Getting Error while connecting nRF9160DK module to nRF7002DK module with spi and use it for wifi locationing
Dear Nordic Team,
I want to connect my nRF9160DK board to my nRF7002DK board and get a wi-fi location. I've followed samples/cellular/nrf_cloud_multi_service as sample and I made wiring as follows
Board nRF9160-DK(P3 & P4) nRF7002-DK (P24)
SPI CLK P0.13 P0.17
SPI CS P0.10 P0.18
SPI MOSI P0.11 P0.13
SPI MISO P0.12 P0.14
HOST-IRQ  P0.07 P0.23
IOVDD-CTR  P0.00 P0.31
BUCKEN P0.01 P0.12
I soldered SB25 and SB20 on the nRF7002 board.
The problem is, whenever I'm trying to build samples/cellular/nrf_cloud_multi_service sample with using overlay-nrf7002ek-wifi-scan-only.conf as Extra Kconfig fragments and -DSHIELD="nrf7002ek" as Extra Cmake arguments.
After flashing the sample to the nrf9160DK board, I'm getting the error below:
*** Booting nRF Connect SDK 4040aa0bf581 ***
[00:00:00.257,720] <inf> main: nRF Cloud multi-service sample has started, version: 1.0.0, protocol: MQTT
[00:00:00.257,751] <inf> cloud_connection: Enabling connectivity...
[00:00:00.260,284] <inf> wifi_nrf_bus: SPIM spi@b000: freq = 8 MHz
[00:00:00.260,314] <inf> wifi_nrf_bus: SPIM spi@b000: latency = 0
[00:00:00.260,864] <err> wifi_nrf_bus: Error: RPU comms test: sig failed: expected 0x42000020, got 0xffffffff
[00:00:00.260,925] <err> wifi_nrf: zep_shim_bus_qspi_dev_add: RPU enable failed with error -1
[00:00:00.260,986] <err> wifi_nrf: nrf_wifi_bus_qspi_dev_add: nrf_wifi_osal_bus_qspi_dev_add failed
[00:00:00.261,077] <err> wifi_nrf: nrf_wifi_bal_dev_add: Bus dev_add failed
[00:00:00.261,169] <err> wifi_nrf: nrf_wifi_hal_dev_add: nrf_wifi_bal_dev_add failed
[00:00:00.261,322] <err> wifi_nrf: nrf_wifi_fmac_dev_add: nrf_wifi_hal_dev_add failed
[00:00:00.261,383] <err> wifi_nrf: nrf_wifi_fmac_dev_add_zep: nrf_wifi_fmac_dev_add failed
[00:00:00.261,413] <err> wifi_nrf: nrf_wifi_if_start_zep: nrf_wifi_fmac_dev_add_zep failed
[00:00:00.537,200] <inf> cloud_connection: Setting up nRF Cloud library...
[00:00:00.539,093] <inf> cloud_connection: Waiting for network ready...
+CEREG: 2,"1644","00DB1564",9
+CSCON: 1
+CGEV: ME PDN ACT 0,0
+CNEC_ESM: 50,0
+CEREG: 5,"1644","00DB1564",9,,,"00010000","11100000"
%XTIME: "21","42118151436521","00"
+CSCON: 0
Then progress stops completely. The error changes when I disconnect any of the cables, so I thought the problem might be the configuration on the devicetree. and here how it looks like:
I tried to assign SPI WAKE to P0.07, the HOST-IRQ pin, but this time it started to give this error serially: ASSERTION FAIL @ WEST_TOPDIR/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c:486
I would be very grateful if you can help me solve this error, if there is any extra information that you think may be useful, I will be happy to share it.
Actually what I want to do is to get the wifi location in a simple way and monitor it on nrf cloud with REST protocol. Then I want to add A-GNSS and experience an effective indoor and outdoor location tracking example. I would be glad to hear your extra advice for that too.
Best wishes!
  • Hi Semih,
    I am sorry for a delayed reply. It was a vacation period, and I was out of the office.
    Can you provide new sharper images of your setup?
    Which error are you getting now when connection to the nRF Cloud is successfully established on nrf9160-dk (running multi_service sample), and you connect it to nrf7002-dk (running scan sample)? Is error the same as shown below?
    For testing, do you have nrf7002ek to use instead of nrf7002-dk?
    Dejan
  • Hi Dejan,
    Same for me, I wish you a happy new year Slight smile
    Sure, here is my setup below, and I would like to inform you that unfortunatelly I don't have nRF7002ek
    And here is my step by step terminal logs from 2 different development kit below.
    First I connected the devices to the computer but I didin't make the connection between Dev kits.
    The result from nRF7002DK
    The result from nRF9160DK
    By the way, today Im not able to open "edit build configuration settings but when I click on copy build command, this is the output,
    west build -p -b nrf9160dk/nrf9160/ns -- -DSHIELD=nrf7002ek_nrf7000 -DSB_CONF_FILE=sysbuild_nrf700x-wifi-scan.conf -DEXTRA_CONF_FILE=overlay-nrf7002ek-wifi-scan-only.conf -DBOARD_ROOT=c:\nordic\myApps\nrf_cloud_multi_service_9 --pristine
    Then I made connection between two development kits and here are the results,
    For nRF7002DK
    For nRF9160DK
    Thank you for your assistance and patience.
    Semih
  • In addition, I realised that my computer was out of charge and turned it back on and this is the terminal output I got from nRF7002DK:
    And everything is looks same with nRF9160DK
    Perhaps the reason for the difference here is also the reason for the error?
    Semih
  • Hi Semih,
    Can you provide logs when you exclude nrf7002ek configuration part from your build command?
    Can you show your build command for the sample running on nrf7002-dk?
    Before connecting devices, can you try to build as usual on nrf9160-dk (using nrf7002ek configuration), recover/erase nrf5340 on nrf7002-dk board, and provide logs after you do that?
    Dejan
  • Hi Dejans,
    I have some good news I guess I managed to fix this connection error with erase nrf5340 on nrf7002dk board from nRF Connect for the desktop programmer section. I just applied "erase all" then I continued with the same samle on nrf9160DK and I didn't flash any sample to the nrf7002dk.
    In meantime, I did a buzzer test on my cables/jumpers and found the faulty ones and I changed them.
    Here are the results,
    Now Im receiving wifi data from the cloud terminal. So, we can assume that there is no fault with connection and wifi scanning, right?
    Now Im having this issue,
    Unfortunatelly, Im not receiving any location data from the nRF Cloud.
    and here are my terminal outputs,
    And this is the final build that Im using
    I think devices are able to scan wifi and sending its data to the nrf cloud, but we are not receiving the location data back from the nrf cloud.
    I guess we are only one step away from the success, How can we fix that?
    Thank you so much, your guidance is teaching me a lot.
    Semih
