nRF5340 SAADC TASKS_CALIBRATEOFFSET calibration time missing in the product specification
Hello, the nRF5340's SAADC has a temperature dependent offset according to the product specification. The offset can be measured (I suppose it is automatically applied within the SAADC) via the TASKS_CALIBRATEOFFSET task.
I could not find any information about the calibration time in the product specification (v1.5). Did I overlook it or search in the wrong place? There is information about acquision time and conversion time, but not about offset calibration time.
Is there any information available? If it is already in the product specification, please let me know where. Otherwise, please let me know here and if possible, include it in the product specification (also for the nRF54 series). This information is important for modelling the delays in real-time systems during a re-calibration cycle.
Is the offset calibration time static or is it dynamic with a worst case upper limit?
One more short question regarding the input voltage. Is it safe to apply voltages that exceed the full-scale reference voltage to an analog input pin? E.g. internal reference voltage and gain are set to 2.4V, and 3.0V are applied at the pin. My understanding from the Absolute Maximum Ratings section would be that this scenario is physically safe for the SoC (AIN pins have same limits as other pins).
Michael
  • Hi Hieu, thanks a lot for looking into this topic! This really helps.
    I have two questions left:
    - which tACQ is used? The one I select in the CONFIG register? (This means would the calibration process depend on my circuit diagram which connects the analog input using a certain impedance?) And if the acquisition time is based on the configuration register, are there any requirements or suggestions on how to set it for optimal calibration?
    - is OVERSAMPLE the integer value that is written into the OVERSAMPLE register? Or the actual oversampling factor, which is actually 2^(register value)? I think the former would make sense, considering your formula.
    In short, the calibration time should be around six times the usual sampling time, considering that tACQ based on the configuration register is used...
  • Hi Michael,
    The value selected in the CONFIG register is used, yes. For calibration, you could set TACQ to 3us temporarily. If you do so, it should be reconfigured for normal ADC operations based on your input impedance, as you have known.
    Please use the integer OVERSAMPLE value from the OVERSAMPLE register.
    This is basically true, yes.
  • Thanks a lot for the detailed information! Thumbsup
