Issue with Enabling MCUboot on Custom Board with nRF5340
I am working on a custom Agora board that includes a BT40 module with an nRF5340 MCU. I am trying to enable the MCUboot bootloader by setting CONFIG_BOOTLOADER_MCUBOOT=y in my prj.conf file. However, I encounter an error during the initial configuration stage.
Here are the details of my setup:
  • Custom Agora board with BT40 module
  • nRF5340 MCU
  • Using Nordic SDK version 2.7.0
  • The bootloader demo works on the nRF52840 development board using the Nordic course
Error Message:
...depends again on SOC_FAMILY_NRF (defined at C:/ncs/v2.7.0/modules/soc-hwmv1/soc/arm\nordic_nrf\Kconfig:9)
CMake Error at C:/ncs/v2.7.0/zephyr/cmake/modules/kconfig.cmake:392 (message):
command failed with return code: 1
C:/ncs/v2.7.0/nrf/cmake/modules/kconfig.cmake:29 (include)
C:/ncs/v2.7.0/zephyr/cmake/modules/zephyr_default.cmake:132 (include)
C:/ncs/v2.7.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
C:/ncs/v2.7.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:97 (include_boilerplate)
CMakeLists.txt:12 (find_package)
See also "C:/Users/YASHAWS/Agora/xyleminc-wwno-gnode-009afda753b5/build_4/mcuboot/CMakeFiles/CMakeOutput.log".
See also "C:/Users/YASHAWS/Agora/xyleminc-wwno-gnode-009afda753b5/build_4/mcuboot/CMakeFiles/CMakeError.log".
CMake Error at C:/ncs/v2.7.0/nrf/cmake/multi_image.cmake:502 (message):
CMake generation for mcuboot failed, aborting. Command: 1
C:/ncs/v2.7.0/nrf/cmake/multi_image.cmake:178 (add_child_image_from_source)
C:/ncs/v2.7.0/nrf/modules/mcuboot/CMakeLists.txt:328 (add_child_image)
See also "C:/Users/YASHAWS/Agora/xyleminc-wwno-gnode-009afda753b5/build_4/CMakeFiles/CMakeOutput.log".
See also "C:/Users/YASHAWS/Agora/xyleminc-wwno-gnode-009afda753b5/build_4/CMakeFiles/CMakeError.log".
FAILED: build.ninja
C:\ncs\toolchains\ce3b5ff664\opt\bin\cmake.exe --regenerate-during-build -SC:\Users\YASHAWS\Agora\xyleminc-wwno-gnode-009afda753b5 -BC:\Users\YASHAWS\Agora\xyleminc-wwno-gnode-009afda753b5\build_4
ninja: error: rebuilding 'build.ninja': subcommand failed
FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\ce3b5ff664\opt\bin\cmake.EXE' --build 'c:\Users\YASHAWS\Agora\xyleminc-wwno-gnode-009afda753b5\build_4'
* The terminal process terminated with exit code: 1.
* Terminal will be reused by tasks, press any key to close it.
Could anyone provide guidance on how to resolve this issue or suggest additional configurations that might be required for the nRF5340 MCU on a custom board?
Thank you!
    I do not see your device tree or board files, but the recomendation here is to copy the DK files and modify what you need. Remember to copy the _ns files if you are making an _ns board, and the secure (non _ns) files if that is appropriate.
    Even after modifying the dts file from the nrf5340dk into customized agora_bt40 dts, continue to encounter the same error.
    After enabling the mcuboot on prj.conf it through error, otherwise builds without error.
    The error point to missing SPU configuration in the board as disussed before, so it seems MCU boot is built for non-secure or that the secure board configuration is incorrect, and does not contain the SPU (which it must). The nRF5340 is quite complex, so to avoid this the simplest is to copy all of the nRF5340 board files, and modify as needed for your custom HW. Note that you need both secure and non-secure board files as MCUboot will always be built as secure even if the application is non-secure.
    If you have not made any progress, can you share your board files as well as full build log (so that I see how you build the project as well as any errors)?
    While working on DTS file, in C:\ncs\v2.7.0\zephyr\boards\nordic\nrf5340dk I have seen different dts file so here which one has to select to work with bootloader development.
    nrf5340_cpuapp_common.dtsi, nrf5340_cpuapp_partition_conf.dtsi,nrf5340dk_nrf5340_cpuapp.dts,nrf5340dk_nrf5340_cpuapp_ns.dts so I have seen these 4 dts files.
    While in our customized agora board we having nrf5340dk, when i try to compare with dts file which file should I need to consider, in that 4.
    Thank you
    There are 3 main boards for the nRF5340 DK in the SDK:
    • nrf5340dk_nrf5340_cpuapp
    • nrf5340dk_nrf5340_cpuapp_ns
    • nrf5340dk_nrf5340_cpunet
    All these boards consist of several files each. If you are using the net core as well as the app core (which you always need for using the radio), you need nrf5340dk_nrf5340_cpunet in addition to nrf5340dk_nrf5340_cpuapp. And if you are using TrustZone, you need nrf5340dk_nrf5340_cpuapp_ns for the non-secure application. However, you also need nrf5340dk_nrf5340_cpuapp for the secure builds, which is for instance the bootloader. The bootloader is always a secure build. And the error you are getting indicate that you are attempting to build the bootlodaser for a non-secure board, which will not work.
    For the files you list:
    • nrf5340_cpuapp_common.dtsi file is included in both the nrf5340dk_nrf5340_cpuapp and nrf5340dk_nrf5340_cpuapp_ns boards.
    • nrf5340_cpuapp_partition_conf.dtsi is also includedin both, by being included in nrf5340_cpuapp_common.dtsi.
    • nrf5340dk_nrf5340_cpuapp.dts is the device tree file for the secure board. This is used for all secure builds (bootloaders etc), but not non-secure applications.
    • nrf5340dk_nrf5340_cpuapp_ns.dts is used if you have a non-secure application (i.e. you are including TF-M to utilize TrustZone).
    In short, as you are using a non-secure application, you need both secure and non-secure boards. And as this is quite complex to get right, I recomend you take all of the nRF5340 DK files and copy and rename to use as your custom baord files. You can see more practical information on this under Board files for multi-core hardware & TF-M in the intermediate nRF Connect SDK course.
