using version 2.7.0 of the toolchain.
