I have a question about nrf7002 custom board.
Hello.
We are developing custom boards with the configuration of nrf5340 + nrf7002.
In the previous sta example, a build error occurs when the "Board Target" in "build configuration" is set to "custom board".
("nRF7002dk/nrf5340/cpuapp" will build normally)
I'm inquiring about how to resolve it.
/dts-v1/;
#include <nordic/nrf5340_cpuapp_qkaa.dtsi>
#include "SC50-pinctrl.dtsi"
	model = "Custom Board auto generated by nRF Connect for VS Code (CPUAPP)";
	compatible = "Algorigo,custom-board-name-cpuapp";
	chosen {
		zephyr,sram = &sram0_image;
		zephyr,flash = &flash0;
		zephyr,code-partition = &slot0_partition;
		zephyr,sram-secure-partition = &sram0_s;
		zephyr,sram-non-secure-partition = &sram0_ns;
		zephyr,wifi = &nordic_wlan0;
	nrf70_tx_power_ceiling: nrf70_tx_power_ceiling_node {
		status = "okay";
		compatible = "nordic,nrf700x-tx-power-ceiling";
		max-pwr-2g-dsss = <0x54>;
		max-pwr-2g-mcs0 = <0x40>;
		max-pwr-2g-mcs7 = <0x40>;
		max-pwr-5g-low-mcs0 = <0x24>;
		max-pwr-5g-low-mcs7 = <0x24>;
		max-pwr-5g-mid-mcs0 = <0x2C>;
		max-pwr-5g-mid-mcs7 = <0x2C>;
		max-pwr-5g-high-mcs0 = <0x34>;
		max-pwr-5g-high-mcs7 = <0x34>;
&timer0 {
	status = "okay";
&adc {
   #address-cells = <1>;
   #size-cells = <0>;
   status = "okay";
   channel@0 {
	   reg = <0>;
	   zephyr,gain = "ADC_GAIN_1_6";
	   zephyr,reference = "ADC_REF_VDD_1_4";
	   zephyr,acquisition-time = <0>;
	   zephyr,resolution = <14>;
	   zephyr,input-positive = <NRF_SAADC_AIN0>;
   channel@1 {
	   reg = <1>;
	   zephyr,resolution = <12>;
	   zephyr,input-positive = <NRF_SAADC_AIN1>;
&gpio0 {
   status = "okay";
&gpio1 {
   status = "okay";
   zephyr,user {
	   io-channels = <&adc 0>, <&adc 1>;
	   DT1-gpios = <&gpio1 11 0>;
	   DT2-gpios = <&gpio1 13 0>;
	   DT3-gpios = <&gpio0 7 0>;
	   DT4-gpios = <&gpio0 25 0>;
	   BAT_EN-gpios = <&gpio0 6 0>;
&wdt {
   status = "okay";
// #include "SC50-cpuapp_partitioning.dtsi"
// #include "SC50-shared_sram.dtsi"
&pinctrl {
	uart0_default: uart0_default {
		group1 {
			psels = <NRF_PSEL(UART_TX, 0, 20)>,
				<NRF_PSEL(UART_RTS, 0, 19)>;
		group2 {
			psels = <NRF_PSEL(UART_RX, 0, 22)>,
				<NRF_PSEL(UART_CTS, 0, 21)>;
			bias-pull-up;
	uart0_sleep: uart0_sleep {
		group1 {
				<NRF_PSEL(UART_RTS, 0, 19)>,
			low-power-enable;
	pwm0_default: pwm0_default {
		group1 {
			psels = <NRF_PSEL(PWM_OUT0, 1, 6)>;
	pwm0_sleep: pwm0_sleep {
		group1 {
			low-power-enable;
	qspi_default: qspi_default {
		group1 {
			psels = <NRF_PSEL(QSPI_SCK, 0, 17)>,
				<NRF_PSEL(QSPI_IO0, 0, 13)>,
				<NRF_PSEL(QSPI_IO1, 0, 14)>,
				<NRF_PSEL(QSPI_IO2, 0, 15)>,
				<NRF_PSEL(QSPI_IO3, 0, 16)>,
				<NRF_PSEL(QSPI_CSN, 0, 18)>;
	qspi_sleep: qspi_sleep {
		group1 {
			low-power-enable;
	uart1_default: uart1_default {
		group1 {
			psels = <NRF_PSEL(UART_TX, 1, 1)>;
		group2 {
			psels = <NRF_PSEL(UART_RX, 1, 0)>;
			bias-pull-up;
	uart1_sleep: uart1_sleep {
		group1 {
			psels = <NRF_PSEL(UART_TX, 1, 1)>,
			low-power-enable;
	spi3_default: spi3_default {
		group1 {
			psels = <NRF_PSEL(SPIM_SCK, 1, 15)>,
				<NRF_PSEL(SPIM_MISO, 1, 14)>,
				<NRF_PSEL(SPIM_MOSI, 1, 13)>;
	spi3_sleep: spi3_sleep {
		group1 {
			low-power-enable;
	spi4_default: spi4_default {
		group1 {
			psels = <NRF_PSEL(SPIM_SCK, 0, 8)>,
				<NRF_PSEL(SPIM_MISO, 0, 10)>,
				<NRF_PSEL(SPIM_MOSI, 0, 9)>;
	spi4_sleep: spi4_sleep {
		group1 {
			low-power-enable;
	// spi2_default: spi2_default {
	// 	group1 {
	// 		psels = <NRF_PSEL(SPIM_SCK, 1, 15)>,
	// 			<NRF_PSEL(SPIM_MISO, 1, 14)>,
	// 			<NRF_PSEL(SPIM_MOSI, 1, 13)>;
	// spi2_sleep: spi2_sleep {
	// 	group1 {
	// 		low-power-enable;
 * Copyright (c) 2022 Nordic Semiconductor ASA
	 chosen {
		 zephyr,console = &uart0;
		 zephyr,shell-uart = &uart0;
		 zephyr,uart-mcumgr = &uart0;
		 zephyr,bt-mon-uart = &uart0;
		 zephyr,bt-c2h-uart = &uart0;
		 zephyr,bt-hci-ipc = &ipc0;
		 nordic,802154-spinel-ipc = &ipc0;
		 zephyr,ieee802154 = &ieee802154;
	 leds {
		 compatible = "gpio-leds";
		 led0: led_0 {
			 gpios = <&gpio1 6 GPIO_ACTIVE_HIGH>;
			 label = "Green LED 0";
		 led1: led_1 {
			 gpios = <&gpio1 7 GPIO_ACTIVE_HIGH>;
			 label = "Green LED 1";
	 pwmleds {
		 compatible = "pwm-leds";
		 pwm_led0: pwm_led_0 {
			 pwms = <&pwm0 0 PWM_MSEC(20) PWM_POLARITY_NORMAL>;
	 buttons {
		 compatible = "gpio-keys";
		 button0: button_0 {
			 gpios = <&gpio1 8 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
			 label = "Push button 1";
		 button1: button_1 {
			 gpios = <&gpio1 9 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
			 label = "Push button 2";
	 gpio_fwd: nrf-gpio-forwarder {
		 compatible = "nordic,nrf-gpio-forwarder";
		 status = "okay";
		 uart {
			 gpios = <&gpio1 1 0>, <&gpio1 0 0>, <&gpio1 5 0>, <&gpio1 4 0>;
	 nrf_radio_coex: nrf7002-coex {
		 status = "okay";
		 compatible = "nordic,nrf700x-coex";
		 req-gpios = <&gpio0 28 GPIO_ACTIVE_HIGH>;
		 status0-gpios = <&gpio0 30 GPIO_ACTIVE_HIGH>;
		 grant-gpios = <&gpio0 24 (GPIO_PULL_DOWN | GPIO_ACTIVE_LOW)>;
		 swctrl1-gpios = <&gpio0 29 GPIO_ACTIVE_HIGH>;
		 srrf-switch-gpios = <&gpio1 10 GPIO_ACTIVE_HIGH>;
	 nordic_wlan0: nordic_wlan0 {
		 compatible = "nordic,wlan0";
		 status = "okay";
	 /* These aliases are provided for compatibility with samples */
	 aliases {
		 led0 = &led0;
		 led1 = &led1;
		 pwm-led0 = &pwm_led0;
		 sw0 = &button0;
		 sw1 = &button1;
		 bootloader-led0 = &led0;
		 mcuboot-button0 = &button0;
		 mcuboot-led0 = &led0;
 &adc {
	 status = "okay";
 &gpiote {
	 status = "okay";
 &gpio0 {
	 status = "okay";
 &gpio1 {
	 status = "okay";
 &uart0 {
	 status = "okay";
	 current-speed = <115200>;
	 pinctrl-0 = <&uart0_default>;
	 pinctrl-1 = <&uart0_sleep>;
 &pwm0 {
	 status = "okay";
	 pinctrl-0 = <&pwm0_default>;
	 pinctrl-1 = <&pwm0_sleep>;
 &spi4 {
	 status = "okay";
	 pinctrl-0 = <&spi4_default>;
	 pinctrl-1 = <&spi4_sleep>;
	 cs-gpios = <&gpio0 11 GPIO_ACTIVE_LOW>;
	 mx25r64: mx25r6435f@0 {
		 compatible = "jedec,spi-nor";
		 reg = <0>;
		 spi-max-frequency = <33000000>;
		 jedec-id = [c2 28 17];
		 sfdp-bfp = [
			 e5 20 f1 ff ff ff ff 03 44 eb 08 6b 08 3b 04 bb
			 ee ff ff ff ff ff 00 ff ff ff 00 ff 0c 20 0f 52
			 10 d8 00 ff 23 72 f5 00 82 ed 04 cc 44 83 68 44
			 30 b0 30 b0 f7 c4 d5 5c 00 be 29 ff f0 d0 ff ff
		 size = <67108864>;
		 has-dpd;
		 t-enter-dpd = <10000>;
		 t-exit-dpd = <5000>;
 &qspi {
	 status = "okay";
	 pinctrl-0 = <&qspi_default>;
	 pinctrl-1 = <&qspi_sleep>;
	 nrf700x: nrf7002@1 {
		 status = "okay";
		 compatible = "nordic,nrf700x-qspi";
		 reg = <1>;
		 sck-frequency = <24000000>;
		 quad-mode;
		 /* Wi-Fi Pins used */
		 iovdd-ctrl-gpios = <&gpio0 31 GPIO_ACTIVE_HIGH>;
		 bucken-gpios = <&gpio0 12 GPIO_ACTIVE_HIGH>;
		 host-irq-gpios = <&gpio0 23 GPIO_ACTIVE_HIGH>;
 &flash0 {
	 partitions {
		 #size-cells = <1>;
		 boot_partition: partition@0 {
			 label = "mcuboot";
			 reg = <0x00000000 0x00010000>;
		 slot0_partition: partition@10000 {
			 label = "image-0";
		 slot0_ns_partition: partition@50000 {
			 label = "image-0-nonsecure";
		 slot1_partition: partition@80000 {
			 label = "image-1";
		 slot1_ns_partition: partition@c0000 {
			 label = "image-1-nonsecure";
		 scratch_partition: partition@f0000 {
			 label = "image-scratch";
			 reg = <0x000f0000 0xa000>;
		 storage_partition: partition@fa000 {
			 label = "storage";
			 reg = <0x000fa000 0x00006000>;
 &ieee802154 {
	 status = "okay";
 zephyr_udc0: &usbd {
	 compatible = "nordic,nrf-usbd";
	 status = "okay";
	 reserved-memory {
		 #size-cells = <1>;
		 ranges;
		 sram0_image: image@20000000 {
			 /* Zephyr image(s) memory */
		 sram0_s: image_s@20000000 {
			 /* Secure image memory */
		 sram0_ns: image_ns@20040000 {
			 /* Non-Secure image memory */
 * Default Flash planning for nrf7002dk_nrf5340 CPUAPP (Application MCU).
 * Zephyr build for nRF5340 with ARM TrustZone-M support,
 * implies building Secure and Non-Secure Zephyr images.
 * Secure image will be placed, by default, in flash0
 * (or in slot0, if MCUboot is present).
 * Secure image will use sram0 for system memory.
 * Non-Secure image will be placed in slot0_ns, and use
 * sram0_ns for system memory.
 * Note that the Secure image only requires knowledge of
 * the beginning of the Non-Secure image (not its size).
 &slot0_partition {
	reg = <0x00010000 0x40000>;
&slot0_ns_partition {
	reg = <0x00050000 0x30000>;
&slot1_partition {
	reg = <0x00080000 0x40000>;
&slot1_ns_partition {
	reg = <0x000c0000 0x30000>;
/* Default SRAM planning when building for nRF5340 with
 * ARM TrustZone-M support
 * - Lowest 256 kB SRAM allocated to Secure image (sram0_s)
 * - Middle 192 kB allocated to Non-Secure image (sram0_ns)
 * - Upper 64 kB SRAM allocated as Shared memory (sram0_shared)
 *   (see nrf5340_shared_sram_planning_conf.dts)
&sram0_image {
	reg = <0x20000000 DT_SIZE_K(448)>;
&sram0_s {
	reg = <0x20000000 DT_SIZE_K(256)>;
&sram0_ns {
	reg = <0x20040000 DT_SIZE_K(192)>;
	chosen {
		/* shared memory reserved for the inter-processor communication */
		zephyr,ipc_shm = &sram0_shared;
	reserved-memory {
		#size-cells = <1>;
		ranges;
		sram0_shared: memory@20070000 {
			/* SRAM allocated to shared memory */
			reg = <0x20070000 0x10000>;
* Executing task: nRF Connect: Build: Algo_SC50_241114/build (active)
Building Algo_SC50_241114
C:\Windows\system32\cmd.exe /d /s /c "west build --build-dir c:/Workspace/Nordic/Algo_SC50_241114/build c:/Workspace/Nordic/Algo_SC50_241114"
[0/1] Re-running CMake...
Loading Zephyr default modules (Zephyr base (cached)).
-- Application: C:/Workspace/Nordic/Algo_SC50_241114
-- CMake version: 3.21.0
-- Cache files will be written to: C:/ncs/v2.7.0/zephyr/.cache
-- Zephyr version: 3.6.99 (C:/ncs/v2.7.0/zephyr)
-- Board: SC50, qualifiers: nrf5340/cpuapp
-- Found host-tools: zephyr 0.16.5 (C:/ncs/toolchains/ce3b5ff664/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.16.5 (C:/ncs/toolchains/ce3b5ff664/opt/zephyr-sdk)
-- Found BOARD.dts: C:/ncs/boards/Algorigo/SC50/SC50_nrf5340_cpuapp.dts
-- Generated zephyr.dts: C:/Workspace/Nordic/Algo_SC50_241114/build/zephyr/zephyr.dts
-- Generated devicetree_generated.h: C:/Workspace/Nordic/Algo_SC50_241114/build/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: C:/Workspace/Nordic/Algo_SC50_241114/build/zephyr/dts.cmake
Parsing C:/Workspace/Nordic/Algo_SC50_241114/Kconfig
Loaded configuration 'C:/Workspace/Nordic/Algo_SC50_241114/build/zephyr/.config'
No change to configuration in 'C:/Workspace/Nordic/Algo_SC50_241114/build/zephyr/.config'
No change to Kconfig header in 'C:/Workspace/Nordic/Algo_SC50_241114/build/zephyr/include/generated/autoconf.h'
CMake Warning at C:/ncs/v2.7.0/zephyr/CMakeLists.txt:895 (message):
No SOURCES given to Zephyr library: drivers__mbox
Excluding target from build.
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Workspace/Nordic/Algo_SC50_241114/build
[108/113] Linking C executable zephyr\zephyr_pre0.elf
FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map C:/Workspace/Nordic/Algo_SC50_241114/build/zephyr/zephyr_pre0.map
cmd.exe /C "cd . && C:\ncs\toolchains\ce3b5ff664\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -gdwarf-4 @CMakeFiles\zephyr_pre0.rsp -o zephyr\zephyr_pre0.elf && cmd.exe /C "cd /D C:\Workspace\Nordic\Algo_SC50_241114\build\zephyr && C:\ncs\toolchains\ce3b5ff664\opt\bin\cmake.exe -E true""
c:/ncs/toolchains/ce3b5ff664/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: zephyr/soc/soc/nrf5340/libsoc__nordic.a(sync_rtc.c.obj): in function `sync_rtc_setup':
C:/ncs/v2.7.0/zephyr/soc/nordic/nrf53/sync_rtc.c:234: undefined reference to `__device_dts_ord_27'
collect2.exe: error: ld returned 1 exit status
FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\ce3b5ff664\opt\bin\cmake.EXE' --build 'c:\Workspace\Nordic\Algo_SC50_241114\build'
* The terminal process terminated with exit code: 1.
* Terminal will be reused by tasks, press any key to close it.
* Executing task: nRF Connect: Build [clean]: Algo_SC50_241114/build (active)
C:\Windows\system32\cmd.exe /d /s /c "west build -t clean --build-dir c:/Workspace/Nordic/Algo_SC50_241114/build"
-- west build: running target clean
[2/2] Cleaning all built files...
Cleaning... 441 files.
* Executing task: nRF Connect: Build [pristine]: Algo_SC50_241114/build (active)
C:\Windows\system32\cmd.exe /d /s /c "west build --build-dir c:/Workspace/Nordic/Algo_SC50_241114/build c:/Workspace/Nordic/Algo_SC50_241114 --pristine --board SC50/nrf5340/cpuapp -- -DNCS_TOOLCHAIN_VERSION=NONE -DBOARD_ROOT=c:/ncs"
-- Found Python3: C:/ncs/toolchains/ce3b5ff664/opt/bin/python.exe (found suitable version "3.9.13", minimum required is "3.8") found components: Interpreter
-- Found Dtc: C:/ncs/toolchains/ce3b5ff664/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
Loaded configuration 'C:/ncs/boards/Algorigo/SC50/SC50_nrf5340_cpuapp_defconfig'
Merged configuration 'C:/Workspace/Nordic/Algo_SC50_241114/prj.conf'
Configuration saved to 'C:/Workspace/Nordic/Algo_SC50_241114/build/zephyr/.config'
Kconfig header saved to 'C:/Workspace/Nordic/Algo_SC50_241114/build/zephyr/include/generated/autoconf.h'
-- Found GnuLd: c:/ncs/toolchains/ce3b5ff664/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38")
-- Found assembler: C:/ncs/toolchains/ce3b5ff664/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
-- Configuring done
-- Generating done
[4/440] Generating include/generated/version.h
-- Zephyr version: 3.6.99 (C:/ncs/v2.7.0/zephyr), build: v3.6.99-ncs2
[153/440] Building C object CMakeFiles/app.dir/src/Algo/TCP_Client.c.obj
C:/Workspace/Nordic/Algo_SC50_241114/src/Algo/TCP_Client.c: In function 'TCP_Client':
C:/Workspace/Nordic/Algo_SC50_241114/src/Algo/TCP_Client.c:57:13: warning: unused variable 'missingBytesToSend' [-Wunused-variable]
57 | int missingBytesToSend = sizeof( TCPClientMessage );
[154/440] Building C object CMakeFiles/app.dir/src/Algo/ADC.c.obj
C:/Workspace/Nordic/Algo_SC50_241114/src/Algo/ADC.c: In function 'gpio_set':
C:/Workspace/Nordic/Algo_SC50_241114/src/Algo/ADC.c:89:31: warning: passing argument 1 of 'gpio_is_ready_dt' from incompatible pointer type [-Wincompatible-pointer-types]
89 | if (!gpio_is_ready_dt(&My_gpios)) {
| const struct gpio_dt_spec (*)[5]
In file included from C:/Workspace/Nordic/Algo_SC50_241114/src/Algo/ADC.c:11:
C:/ncs/v2.7.0/zephyr/include/zephyr/drivers/gpio.h:835:64: note: expected 'const struct gpio_dt_spec *' but argument is of type 'const struct gpio_dt_spec (*)[5]'
835 | static inline bool gpio_is_ready_dt(const struct gpio_dt_spec *spec)
C:/Workspace/Nordic/Algo_SC50_241114/src/Algo/ADC.c:90:24: warning: 'return' with a value, in function returning void [-Wreturn-type]
90 | return 0;
C:/Workspace/Nordic/Algo_SC50_241114/src/Algo/ADC.c:87:6: note: declared here
87 | void gpio_set(void)
C:/Workspace/Nordic/Algo_SC50_241114/src/Algo/ADC.c: In function 'ADC':
C:/Workspace/Nordic/Algo_SC50_241114/src/Algo/ADC.c:128:32: warning: 'return' with a value, in function returning void [-Wreturn-type]
128 | return 0;
C:/Workspace/Nordic/Algo_SC50_241114/src/Algo/ADC.c:113:6: note: declared here
113 | void ADC( void )
C:/Workspace/Nordic/Algo_SC50_241114/src/Algo/ADC.c:134:32: warning: 'return' with a value, in function returning void [-Wreturn-type]
134 | return 0;
C:/Workspace/Nordic/Algo_SC50_241114/src/Algo/ADC.c:146:32: warning: 'return' with a value, in function returning void [-Wreturn-type]
146 | return err;
C:/Workspace/Nordic/Algo_SC50_241114/src/Algo/ADC.c:138:13: warning: unused variable 'ret' [-Wunused-variable]
138 | int ret;
[435/440] Linking C executable zephyr\zephyr_pre0.elf
-- Configuring done
-- Generating done
[145/440] Building C object CMakeFiles/app.dir/src/Algo/ADC.c.obj
90 | return 0;
128 | return 0;
134 | return 0;
146 | return err;
138 | int ret;
[149/440] Building C object CMakeFiles/app.dir/src/Algo/TCP_Client.c.obj
    Your custom board seems to enable the mbox library:
    This is typically used by the network core in case of bluetooth being enabled, and not enabled directly on the application core.
    Can you share your build/zephyr/.config file? Or check your board kconfig_defconfig files to see if something there selects MBOX component?
    Håkon
  • I don't know where the kconfig_defconfig file is located.
    I am sharing the build/zephyr/.config file.
    # CONFIG_INPUT is not set
    CONFIG_WIFI=y
    CONFIG_NET_L2_ETHERNET=y
    CONFIG_ADC_INIT_PRIORITY=50
    # CONFIG_MIPI_DSI is not set
    # CONFIG_MODEM is not set
    # CONFIG_UART_INTERRUPT_DRIVEN is not set
    CONFIG_NET_IPV6=y
    # CONFIG_NET_CONFIG_NEED_IPV6 is not set
    # CONFIG_SPI is not set
    CONFIG_FLASH_LOAD_SIZE=0
    CONFIG_SRAM_SIZE=448
    CONFIG_FLASH_LOAD_OFFSET=0
    CONFIG_NUM_IRQS=69
    CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
    CONFIG_FLASH_SIZE=1024
    CONFIG_FLASH_BASE_ADDRESS=0x0
    CONFIG_MP_MAX_NUM_CPUS=1
    CONFIG_PLATFORM_SPECIFIC_INIT=y
    CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
    CONFIG_ROM_START_OFFSET=0
    CONFIG_PINCTRL=y
    CONFIG_BUILD_OUTPUT_BIN=y
    CONFIG_XIP=y
    CONFIG_MAIN_STACK_SIZE=4096
    CONFIG_IDLE_STACK_SIZE=320
    CONFIG_HAS_FLASH_LOAD_OFFSET=y
    # CONFIG_SRAM_VECTOR_TABLE is not set
    CONFIG_CPU_HAS_ARM_MPU=y
    # CONFIG_COUNTER is not set
    # CONFIG_SHARED_INTERRUPTS is not set
    # CONFIG_PM_DEVICE is not set
    CONFIG_TICKLESS_KERNEL=y
    CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30
    CONFIG_PHY_INIT_PRIORITY=70
    # CONFIG_USE_DT_CODE_PARTITION is not set
    # CONFIG_FPU is not set
    CONFIG_HW_STACK_PROTECTION=y
    CONFIG_NET_TCP_CHECKSUM=y
    CONFIG_NET_UDP_CHECKSUM=y
    # CONFIG_CODE_DATA_RELOCATION_SRAM is not set
    CONFIG_SERIAL_INIT_PRIORITY=50
    CONFIG_GPIO=y
    CONFIG_SERIAL=y
    # CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
    # CONFIG_NET_L2_IEEE802154 is not set
    # CONFIG_TINYCRYPT is not set
    CONFIG_MBEDTLS=y
    # CONFIG_MEMC is not set
    CONFIG_KERNEL_ENTRY="__start"
    # CONFIG_MULTI_LEVEL_INTERRUPTS is not set
    # CONFIG_DYNAMIC_INTERRUPTS is not set
    # CONFIG_CACHE is not set
    CONFIG_LOG=y
    # CONFIG_CODE_DATA_RELOCATION is not set
    CONFIG_DCACHE_LINE_SIZE=32
    CONFIG_GEN_IRQ_VECTOR_TABLE=y
    CONFIG_SOC="nrf5340"
    # CONFIG_RESET is not set
    CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4
    CONFIG_NRF_RTC_TIMER=y
    CONFIG_LOG_DOMAIN_NAME=""
    CONFIG_BUILD_OUTPUT_HEX=y
    CONFIG_CLOCK_CONTROL=y
    CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
    # CONFIG_UART_USE_RUNTIME_CONFIGURE is not set
    # CONFIG_SYSCON is not set
    CONFIG_ENTROPY_INIT_PRIORITY=50
    CONFIG_GEN_ISR_TABLES=y
    CONFIG_GEN_IRQ_START_VECTOR=0
    CONFIG_GEN_SW_ISR_TABLE=y
    CONFIG_SRAM_OFFSET=0
    # CONFIG_REBOOT is not set
    # CONFIG_POWER_DOMAIN is not set
    CONFIG_CONSOLE=y
    CONFIG_SOC_SERIES="nrf53"
    CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4
    CONFIG_ISR_STACK_SIZE=2048
    # CONFIG_SCHED_CPU_MASK is not set
    # CONFIG_WATCHDOG is not set
    CONFIG_ICACHE_LINE_SIZE=32
    CONFIG_PRIVILEGED_STACK_SIZE=1024
    # Devicetree Info
    CONFIG_DT_HAS_ARM_ARMV8M_ITM_ENABLED=y
    CONFIG_DT_HAS_ARM_ARMV8M_MPU_ENABLED=y
    CONFIG_DT_HAS_ARM_CORTEX_M33F_ENABLED=y
    CONFIG_DT_HAS_ARM_CRYPTOCELL_312_ENABLED=y
    CONFIG_DT_HAS_ARM_V8M_NVIC_ENABLED=y
    CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y
    CONFIG_DT_HAS_GPIO_KEYS_ENABLED=y
    CONFIG_DT_HAS_GPIO_LEDS_ENABLED=y
    CONFIG_DT_HAS_JEDEC_SPI_NOR_ENABLED=y
    CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_MBOX_NRF_IPC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_CTRLAPPERI_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_DCNF_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_DPPIC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_FICR_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIO_FORWARDER_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPREGRET_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_IEEE802154_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_IPC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_KMU_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_MUTEX_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_OSCILLATORS_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PWM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_QSPI_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_REGULATORS_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_RESET_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SAADC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SPIM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SPU_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_TIMER_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_UARTE_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_UICR_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_USBD_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_USBREG_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_VMC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF53_FLASH_CONTROLLER_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF700X_COEX_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF700X_QSPI_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF700X_TX_POWER_CEILING_ENABLED=y
    CONFIG_DT_HAS_PWM_LEDS_ENABLED=y
    CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y
    CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED=y
    CONFIG_DT_HAS_ZEPHYR_IPC_OPENAMP_STATIC_VRINGS_ENABLED=y
    # end of Devicetree Info
    # Modules
    # Available modules.
    # nrf (C:/ncs/v2.7.0/nrf)
    CONFIG_MBOX=y
    # CONFIG_NEWLIB_LIBC_NANO is not set
    CONFIG_NUM_METAIRQ_PRIORITIES=1
    CONFIG_LOG_BUFFER_SIZE=2048
    CONFIG_INIT_STACKS=y
    CONFIG_NET_IPV6_NBR_CACHE=y
    CONFIG_NET_IPV6_MLD=y
    CONFIG_NET_PKT_RX_COUNT=8
    CONFIG_NET_PKT_TX_COUNT=8
    # CONFIG_MBEDTLS_SSL_PROTO_DTLS is not set
    # CONFIG_MBEDTLS_SSL_MAX_FRAGMENT_LENGTH is not set
    # CONFIG_MBEDTLS_ENTROPY_C is not set
    CONFIG_MBEDTLS_CIPHER_MODE_CBC=y
    CONFIG_MBEDTLS_CIPHER_MODE_CTR=y
    CONFIG_MBEDTLS_CHACHA20_C=y
    CONFIG_MBEDTLS_POLY1305_C=y
    CONFIG_MBEDTLS_CHACHAPOLY_C=y
    CONFIG_MBEDTLS_DHM_C=y
    # CONFIG_MBEDTLS_RSA_C is not set
    CONFIG_MBEDTLS_SHA512_C=y
    CONFIG_MBEDTLS_GCM_C=y
    CONFIG_MBEDTLS_SSL_SRV_C=y
    CONFIG_MBEDTLS_SSL_COOKIE_C=y
    CONFIG_MBEDTLS_SSL_CLI_C=y
    CONFIG_MBEDTLS_SSL_TLS_C=y
    # CONFIG_NET_PKT_TXTIME is not set
    # CONFIG_NET_PKT_TIMESTAMP is not set
    CONFIG_MBEDTLS_PSA_KEY_SLOT_COUNT=32
    CONFIG_MPSL_WORK_STACK_SIZE=1024
    CONFIG_NET_RX_STACK_SIZE=4096
    CONFIG_NET_TX_STACK_SIZE=4096
    CONFIG_MBEDTLS_SHA1_C=y
    # CONFIG_MBEDTLS_TLS_VERSION_1_2 is not set
    CONFIG_MBEDTLS_MAC_SHA256_ENABLED=y
    # CONFIG_MBEDTLS_CTR_DRBG_ENABLED is not set
    CONFIG_MBEDTLS_MD_C=y
    CONFIG_MBEDTLS_TLS_LIBRARY=y
    CONFIG_MBEDTLS_X509_LIBRARY=y
    # CONFIG_MBEDTLS_ENABLE_HEAP is not set
    CONFIG_MBEDTLS_ECP_C=y
    CONFIG_MBEDTLS_CTR_DRBG_C=y
    CONFIG_MBEDTLS_CMAC_C=y
    CONFIG_MBEDTLS_CCM_C=y
    # CONFIG_MBEDTLS_PSA_CRYPTO_STORAGE_C is not set
    CONFIG_MBEDTLS_LEGACY_CRYPTO_C=y
    # Nordic nRF Connect
    CONFIG_WARN_EXPERIMENTAL=y
    CONFIG_BT_BUF_CMD_TX_COUNT=10
    CONFIG_INIT_ARCH_HW_AT_BOOT=y
    CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
    # CONFIG_GETOPT is not set
    # CONFIG_NCS_SAMPLES_DEFAULTS is not set
    # CONFIG_NRF700X_RADIO_TEST_COMBO is not set
    # Image build variants
    # CONFIG_NCS_MCUBOOT_IN_BUILD is not set
    # end of Image build variants
    # Subsystems
    # Bootloader
    # CONFIG_BUILD_S1_VARIANT is not set
    # CONFIG_SECURE_BOOT is not set
    CONFIG_PM_PARTITION_SIZE_PROVISION=0x280
    # CONFIG_B0_MIN_PARTITION_SIZE is not set
    CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x8000
    # CONFIG_IS_SECURE_BOOTLOADER is not set
    # Secure Boot firmware validation
    CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
    CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
    CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
    CONFIG_SB_VALIDATION_INFO_VERSION=2
    CONFIG_SB_VALIDATION_METADATA_OFFSET=0
    CONFIG_SB_VALIDATE_FW_SIGNATURE=y
    # end of Secure Boot firmware validation
    # CONFIG_SECURE_BOOT_STORAGE is not set
    # end of Bootloader
    # Bluetooth Low Energy
    CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
    # BLE over nRF RPC
    CONFIG_HEAP_MEM_POOL_SIZE=153600
    # end of BLE over nRF RPC
    # end of Bluetooth Low Energy
    # DFU
    # CONFIG_DFU_MULTI_IMAGE is not set
    # CONFIG_DFU_TARGET is not set
    # end of DFU
    # CONFIG_ESB is not set
    # Peripheral CPU DFU (PCD)
    # CONFIG_PCD is not set
    # CONFIG_PCD_APP is not set
    CONFIG_PCD_VERSION_PAGE_BUF_SIZE=2046
    # CONFIG_PCD_NET is not set
    # end of Peripheral CPU DFU (PCD)
    # Networking
    # Application protocols
    # nRF Cloud
    # Client ID (nRF Cloud Device ID)
    CONFIG_NRF_CLOUD_CLIENT_ID_SRC_COMPILE_TIME=y
    CONFIG_NRF_CLOUD_CLIENT_ID="my-client-id"
    # end of Client ID (nRF Cloud Device ID)
    # CONFIG_NRF_CLOUD_MQTT is not set
    # CONFIG_NRF_CLOUD_FOTA is not set
    CONFIG_FOTA_USE_NRF_CLOUD_SETTINGS_AREA=y
    CONFIG_FOTA_DL_TIMEOUT_MIN=15
    # CONFIG_NRF_CLOUD_FOTA_FULL_MODEM_UPDATE is not set
    # CONFIG_NRF_CLOUD_REST is not set
    # CONFIG_NRF_CLOUD_LOCATION_PARSE_ANCHORS is not set
    # CONFIG_NRF_CLOUD_ALERT is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_INF is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_DBG is not set
    CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL=3
    CONFIG_NRF_CLOUD_LOG_OUTPUT_LEVEL=1
    # CONFIG_NRF_CLOUD_LOG_INCLUDE_LEVEL_0 is not set
    CONFIG_NRF_CLOUD_LOG_BUF_SIZE=256
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_INF is not set
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_DBG is not set
    CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_CLOUD_LOG_LOG_LEVEL=3
    # CONFIG_NRF_CLOUD_COAP is not set
    # Send shadow info sections on initial connect (MQTT/CoAP)
    # end of Send shadow info sections on initial connect (MQTT/CoAP)
    # CONFIG_NRF_CLOUD_GATEWAY is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_INF is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_DBG is not set
    CONFIG_NRF_CLOUD_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_CLOUD_LOG_LEVEL=3
    # end of nRF Cloud
    # CONFIG_REST_CLIENT is not set
    # CONFIG_DOWNLOAD_CLIENT is not set
    # CONFIG_AWS_IOT is not set
    # CONFIG_AWS_JOBS is not set
    # CONFIG_AZURE_IOT_HUB is not set
    # Self-Registration (Zi ZHu Ce)
    # end of Self-Registration (Zi ZHu Ce)
    # CONFIG_ICAL_PARSER is not set
    # CONFIG_FTP_CLIENT is not set
    # CONFIG_LWM2M_CLIENT_UTILS is not set
    # CONFIG_WIFI_CREDENTIALS is not set
    # CONFIG_WIFI_CREDENTIALS_STATIC is not set
    # CONFIG_WIFI_READY_LIB is not set
    # CONFIG_MQTT_HELPER is not set
    # CONFIG_NRF_MCUMGR_SMP_CLIENT is not set
    # end of Application protocols
    # end of Networking
    # NFC
    # CONFIG_NFC_NDEF is not set
    # CONFIG_NFC_NDEF_PARSER is not set
    # CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
    # CONFIG_NFC_T2T_PARSER is not set
    # CONFIG_NFC_T4T_NDEF_FILE is not set
    # CONFIG_NFC_T4T_ISODEP is not set
    # CONFIG_NFC_T4T_APDU is not set
    # CONFIG_NFC_T4T_CC_FILE is not set
    # CONFIG_NFC_T4T_HL_PROCEDURE is not set
    # CONFIG_NFC_PLATFORM is not set
    # CONFIG_NFC_TNEP_TAG is not set
    # CONFIG_NFC_TNEP_POLLER is not set
    # CONFIG_NFC_TNEP_CH is not set
    # end of NFC
    # CONFIG_APP_EVENT_MANAGER is not set
    # CONFIG_NRF_PROFILER is not set
    # CONFIG_FW_INFO is not set
    # Debug
    # CONFIG_CPU_LOAD is not set
    # CONFIG_PPI_TRACE is not set
    # end of Debug
    # Multiprotocol service layer (MPSL)
    # CONFIG_MPSL_FEM_ONLY is not set
    # CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_OFF is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_ERR is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_WRN is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_INF is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_DBG is not set
    CONFIG_MPSL_FEM_LOG_LEVEL_DEFAULT=y
    CONFIG_MPSL_FEM_LOG_LEVEL=3
    CONFIG_MPSL_CX_ANY_SUPPORT=y
    CONFIG_MPSL_CX_NRF700X_SUPPORT=y
    # CONFIG_MPSL_CX is not set
    CONFIG_MPSL_THREAD_COOP_PRIO=8
    CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
    # CONFIG_MPSL_ASSERT_HANDLER is not set
    CONFIG_MPSL_LOW_PRIO_IRQN=26
    # CONFIG_MPSL_LOG_LEVEL_OFF is not set
    # CONFIG_MPSL_LOG_LEVEL_ERR is not set
    # CONFIG_MPSL_LOG_LEVEL_WRN is not set
    # CONFIG_MPSL_LOG_LEVEL_INF is not set
    # CONFIG_MPSL_LOG_LEVEL_DBG is not set
    CONFIG_MPSL_LOG_LEVEL_DEFAULT=y
    CONFIG_MPSL_LOG_LEVEL=3
    # end of Multiprotocol service layer (MPSL)
    # Partition Manager
    # CONFIG_PARTITION_MANAGER_ENABLED is not set
    CONFIG_SRAM_BASE_ADDRESS=0x20000000
    # Zephyr subsystem configurations
    # end of Zephyr subsystem configurations
    # NCS subsystem configurations
    # CONFIG_PM_SINGLE_IMAGE is not set
    CONFIG_PM_EXTERNAL_FLASH_BASE=0
    CONFIG_PM_EXTERNAL_FLASH_PATH=""
    CONFIG_PM_EXTERNAL_FLASH_SIZE_BITS=0
    # CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK is not set
    CONFIG_PM_SRAM_BASE=0x20000000
    CONFIG_PM_SRAM_SIZE=0x80000
    # end of Partition Manager
    # nRF RPC (Remote Procedure Call) library
    # end of nRF RPC (Remote Procedure Call) library
    # CONFIG_ZIGBEE is not set
    # Full Modem Firmware Update Management(FMFU)
    # CONFIG_MGMT_FMFU_LOG_LEVEL_OFF is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_ERR is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_WRN is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_INF is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_DBG is not set
    CONFIG_MGMT_FMFU_LOG_LEVEL_DEFAULT=y
    CONFIG_MGMT_FMFU_LOG_LEVEL=3
    # end of Full Modem Firmware Update Management(FMFU)
    # SUIT-based Firmware Update Management
    CONFIG_MGMT_SUITFU_TRIGGER_UPDATE_RESET_DELAY_MS=100
    CONFIG_MGMT_SUITFU_AUTO_REGISTER_HANDLERS=y
    CONFIG_MGMT_SUITFU_GRP_IMG=y
    CONFIG_MGMT_SUITFU_IMAGE_NUMBER=0
    # CONFIG_MGMT_SUITFU_GRP_SUIT is not set
    # CONFIG_MGMT_SUITFU_LOG_LEVEL_OFF is not set
    # CONFIG_MGMT_SUITFU_LOG_LEVEL_ERR is not set
    # CONFIG_MGMT_SUITFU_LOG_LEVEL_WRN is not set
    # CONFIG_MGMT_SUITFU_LOG_LEVEL_INF is not set
    # CONFIG_MGMT_SUITFU_LOG_LEVEL_DBG is not set
    CONFIG_MGMT_SUITFU_LOG_LEVEL_DEFAULT=y
    CONFIG_MGMT_SUITFU_LOG_LEVEL=3
    # end of SUIT-based Firmware Update Management
    # CONFIG_CAF is not set
    # Nordic IEEE 802.15.4
    # end of Nordic IEEE 802.15.4
    # CONFIG_DM_MODULE is not set
    # nRF Security
    # CONFIG_NORDIC_SECURITY_BACKEND is not set
    CONFIG_NRF_SECURITY=y
    CONFIG_MBEDTLS_CFG_FILE="nrf-config.h"
    CONFIG_MBEDTLS_USER_CONFIG_FILE="nrf-config-user-empty.h"
    CONFIG_MBEDTLS_PSA_CRYPTO_CONFIG_FILE="nrf-psa-crypto-want-config.h"
    CONFIG_MBEDTLS_PSA_CRYPTO_USER_CONFIG_FILE="nrf-psa-crypto-config.h"
    CONFIG_GENERATE_MBEDTLS_CFG_FILE=y
    CONFIG_MBEDTLS_X509_USE_C=y
    # CONFIG_MBEDTLS_X509_CREATE_C is not set
    CONFIG_MBEDTLS_X509_CHECK_KEY_USAGE=y
    CONFIG_MBEDTLS_X509_CHECK_EXTENDED_KEY_USAGE=y
    CONFIG_MBEDTLS_X509_CRL_PARSE_C=y
    CONFIG_MBEDTLS_X509_CSR_PARSE_C=y
    CONFIG_MBEDTLS_X509_CRT_PARSE_C=y
    # CONFIG_MBEDTLS_X509_CSR_WRITE_C is not set
    CONFIG_MBEDTLS_X509_REMOVE_INFO=y
    CONFIG_MBEDTLS_SSL_PROTO_TLS1_2=y
    CONFIG_MBEDTLS_SSL_ENCRYPT_THEN_MAC=y
    CONFIG_MBEDTLS_SSL_EXTENDED_MASTER_SECRET=y
    # CONFIG_MBEDTLS_DEBUG_C is not set
    # CONFIG_MBEDTLS_MEMORY_DEBUG is not set
    CONFIG_MBEDTLS_SSL_ALL_ALERT_MESSAGES=y
    CONFIG_MBEDTLS_SSL_CONTEXT_SERIALIZATION=y
    # CONFIG_MBEDTLS_SSL_DEBUG_ALL is not set
    CONFIG_MBEDTLS_SSL_KEEP_PEER_CERTIFICATE=y
    # CONFIG_MBEDTLS_SSL_RENEGOTIATION is not set
    # CONFIG_MBEDTLS_SSL_SESSION_TICKETS is not set
    # CONFIG_MBEDTLS_SSL_SERVER_NAME_INDICATION is not set
    # CONFIG_MBEDTLS_SSL_CACHE_C is not set
    # CONFIG_MBEDTLS_SSL_TICKET_C is not set
    CONFIG_MBEDTLS_SSL_EXPORT_KEYS=y
    CONFIG_MBEDTLS_SSL_OUT_CONTENT_LEN=16380
    CONFIG_MBEDTLS_SSL_IN_CONTENT_LEN=16380
    CONFIG_MBEDTLS_SSL_CIPHERSUITES=""
    # TLS/DTL Cipher Suites
    CONFIG_MBEDTLS_HAS_CBC_CIPHERSUITE_REQUIREMENTS=y
    CONFIG_MBEDTLS_HAS_GCM_CIPHERSUITE_REQUIREMENTS=y
    CONFIG_MBEDTLS_HAS_CCM_CIPHERSUITE_REQUIREMENTS=y
    CONFIG_MBEDTLS_HAS_CHACHAPOLY_CIPHERSUITE_REQUIREMENTS=y
    CONFIG_MBEDTLS_HAS_CIPHER_MODE_CIPHERSUITE_REQUIREMENTS=y
    CONFIG_MBEDTLS_HAS_ECDH_CIPHERSUITE_REQUIREMENTS=y
    CONFIG_MBEDTLS_HAS_ECDSA_CIPHERSUITE_REQUIREMENTS=y
    CONFIG_MBEDTLS_HAS_ECJPAKE_CIPHERSUITE_REQUIREMENTS=y
    CONFIG_MBEDTLS_KEY_EXCHANGE_PSK_ENABLED=y
    CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_PSK_ENABLED=y
    CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA_ENABLED=y
    CONFIG_MBEDTLS_KEY_EXCHANGE_ECDH_ECDSA_ENABLED=y
    CONFIG_MBEDTLS_KEY_EXCHANGE_ECJPAKE_ENABLED=y
    # end of TLS/DTL Cipher Suites
    CONFIG_MBEDTLS_PSA_CRYPTO_C=y
    CONFIG_MBEDTLS_PSA_CRYPTO_CLIENT=y
    CONFIG_PSA_WANT_ALG_SHA_256=y
    # PSA RNG support
    # CONFIG_PSA_WANT_GENERATE_RANDOM is not set
    # CONFIG_PSA_WANT_ALG_CTR_DRBG is not set
    # CONFIG_PSA_WANT_ALG_HMAC_DRBG is not set
    # end of PSA RNG support
    # PSA key type support
    # CONFIG_PSA_WANT_KEY_TYPE_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RAW_DATA is not set
    # CONFIG_PSA_WANT_KEY_TYPE_HMAC is not set
    # CONFIG_PSA_WANT_KEY_TYPE_PASSWORD is not set
    # CONFIG_PSA_WANT_KEY_TYPE_PASSWORD_HASH is not set
    # CONFIG_PSA_WANT_KEY_TYPE_PEPPER is not set
    # CONFIG_PSA_WANT_KEY_TYPE_AES is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ARIA is not set
    # CONFIG_PSA_WANT_KEY_TYPE_DES is not set
    # CONFIG_PSA_WANT_KEY_TYPE_CAMELLIA is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SM4 is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ARC4 is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_DH_KEY_PAIR is not set
    # CONFIG_PSA_WANT_KEY_TYPE_DH_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR is not set
    # end of PSA key type support
    # PSA AEAD support
    # CONFIG_PSA_WANT_ALG_CCM is not set
    # CONFIG_PSA_WANT_ALG_GCM is not set
    # CONFIG_PSA_WANT_ALG_CHACHA20_POLY1305 is not set
    # end of PSA AEAD support
    # PSA MAC support
    CONFIG_PSA_HAS_MAC_SUPPORT=y
    # CONFIG_PSA_WANT_ALG_CBC_MAC is not set
    # CONFIG_PSA_WANT_ALG_CMAC is not set
    CONFIG_PSA_WANT_ALG_HMAC=y
    # end of PSA MAC support
    # PSA Hash support
    CONFIG_PSA_HAS_HASH_SUPPORT=y
    # CONFIG_PSA_WANT_ALG_SHA_1 is not set
    CONFIG_PSA_WANT_ALG_SHA_224=y
    # CONFIG_PSA_WANT_ALG_SHA_384 is not set
    # CONFIG_PSA_WANT_ALG_SHA_512 is not set
    # CONFIG_PSA_WANT_ALG_SHA_512_224 is not set
    # CONFIG_PSA_WANT_ALG_SHA_512_256 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_224 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_256 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_384 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_512 is not set
    # CONFIG_PSA_WANT_ALG_SM3 is not set
    # CONFIG_PSA_WANT_ALG_SHAKE256_512 is not set
    # CONFIG_PSA_WANT_ALG_RIPEMD160 is not set
    # CONFIG_PSA_WANT_ALG_MD2 is not set
    # CONFIG_PSA_WANT_ALG_MD4 is not set
    # CONFIG_PSA_WANT_ALG_MD5 is not set
    # end of PSA Hash support
    # PSA Cipher support
    # CONFIG_PSA_WANT_ALG_ECB_NO_PADDING is not set
    # CONFIG_PSA_WANT_ALG_CBC_NO_PADDING is not set
    # CONFIG_PSA_WANT_ALG_CBC_PKCS7 is not set
    # CONFIG_PSA_WANT_ALG_CFB is not set
    # CONFIG_PSA_WANT_ALG_CTR is not set
    # CONFIG_PSA_WANT_ALG_OFB is not set
    # CONFIG_PSA_WANT_ALG_XTS is not set
    # CONFIG_PSA_WANT_ALG_CCM_STAR_NO_TAG is not set
    # CONFIG_PSA_WANT_ALG_STREAM_CIPHER is not set
    # end of PSA Cipher support
    # PSA Key agreement support
    # CONFIG_PSA_WANT_ALG_ECDH is not set
    # CONFIG_PSA_WANT_ALG_FFDH is not set
    # end of PSA Key agreement support
    # PSA Key derivation support
    CONFIG_PSA_HAS_KEY_DERIVATION=y
    # CONFIG_PSA_WANT_ALG_HKDF is not set
    # CONFIG_PSA_WANT_ALG_HKDF_EXTRACT is not set
    # CONFIG_PSA_WANT_ALG_HKDF_EXPAND is not set
    # CONFIG_PSA_WANT_ALG_PBKDF2_HMAC is not set
    # CONFIG_PSA_WANT_ALG_SP800_108_COUNTER_HMAC is not set
    CONFIG_PSA_WANT_ALG_TLS12_PRF=y
    CONFIG_PSA_WANT_ALG_TLS12_PSK_TO_MS=y
    # CONFIG_PSA_WANT_ALG_TLS12_ECJPAKE_TO_PMS is not set
    # end of PSA Key derivation support
    # PSA Asymmetric support
    # CONFIG_PSA_WANT_ALG_ECDSA is not set
    # CONFIG_PSA_WANT_ALG_ECDSA_ANY is not set
    # CONFIG_PSA_WANT_ALG_DETERMINISTIC_ECDSA is not set
    # Elliptic Curve type support
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_160 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_192 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_224 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_256 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_320 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_384 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_512 is not set
    # CONFIG_PSA_WANT_ECC_MONTGOMERY_255 is not set
    # CONFIG_PSA_WANT_ECC_MONTGOMERY_448 is not set
    # CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_255 is not set
    # CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_448 is not set
    # CONFIG_PSA_WANT_ECC_SECP_K1_192 is not set
    # CONFIG_PSA_WANT_ECC_SECP_K1_224 is not set
    # CONFIG_PSA_WANT_ECC_SECP_K1_256 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_192 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_224 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_256 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_384 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_521 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R2_160 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_163 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_233 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_239 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_283 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_409 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_571 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_163 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_233 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_283 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_409 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_571 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R2_163 is not set
    # CONFIG_PSA_WANT_ECC_FRP_V1_256 is not set
    # end of Elliptic Curve type support
    # CONFIG_PSA_WANT_ALG_RSA_OAEP is not set
    # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_CRYPT is not set
    # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN is not set
    # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN_RAW is not set
    # CONFIG_PSA_WANT_ALG_RSA_PSS is not set
    # CONFIG_PSA_WANT_ALG_RSA_PSS_ANY_SALT is not set
    # end of PSA Asymmetric support
    # CONFIG_PSA_WANT_ALG_JPAKE is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_HMAC is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_CMAC is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_MATTER is not set
    # CONFIG_PSA_WANT_ALG_SRP_6 is not set
    # CONFIG_PSA_WANT_ALG_SRP_PASSWORD_HASH is not set
    # CONFIG_PSA_WANT_ALG_PURE_EDDSA is not set
    # CONFIG_PSA_WANT_ALG_ED25519PH is not set
    # CONFIG_PSA_WANT_ALG_ED448PH is not set
    CONFIG_PSA_CORE_OBERON=y
    # PSA Driver Support
    CONFIG_MBEDTLS_PSA_CRYPTO_DRIVERS=y
    CONFIG_PSA_CRYPTO_DRIVER_OBERON=y
    # CONFIG_PSA_CRYPTO_DRIVER_CC3XX is not set
    # Choose DRBG algorithm
    # end of Choose DRBG algorithm
    # CryptoCell PSA Driver Configuration
    # end of CryptoCell PSA Driver Configuration
    # CRACEN PSA Driver Configuration
    # end of CRACEN PSA Driver Configuration
    # AES key size configuration
    CONFIG_PSA_WANT_AES_KEY_SIZE_128=y
    CONFIG_PSA_WANT_AES_KEY_SIZE_192=y
    CONFIG_PSA_WANT_AES_KEY_SIZE_256=y
    # end of AES key size configuration
    # RSA key size configuration
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_1024 is not set
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_1536 is not set
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_2048 is not set
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_3072 is not set
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_4096 is not set
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_6144 is not set
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_8192 is not set
    CONFIG_PSA_MAX_RSA_KEY_BITS=0
    # end of RSA key size configuration
    # CONFIG_CRACEN_LOG_LEVEL_OFF is not set
    # CONFIG_CRACEN_LOG_LEVEL_ERR is not set
    # CONFIG_CRACEN_LOG_LEVEL_WRN is not set
    # CONFIG_CRACEN_LOG_LEVEL_INF is not set
    # CONFIG_CRACEN_LOG_LEVEL_DBG is not set
    CONFIG_CRACEN_LOG_LEVEL_DEFAULT=y
    CONFIG_CRACEN_LOG_LEVEL=3
    CONFIG_PSA_NEED_OBERON_SHA_224=y
    CONFIG_PSA_NEED_OBERON_SHA_256=y
    CONFIG_PSA_NEED_OBERON_HASH_DRIVER=y
    CONFIG_PSA_NEED_OBERON_HMAC=y
    CONFIG_PSA_NEED_OBERON_MAC_DRIVER=y
    CONFIG_PSA_NEED_OBERON_TLS12_PRF=y
    CONFIG_PSA_NEED_OBERON_TLS12_PSK_TO_MS=y
    CONFIG_PSA_NEED_OBERON_KEY_DERIVATION_DRIVER=y
    # PSA API support
    # CONFIG_MBEDTLS_USE_PSA_CRYPTO is not set
    # end of PSA API support
    CONFIG_MBEDTLS_PLATFORM_MEMORY=y
    CONFIG_MBEDTLS_PLATFORM_C=y
    CONFIG_MBEDTLS_MEMORY_C=y
    CONFIG_MBEDTLS_MEMORY_BUFFER_ALLOC_C=y
    CONFIG_MBEDTLS_ENTROPY_HARDWARE_ALT=y
    CONFIG_MBEDTLS_AES_SETKEY_ENC_ALT=y
    CONFIG_MBEDTLS_AES_SETKEY_DEC_ALT=y
    CONFIG_MBEDTLS_AES_ENCRYPT_ALT=y
    CONFIG_MBEDTLS_AES_DECRYPT_ALT=y
    CONFIG_MBEDTLS_CHACHA20_ALT=y
    CONFIG_MBEDTLS_POLY1305_ALT=y
    CONFIG_MBEDTLS_ECDH_GEN_PUBLIC_ALT=y
    CONFIG_MBEDTLS_ECDH_COMPUTE_SHARED_ALT=y
    CONFIG_MBEDTLS_ECDSA_GENKEY_ALT=y
    CONFIG_MBEDTLS_ECDSA_SIGN_ALT=y
    CONFIG_MBEDTLS_ECDSA_VERIFY_ALT=y
    CONFIG_MBEDTLS_ECJPAKE_ALT=y
    CONFIG_MBEDTLS_SHA1_ALT=y
    CONFIG_MBEDTLS_SHA224_ALT=y
    CONFIG_MBEDTLS_SHA256_ALT=y
    CONFIG_MBEDTLS_ENTROPY_FORCE_SHA256=y
    CONFIG_MBEDTLS_ENTROPY_MAX_SOURCES=1
    CONFIG_MBEDTLS_NO_PLATFORM_ENTROPY=y
    # CONFIG_NRF_SECURITY_ADVANCED is not set
    CONFIG_OBERON_ONLY_PSA_ENABLED=y
    CONFIG_OBERON_ONLY_ENABLED=y
    # Legacy mbed TLS crypto APIs
    CONFIG_MBEDTLS_MPI_WINDOW_SIZE=6
    CONFIG_MBEDTLS_MPI_MAX_SIZE=256
    # CONFIG_CC3XX_BACKEND is not set
    # CONFIG_OBERON_BACKEND is not set
    CONFIG_MBEDTLS_HMAC_DRBG_C=y
    CONFIG_MBEDTLS_AES_C=y
    # Cipher Selection
    # CBC cipher padding modes
    CONFIG_MBEDTLS_CIPHER_PADDING_PKCS7=y
    CONFIG_MBEDTLS_CIPHER_PADDING_ONE_AND_ZEROS=y
    CONFIG_MBEDTLS_CIPHER_PADDING_ZEROS_AND_LEN=y
    CONFIG_MBEDTLS_CIPHER_PADDING_ZEROS=y
    # CONFIG_MBEDTLS_AES_FEWER_TABLES is not set
    # CONFIG_MBEDTLS_AES_ROM_TABLES is not set
    # end of CBC cipher padding modes
    # CONFIG_MBEDTLS_AES_ONLY_128_BIT_KEY_LENGTH is not set
    # AEAD  - Authenticated Encryption with Associated Data
    # end of AEAD  - Authenticated Encryption with Associated Data
    CONFIG_MBEDTLS_ECDH_C=y
    CONFIG_MBEDTLS_ECDSA_C=y
    CONFIG_MBEDTLS_ECDSA_DETERMINISTIC=y
    CONFIG_MBEDTLS_ECJPAKE_C=y
    # ECC curves
    # CONFIG_MBEDTLS_ECP_DP_SECP192R1_ENABLED is not set
    # CONFIG_MBEDTLS_ECP_DP_SECP224R1_ENABLED is not set
    CONFIG_MBEDTLS_ECP_DP_SECP256R1_ENABLED=y
    # CONFIG_MBEDTLS_ECP_DP_SECP384R1_ENABLED is not set
    # CONFIG_MBEDTLS_ECP_DP_SECP521R1_ENABLED is not set
    # CONFIG_MBEDTLS_ECP_DP_SECP192K1_ENABLED is not set
    # CONFIG_MBEDTLS_ECP_DP_SECP224K1_ENABLED is not set
    # CONFIG_MBEDTLS_ECP_DP_SECP256K1_ENABLED is not set
    # CONFIG_MBEDTLS_ECP_DP_BP256R1_ENABLED is not set
    # CONFIG_MBEDTLS_ECP_DP_BP384R1_ENABLED is not set
    # CONFIG_MBEDTLS_ECP_DP_BP512R1_ENABLED is not set
    # CONFIG_MBEDTLS_ECP_DP_CURVE25519_ENABLED is not set
    # CONFIG_MBEDTLS_ECP_DP_CURVE448_ENABLED is not set
    # end of ECC curves
    CONFIG_MBEDTLS_HKDF_C=y
    # SHA - Secure Hash Algorithm
    CONFIG_MBEDTLS_MD5_C=y
    CONFIG_MBEDTLS_SHA224_C=y
    CONFIG_MBEDTLS_SHA256_C=y
    # CONFIG_MBEDTLS_SHA256_SMALLER is not set
    CONFIG_MBEDTLS_SHA384_C=y
    # CONFIG_MBEDTLS_512_SMALLER is not set
    # end of SHA - Secure Hash Algorithm
    CONFIG_MBEDTLS_CIPHER_C=y
    CONFIG_MBEDTLS_PK_C=y
    CONFIG_MBEDTLS_PKCS5_C=y
    CONFIG_MBEDTLS_PK_WRITE_C=y
    CONFIG_MBEDTLS_PK_PARSE_C=y
    CONFIG_MBEDTLS_PK_PARSE_EC_EXTENDED=y
    # end of Legacy mbed TLS crypto APIs
    # Zephyr legacy configurations
    # CONFIG_MBEDTLS_DTLS is not set
    CONFIG_MBEDTLS_KEY_EXCHANGE_ALL_ENABLED=y
    # CONFIG_MBEDTLS_KEY_EXCHANGE_SOME_PSK_ENABLED is not set
    # CONFIG_MBEDTLS_ECP_ALL_ENABLED is not set
    # CONFIG_MBEDTLS_CIPHER_ALL_ENABLED is not set
    # CONFIG_MBEDTLS_MAC_ALL_ENABLED is not set
    # CONFIG_MBEDTLS_MAC_MD5_ENABLED is not set
    # CONFIG_MBEDTLS_HMAC_DRBG_ENABLED is not set
    # CONFIG_MBEDTLS_CIPHER is not set
    # CONFIG_MBEDTLS_MD is not set
    # CONFIG_MBEDTLS_ENTROPY_ENABLED is not set
    # CONFIG_MBEDTLS_GENPRIME_ENABLED is not set
    # end of Zephyr legacy configurations
    CONFIG_MBEDTLS_LIBRARY_NRF_SECURITY=y
    # end of nRF Security
    # CONFIG_NET_CORE_MONITOR is not set
    # Audio Module
    # CONFIG_AUDIO_MODULE_TEST is not set
    CONFIG_AUDIO_MODULE_NAME_SIZE=20
    # CONFIG_AUDIO_MODULE_LOG_LEVEL_OFF is not set
    # CONFIG_AUDIO_MODULE_LOG_LEVEL_ERR is not set
    # CONFIG_AUDIO_MODULE_LOG_LEVEL_WRN is not set
    # CONFIG_AUDIO_MODULE_LOG_LEVEL_INF is not set
    # CONFIG_AUDIO_MODULE_LOG_LEVEL_DBG is not set
    CONFIG_AUDIO_MODULE_LOG_LEVEL_DEFAULT=y
    CONFIG_AUDIO_MODULE_LOG_LEVEL=3
    # end of Audio Module
    # CONFIG_UART_ASYNC_ADAPTER is not set
    # CONFIG_TRUSTED_STORAGE is not set
    # SUIT provisioning
    # CONFIG_SUIT_MPI_GENERATE is not set
    # end of SUIT provisioning
    # CONFIG_SUIT is not set
    # CONFIG_MBEDTLS_ZEPHYR_ENTROPY is not set
    # end of Subsystems
    CONFIG_WPA_SUPP=y
    CONFIG_COMMON_LIBC_MALLOC_ARENA_SIZE=30000
    CONFIG_WPA_SUPP_WMM_AC=y
    CONFIG_WPA_SUPP_MBO=y
    CONFIG_WPA_SUPP_ADVANCED_FEATURES=y
    CONFIG_WPA_SUPP_ROBUST_AV=y
    CONFIG_WPA_SUPP_WNM=y
    CONFIG_WPA_SUPP_RRM=y
    CONFIG_WPA_SUPP_MGD_IFACES_PREFIXES="wlan,esp,nordic_wlan"
    CONFIG_WPA_SUPP_THREAD_STACK_SIZE=5200
    CONFIG_WPA_SUPP_WQ_STACK_SIZE=4400
    CONFIG_WPA_SUPP_WQ_PRIORITY=7
    # CONFIG_WPA_SUPP_CRYPTO_WEP is not set
    # CONFIG_WPA_SUPP_CRYPTO_PSA is not set
    CONFIG_WPA_SUPP_CRYPTO_LEGACY=y
    # CONFIG_WPA_SUPP_CRYPTO_LEGACY_MBEDTLS is not set
    # CONFIG_WPA_SUPP_CRYPTO_NONE is not set
    # CONFIG_NET_TCP_ISN_RFC6528 is not set
    # CONFIG_WPA_SUPP_CRYPTO_ENTERPRISE is not set
    CONFIG_WPA_SUPP_WPA3=y
    # CONFIG_WPA_SUPP_AP is not set
    # CONFIG_WPA_SUPP_WPS is not set
    # CONFIG_WPA_SUPP_P2P is not set
    # CONFIG_WPA_SUPP_EAPOL is not set
    # CONFIG_WPA_CLI is not set
    CONFIG_NET_SOCKETPAIR_BUFFER_SIZE=4096
    CONFIG_POSIX_MAX_FDS=16
    CONFIG_BSS_MAX_IDLE_TIME=300
    CONFIG_NET_MGMT_EVENT_STACK_SIZE=4400
    CONFIG_NET_SOCKETS_POLL_MAX=10
    # CONFIG_WPA_SUPP_LOG_LEVEL_OFF is not set
    # CONFIG_WPA_SUPP_LOG_LEVEL_ERR is not set
    # CONFIG_WPA_SUPP_LOG_LEVEL_WRN is not set
    # CONFIG_WPA_SUPP_LOG_LEVEL_INF is not set
    # CONFIG_WPA_SUPP_LOG_LEVEL_DBG is not set
    CONFIG_WPA_SUPP_LOG_LEVEL_DEFAULT=y
    CONFIG_WPA_SUPP_LOG_LEVEL=3
    CONFIG_WPA_SUPP_DEBUG_LEVEL=6
    # CONFIG_WPA_SUPP_NO_DEBUG is not set
    CONFIG_WPA_SUPP_NW_SEL_THROUGHPUT=y
    # CONFIG_WPA_SUPP_NW_SEL_RELIABILITY is not set
    # CONFIG_WFA_QT_LOG_LEVEL_OFF is not set
    # CONFIG_WFA_QT_LOG_LEVEL_ERR is not set
    # CONFIG_WFA_QT_LOG_LEVEL_WRN is not set
    # CONFIG_WFA_QT_LOG_LEVEL_INF is not set
    # CONFIG_WFA_QT_LOG_LEVEL_DBG is not set
    CONFIG_WFA_QT_LOG_LEVEL_DEFAULT=y
    CONFIG_WFA_QT_LOG_LEVEL=3
    # CONFIG_WFA_QT_CONTROL_APP is not set
    CONFIG_WFA_QT_THREAD_STACK_SIZE=4096
    CONFIG_WFA_QT_REBOOT_TIMEOUT_MS=1000
    CONFIG_WFA_QT_DEFAULT_INTERFACE="nordic_wlan0"
    CONFIG_WPAS_READY_TIMEOUT_MS=10000
    # Libraries
    # Binary libraries
    # end of Binary libraries
    # CONFIG_AT_MONITOR is not set
    # CONFIG_LTE_LINK_CONTROL is not set
    CONFIG_NRF_SPU_FLASH_REGION_SIZE=0x4000
    CONFIG_FPROTECT_BLOCK_SIZE=0x4000
    # CONFIG_FPROTECT is not set
    # CONFIG_AT_CMD_CUSTOM is not set
    # CONFIG_DK_LIBRARY is not set
    # CONFIG_AT_CMD_PARSER is not set
    # CONFIG_MODEM_INFO is not set
    # CONFIG_RESET_ON_FATAL_ERROR is not set
    # CONFIG_SMS is not set
    # CONFIG_SUPL_CLIENT_LIB is not set
    # CONFIG_DATE_TIME is not set
    # CONFIG_HW_ID_LIBRARY is not set
    # CONFIG_RAM_POWER_DOWN_LIBRARY is not set
    # CONFIG_WAVE_GEN_LIB is not set
    CONFIG_HW_UNIQUE_KEY_SUPPORTED=y
    CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0
    # CONFIG_MODEM_JWT is not set
    # CONFIG_LOCATION is not set
    # CONFIG_QOS is not set
    # CONFIG_SFLOAT is not set
    # CONFIG_CONTIN_ARRAY is not set
    # CONFIG_PCM_MIX is not set
    # CONFIG_TONE is not set
    # CONFIG_PSCM is not set
    # CONFIG_DATA_FIFO is not set
    # CONFIG_FEM_AL_LIB is not set
    # CONFIG_SAMPLE_RATE_CONVERTER is not set
    CONFIG_NCS_BOOT_BANNER=y
    CONFIG_NCS_NCS_BOOT_BANNER_STRING="nRF Connect SDK"
    CONFIG_NCS_ZEPHYR_BOOT_BANNER_STRING="Zephyr OS"
    # end of Libraries
    # Device Drivers
    # CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set
    CONFIG_ENTROPY_CC3XX=y
    CONFIG_HW_CC3XX=y
    # CONFIG_ETH_RTT is not set
    # CONFIG_SENSOR is not set
    # CONFIG_NRF_SW_LPUART is not set
    CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=1
    CONFIG_WIFI_NRF700X=y
    # CONFIG_WIFI_NRF700X_BUS_LOG_LEVEL_OFF is not set
    # CONFIG_WIFI_NRF700X_BUS_LOG_LEVEL_ERR is not set
    # CONFIG_WIFI_NRF700X_BUS_LOG_LEVEL_WRN is not set
    # CONFIG_WIFI_NRF700X_BUS_LOG_LEVEL_INF is not set
    # CONFIG_WIFI_NRF700X_BUS_LOG_LEVEL_DBG is not set
    CONFIG_WIFI_NRF700X_BUS_LOG_LEVEL_DEFAULT=y
    CONFIG_WIFI_NRF700X_BUS_LOG_LEVEL=3
    CONFIG_NRF700X_SYSTEM_MODE=y
    # CONFIG_NRF700X_SCAN_ONLY is not set
    # CONFIG_NRF700X_RADIO_TEST is not set
    # CONFIG_NRF700X_SYSTEM_WITH_RAW_MODES is not set
    CONFIG_NRF700X_STA_MODE=y
    # CONFIG_NRF700X_P2P_MODE is not set
    # CONFIG_NRF700X_RAW_DATA_TX is not set
    # CONFIG_NRF700X_RAW_DATA_RX is not set
    # CONFIG_NRF700X_PROMISC_DATA_RX is not set
    CONFIG_NRF700X_DATA_TX=y
    CONFIG_NRF_WIFI_IF_AUTO_START=y
    CONFIG_NRF_WIFI_PATCHES_BUILTIN=y
    CONFIG_NRF_WIFI_PATCHES_EXT_FLASH_DISABLED=y
    # CONFIG_NRF_WIFI_PATCHES_EXT_FLASH_XIP is not set
    # CONFIG_NRF_WIFI_PATCHES_EXT_FLASH_STORE is not set
    CONFIG_CUSTOM_LINKER_SCRIPT="C:/ncs/v2.7.0/zephyr/../nrf/drivers/wifi/nrf700x/rpu_fw_patches.ld"
    CONFIG_NRF_WIFI_LOW_POWER=y
    CONFIG_NRF700X_TCP_IP_CHECKSUM_OFFLOAD=y
    CONFIG_NRF700X_REG_DOMAIN="00"
    CONFIG_NRF700X_LOG_VERBOSE=y
    # CONFIG_WIFI_NRF700X_LOG_LEVEL_OFF is not set
    # CONFIG_WIFI_NRF700X_LOG_LEVEL_ERR is not set
    # CONFIG_WIFI_NRF700X_LOG_LEVEL_WRN is not set
    # CONFIG_WIFI_NRF700X_LOG_LEVEL_INF is not set
    # CONFIG_WIFI_NRF700X_LOG_LEVEL_DBG is not set
    CONFIG_WIFI_NRF700X_LOG_LEVEL_DEFAULT=y
    CONFIG_WIFI_NRF700X_LOG_LEVEL=3
    CONFIG_NRF700X_ON_QSPI=y
    CONFIG_NRF700X_SR_COEX=y
    CONFIG_NRF700X_SR_COEX_RF_SWITCH=y
    CONFIG_NRF700X_WORKQ_STACK_SIZE=4096
    CONFIG_NRF700X_WORKQ_MAX_ITEMS=100
    CONFIG_NRF700X_MAX_TX_PENDING_QLEN=18
    CONFIG_NRF700X_QSPI_LOW_POWER=y
    CONFIG_NRF700X_PCB_LOSS_2G=0
    CONFIG_NRF700X_PCB_LOSS_5G_BAND1=0
    CONFIG_NRF700X_PCB_LOSS_5G_BAND2=0
    CONFIG_NRF700X_PCB_LOSS_5G_BAND3=0
    CONFIG_NRF700X_ANT_GAIN_2G=0
    CONFIG_NRF700X_ANT_GAIN_5G_BAND1=0
    CONFIG_NRF700X_ANT_GAIN_5G_BAND2=0
    CONFIG_NRF700X_ANT_GAIN_5G_BAND3=0
    CONFIG_NRF700X_BAND_2G_LOWER_EDGE_BACKOFF_DSSS=0
    CONFIG_NRF700X_BAND_2G_LOWER_EDGE_BACKOFF_HT=0
    CONFIG_NRF700X_BAND_2G_LOWER_EDGE_BACKOFF_HE=0
    CONFIG_NRF700X_BAND_2G_UPPER_EDGE_BACKOFF_DSSS=0
    CONFIG_NRF700X_BAND_2G_UPPER_EDGE_BACKOFF_HT=0
    CONFIG_NRF700X_BAND_2G_UPPER_EDGE_BACKOFF_HE=0
    CONFIG_NRF700X_BAND_UNII_1_LOWER_EDGE_BACKOFF_HT=0
    CONFIG_NRF700X_BAND_UNII_1_LOWER_EDGE_BACKOFF_HE=0
    CONFIG_NRF700X_BAND_UNII_1_UPPER_EDGE_BACKOFF_HT=0
    CONFIG_NRF700X_BAND_UNII_1_UPPER_EDGE_BACKOFF_HE=0
    CONFIG_NRF700X_BAND_UNII_2A_LOWER_EDGE_BACKOFF_HT=0
    CONFIG_NRF700X_BAND_UNII_2A_LOWER_EDGE_BACKOFF_HE=0
    CONFIG_NRF700X_BAND_UNII_2A_UPPER_EDGE_BACKOFF_HT=0
    CONFIG_NRF700X_BAND_UNII_2A_UPPER_EDGE_BACKOFF_HE=0
    CONFIG_NRF700X_BAND_UNII_2C_LOWER_EDGE_BACKOFF_HT=0
    CONFIG_NRF700X_BAND_UNII_2C_LOWER_EDGE_BACKOFF_HE=0
    CONFIG_NRF700X_BAND_UNII_2C_UPPER_EDGE_BACKOFF_HT=0
    CONFIG_NRF700X_BAND_UNII_2C_UPPER_EDGE_BACKOFF_HE=0
    CONFIG_NRF700X_BAND_UNII_3_LOWER_EDGE_BACKOFF_HT=0
    CONFIG_NRF700X_BAND_UNII_3_LOWER_EDGE_BACKOFF_HE=0
    CONFIG_NRF700X_BAND_UNII_3_UPPER_EDGE_BACKOFF_HT=0
    CONFIG_NRF700X_BAND_UNII_3_UPPER_EDGE_BACKOFF_HE=0
    CONFIG_NRF700X_BAND_UNII_4_LOWER_EDGE_BACKOFF_HT=0
    CONFIG_NRF700X_BAND_UNII_4_LOWER_EDGE_BACKOFF_HE=0
    CONFIG_NRF700X_BAND_UNII_4_UPPER_EDGE_BACKOFF_HT=0
    CONFIG_NRF700X_BAND_UNII_4_UPPER_EDGE_BACKOFF_HE=0
    CONFIG_NRF700X_RX_NUM_BUFS=48
    CONFIG_NRF700X_MAX_TX_AGGREGATION=12
    CONFIG_NRF700X_MAX_TX_TOKENS=10
    CONFIG_NRF700X_TX_MAX_DATA_SIZE=1600
    CONFIG_NRF700X_RX_MAX_DATA_SIZE=1600
    # CONFIG_NRF700X_TX_DONE_WQ_ENABLED is not set
    # CONFIG_NRF700X_RX_WQ_ENABLED is not set
    CONFIG_NRF700X_IRQ_WQ_PRIORITY=-15
    CONFIG_NRF700X_BH_WQ_PRIORITY=0
    CONFIG_NRF700X_IRQ_WQ_STACK_SIZE=2048
    CONFIG_NRF700X_BH_WQ_STACK_SIZE=2048
    CONFIG_NRF700X_RPU_PS_IDLE_TIMEOUT_MS=10
    # CONFIG_NRF700X_RPU_EXTEND_TWT_SP is not set
    CONFIG_WIFI_FIXED_MAC_ADDRESS=""
    CONFIG_WIFI_OTP_MAC_ADDRESS=y
    # CONFIG_WIFI_FIXED_MAC_ADDRESS_ENABLED is not set
    # CONFIG_WIFI_RANDOM_MAC_ADDRESS is not set
    CONFIG_NRF700X_RSSI_STALE_TIMEOUT_MS=1000
    CONFIG_NET_TC_TX_COUNT=1
    CONFIG_WIFI_MGMT_SCAN_SSID_FILT_MAX=2
    CONFIG_NRF_WIFI_SCAN_MAX_BSS_CNT=0
    CONFIG_NRF_WIFI_BEAMFORMING=y
    CONFIG_WIFI_NRF700X_SCAN_TIMEOUT_S=30
    # nRF Wi-Fi operation band(s)
    # CONFIG_NRF_WIFI_2G_BAND is not set
    # CONFIG_NRF_WIFI_5G_BAND is not set
    CONFIG_NRF_WIFI_OP_BAND=3
    # end of nRF Wi-Fi operation band(s)
    CONFIG_NRF_WIFI_IFACE_MTU=1500
    # CONFIG_WIFI_NRF700X_SKIP_LOCAL_ADMIN_MAC is not set
    # CONFIG_WIFI_NRF700X_SCAN_DISABLE_DFS_CHANNELS is not set
    CONFIG_NET_INTERFACE_NAME_LEN=15
    CONFIG_NRF_WIFI_AP_DEAD_DETECT_TIMEOUT=20
    # CONFIG_NRF_WIFI_RPU_RECOVERY is not set
    CONFIG_NET_MGMT_EVENT_QUEUE_SIZE=5
    # CONFIG_FLASH_RPC is not set
    # end of Device Drivers
    # External libraries
    # CONFIG_GETOPT_LIB is not set
    # end of External libraries
    # Test
    CONFIG_ZTEST_MULTICORE_DEFAULT_SETTINGS=y
    # CONFIG_UNITY is not set
    # Mocks
    # CONFIG_MOCK_NRF_MODEM_AT is not set
    # end of Mocks
    # end of Test
    # end of Nordic nRF Connect
    CONFIG_ZEPHYR_NRF_MODULE=y
    # end of nrf (C:/ncs/v2.7.0/nrf)
    # mcuboot (C:/ncs/v2.7.0/bootloader/mcuboot)
    # MCUboot
    CONFIG_BOOT_SIGNATURE_KEY_FILE=""
    CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4
    CONFIG_MCUBOOT_USB_SUPPORT=y
    # CONFIG_MCUBOOT_USE_ALL_AVAILABLE_RAM is not set
    # end of MCUboot
    # CONFIG_XIP_SPLIT_IMAGE is not set
    CONFIG_ZEPHYR_MCUBOOT_MODULE=y
    # end of mcuboot (C:/ncs/v2.7.0/bootloader/mcuboot)
    # mbedtls (C:/ncs/v2.7.0/modules/crypto/mbedtls)
    CONFIG_ZEPHYR_MBEDTLS_MODULE=y
    # PSA RNG support
    # PSA AEAD support
    # PSA MAC support
    # PSA Hash support
    # CONFIG_MBEDTLS_LIBRARY is not set
    CONFIG_DISABLE_MBEDTLS_BUILTIN=y
    # CONFIG_CUSTOM_MBEDTLS_CFG_FILE is not set
    # CONFIG_MBEDTLS_LOG_LEVEL_OFF is not set
    # CONFIG_MBEDTLS_LOG_LEVEL_ERR is not set
    # CONFIG_MBEDTLS_LOG_LEVEL_WRN is not set
    # CONFIG_MBEDTLS_LOG_LEVEL_INF is not set
    # CONFIG_MBEDTLS_LOG_LEVEL_DBG is not set
    CONFIG_MBEDTLS_LOG_LEVEL_DEFAULT=y
    CONFIG_MBEDTLS_LOG_LEVEL=3
    # CONFIG_MBEDTLS_DEBUG is not set
    CONFIG_MBEDTLS_INIT=y
    # CONFIG_MBEDTLS_ZEROIZE_ALT is not set
    CONFIG_APP_LINK_WITH_MBEDTLS=y
    # end of mbedtls (C:/ncs/v2.7.0/modules/crypto/mbedtls)
    # oberon-psa-crypto (C:/ncs/v2.7.0/modules/crypto/oberon-psa-crypto)
    CONFIG_ZEPHYR_OBERON_PSA_CRYPTO_MODULE=y
    # end of oberon-psa-crypto (C:/ncs/v2.7.0/modules/crypto/oberon-psa-crypto)
    # trusted-firmware-m (C:/ncs/v2.7.0/modules/tee/tf-m/trusted-firmware-m)
    CONFIG_TFM_BOARD="C:/ncs/v2.7.0/zephyr/modules/trusted-firmware-m/nordic/nrf5340_cpuapp"
    # CONFIG_BOOTLOADER_MCUBOOT is not set
    CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
    # end of trusted-firmware-m (C:/ncs/v2.7.0/modules/tee/tf-m/trusted-firmware-m)
    CONFIG_ZEPHYR_PSA_ARCH_TESTS_MODULE=y
    CONFIG_ZEPHYR_SOC_HWMV1_MODULE=y
    # cjson (C:/ncs/v2.7.0/modules/lib/cjson)
    CONFIG_ZEPHYR_CJSON_MODULE=y
    # end of cjson (C:/ncs/v2.7.0/modules/lib/cjson)
    # azure-sdk-for-c (C:/ncs/v2.7.0/modules/lib/azure-sdk-for-c)
    # CONFIG_AZURE_SDK is not set
    CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y
    # end of azure-sdk-for-c (C:/ncs/v2.7.0/modules/lib/azure-sdk-for-c)
    # cirrus-logic (C:/ncs/v2.7.0/modules/hal/cirrus-logic)
    # CONFIG_HW_CODEC_CIRRUS_LOGIC is not set
    CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y
    # end of cirrus-logic (C:/ncs/v2.7.0/modules/hal/cirrus-logic)
    # openthread (C:/ncs/v2.7.0/modules/lib/openthread)
    # CONFIG_OPENTHREAD is not set
    CONFIG_ZEPHYR_OPENTHREAD_MODULE=y
    # end of openthread (C:/ncs/v2.7.0/modules/lib/openthread)
    # suit-generator (C:/ncs/v2.7.0/modules/lib/suit-generator)
    CONFIG_SUIT_ENVELOPE_TEMPLATE=""
    CONFIG_SUIT_ENVELOPE_TARGET=""
    CONFIG_SUIT_ENVELOPE_OUTPUT_ARTIFACT="merged.hex"
    CONFIG_SUIT_ENVELOPE_OUTPUT_MPI_MERGE=y
    # CONFIG_SUIT_LOCAL_ENVELOPE_GENERATE is not set
    CONFIG_ZEPHYR_SUIT_GENERATOR_MODULE=y
    # end of suit-generator (C:/ncs/v2.7.0/modules/lib/suit-generator)
    # suit-processor (C:/ncs/v2.7.0/modules/lib/suit-processor)
    # CONFIG_SUIT_PROCESSOR is not set
    CONFIG_SUIT_PLATFORM_DRY_RUN_SUPPORT=y
    CONFIG_ZEPHYR_SUIT_PROCESSOR_MODULE=y
    # end of suit-processor (C:/ncs/v2.7.0/modules/lib/suit-processor)
    # memfault-firmware-sdk (C:/ncs/v2.7.0/modules/lib/memfault-firmware-sdk)
    # CONFIG_MEMFAULT is not set
    CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
    # end of memfault-firmware-sdk (C:/ncs/v2.7.0/modules/lib/memfault-firmware-sdk)
    # coremark (C:/ncs/v2.7.0/modules/benchmark/coremark)
    # CONFIG_COREMARK is not set
    CONFIG_ZEPHYR_COREMARK_MODULE=y
    # end of coremark (C:/ncs/v2.7.0/modules/benchmark/coremark)
    # canopennode (C:/ncs/v2.7.0/modules/lib/canopennode)
    CONFIG_ZEPHYR_CANOPENNODE_MODULE=y
    # end of canopennode (C:/ncs/v2.7.0/modules/lib/canopennode)
    # chre (C:/ncs/v2.7.0/modules/lib/chre)
    CONFIG_ZEPHYR_CHRE_MODULE=y
    # CONFIG_CHRE is not set
    # end of chre (C:/ncs/v2.7.0/modules/lib/chre)
    # lz4 (C:/ncs/v2.7.0/modules/lib/lz4)
    CONFIG_ZEPHYR_LZ4_MODULE=y
    # CONFIG_LZ4 is not set
    # end of lz4 (C:/ncs/v2.7.0/modules/lib/lz4)
    # nanopb (C:/ncs/v2.7.0/modules/lib/nanopb)
    CONFIG_ZEPHYR_NANOPB_MODULE=y
    # CONFIG_NANOPB is not set
    # end of nanopb (C:/ncs/v2.7.0/modules/lib/nanopb)
    CONFIG_ZEPHYR_TF_M_TESTS_MODULE=y
    # zscilib (C:/ncs/v2.7.0/modules/lib/zscilib)
    # CONFIG_ZSL is not set
    CONFIG_ZEPHYR_ZSCILIB_MODULE=y
    # end of zscilib (C:/ncs/v2.7.0/modules/lib/zscilib)
    # cmsis (C:/ncs/v2.7.0/modules/hal/cmsis)
    CONFIG_ZEPHYR_CMSIS_MODULE=y
    CONFIG_HAS_CMSIS_CORE=y
    CONFIG_HAS_CMSIS_CORE_M=y
    # CONFIG_CMSIS_M_CHECK_DEVICE_DEFINES is not set
    # end of cmsis (C:/ncs/v2.7.0/modules/hal/cmsis)
    # cmsis-dsp (C:/ncs/v2.7.0/modules/lib/cmsis-dsp)
    CONFIG_ZEPHYR_CMSIS_DSP_MODULE=y
    # CONFIG_CMSIS_DSP is not set
    # end of cmsis-dsp (C:/ncs/v2.7.0/modules/lib/cmsis-dsp)
    # cmsis-nn (C:/ncs/v2.7.0/modules/lib/cmsis-nn)
    CONFIG_ZEPHYR_CMSIS_NN_MODULE=y
    # CONFIG_CMSIS_NN is not set
    # end of cmsis-nn (C:/ncs/v2.7.0/modules/lib/cmsis-nn)
    # fatfs (C:/ncs/v2.7.0/modules/fs/fatfs)
    CONFIG_ZEPHYR_FATFS_MODULE=y
    # end of fatfs (C:/ncs/v2.7.0/modules/fs/fatfs)
    # hal_nordic (C:/ncs/v2.7.0/modules/hal/nordic)
    CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
    CONFIG_HAS_NORDIC_DRIVERS=y
    # Nordic drivers
    # CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set
    # CONFIG_NRF_802154_SER_HOST is not set
    # end of Nordic drivers
    CONFIG_HAS_NRFX=y
    # nrfx drivers
    # nrfx drivers logging
    # CONFIG_NRFX_CLOCK_LOG is not set
    # CONFIG_NRFX_DPPI_LOG is not set
    # CONFIG_NRFX_GPIOTE_LOG is not set
    # CONFIG_NRFX_QSPI_LOG is not set
    # end of nrfx drivers logging
    CONFIG_NRFX_CLOCK=y
    CONFIG_NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED=y
    # CONFIG_NRFX_COMP is not set
    CONFIG_NRFX_DPPI=y
    # CONFIG_NRFX_EGU0 is not set
    # CONFIG_NRFX_EGU1 is not set
    # CONFIG_NRFX_EGU2 is not set
    # CONFIG_NRFX_EGU3 is not set
    # CONFIG_NRFX_EGU4 is not set
    # CONFIG_NRFX_EGU5 is not set
    CONFIG_NRFX_GPIOTE=y
    CONFIG_NRFX_GPIOTE0=y
    # CONFIG_NRFX_GPIOTE1 is not set
    # CONFIG_NRFX_I2S0 is not set
    # CONFIG_NRFX_IPC is not set
    # CONFIG_NRFX_NFCT is not set
    # CONFIG_NRFX_NVMC is not set
    # CONFIG_NRFX_PDM is not set
    # CONFIG_NRFX_POWER is not set
    # CONFIG_NRFX_PWM0 is not set
    # CONFIG_NRFX_PWM1 is not set
    # CONFIG_NRFX_PWM2 is not set
    # CONFIG_NRFX_PWM3 is not set
    # CONFIG_NRFX_QDEC0 is not set
    # CONFIG_NRFX_QDEC1 is not set
    CONFIG_NRFX_QSPI=y
    # CONFIG_NRFX_RTC0 is not set
    # CONFIG_NRFX_RTC1 is not set
    # CONFIG_NRFX_SAADC is not set
    # CONFIG_NRFX_SPIM0 is not set
    # CONFIG_NRFX_SPIM1 is not set
    # CONFIG_NRFX_SPIM2 is not set
    # CONFIG_NRFX_SPIM3 is not set
    # CONFIG_NRFX_SPIM4 is not set
    # CONFIG_NRFX_SYSTICK is not set
    # CONFIG_NRFX_TIMER0 is not set
    # CONFIG_NRFX_TIMER1 is not set
    # CONFIG_NRFX_TIMER2 is not set
    # CONFIG_NRFX_TWIM0 is not set
    # CONFIG_NRFX_TWIM1 is not set
    # CONFIG_NRFX_TWIM2 is not set
    # CONFIG_NRFX_TWIM3 is not set
    # CONFIG_NRFX_UARTE0 is not set
    # CONFIG_NRFX_UARTE1 is not set
    # CONFIG_NRFX_UARTE2 is not set
    # CONFIG_NRFX_UARTE3 is not set
    # CONFIG_NRFX_USBREG is not set
    # CONFIG_NRFX_WDT0 is not set
    # CONFIG_NRFX_WDT1 is not set
    # Peripheral Resource Sharing module
    # CONFIG_NRFX_PRS_BOX_0 is not set
    # CONFIG_NRFX_PRS_BOX_1 is not set
    # CONFIG_NRFX_PRS_BOX_2 is not set
    # CONFIG_NRFX_PRS_BOX_3 is not set
    # CONFIG_NRFX_PRS_BOX_4 is not set
    # end of Peripheral Resource Sharing module
    # end of hal_nordic (C:/ncs/v2.7.0/modules/hal/nordic)
    # hal_st (C:/ncs/v2.7.0/modules/hal/st)
    CONFIG_ZEPHYR_HAL_ST_MODULE=y
    # end of hal_st (C:/ncs/v2.7.0/modules/hal/st)
    CONFIG_ZEPHYR_HAL_WURTHELEKTRONIK_MODULE=y
    CONFIG_ZEPHYR_LIBMETAL_MODULE=y
    # liblc3 (C:/ncs/v2.7.0/modules/lib/liblc3)
    CONFIG_ZEPHYR_LIBLC3_MODULE=y
    # end of liblc3 (C:/ncs/v2.7.0/modules/lib/liblc3)
    # littlefs (C:/ncs/v2.7.0/modules/fs/littlefs)
    CONFIG_ZEPHYR_LITTLEFS_MODULE=y
    # end of littlefs (C:/ncs/v2.7.0/modules/fs/littlefs)
    # loramac-node (C:/ncs/v2.7.0/modules/lib/loramac-node)
    CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y
    # CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set
    # end of loramac-node (C:/ncs/v2.7.0/modules/lib/loramac-node)
    # lvgl (C:/ncs/v2.7.0/modules/lib/gui/lvgl)
    CONFIG_ZEPHYR_LVGL_MODULE=y
    # end of lvgl (C:/ncs/v2.7.0/modules/lib/gui/lvgl)
    CONFIG_ZEPHYR_MIPI_SYS_T_MODULE=y
    CONFIG_ZEPHYR_NRF_HW_MODELS_MODULE=y
    CONFIG_ZEPHYR_OPEN_AMP_MODULE=y
    # picolibc (C:/ncs/v2.7.0/modules/lib/picolibc)
    # CONFIG_PICOLIBC_MODULE is not set
    CONFIG_ZEPHYR_PICOLIBC_MODULE=y
    # end of picolibc (C:/ncs/v2.7.0/modules/lib/picolibc)
    # segger (C:/ncs/v2.7.0/modules/debug/segger)
    CONFIG_ZEPHYR_SEGGER_MODULE=y
    CONFIG_HAS_SEGGER_RTT=y
    CONFIG_USE_SEGGER_RTT=y
    CONFIG_SEGGER_RTT_CUSTOM_LOCKING=y
    CONFIG_SEGGER_RTT_MAX_NUM_UP_BUFFERS=3
    CONFIG_SEGGER_RTT_MAX_NUM_DOWN_BUFFERS=3
    CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=1024
    CONFIG_SEGGER_RTT_BUFFER_SIZE_DOWN=16
    CONFIG_SEGGER_RTT_PRINTF_BUFFER_SIZE=64
    CONFIG_SEGGER_RTT_MODE_NO_BLOCK_SKIP=y
    # CONFIG_SEGGER_RTT_MODE_NO_BLOCK_TRIM is not set
    # CONFIG_SEGGER_RTT_MODE_BLOCK_IF_FIFO_FULL is not set
    CONFIG_SEGGER_RTT_MODE=0
    # CONFIG_SEGGER_RTT_MEMCPY_USE_BYTELOOP is not set
    CONFIG_SEGGER_RTT_SECTION_NONE=y
    # CONFIG_SEGGER_RTT_SECTION_DTCM is not set
    # CONFIG_SEGGER_RTT_SECTION_CCM is not set
    # end of segger (C:/ncs/v2.7.0/modules/debug/segger)
    CONFIG_ZEPHYR_TINYCRYPT_MODULE=y
    # uoscore-uedhoc (C:/ncs/v2.7.0/modules/lib/uoscore-uedhoc)
    CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y
    # end of uoscore-uedhoc (C:/ncs/v2.7.0/modules/lib/uoscore-uedhoc)
    # zcbor (C:/ncs/v2.7.0/modules/lib/zcbor)
    CONFIG_ZEPHYR_ZCBOR_MODULE=y
    # CONFIG_ZCBOR is not set
    # end of zcbor (C:/ncs/v2.7.0/modules/lib/zcbor)
    # nrfxlib (C:/ncs/v2.7.0/nrfxlib)
    # Nordic nrfxlib
    # nrf_modem (Modem library)
    # end of nrf_modem (Modem library)
    CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8
    # CONFIG_NFC_T2T_NRFXLIB is not set
    # CONFIG_NFC_T4T_NRFXLIB is not set
    # Crypto libraries for nRF5x SOCs.
    CONFIG_NRFXLIB_CRYPTO=y
    CONFIG_HAS_HW_NRF_CC3XX=y
    # CONFIG_NRF_OBERON is not set
    # CONFIG_NRF_CC310_BL is not set
    CONFIG_NRF_CC3XX_PLATFORM=y
    CONFIG_CC3XX_MUTEX_LOCK=y
    # CONFIG_CC3XX_ATOMIC_LOCK is not set
    # CONFIG_CC3XX_HW_MUTEX_LOCK is not set
    # end of Crypto libraries for nRF5x SOCs.
    # CONFIG_NRF_RPC is not set
    CONFIG_NRF_802154_SOURCE_NRFXLIB=y
    # CONFIG_GZLL is not set
    # CONFIG_NRF_DM is not set
    # CONFIG_NRF_FUEL_GAUGE is not set
    # end of Nordic nrfxlib
    CONFIG_ZEPHYR_NRFXLIB_MODULE=y
    # end of nrfxlib (C:/ncs/v2.7.0/nrfxlib)
    # connectedhomeip (C:/ncs/v2.7.0/modules/lib/matter)
    # CONFIG_CHIP is not set
    CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
    # end of connectedhomeip (C:/ncs/v2.7.0/modules/lib/matter)
    # CONFIG_LIBMETAL is not set
    # CONFIG_LVGL is not set
    # CONFIG_HAS_MEC_HAL is not set
    # CONFIG_HAS_MPFS_HAL is not set
    # CONFIG_HAS_MEC5_HAL is not set
    # CONFIG_OPENAMP is not set
    # CONFIG_MIPI_SYST_LIB is not set
    # CONFIG_HAS_TELINK_DRIVERS is not set
    # CONFIG_MCUBOOT_BOOTUTIL_LIB is not set
    # CONFIG_WIFI_NM_WPA_SUPPLICANT is not set
    # Unavailable modules, please install those via the project manifest.
    # hal_gigadevice module not available.
    # Trusted-firmware-a module not available.
    # THRIFT module not available.
    # CONFIG_ACPI is not set
    # end of Modules
    CONFIG_BOARD="SC50"
    CONFIG_BOARD_REVISION=""
    CONFIG_BOARD_TARGET="SC50/nrf5340/cpuapp"
    # CONFIG_NET_DRIVERS is not set
    CONFIG_BOARD_SC50=y
    CONFIG_BOARD_SC50_NRF5340_CPUAPP=y
    CONFIG_BOARD_QUALIFIERS="nrf5340/cpuapp"
    # Board Options
    # end of Board Options
    # Hardware Configuration
    CONFIG_SOC_FAMILY="nordic_nrf"
    CONFIG_SOC_FAMILY_NORDIC_NRF=y
    CONFIG_SOC_SERIES_NRF53X=y
    CONFIG_SOC_NRF5340_CPUAPP=y
    CONFIG_SOC_NRF5340_CPUAPP_QKAA=y
    # CONFIG_MFD is not set
    # CONFIG_BUILD_OUTPUT_INFO_HEADER is not set
    CONFIG_HAS_HW_NRF_CC312=y
    CONFIG_HAS_HW_NRF_CLOCK=y
    CONFIG_HAS_HW_NRF_CTRLAP=y
    CONFIG_HAS_HW_NRF_DCNF=y
    CONFIG_HAS_HW_NRF_DPPIC=y
    CONFIG_HAS_HW_NRF_EGU0=y
    CONFIG_HAS_HW_NRF_EGU1=y
    CONFIG_HAS_HW_NRF_EGU2=y
    CONFIG_HAS_HW_NRF_EGU3=y
    CONFIG_HAS_HW_NRF_EGU4=y
    CONFIG_HAS_HW_NRF_EGU5=y
    CONFIG_HAS_HW_NRF_GPIO0=y
    CONFIG_HAS_HW_NRF_GPIO1=y
    CONFIG_HAS_HW_NRF_GPIOTE0=y
    CONFIG_HAS_HW_NRF_IPC=y
    CONFIG_HAS_HW_NRF_KMU=y
    CONFIG_HAS_HW_NRF_MUTEX=y
    CONFIG_HAS_HW_NRF_NVMC_PE=y
    CONFIG_HAS_HW_NRF_OSCILLATORS=y
    CONFIG_HAS_HW_NRF_POWER=y
    CONFIG_HAS_HW_NRF_PWM0=y
    CONFIG_HAS_HW_NRF_QSPI=y
    CONFIG_HAS_HW_NRF_REGULATORS=y
    CONFIG_HAS_HW_NRF_RESET=y
    CONFIG_HAS_HW_NRF_SAADC=y
    CONFIG_HAS_HW_NRF_SPIM4=y
    CONFIG_HAS_HW_NRF_SPU=y
    CONFIG_HAS_HW_NRF_TIMER0=y
    CONFIG_HAS_HW_NRF_UARTE0=y
    CONFIG_HAS_HW_NRF_USBD=y
    CONFIG_HAS_HW_NRF_USBREG=y
    CONFIG_HAS_HW_NRF_VMC=y
    CONFIG_HAS_HW_NRF_WDT0=y
    # CONFIG_SOC_NRF53_ANOMALY_160_WORKAROUND_NEEDED is not set
    CONFIG_SOC_NRF53_ANOMALY_168_WORKAROUND=y
    # CONFIG_SOC_NRF53_ANOMALY_168_WORKAROUND_FOR_EXECUTION_FROM_RAM is not set
    CONFIG_SOC_NRF53_RTC_PRETICK=y
    CONFIG_SOC_NRF53_RTC_PRETICK_IPC_CH_FROM_NET=10
    CONFIG_SOC_NRF53_RTC_PRETICK_IPC_CH_TO_NET=11
    CONFIG_NRF_SPU_FLASH_REGION_ALIGNMENT=0x4000
    CONFIG_NRF_SPU_RAM_REGION_SIZE=0x2000
    CONFIG_NRF_SPU_RAM_REGION_ALIGNMENT=0x2000
    CONFIG_SOC_NRF53_CPUNET_MGMT=y
    CONFIG_SOC_ENABLE_LFXO=y
    # CONFIG_SOC_LFXO_CAP_EXTERNAL is not set
    # CONFIG_SOC_LFXO_CAP_INT_6PF is not set
    CONFIG_SOC_LFXO_CAP_INT_7PF=y
    # CONFIG_SOC_LFXO_CAP_INT_9PF is not set
    CONFIG_SOC_HFXO_CAP_DEFAULT=y
    # CONFIG_SOC_HFXO_CAP_EXTERNAL is not set
    # CONFIG_SOC_HFXO_CAP_INTERNAL is not set
    CONFIG_NRF_ENABLE_CACHE=y
    CONFIG_NRF53_SYNC_RTC=y
    # CONFIG_SYNC_RTC_LOG_LEVEL_OFF is not set
    # CONFIG_SYNC_RTC_LOG_LEVEL_ERR is not set
    # CONFIG_SYNC_RTC_LOG_LEVEL_WRN is not set
    # CONFIG_SYNC_RTC_LOG_LEVEL_INF is not set
    # CONFIG_SYNC_RTC_LOG_LEVEL_DBG is not set
    CONFIG_SYNC_RTC_LOG_LEVEL_DEFAULT=y
    CONFIG_SYNC_RTC_LOG_LEVEL=3
    CONFIG_NRF53_SYNC_RTC_INIT_PRIORITY=90
    CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=1
    CONFIG_NRF53_SYNC_RTC_LOG_TIMESTAMP=y
    CONFIG_NRF53_SYNC_RTC_IPM_OUT=7
    CONFIG_NRF53_SYNC_RTC_IPM_IN=8
    CONFIG_IPM_MSG_CH_8_ENABLE=y
    CONFIG_IPM_MSG_CH_8_RX=y
    CONFIG_NRF_SOC_SECURE_SUPPORTED=y
    # CONFIG_NFCT_PINS_AS_GPIOS is not set
    CONFIG_NRF_APPROTECT_USE_UICR=y
    # CONFIG_NRF_APPROTECT_LOCK is not set
    # CONFIG_NRF_APPROTECT_USER_HANDLING is not set
    CONFIG_NRF_SECURE_APPROTECT_USE_UICR=y
    # CONFIG_NRF_SECURE_APPROTECT_LOCK is not set
    # CONFIG_NRF_SECURE_APPROTECT_USER_HANDLING is not set
    # CONFIG_NRF_TRACE_PORT is not set
    CONFIG_GPIO_INIT_PRIORITY=40
    # CONFIG_SOC_LOG_LEVEL_OFF is not set
    # CONFIG_SOC_LOG_LEVEL_ERR is not set
    # CONFIG_SOC_LOG_LEVEL_WRN is not set
    # CONFIG_SOC_LOG_LEVEL_INF is not set
    # CONFIG_SOC_LOG_LEVEL_DBG is not set
    CONFIG_SOC_LOG_LEVEL_DEFAULT=y
    CONFIG_SOC_LOG_LEVEL=3
    # end of Hardware Configuration
    CONFIG_SOC_COMPATIBLE_NRF=y
    CONFIG_SOC_COMPATIBLE_NRF53X=y
    CONFIG_SOC_COMPATIBLE_NRF5340_CPUAPP=y
    CONFIG_ARCH="arm"
    CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y
    # CONFIG_EXTRA_EXCEPTION_INFO is not set
    CONFIG_CPU_CORTEX=y
    CONFIG_KOBJECT_TEXT_AREA=256
    CONFIG_ARM_MPU=y
    CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
    # CONFIG_MPU_ALLOW_FLASH_WRITE is not set
    # ARM Options
    CONFIG_ARM_ON_EXIT_CPU_IDLE=y
    CONFIG_CPU_CORTEX_M=y
    # CONFIG_ARM_ZIMAGE_HEADER is not set
    CONFIG_ISA_THUMB2=y
    CONFIG_ASSEMBLER_ISA_THUMB2=y
    CONFIG_COMPILER_ISA_THUMB2=y
    CONFIG_STACK_ALIGN_DOUBLE_WORD=y
    # CONFIG_RUNTIME_NMI is not set
    CONFIG_FAULT_DUMP=2
    CONFIG_BUILTIN_STACK_GUARD=y
    CONFIG_ARM_STACK_PROTECTION=y
    CONFIG_FP16=y
    CONFIG_FP16_IEEE=y
    # CONFIG_FP16_ALT is not set
    CONFIG_CPU_CORTEX_M33=y
    CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
    CONFIG_CPU_CORTEX_M_HAS_DWT=y
    CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
    CONFIG_CPU_CORTEX_M_HAS_VTOR=y
    CONFIG_CPU_CORTEX_M_HAS_SPLIM=y
    CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
    CONFIG_CPU_CORTEX_M_HAS_CMSE=y
    CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
    CONFIG_ARMV8_M_MAINLINE=y
    CONFIG_ARMV8_M_SE=y
    CONFIG_ARMV7_M_ARMV8_M_FP=y
    CONFIG_ARMV8_M_DSP=y
    # ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
    # CONFIG_ZERO_LATENCY_IRQS is not set
    # CONFIG_SW_VECTOR_RELAY is not set
    CONFIG_CORTEX_M_DWT=y
    # CONFIG_CORTEX_M_DEBUG_MONITOR_HOOK is not set
    # CONFIG_TRAP_UNALIGNED_ACCESS is not set
    # end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
    CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y
    # CONFIG_NULL_POINTER_EXCEPTION_DETECTION_DWT is not set
    # CONFIG_NULL_POINTER_EXCEPTION_DETECTION_MPU is not set
    CONFIG_ARM_TRUSTZONE_M=y
    # CONFIG_MPU_STACK_GUARD is not set
    # CONFIG_MPU_DISABLE_BACKGROUND_MAP is not set
    # CONFIG_CUSTOM_SECTION_ALIGN is not set
    CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
    CONFIG_CPU_HAS_NRF_IDAU=y
    CONFIG_HAS_SWO=y
    # end of ARM Options
    CONFIG_ARM=y
    CONFIG_ARCH_IS_SET=y
    # General Architecture Options
    # CONFIG_SEMIHOST is not set
    # CONFIG_ARCH_LOG_LEVEL_OFF is not set
    # CONFIG_ARCH_LOG_LEVEL_ERR is not set
    # CONFIG_ARCH_LOG_LEVEL_WRN is not set
    # CONFIG_ARCH_LOG_LEVEL_INF is not set
    # CONFIG_ARCH_LOG_LEVEL_DBG is not set
    CONFIG_ARCH_LOG_LEVEL_DEFAULT=y
    CONFIG_ARCH_LOG_LEVEL=3
    CONFIG_LITTLE_ENDIAN=y
    # CONFIG_TRUSTED_EXECUTION_SECURE is not set
    # CONFIG_TRUSTED_EXECUTION_NONSECURE is not set
    # CONFIG_USERSPACE is not set
    CONFIG_KOBJECT_DATA_AREA_RESERVE_EXTRA_PERCENT=100
    CONFIG_KOBJECT_RODATA_AREA_EXTRA_BYTES=16
    CONFIG_GEN_PRIV_STACKS=y
    # CONFIG_STACK_GROWS_UP is not set
    # Interrupt Configuration
    CONFIG_ISR_TABLES_LOCAL_DECLARATION_SUPPORTED=y
    # CONFIG_ISR_TABLES_LOCAL_DECLARATION is not set
    CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y
    # CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set
    CONFIG_EXCEPTION_DEBUG=y
    # CONFIG_SIMPLIFIED_EXCEPTION_CODES is not set
    # end of Interrupt Configuration
    # end of General Architecture Options
    CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y
    CONFIG_ARCH_HAS_TRUSTED_EXECUTION=y
    CONFIG_ARCH_HAS_STACK_PROTECTION=y
    CONFIG_ARCH_HAS_USERSPACE=y
    CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
    CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
    CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
    CONFIG_ARCH_SUPPORTS_COREDUMP=y
    CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y
    CONFIG_ARCH_SUPPORTS_ROM_START=y
    CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y
    CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y
    CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y
    CONFIG_ARCH_HAS_THREAD_ABORT=y
    CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y
    CONFIG_CPU_HAS_TEE=y
    CONFIG_CPU_HAS_FPU=y
    CONFIG_CPU_HAS_MPU=y
    CONFIG_MPU=y
    # CONFIG_MPU_LOG_LEVEL_OFF is not set
    # CONFIG_MPU_LOG_LEVEL_ERR is not set
    # CONFIG_MPU_LOG_LEVEL_WRN is not set
    # CONFIG_MPU_LOG_LEVEL_INF is not set
    # CONFIG_MPU_LOG_LEVEL_DBG is not set
    CONFIG_MPU_LOG_LEVEL_DEFAULT=y
    CONFIG_MPU_LOG_LEVEL=3
    CONFIG_MPU_REQUIRES_NON_OVERLAPPING_REGIONS=y
    CONFIG_MPU_GAP_FILLING=y
    CONFIG_SRAM_REGION_PERMISSIONS=y
    # DSP Options
    # end of DSP Options
    # Floating Point Options
    # end of Floating Point Options
    # Cache Options
    # end of Cache Options
    CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y
    # CONFIG_ARCH_CPU_IDLE_CUSTOM is not set
    # General Kernel Options
    # CONFIG_KERNEL_LOG_LEVEL_OFF is not set
    # CONFIG_KERNEL_LOG_LEVEL_ERR is not set
    # CONFIG_KERNEL_LOG_LEVEL_WRN is not set
    # CONFIG_KERNEL_LOG_LEVEL_INF is not set
    # CONFIG_KERNEL_LOG_LEVEL_DBG is not set
    CONFIG_KERNEL_LOG_LEVEL_DEFAULT=y
    CONFIG_KERNEL_LOG_LEVEL=3
    CONFIG_MULTITHREADING=y
    CONFIG_NUM_COOP_PRIORITIES=16
    CONFIG_NUM_PREEMPT_PRIORITIES=15
    CONFIG_MAIN_THREAD_PRIORITY=0
    CONFIG_COOP_ENABLED=y
    CONFIG_PREEMPT_ENABLED=y
    CONFIG_PRIORITY_CEILING=-127
    # CONFIG_SCHED_DEADLINE is not set
    CONFIG_THREAD_STACK_INFO=y
    # CONFIG_THREAD_CUSTOM_DATA is not set
    # CONFIG_DYNAMIC_THREAD is not set
    CONFIG_SCHED_DUMB=y
    # CONFIG_SCHED_SCALABLE is not set
    # CONFIG_SCHED_MULTIQ is not set
    # CONFIG_WAITQ_SCALABLE is not set
    CONFIG_WAITQ_DUMB=y
    # Misc Kernel related options
    CONFIG_ERRNO=y
    # end of Misc Kernel related options
    # Kernel Debugging and Metrics
    CONFIG_BOOT_DELAY=0
    # CONFIG_THREAD_MONITOR is not set
    # CONFIG_THREAD_NAME is not set
    # CONFIG_THREAD_RUNTIME_STATS is not set
    # end of Kernel Debugging and Metrics
    # CONFIG_OBJ_CORE is not set
    # System Work Queue Options
    # CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set
    # end of System Work Queue Options
    # Barrier Operations
    CONFIG_BARRIER_OPERATIONS_ARCH=y
    # end of Barrier Operations
    # Atomic Operations
    CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
    # end of Atomic Operations
    # Timer API Options
    CONFIG_TIMESLICING=y
    CONFIG_TIMESLICE_SIZE=0
    CONFIG_TIMESLICE_PRIORITY=0
    # CONFIG_TIMESLICE_PER_THREAD is not set
    # end of Timer API Options
    # Other Kernel Object Options
    CONFIG_POLL=y
    # CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set
    CONFIG_NUM_MBOX_ASYNC_MSGS=10
    # CONFIG_EVENTS is not set
    CONFIG_PIPES=y
    CONFIG_KERNEL_MEM_POOL=y
    # CONFIG_HEAP_MEM_POOL_IGNORE_MIN is not set
    # end of Other Kernel Object Options
    CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
    CONFIG_SWAP_NONATOMIC=y
    CONFIG_SYS_CLOCK_EXISTS=y
    CONFIG_TIMEOUT_64BIT=y
    CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365
    # Security Options
    # CONFIG_STACK_CANARIES is not set
    CONFIG_STACK_POINTER_RANDOM=0
    # end of Security Options
    # Memory Domains
    CONFIG_ARCH_MEM_DOMAIN_SUPPORTS_ISOLATED_STACKS=y
    CONFIG_MEM_DOMAIN_ISOLATED_STACKS=y
    # end of Memory Domains
    # SMP Options
    CONFIG_MP_NUM_CPUS=1
    # CONFIG_TICKET_SPINLOCKS is not set
    # end of SMP Options
    CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y
    # CONFIG_THREAD_LOCAL_STORAGE is not set
    # end of General Kernel Options
    # Device Options
    # CONFIG_DEVICE_DEPS is not set
    # CONFIG_DEVICE_MUTABLE is not set
    # end of Device Options
    # Initialization Priorities
    CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
    CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
    CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
    CONFIG_APPLICATION_INIT_PRIORITY=90
    # end of Initialization Priorities
    # Virtual Memory Support
    # end of Virtual Memory Support
    # Device Drivers
    CONFIG_ADC=y
    CONFIG_ADC_CONFIGURABLE_INPUTS=y
    # CONFIG_ADC_ASYNC is not set
    # CONFIG_ADC_LOG_LEVEL_OFF is not set
    # CONFIG_ADC_LOG_LEVEL_ERR is not set
    # CONFIG_ADC_LOG_LEVEL_WRN is not set
    # CONFIG_ADC_LOG_LEVEL_INF is not set
    # CONFIG_ADC_LOG_LEVEL_DBG is not set
    CONFIG_ADC_LOG_LEVEL_DEFAULT=y
    CONFIG_ADC_LOG_LEVEL=3
    CONFIG_ADC_NRFX_SAADC=y
    # CONFIG_AUDIO is not set
    # CONFIG_AUXDISPLAY is not set
    # CONFIG_BBRAM is not set
    # CONFIG_CAN is not set
    # CONFIG_CHARGER is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_OFF is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_ERR is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_WRN is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_INF is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_DBG is not set
    CONFIG_CLOCK_CONTROL_LOG_LEVEL_DEFAULT=y
    CONFIG_CLOCK_CONTROL_LOG_LEVEL=3
    CONFIG_CLOCK_CONTROL_NRF=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set
    CONFIG_CLOCK_CONTROL_NRF_ACCURACY=50
    # CONFIG_CLOCK_CONTROL_FIXED_RATE_CLOCK is not set
    CONFIG_CONSOLE_INPUT_MAX_LINE_LEN=128
    CONFIG_CONSOLE_HAS_DRIVER=y
    CONFIG_CONSOLE_INIT_PRIORITY=40
    # CONFIG_UART_CONSOLE is not set
    # CONFIG_RAM_CONSOLE is not set
    CONFIG_RTT_CONSOLE=y
    CONFIG_RTT_TX_RETRY_CNT=2
    CONFIG_RTT_TX_RETRY_DELAY_MS=2
    # CONFIG_RTT_TX_RETRY_IN_INTERRUPT is not set
    # CONFIG_IPM_CONSOLE_SENDER is not set
    # CONFIG_IPM_CONSOLE_RECEIVER is not set
    # CONFIG_UART_MCUMGR is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_OFF is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_ERR is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_WRN is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_INF is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_DBG is not set
    CONFIG_UART_CONSOLE_LOG_LEVEL_DEFAULT=y
    CONFIG_UART_CONSOLE_LOG_LEVEL=3
    # CONFIG_GSM_MUX is not set
    # CONFIG_EFI_CONSOLE is not set
    # CONFIG_COREDUMP_DEVICE is not set
    # CONFIG_CRYPTO is not set
    # CONFIG_DAC is not set
    # CONFIG_DAI is not set
    # CONFIG_DISK_DRIVERS is not set
    # CONFIG_DISPLAY is not set
    # CONFIG_DMA is not set
    # CONFIG_EDAC is not set
    # CONFIG_EEPROM is not set
    CONFIG_ENTROPY_GENERATOR=y
    # CONFIG_ENTROPY_LOG_LEVEL_OFF is not set
    # CONFIG_ENTROPY_LOG_LEVEL_ERR is not set
    # CONFIG_ENTROPY_LOG_LEVEL_WRN is not set
    # CONFIG_ENTROPY_LOG_LEVEL_INF is not set
    # CONFIG_ENTROPY_LOG_LEVEL_DBG is not set
    CONFIG_ENTROPY_LOG_LEVEL_DEFAULT=y
    CONFIG_ENTROPY_LOG_LEVEL=3
    CONFIG_ENTROPY_HAS_DRIVER=y
    # CONFIG_ESPI is not set
    CONFIG_ETH_DRIVER=y
    # CONFIG_ETHERNET_LOG_LEVEL_OFF is not set
    # CONFIG_ETHERNET_LOG_LEVEL_ERR is not set
    # CONFIG_ETHERNET_LOG_LEVEL_WRN is not set
    # CONFIG_ETHERNET_LOG_LEVEL_INF is not set
    # CONFIG_ETHERNET_LOG_LEVEL_DBG is not set
    CONFIG_ETHERNET_LOG_LEVEL_DEFAULT=y
    CONFIG_ETHERNET_LOG_LEVEL=3
    # CONFIG_ETH_IVSHMEM is not set
    CONFIG_ETH_PHY_DRIVER=y
    # CONFIG_PHY_LOG_LEVEL_OFF is not set
    # CONFIG_PHY_LOG_LEVEL_ERR is not set
    # CONFIG_PHY_LOG_LEVEL_WRN is not set
    # CONFIG_PHY_LOG_LEVEL_INF is not set
    # CONFIG_PHY_LOG_LEVEL_DBG is not set
    CONFIG_PHY_LOG_LEVEL_DEFAULT=y
    CONFIG_PHY_LOG_LEVEL=3
    CONFIG_PHY_AUTONEG_TIMEOUT_MS=4000
    CONFIG_PHY_MONITOR_PERIOD=500
    # NXP ENET
    # end of NXP ENET
    CONFIG_ETH_INIT_PRIORITY=80
    # CONFIG_FLASH is not set
    # CONFIG_FPGA is not set
    # CONFIG_FUEL_GAUGE is not set
    # CONFIG_GNSS is not set
    # CONFIG_GPIO_LOG_LEVEL_OFF is not set
    # CONFIG_GPIO_LOG_LEVEL_ERR is not set
    # CONFIG_GPIO_LOG_LEVEL_WRN is not set
    # CONFIG_GPIO_LOG_LEVEL_INF is not set
    # CONFIG_GPIO_LOG_LEVEL_DBG is not set
    CONFIG_GPIO_LOG_LEVEL_DEFAULT=y
    CONFIG_GPIO_LOG_LEVEL=3
    # CONFIG_GPIO_GET_DIRECTION is not set
    # CONFIG_GPIO_GET_CONFIG is not set
    # CONFIG_GPIO_HOGS is not set
    # CONFIG_GPIO_ENABLE_DISABLE_INTERRUPT is not set
    CONFIG_GPIO_NRFX=y
    CONFIG_GPIO_NRFX_INTERRUPT=y
    # CONFIG_HWINFO is not set
    # CONFIG_HWSPINLOCK is not set
    # CONFIG_I2C is not set
    # CONFIG_I2S is not set
    # CONFIG_I3C is not set
    # CONFIG_IEEE802154 is not set
    # Interrupt controller drivers
    CONFIG_INTC_INIT_PRIORITY=40
    # CONFIG_INTC_LOG_LEVEL_OFF is not set
    # CONFIG_INTC_LOG_LEVEL_ERR is not set
    # CONFIG_INTC_LOG_LEVEL_WRN is not set
    # CONFIG_INTC_LOG_LEVEL_INF is not set
    # CONFIG_INTC_LOG_LEVEL_DBG is not set
    CONFIG_INTC_LOG_LEVEL_DEFAULT=y
    CONFIG_INTC_LOG_LEVEL=3
    # CONFIG_INTC_ESP32 is not set
    # end of Interrupt controller drivers
    # CONFIG_IPM is not set
    # CONFIG_KSCAN is not set
    # CONFIG_LED is not set
    # CONFIG_LED_STRIP is not set
    # CONFIG_LORA is not set
    # CONFIG_MBOX_NRFX_IPC is not set
    CONFIG_MBOX_INIT_PRIORITY=40
    # CONFIG_MBOX_LOG_LEVEL_OFF is not set
    # CONFIG_MBOX_LOG_LEVEL_ERR is not set
    # CONFIG_MBOX_LOG_LEVEL_WRN is not set
    # CONFIG_MBOX_LOG_LEVEL_INF is not set
    # CONFIG_MBOX_LOG_LEVEL_DBG is not set
    CONFIG_MBOX_LOG_LEVEL_DEFAULT=y
    CONFIG_MBOX_LOG_LEVEL=3
    # CONFIG_MDIO is not set
    # CONFIG_MIPI_DBI is not set
    # Miscellaneous Drivers
    # CONFIG_TIMEAWARE_GPIO is not set
    # end of Miscellaneous Drivers
    # CONFIG_MM_DRV is not set
    # CONFIG_PCIE is not set
    # CONFIG_PCIE_ENDPOINT is not set
    # CONFIG_PECI is not set
    # CONFIG_PINCTRL_LOG_LEVEL_OFF is not set
    # CONFIG_PINCTRL_LOG_LEVEL_ERR is not set
    # CONFIG_PINCTRL_LOG_LEVEL_WRN is not set
    # CONFIG_PINCTRL_LOG_LEVEL_INF is not set
    # CONFIG_PINCTRL_LOG_LEVEL_DBG is not set
    CONFIG_PINCTRL_LOG_LEVEL_DEFAULT=y
    CONFIG_PINCTRL_LOG_LEVEL=3
    CONFIG_PINCTRL_STORE_REG=y
    # CONFIG_PINCTRL_DYNAMIC is not set
    CONFIG_PINCTRL_NRF=y
    # CONFIG_PM_CPU_OPS is not set
    # CONFIG_PS2 is not set
    # CONFIG_PTP_CLOCK is not set
    # CONFIG_PWM is not set
    # CONFIG_REGULATOR is not set
    # CONFIG_RETAINED_MEM is not set
    # CONFIG_RTC is not set
    # CONFIG_SDHC is not set
    # Capabilities
    CONFIG_SERIAL_HAS_DRIVER=y
    CONFIG_SERIAL_SUPPORT_ASYNC=y
    CONFIG_SERIAL_SUPPORT_INTERRUPT=y
    # CONFIG_UART_LOG_LEVEL_OFF is not set
    # CONFIG_UART_LOG_LEVEL_ERR is not set
    # CONFIG_UART_LOG_LEVEL_WRN is not set
    # CONFIG_UART_LOG_LEVEL_INF is not set
    # CONFIG_UART_LOG_LEVEL_DBG is not set
    CONFIG_UART_LOG_LEVEL_DEFAULT=y
    CONFIG_UART_LOG_LEVEL=3
    # CONFIG_UART_ASYNC_API is not set
    # CONFIG_UART_LINE_CTRL is not set
    # CONFIG_UART_DRV_CMD is not set
    # CONFIG_UART_WIDE_DATA is not set
    # CONFIG_UART_PIPE is not set
    # CONFIG_UART_ASYNC_RX_HELPER is not set
    # Serial Drivers
    CONFIG_UART_NRFX=y
    CONFIG_UART_NRFX_UARTE=y
    CONFIG_UART_NRFX_UARTE_LEGACY_SHIM=y
    CONFIG_UART_0_ENHANCED_POLL_OUT=y
    # CONFIG_UART_0_NRF_PARITY_BIT is not set
    CONFIG_UART_0_NRF_TX_BUFFER_SIZE=32
    # CONFIG_SMBUS is not set
    # Timer drivers
    # CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
    # CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
    CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
    CONFIG_TICKLESS_CAPABLE=y
    CONFIG_SYSTEM_TIMER_HAS_DISABLE_SUPPORT=y
    # CONFIG_NRF_RTC_TIMER_TRIGGER_OVERFLOW is not set
    # CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
    # CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
    CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
    # end of Timer drivers
    # CONFIG_USB_BC12 is not set
    # CONFIG_UDC_DRIVER is not set
    # CONFIG_UHC_DRIVER is not set
    # CONFIG_UVB is not set
    # CONFIG_USB_DEVICE_DRIVER is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_INF is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DBG is not set
    CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_USBD_COMMON_LOG_LEVEL=3
    # CONFIG_NRF_USBD_COMMON is not set
    # CONFIG_USBC_TCPC_DRIVER is not set
    # CONFIG_USBC_LOG_LEVEL_OFF is not set
    # CONFIG_USBC_LOG_LEVEL_ERR is not set
    # CONFIG_USBC_LOG_LEVEL_WRN is not set
    # CONFIG_USBC_LOG_LEVEL_INF is not set
    # CONFIG_USBC_LOG_LEVEL_DBG is not set
    CONFIG_USBC_LOG_LEVEL_DEFAULT=y
    CONFIG_USBC_LOG_LEVEL=3
    # CONFIG_USBC_VBUS_DRIVER is not set
    # CONFIG_USBC_PPC_DRIVER is not set
    # CONFIG_VIDEO is not set
    # CONFIG_VIRTUALIZATION is not set
    # CONFIG_W1 is not set
    # CONFIG_WIFI_LOG_LEVEL_OFF is not set
    # CONFIG_WIFI_LOG_LEVEL_ERR is not set
    # CONFIG_WIFI_LOG_LEVEL_WRN is not set
    # CONFIG_WIFI_LOG_LEVEL_INF is not set
    # CONFIG_WIFI_LOG_LEVEL_DBG is not set
    CONFIG_WIFI_LOG_LEVEL_DEFAULT=y
    CONFIG_WIFI_LOG_LEVEL=3
    CONFIG_WIFI_INIT_PRIORITY=80
    # CONFIG_WIFI_OFFLOAD is not set
    CONFIG_WIFI_USE_NATIVE_NETWORKING=y
    # CONFIG_WIFI_SIMPLELINK is not set
    CONFIG_NET_TCP_WORKQ_STACK_SIZE=1024
    # CONFIG_REQUIRES_FULL_LIBC is not set
    # CONFIG_REQUIRES_FLOAT_PRINTF is not set
    CONFIG_FULL_LIBC_SUPPORTED=y
    CONFIG_MINIMAL_LIBC_SUPPORTED=y
    CONFIG_NEWLIB_LIBC_SUPPORTED=y
    CONFIG_PICOLIBC_SUPPORTED=y
    CONFIG_NATIVE_LIBC_INCOMPATIBLE=y
    # C Library
    # CONFIG_MINIMAL_LIBC is not set
    # CONFIG_PICOLIBC is not set
    CONFIG_NEWLIB_LIBC=y
    # CONFIG_EXTERNAL_LIBC is not set
    CONFIG_HAS_NEWLIB_LIBC_NANO=y
    CONFIG_COMMON_LIBC_ABORT=y
    CONFIG_COMMON_LIBC_MALLOC=y
    CONFIG_COMMON_LIBC_CALLOC=y
    CONFIG_COMMON_LIBC_REALLOCARRAY=y
    CONFIG_NEWLIB_LIBC_MIN_REQUIRED_HEAP_SIZE=8192
    # CONFIG_NEWLIB_LIBC_FLOAT_PRINTF is not set
    # CONFIG_NEWLIB_LIBC_FLOAT_SCANF is not set
    # CONFIG_NEWLIB_LIBC_HEAP_LISTENER is not set
    CONFIG_STDOUT_CONSOLE=y
    CONFIG_NEED_LIBC_MEM_PARTITION=y
    # end of C Library
    # C++ Language Support
    # CONFIG_CPP is not set
    # Deprecated
    # CONFIG_CPLUSPLUS is not set
    # CONFIG_LIB_CPLUSPLUS is not set
    # end of Deprecated
    # end of C++ Language Support
    # CONFIG_CRC is not set
    # Additional libraries
    # Hash Function Support
    # CONFIG_SYS_HASH_FUNC32 is not set
    # end of Hash Function Support
    # Hashmap (Hash Table) Support
    # CONFIG_SYS_HASH_MAP is not set
    # end of Hashmap (Hash Table) Support
    # Heap and Memory Allocation
    # CONFIG_SYS_HEAP_VALIDATE is not set
    # CONFIG_SYS_HEAP_STRESS is not set
    # CONFIG_SYS_HEAP_INFO is not set
    CONFIG_SYS_HEAP_ALLOC_LOOPS=3
    # CONFIG_SYS_HEAP_RUNTIME_STATS is not set
    # CONFIG_SYS_HEAP_LISTENER is not set
    # CONFIG_SYS_HEAP_SMALL_ONLY is not set
    # CONFIG_SYS_HEAP_BIG_ONLY is not set
    CONFIG_SYS_HEAP_AUTO=y
    # CONFIG_MULTI_HEAP is not set
    # CONFIG_SHARED_MULTI_HEAP is not set
    # end of Heap and Memory Allocation
    # Memory Blocks
    # CONFIG_SYS_MEM_BLOCKS is not set
    # end of Memory Blocks
    # OS Support Library
    CONFIG_FDTABLE=y
    # CONFIG_PRINTK_SYNC is not set
    CONFIG_MPSC_PBUF=y
    # CONFIG_SPSC_PBUF is not set
    # CONFIG_MPSC_CLEAR_ALLOCATED is not set
    CONFIG_HAS_POWEROFF=y
    # CONFIG_POWEROFF is not set
    CONFIG_CBPRINTF_COMPLETE=y
    # CONFIG_CBPRINTF_NANO is not set
    CONFIG_CBPRINTF_FULL_INTEGRAL=y
    # CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set
    # CONFIG_CBPRINTF_FP_SUPPORT is not set
    # CONFIG_CBPRINTF_FP_A_SUPPORT is not set
    # CONFIG_CBPRINTF_FP_ALWAYS_A is not set
    CONFIG_CBPRINTF_N_SPECIFIER=y
    # CONFIG_CBPRINTF_LIBC_SUBSTS is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_OFF is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_ERR is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_WRN is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_INF is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DBG is not set
    CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DEFAULT=y
    CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL=3
    # CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set
    CONFIG_CBPRINTF_CONVERT_CHECK_PTR=y
    # end of OS Support Library
    # POSIX API Support
    # POSIX Options
    CONFIG_POSIX_API=y
    CONFIG_PTHREAD_IPC=y
    CONFIG_POSIX_ASYNCHRONOUS_IO=y
    CONFIG_PTHREAD_BARRIER=y
    CONFIG_MAX_PTHREAD_BARRIER_COUNT=5
    # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_BARRIER_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_BARRIER_LOG_LEVEL=3
    # CONFIG_PTHREAD_CREATE_BARRIER is not set
    CONFIG_POSIX_CLOCK=y
    CONFIG_PTHREAD_COND=y
    CONFIG_MAX_PTHREAD_COND_COUNT=5
    # CONFIG_PTHREAD_COND_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_COND_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_COND_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_COND_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_COND_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_COND_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_COND_LOG_LEVEL=3
    CONFIG_POSIX_CONFSTR=y
    CONFIG_POSIX_ENV=y
    # CONFIG_POSIX_ENV_LOG_LEVEL_OFF is not set
    # CONFIG_POSIX_ENV_LOG_LEVEL_ERR is not set
    # CONFIG_POSIX_ENV_LOG_LEVEL_WRN is not set
    # CONFIG_POSIX_ENV_LOG_LEVEL_INF is not set
    # CONFIG_POSIX_ENV_LOG_LEVEL_DBG is not set
    CONFIG_POSIX_ENV_LOG_LEVEL_DEFAULT=y
    CONFIG_POSIX_ENV_LOG_LEVEL=3
    CONFIG_EVENTFD=y
    CONFIG_EVENTFD_MAX=1
    # File descriptor table options
    # end of File descriptor table options
    CONFIG_FNMATCH=y
    # CONFIG_GETENTROPY is not set
    CONFIG_PTHREAD_KEY=y
    CONFIG_MAX_PTHREAD_KEY_COUNT=5
    # CONFIG_PTHREAD_KEY_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_KEY_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_KEY_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_KEY_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_KEY_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_KEY_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_KEY_LOG_LEVEL=3
    CONFIG_POSIX_MQUEUE=y
    CONFIG_MSG_COUNT_MAX=16
    CONFIG_MSG_SIZE_MAX=16
    CONFIG_MQUEUE_NAMELEN_MAX=16
    CONFIG_HEAP_MEM_POOL_ADD_SIZE_MQUEUE=1024
    CONFIG_PTHREAD_MUTEX=y
    CONFIG_MAX_PTHREAD_MUTEX_COUNT=5
    # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_MUTEX_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_MUTEX_LOG_LEVEL=3
    CONFIG_POSIX_NETWORKING=y
    CONFIG_PTHREAD=y
    CONFIG_MAX_PTHREAD_COUNT=5
    # CONFIG_PTHREAD_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_LOG_LEVEL=3
    CONFIG_PTHREAD_RECYCLER_DELAY_MS=100
    CONFIG_POSIX_PTHREAD_ATTR_STACKSIZE_BITS=23
    CONFIG_POSIX_PTHREAD_ATTR_GUARDSIZE_BITS=9
    CONFIG_POSIX_PTHREAD_ATTR_GUARDSIZE_DEFAULT=0
    CONFIG_PTHREAD_RWLOCK=y
    CONFIG_MAX_PTHREAD_RWLOCK_COUNT=5
    # CONFIG_PTHREAD_RWLOCK_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_RWLOCK_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_RWLOCK_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_RWLOCK_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_RWLOCK_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_RWLOCK_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_RWLOCK_LOG_LEVEL=3
    CONFIG_POSIX_PRIORITY_SCHEDULING=y
    # sem_t support
    CONFIG_SEM_VALUE_MAX=32767
    CONFIG_SEM_NAMELEN_MAX=16
    # end of sem_t support
    # Signal support
    CONFIG_POSIX_RTSIG_MAX=31
    CONFIG_POSIX_SIGNAL=y
    CONFIG_POSIX_SIGNAL_STRING_DESC=y
    CONFIG_POSIX_LIMITS_RTSIG_MAX=8
    # end of Signal support
    CONFIG_PTHREAD_SPINLOCK=y
    CONFIG_MAX_PTHREAD_SPINLOCK_COUNT=5
    # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL=3
    CONFIG_POSIX_PUTMSG=y
    # Sysconf support
    CONFIG_POSIX_SYSCONF=y
    CONFIG_POSIX_PAGE_SIZE_BITS=12
    CONFIG_POSIX_SYSCONF_IMPL_MACRO=y
    # CONFIG_POSIX_SYSCONF_IMPL_FULL is not set
    # end of Sysconf support
    CONFIG_POSIX_SYSLOG=y
    CONFIG_TIMER=y
    CONFIG_MAX_TIMER_COUNT=5
    # CONFIG_TIMER_LOG_LEVEL_OFF is not set
    # CONFIG_TIMER_LOG_LEVEL_ERR is not set
    # CONFIG_TIMER_LOG_LEVEL_WRN is not set
    # CONFIG_TIMER_LOG_LEVEL_INF is not set
    # CONFIG_TIMER_LOG_LEVEL_DBG is not set
    CONFIG_TIMER_LOG_LEVEL_DEFAULT=y
    CONFIG_TIMER_LOG_LEVEL=3
    CONFIG_TIMER_CREATE_WAIT=100
    CONFIG_TIMER_DELAYTIMER_MAX=20
    CONFIG_POSIX_UNAME=y
    CONFIG_POSIX_UNAME_VERSION_LEN=70
    CONFIG_POSIX_UNAME_NODENAME_LEN=6
    # end of POSIX Options
    # POSIX Shell Utilities
    # end of POSIX Shell Utilities
    # end of POSIX API Support
    # CONFIG_OPENAMP_RSC_TABLE is not set
    # CONFIG_SMF is not set
    CONFIG_LIBGCC_RTLIB=y
    # Utility Library
    # CONFIG_JSON_LIBRARY is not set
    # CONFIG_RING_BUFFER is not set
    CONFIG_NOTIFY=y
    # CONFIG_BASE64 is not set
    CONFIG_ONOFF=y
    # CONFIG_WINSTREAM is not set
    # CONFIG_UTF8 is not set
    # end of Utility Library
    # end of Additional libraries
    # Subsystems and OS Services
    # CONFIG_BINDESC is not set
    # CONFIG_BT is not set
    # Controller Area Network (CAN) bus subsystem
    # end of Controller Area Network (CAN) bus subsystem
    # CONFIG_CONSOLE_SUBSYS is not set
    # System Monitoring Options
    # CONFIG_THREAD_ANALYZER is not set
    # end of System Monitoring Options
    # Debugging Options
    # CONFIG_DEBUG is not set
    # CONFIG_STACK_USAGE is not set
    CONFIG_STACK_SENTINEL=y
    CONFIG_PRINTK=y
    CONFIG_EARLY_CONSOLE=y
    # CONFIG_ASSERT is not set
    # CONFIG_FORCE_NO_ASSERT is not set
    CONFIG_ASSERT_VERBOSE=y
    # CONFIG_ASSERT_NO_FILE_INFO is not set
    # CONFIG_ASSERT_NO_COND_INFO is not set
    # CONFIG_ASSERT_NO_MSG_INFO is not set
    # CONFIG_ASSERT_TEST is not set
    # CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
    # CONFIG_DEBUG_INFO is not set
    # CONFIG_DEBUG_THREAD_INFO is not set
    CONFIG_DEBUG_COREDUMP=y
    CONFIG_DEBUG_COREDUMP_BACKEND_LOGGING=y
    # CONFIG_DEBUG_COREDUMP_BACKEND_OTHER is not set
    CONFIG_DEBUG_COREDUMP_MEMORY_DUMP_MIN=y
    # CONFIG_DEBUG_COREDUMP_MEMORY_DUMP_LINKER_RAM is not set
    # end of Debugging Options
    # CONFIG_MIPI_STP_DECODER is not set
    # CONFIG_DISK_ACCESS is not set
    # CONFIG_DSP is not set
    # CONFIG_EMUL is not set
    # CONFIG_CHARACTER_FRAMEBUFFER is not set
    # File Systems
    # CONFIG_FILE_SYSTEM is not set
    # end of File Systems
    # Inter Processor Communication
    # CONFIG_RPMSG_SERVICE is not set
    # CONFIG_IPC_SERVICE is not set
    # end of Inter Processor Communication
    # CONFIG_JWT is not set
    # CONFIG_LLEXT is not set
    # Linkable loadable Extension Development Kit (EDK)
    CONFIG_LLEXT_EDK_NAME="llext-edk"
    # CONFIG_LLEXT_EDK_USERSPACE_ONLY is not set
    # end of Linkable loadable Extension Development Kit (EDK)
    # Logging
    CONFIG_LOG_CORE_INIT_PRIORITY=0
    CONFIG_LOG_MODE_DEFERRED=y
    # CONFIG_LOG_MODE_IMMEDIATE is not set
    # CONFIG_LOG_MODE_MINIMAL is not set
    # CONFIG_LOG_FRONTEND is not set
    # CONFIG_LOG_FRONTEND_OPT_API is not set
    # CONFIG_LOG_CUSTOM_HEADER is not set
    # CONFIG_LOG_MULTIDOMAIN is not set
    # Logging levels filtering
    # CONFIG_LOG_RUNTIME_FILTERING is not set
    CONFIG_LOG_DEFAULT_LEVEL=3
    CONFIG_LOG_OVERRIDE_LEVEL=0
    CONFIG_LOG_MAX_LEVEL=4
    # end of Logging levels filtering
    # Processing
    CONFIG_LOG_PRINTK=y
    CONFIG_LOG_MODE_OVERFLOW=y
    # CONFIG_LOG_BLOCK_IN_THREAD is not set
    CONFIG_LOG_PROCESS_TRIGGER_THRESHOLD=10
    CONFIG_LOG_PROCESS_THREAD=y
    CONFIG_LOG_PROCESS_THREAD_STARTUP_DELAY_MS=0
    CONFIG_LOG_PROCESS_THREAD_SLEEP_MS=1000
    CONFIG_LOG_PROCESS_THREAD_STACK_SIZE=768
    # CONFIG_LOG_PROCESS_THREAD_CUSTOM_PRIORITY is not set
    CONFIG_LOG_TRACE_SHORT_TIMESTAMP=y
    # CONFIG_LOG_TIMESTAMP_64BIT is not set
    # CONFIG_LOG_TIMESTAMP_USE_REALTIME is not set
    # CONFIG_LOG_SPEED is not set
    # end of Processing
    # Output Formatting
    # Prepend non-hexdump log message with function name
    # CONFIG_LOG_FUNC_NAME_PREFIX_ERR is not set
    # CONFIG_LOG_FUNC_NAME_PREFIX_WRN is not set
    # CONFIG_LOG_FUNC_NAME_PREFIX_INF is not set
    CONFIG_LOG_FUNC_NAME_PREFIX_DBG=y
    # end of Prepend non-hexdump log message with function name
    # CONFIG_LOG_MIPI_SYST_ENABLE is not set
    # CONFIG_LOG_THREAD_ID_PREFIX is not set
    # CONFIG_LOG_CUSTOM_FORMAT_SUPPORT is not set
    CONFIG_LOG_BACKEND_SHOW_COLOR=y
    # CONFIG_LOG_INFO_COLOR_GREEN is not set
    CONFIG_LOG_TAG_MAX_LEN=0
    CONFIG_LOG_BACKEND_FORMAT_TIMESTAMP=y
    # CONFIG_LOG_OUTPUT_FORMAT_LINUX_TIMESTAMP is not set
    # CONFIG_LOG_OUTPUT_FORMAT_CUSTOM_TIMESTAMP is not set
    # end of Output Formatting
    # Backends
    # CONFIG_LOG_BACKEND_NET is not set
    CONFIG_LOG_BACKEND_RTT=y
    # CONFIG_LOG_BACKEND_RTT_MODE_DROP is not set
    CONFIG_LOG_BACKEND_RTT_MODE_BLOCK=y
    # CONFIG_LOG_BACKEND_RTT_MODE_OVERWRITE is not set
    CONFIG_LOG_BACKEND_RTT_OUTPUT_TEXT=y
    # CONFIG_LOG_BACKEND_RTT_OUTPUT_DICTIONARY is not set
    # CONFIG_LOG_BACKEND_RTT_OUTPUT_CUSTOM is not set
    CONFIG_LOG_BACKEND_RTT_OUTPUT_DEFAULT=0
    CONFIG_LOG_BACKEND_RTT_OUTPUT_BUFFER_SIZE=16
    CONFIG_LOG_BACKEND_RTT_RETRY_CNT=4
    CONFIG_LOG_BACKEND_RTT_RETRY_DELAY_MS=5
    CONFIG_LOG_BACKEND_RTT_BUFFER=0
    CONFIG_LOG_BACKEND_RTT_FORCE_PRINTK=y
    # CONFIG_LOG_BACKEND_SWO is not set
    # CONFIG_LOG_BACKEND_IPC_SERVICE is not set
    # end of Backends
    # Misc
    CONFIG_LOG_DOMAIN_ID=0
    CONFIG_LOG_USE_VLA=y
    CONFIG_LOG_SIMPLE_MSG_OPTIMIZE=y
    # CONFIG_LOG_ALWAYS_RUNTIME is not set
    # CONFIG_LOG_FMT_SECTION is not set
    # CONFIG_LOG_FMT_STRING_VALIDATE is not set
    # CONFIG_LOG_USE_TAGGED_ARGUMENTS is not set
    # CONFIG_LOG_MEM_UTILIZATION is not set
    CONFIG_LOG_FAILURE_REPORT_PERIOD=1000
    # end of Misc
    CONFIG_LOG_OUTPUT=y
    # end of Logging
    CONFIG_MEM_ATTR=y
    # CONFIG_MEM_ATTR_HEAP is not set
    # Device Management
    # Host command handler subsystem
    # CONFIG_EC_HOST_CMD is not set
    # end of Host command handler subsystem
    # CONFIG_OSDP is not set
    # end of Device Management
    # CONFIG_MODBUS is not set
    # CONFIG_MODEM_MODULES is not set
    # Networking
    CONFIG_NET_BUF=y
    # CONFIG_NET_BUF_LOG is not set
    # CONFIG_NET_BUF_LOG_LEVEL_OFF is not set
    # CONFIG_NET_BUF_LOG_LEVEL_ERR is not set
    # CONFIG_NET_BUF_LOG_LEVEL_WRN is not set
    # CONFIG_NET_BUF_LOG_LEVEL_INF is not set
    # CONFIG_NET_BUF_LOG_LEVEL_DBG is not set
    CONFIG_NET_BUF_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_BUF_LOG_LEVEL=3
    # CONFIG_NET_BUF_POOL_USAGE is not set
    CONFIG_NET_BUF_ALIGNMENT=0
    CONFIG_NETWORKING=y
    # CONFIG_NET_HOSTNAME_ENABLE is not set
    # Link layer options
    # CONFIG_NET_L2_DUMMY is not set
    # CONFIG_NET_L2_VIRTUAL is not set
    # CONFIG_NET_L2_ETHERNET_LOG_LEVEL_OFF is not set
    # CONFIG_NET_L2_ETHERNET_LOG_LEVEL_ERR is not set
    # CONFIG_NET_L2_ETHERNET_LOG_LEVEL_WRN is not set
    # CONFIG_NET_L2_ETHERNET_LOG_LEVEL_INF is not set
    # CONFIG_NET_L2_ETHERNET_LOG_LEVEL_DBG is not set
    CONFIG_NET_L2_ETHERNET_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_L2_ETHERNET_LOG_LEVEL=3
    CONFIG_NET_L2_ETHERNET_MGMT=y
    # CONFIG_NET_VLAN is not set
    CONFIG_NET_ARP=y
    CONFIG_NET_ARP_TABLE_SIZE=2
    CONFIG_NET_ARP_GRATUITOUS=y
    # CONFIG_NET_ARP_GRATUITOUS_TRANSMISSION is not set
    # CONFIG_NET_ARP_LOG_LEVEL_OFF is not set
    # CONFIG_NET_ARP_LOG_LEVEL_ERR is not set
    # CONFIG_NET_ARP_LOG_LEVEL_WRN is not set
    # CONFIG_NET_ARP_LOG_LEVEL_INF is not set
    # CONFIG_NET_ARP_LOG_LEVEL_DBG is not set
    CONFIG_NET_ARP_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_ARP_LOG_LEVEL=3
    # CONFIG_NET_GPTP is not set
    # CONFIG_NET_LLDP is not set
    # CONFIG_NET_ETHERNET_BRIDGE is not set
    CONFIG_NET_ETHERNET_FORWARD_UNRECOGNISED_ETHERTYPE=y
    # CONFIG_NET_L2_PPP is not set
    # CONFIG_NET_L2_OPENTHREAD is not set
    # CONFIG_NET_L2_CUSTOM_IEEE802154 is not set
    # CONFIG_NET_L2_CANBUS_RAW is not set
    CONFIG_NET_L2_WIFI_UTILS=y
    CONFIG_NET_L2_WIFI_MGMT=y
    # CONFIG_NET_L2_WIFI_MGMT_LOG_LEVEL_OFF is not set
    # CONFIG_NET_L2_WIFI_MGMT_LOG_LEVEL_ERR is not set
    # CONFIG_NET_L2_WIFI_MGMT_LOG_LEVEL_WRN is not set
    # CONFIG_NET_L2_WIFI_MGMT_LOG_LEVEL_INF is not set
    # CONFIG_NET_L2_WIFI_MGMT_LOG_LEVEL_DBG is not set
    CONFIG_NET_L2_WIFI_MGMT_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_L2_WIFI_MGMT_LOG_LEVEL=3
    # CONFIG_WIFI_MGMT_RAW_SCAN_RESULTS is not set
    CONFIG_WIFI_MGMT_TWT_CHECK_IP=y
    # CONFIG_WIFI_MGMT_FORCED_PASSIVE_SCAN is not set
    CONFIG_WIFI_MGMT_SCAN_CHAN_MAX_MANUAL=3
    CONFIG_WIFI_SHELL_MAX_AP_STA=1
    CONFIG_WIFI_NM=y
    CONFIG_WIFI_NM_MAX_MANAGED_INTERFACES=1
    # CONFIG_WIFI_NM_LOG_LEVEL_OFF is not set
    # CONFIG_WIFI_NM_LOG_LEVEL_ERR is not set
    # CONFIG_WIFI_NM_LOG_LEVEL_WRN is not set
    # CONFIG_WIFI_NM_LOG_LEVEL_INF is not set
    # CONFIG_WIFI_NM_LOG_LEVEL_DBG is not set
    CONFIG_WIFI_NM_LOG_LEVEL_DEFAULT=y
    CONFIG_WIFI_NM_LOG_LEVEL=3
    CONFIG_WIFI_MGMT_AP_STA_INACTIVITY_TIMEOUT=300
    # CONFIG_WIFI_MGMT_AP_STA_SKIP_INACTIVITY_POLL is not set
    CONFIG_WIFI_MGMT_AP_MAX_NUM_STA=4
    # CONFIG_NET_L2_WIFI_SHELL is not set
    # CONFIG_NET_L2_PTP is not set
    # end of Link layer options
    # IP stack
    CONFIG_NET_IP=y
    CONFIG_NET_CONNECTION_SOCKETS=y
    CONFIG_NET_NATIVE=y
    CONFIG_NET_NATIVE_IP=y
    CONFIG_NET_NATIVE_IPV6=y
    CONFIG_NET_NATIVE_IPV4=y
    CONFIG_NET_NATIVE_TCP=y
    CONFIG_NET_NATIVE_UDP=y
    # CONFIG_NET_OFFLOAD is not set
    CONFIG_NET_INIT_PRIO=90
    CONFIG_NET_IP_DSCP_ECN=y
    CONFIG_NET_IF_MAX_IPV6_COUNT=1
    CONFIG_NET_IF_UNICAST_IPV6_ADDR_COUNT=2
    CONFIG_NET_IF_MCAST_IPV6_ADDR_COUNT=3
    CONFIG_NET_IF_IPV6_PREFIX_COUNT=2
    CONFIG_NET_IPV6_MTU=1280
    CONFIG_NET_INITIAL_HOP_LIMIT=64
    CONFIG_NET_INITIAL_MCAST_HOP_LIMIT=1
    CONFIG_NET_IPV6_MAX_NEIGHBORS=8
    # CONFIG_NET_IPV6_FRAGMENT is not set
    CONFIG_NET_IPV6_ND=y
    CONFIG_NET_IPV6_DAD=y
    # CONFIG_NET_IPV6_PE is not set
    # CONFIG_NET_6LO is not set
    # CONFIG_NET_IPV6_LOG_LEVEL_OFF is not set
    # CONFIG_NET_IPV6_LOG_LEVEL_ERR is not set
    # CONFIG_NET_IPV6_LOG_LEVEL_WRN is not set
    # CONFIG_NET_IPV6_LOG_LEVEL_INF is not set
    # CONFIG_NET_IPV6_LOG_LEVEL_DBG is not set
    CONFIG_NET_IPV6_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_IPV6_LOG_LEVEL=3
    # CONFIG_NET_IPV6_ND_LOG_LEVEL_OFF is not set
    # CONFIG_NET_IPV6_ND_LOG_LEVEL_ERR is not set
    # CONFIG_NET_IPV6_ND_LOG_LEVEL_WRN is not set
    # CONFIG_NET_IPV6_ND_LOG_LEVEL_INF is not set
    # CONFIG_NET_IPV6_ND_LOG_LEVEL_DBG is not set
    CONFIG_NET_IPV6_ND_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_IPV6_ND_LOG_LEVEL=3
    # CONFIG_NET_IPV6_PE_LOG_LEVEL_OFF is not set
    # CONFIG_NET_IPV6_PE_LOG_LEVEL_ERR is not set
    # CONFIG_NET_IPV6_PE_LOG_LEVEL_WRN is not set
    # CONFIG_NET_IPV6_PE_LOG_LEVEL_INF is not set
    # CONFIG_NET_IPV6_PE_LOG_LEVEL_DBG is not set
    CONFIG_NET_IPV6_PE_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_IPV6_PE_LOG_LEVEL=3
    # CONFIG_NET_ICMPV6_LOG_LEVEL_OFF is not set
    # CONFIG_NET_ICMPV6_LOG_LEVEL_ERR is not set
    # CONFIG_NET_ICMPV6_LOG_LEVEL_WRN is not set
    # CONFIG_NET_ICMPV6_LOG_LEVEL_INF is not set
    # CONFIG_NET_ICMPV6_LOG_LEVEL_DBG is not set
    CONFIG_NET_ICMPV6_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_ICMPV6_LOG_LEVEL=3
    # CONFIG_NET_IPV6_NBR_CACHE_LOG_LEVEL_OFF is not set
    # CONFIG_NET_IPV6_NBR_CACHE_LOG_LEVEL_ERR is not set
    # CONFIG_NET_IPV6_NBR_CACHE_LOG_LEVEL_WRN is not set
    # CONFIG_NET_IPV6_NBR_CACHE_LOG_LEVEL_INF is not set
    # CONFIG_NET_IPV6_NBR_CACHE_LOG_LEVEL_DBG is not set
    CONFIG_NET_IPV6_NBR_CACHE_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_IPV6_NBR_CACHE_LOG_LEVEL=3
    CONFIG_NET_IPV4=y
    CONFIG_NET_INITIAL_TTL=64
    CONFIG_NET_INITIAL_MCAST_TTL=1
    CONFIG_NET_IF_MAX_IPV4_COUNT=1
    CONFIG_NET_IF_UNICAST_IPV4_ADDR_COUNT=1
    CONFIG_NET_IF_MCAST_IPV4_ADDR_COUNT=1
    CONFIG_NET_IF_MCAST_IPV4_SOURCE_COUNT=1
    # CONFIG_NET_ICMPV4_ACCEPT_BROADCAST is not set
    # CONFIG_NET_IPV4_ACCEPT_ZERO_BROADCAST is not set
    # CONFIG_NET_IPV4_IGMP is not set
    # CONFIG_NET_IPV4_AUTO is not set
    # CONFIG_NET_IPV4_HDR_OPTIONS is not set
    # CONFIG_NET_IPV4_FRAGMENT is not set
    # CONFIG_NET_IPV4_LOG_LEVEL_OFF is not set
    # CONFIG_NET_IPV4_LOG_LEVEL_ERR is not set
    # CONFIG_NET_IPV4_LOG_LEVEL_WRN is not set
    # CONFIG_NET_IPV4_LOG_LEVEL_INF is not set
    # CONFIG_NET_IPV4_LOG_LEVEL_DBG is not set
    CONFIG_NET_IPV4_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_IPV4_LOG_LEVEL=3
    # CONFIG_NET_ICMPV4_LOG_LEVEL_OFF is not set
    # CONFIG_NET_ICMPV4_LOG_LEVEL_ERR is not set
    # CONFIG_NET_ICMPV4_LOG_LEVEL_WRN is not set
    # CONFIG_NET_ICMPV4_LOG_LEVEL_INF is not set
    # CONFIG_NET_ICMPV4_LOG_LEVEL_DBG is not set
    CONFIG_NET_ICMPV4_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_ICMPV4_LOG_LEVEL=3
    # CONFIG_NET_IPV4_MAPPING_TO_IPV6 is not set
    # CONFIG_NET_SHELL is not set
    CONFIG_NET_TC_RX_COUNT=1
    # CONFIG_NET_TC_SKIP_FOR_HIGH_PRIO is not set
    CONFIG_NET_TC_THREAD_COOPERATIVE=y
    # CONFIG_NET_TC_THREAD_PREEMPTIVE is not set
    CONFIG_NET_TC_NUM_PRIORITIES=16
    # CONFIG_NET_TC_THREAD_PRIO_CUSTOM is not set
    CONFIG_NET_TC_MAPPING_STRICT=y
    CONFIG_NET_TX_DEFAULT_PRIORITY=1
    CONFIG_NET_RX_DEFAULT_PRIORITY=0
    # CONFIG_NET_ALLOW_ANY_PRIORITY is not set
    CONFIG_NET_IP_ADDR_CHECK=y
    CONFIG_NET_MAX_ROUTERS=2
    CONFIG_NET_ROUTE=y
    CONFIG_NET_MAX_ROUTES=8
    CONFIG_NET_MAX_NEXTHOPS=8
    # CONFIG_NET_ROUTE_MCAST is not set
    CONFIG_NET_TCP=y
    # CONFIG_NET_TCP_LOG_LEVEL_OFF is not set
    # CONFIG_NET_TCP_LOG_LEVEL_ERR is not set
    # CONFIG_NET_TCP_LOG_LEVEL_WRN is not set
    # CONFIG_NET_TCP_LOG_LEVEL_INF is not set
    # CONFIG_NET_TCP_LOG_LEVEL_DBG is not set
    CONFIG_NET_TCP_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_TCP_LOG_LEVEL=3
    CONFIG_NET_TCP_WORKER_PRIO=2
    CONFIG_NET_TCP_TIME_WAIT_DELAY=1500
    CONFIG_NET_TCP_ACK_TIMEOUT=1000
    CONFIG_NET_TCP_INIT_RETRANSMISSION_TIMEOUT=200
    CONFIG_NET_TCP_RANDOMIZED_RTO=y
    CONFIG_NET_TCP_RETRY_COUNT=9
    CONFIG_NET_TCP_MAX_SEND_WINDOW_SIZE=0
    CONFIG_NET_TCP_MAX_RECV_WINDOW_SIZE=0
    CONFIG_NET_TCP_RECV_QUEUE_TIMEOUT=2000
    CONFIG_NET_TCP_PKT_ALLOC_TIMEOUT=100
    CONFIG_NET_TCP_FAST_RETRANSMIT=y
    CONFIG_NET_TCP_CONGESTION_AVOIDANCE=y
    # CONFIG_NET_TCP_KEEPALIVE is not set
    CONFIG_NET_TCP_REJECT_CONN_WITH_RST=y
    # CONFIG_NET_TCP_IPV6_ND_REACHABILITY_HINT is not set
    # CONFIG_NET_TEST_PROTOCOL is not set
    CONFIG_NET_UDP=y
    CONFIG_NET_UDP_MISSING_CHECKSUM=y
    # CONFIG_NET_UDP_LOG_LEVEL_OFF is not set
    # CONFIG_NET_UDP_LOG_LEVEL_ERR is not set
    # CONFIG_NET_UDP_LOG_LEVEL_WRN is not set
    # CONFIG_NET_UDP_LOG_LEVEL_INF is not set
    # CONFIG_NET_UDP_LOG_LEVEL_DBG is not set
    CONFIG_NET_UDP_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_UDP_LOG_LEVEL=3
    CONFIG_NET_MAX_CONN=8
    CONFIG_NET_MAX_CONTEXTS=5
    # CONFIG_NET_CONTEXT_NET_PKT_POOL is not set
    CONFIG_NET_CONTEXT_SYNC_RECV=y
    CONFIG_NET_CONTEXT_CHECK=y
    # CONFIG_NET_CONTEXT_PRIORITY is not set
    # CONFIG_NET_CONTEXT_TXTIME is not set
    # CONFIG_NET_CONTEXT_RCVTIMEO is not set
    # CONFIG_NET_CONTEXT_SNDTIMEO is not set
    # CONFIG_NET_CONTEXT_RCVBUF is not set
    # CONFIG_NET_CONTEXT_SNDBUF is not set
    CONFIG_NET_CONTEXT_DSCP_ECN=y
    CONFIG_NET_CONTEXT_REUSEADDR=y
    CONFIG_NET_CONTEXT_REUSEPORT=y
    # CONFIG_NET_CONTEXT_RECV_PKTINFO is not set
    # CONFIG_NET_TEST is not set
    CONFIG_NET_BUF_RX_COUNT=48
    CONFIG_NET_BUF_TX_COUNT=48
    CONFIG_NET_BUF_FIXED_DATA_SIZE=y
    # CONFIG_NET_BUF_VARIABLE_DATA_SIZE is not set
    CONFIG_NET_BUF_DATA_SIZE=128
    CONFIG_NET_PKT_BUF_USER_DATA_SIZE=4
    CONFIG_NET_DEFAULT_IF_FIRST=y
    # CONFIG_NET_DEFAULT_IF_UP is not set
    # CONFIG_NET_DEFAULT_IF_ETHERNET is not set
    # CONFIG_NET_DEFAULT_IF_WIFI is not set
    CONFIG_NET_INTERFACE_NAME=y
    # CONFIG_NET_PKT_RXTIME_STATS is not set
    # CONFIG_NET_PKT_TXTIME_STATS is not set
    # CONFIG_NET_PROMISCUOUS_MODE is not set
    # CONFIG_NET_DISABLE_ICMP_DESTINATION_UNREACHABLE is not set
    # Stack usage
    # end of Stack usage
    CONFIG_NET_MGMT=y
    CONFIG_NET_MGMT_EVENT=y
    CONFIG_NET_MGMT_EVENT_THREAD=y
    # CONFIG_NET_MGMT_EVENT_SYSTEM_WORKQUEUE is not set
    # CONFIG_NET_MGMT_EVENT_DIRECT is not set
    CONFIG_NET_MGMT_EVENT_QUEUE=y
    CONFIG_NET_MGMT_EVENT_QUEUE_TIMEOUT=5000
    CONFIG_NET_MGMT_EVENT_INFO=y
    # CONFIG_NET_MGMT_EVENT_LOG_LEVEL_OFF is not set
    # CONFIG_NET_MGMT_EVENT_LOG_LEVEL_ERR is not set
    # CONFIG_NET_MGMT_EVENT_LOG_LEVEL_WRN is not set
    # CONFIG_NET_MGMT_EVENT_LOG_LEVEL_INF is not set
    # CONFIG_NET_MGMT_EVENT_LOG_LEVEL_DBG is not set
    CONFIG_NET_MGMT_EVENT_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_MGMT_EVENT_LOG_LEVEL=3
    # CONFIG_NET_DEBUG_MGMT_EVENT_STACK is not set
    # CONFIG_NET_STATISTICS is not set
    CONFIG_NET_LOG=y
    # CONFIG_NET_PKT_LOG_LEVEL_OFF is not set
    # CONFIG_NET_PKT_LOG_LEVEL_ERR is not set
    # CONFIG_NET_PKT_LOG_LEVEL_WRN is not set
    # CONFIG_NET_PKT_LOG_LEVEL_INF is not set
    # CONFIG_NET_PKT_LOG_LEVEL_DBG is not set
    CONFIG_NET_PKT_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_PKT_LOG_LEVEL=3
    # CONFIG_NET_DEBUG_NET_PKT_ALLOC is not set
    CONFIG_NET_DEBUG_NET_PKT_EXTERNALS=0
    # CONFIG_NET_DEBUG_NET_PKT_NON_FRAGILE_ACCESS is not set
    # CONFIG_NET_CORE_LOG_LEVEL_OFF is not set
    # CONFIG_NET_CORE_LOG_LEVEL_ERR is not set
    # CONFIG_NET_CORE_LOG_LEVEL_WRN is not set
    # CONFIG_NET_CORE_LOG_LEVEL_INF is not set
    # CONFIG_NET_CORE_LOG_LEVEL_DBG is not set
    CONFIG_NET_CORE_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_CORE_LOG_LEVEL=3
    # CONFIG_NET_IF_LOG_LEVEL_OFF is not set
    # CONFIG_NET_IF_LOG_LEVEL_ERR is not set
    # CONFIG_NET_IF_LOG_LEVEL_WRN is not set
    # CONFIG_NET_IF_LOG_LEVEL_INF is not set
    # CONFIG_NET_IF_LOG_LEVEL_DBG is not set
    CONFIG_NET_IF_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_IF_LOG_LEVEL=3
    # CONFIG_NET_TC_LOG_LEVEL_OFF is not set
    # CONFIG_NET_TC_LOG_LEVEL_ERR is not set
    # CONFIG_NET_TC_LOG_LEVEL_WRN is not set
    # CONFIG_NET_TC_LOG_LEVEL_INF is not set
    # CONFIG_NET_TC_LOG_LEVEL_DBG is not set
    CONFIG_NET_TC_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_TC_LOG_LEVEL=3
    # CONFIG_NET_UTILS_LOG_LEVEL_OFF is not set
    # CONFIG_NET_UTILS_LOG_LEVEL_ERR is not set
    # CONFIG_NET_UTILS_LOG_LEVEL_WRN is not set
    # CONFIG_NET_UTILS_LOG_LEVEL_INF is not set
    # CONFIG_NET_UTILS_LOG_LEVEL_DBG is not set
    CONFIG_NET_UTILS_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_UTILS_LOG_LEVEL=3
    # CONFIG_NET_CONTEXT_LOG_LEVEL_OFF is not set
    # CONFIG_NET_CONTEXT_LOG_LEVEL_ERR is not set
    # CONFIG_NET_CONTEXT_LOG_LEVEL_WRN is not set
    # CONFIG_NET_CONTEXT_LOG_LEVEL_INF is not set
    # CONFIG_NET_CONTEXT_LOG_LEVEL_DBG is not set
    CONFIG_NET_CONTEXT_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_CONTEXT_LOG_LEVEL=3
    # CONFIG_NET_CONN_LOG_LEVEL_OFF is not set
    # CONFIG_NET_CONN_LOG_LEVEL_ERR is not set
    # CONFIG_NET_CONN_LOG_LEVEL_WRN is not set
    # CONFIG_NET_CONN_LOG_LEVEL_INF is not set
    # CONFIG_NET_CONN_LOG_LEVEL_DBG is not set
    CONFIG_NET_CONN_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_CONN_LOG_LEVEL=3
    # CONFIG_NET_ROUTE_LOG_LEVEL_OFF is not set
    # CONFIG_NET_ROUTE_LOG_LEVEL_ERR is not set
    # CONFIG_NET_ROUTE_LOG_LEVEL_WRN is not set
    # CONFIG_NET_ROUTE_LOG_LEVEL_INF is not set
    # CONFIG_NET_ROUTE_LOG_LEVEL_DBG is not set
    CONFIG_NET_ROUTE_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_ROUTE_LOG_LEVEL=3
    # end of IP stack
    # Network Packet Filtering
    # CONFIG_NET_PKT_FILTER is not set
    # end of Network Packet Filtering
    # Network Protocols
    # CONFIG_COAP is not set
    # CONFIG_DNS_RESOLVER is not set
    # CONFIG_DNS_SD is not set
    # CONFIG_MQTT_LIB is not set
    # CONFIG_MQTT_SN_LIB is not set
    # CONFIG_TFTP_LIB is not set
    # CONFIG_HTTP_PARSER is not set
    # CONFIG_HTTP_PARSER_URL is not set
    # CONFIG_HTTP_CLIENT is not set
    # CONFIG_HTTP_SERVER is not set
    # CONFIG_NET_HTTP_LOG_LEVEL_OFF is not set
    # CONFIG_NET_HTTP_LOG_LEVEL_ERR is not set
    # CONFIG_NET_HTTP_LOG_LEVEL_WRN is not set
    # CONFIG_NET_HTTP_LOG_LEVEL_INF is not set
    # CONFIG_NET_HTTP_LOG_LEVEL_DBG is not set
    CONFIG_NET_HTTP_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_HTTP_LOG_LEVEL=3
    # CONFIG_NET_HTTP_SERVER_LOG_LEVEL_OFF is not set
    # CONFIG_NET_HTTP_SERVER_LOG_LEVEL_ERR is not set
    # CONFIG_NET_HTTP_SERVER_LOG_LEVEL_WRN is not set
    # CONFIG_NET_HTTP_SERVER_LOG_LEVEL_INF is not set
    # CONFIG_NET_HTTP_SERVER_LOG_LEVEL_DBG is not set
    CONFIG_NET_HTTP_SERVER_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_HTTP_SERVER_LOG_LEVEL=3
    # CONFIG_WEBSOCKET_CLIENT is not set
    # CONFIG_LWM2M is not set
    # CONFIG_SOCKS is not set
    # CONFIG_SNTP is not set
    # end of Network Protocols
    # Network Libraries
    # CONFIG_NET_CONFIG_LOG_LEVEL_OFF is not set
    # CONFIG_NET_CONFIG_LOG_LEVEL_ERR is not set
    # CONFIG_NET_CONFIG_LOG_LEVEL_WRN is not set
    # CONFIG_NET_CONFIG_LOG_LEVEL_INF is not set
    # CONFIG_NET_CONFIG_LOG_LEVEL_DBG is not set
    CONFIG_NET_CONFIG_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_CONFIG_LOG_LEVEL=3
    CONFIG_NET_CONFIG_SETTINGS=y
    CONFIG_NET_CONFIG_AUTO_INIT=y
    CONFIG_NET_CONFIG_INIT_PRIO=95
    # CONFIG_NET_CONFIG_NEED_IPV6_ROUTER is not set
    # CONFIG_NET_CONFIG_NEED_IPV4 is not set
    CONFIG_NET_CONFIG_INIT_TIMEOUT=0
    CONFIG_NET_CONFIG_MY_IPV6_ADDR=""
    CONFIG_NET_CONFIG_PEER_IPV6_ADDR=""
    CONFIG_NET_CONFIG_MY_IPV4_ADDR="192.168.1.99"
    CONFIG_NET_CONFIG_MY_IPV4_NETMASK="255.255.255.0"
    CONFIG_NET_CONFIG_MY_IPV4_GW="192.168.1.1"
    CONFIG_NET_CONFIG_PEER_IPV4_ADDR="192.168.1.202"
    CONFIG_NET_SOCKETS=y
    CONFIG_NET_SOCKETS_PRIORITY_DEFAULT=50
    CONFIG_NET_SOCKETS_CONNECT_TIMEOUT=3000
    CONFIG_NET_SOCKET_MAX_SEND_WAIT=10000
    # CONFIG_NET_SOCKETS_SERVICE is not set
    # CONFIG_NET_SOCKETS_SOCKOPT_TLS is not set
    CONFIG_NET_SOCKETS_TLS_PRIORITY=45
    CONFIG_NET_SOCKETS_TLS_SET_MAX_FRAGMENT_LENGTH=y
    # CONFIG_NET_SOCKETS_OFFLOAD is not set
    CONFIG_NET_SOCKETS_OFFLOAD_PRIORITY=40
    CONFIG_NET_SOCKETS_PACKET=y
    CONFIG_NET_SOCKETS_PACKET_DGRAM=y
    # CONFIG_NET_SOCKETS_CAN is not set
    CONFIG_NET_SOCKETPAIR=y
    # CONFIG_NET_SOCKETPAIR_STATIC is not set
    CONFIG_NET_SOCKETPAIR_HEAP=y
    # CONFIG_NET_SOCKETS_NET_MGMT is not set
    # CONFIG_NET_SOCKETS_LOG_LEVEL_OFF is not set
    # CONFIG_NET_SOCKETS_LOG_LEVEL_ERR is not set
    # CONFIG_NET_SOCKETS_LOG_LEVEL_WRN is not set
    # CONFIG_NET_SOCKETS_LOG_LEVEL_INF is not set
    # CONFIG_NET_SOCKETS_LOG_LEVEL_DBG is not set
    CONFIG_NET_SOCKETS_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_SOCKETS_LOG_LEVEL=3
    # CONFIG_TLS_CREDENTIALS is not set
    # end of Network Libraries
    # Network additional services
    # CONFIG_NET_CAPTURE is not set
    CONFIG_NET_DHCPV4=y
    # CONFIG_NET_DHCPV4_LOG_LEVEL_OFF is not set
    # CONFIG_NET_DHCPV4_LOG_LEVEL_ERR is not set
    # CONFIG_NET_DHCPV4_LOG_LEVEL_WRN is not set
    # CONFIG_NET_DHCPV4_LOG_LEVEL_INF is not set
    # CONFIG_NET_DHCPV4_LOG_LEVEL_DBG is not set
    CONFIG_NET_DHCPV4_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_DHCPV4_LOG_LEVEL=3
    CONFIG_NET_DHCPV4_INITIAL_DELAY_MAX=10
    # CONFIG_NET_DHCPV4_OPTION_CALLBACKS is not set
    # CONFIG_NET_DHCPV4_OPTION_CALLBACKS_VENDOR_SPECIFIC is not set
    CONFIG_NET_DHCPV4_ACCEPT_UNICAST=y
    # CONFIG_NET_DHCPV4_VENDOR_CLASS_IDENTIFIER is not set
    # CONFIG_NET_DHCPV4_SERVER is not set
    # CONFIG_NET_DHCPV6 is not set
    CONFIG_NET_DHCPV6_DUID_MAX_LEN=22
    # CONFIG_NET_TRICKLE is not set
    # CONFIG_NET_ZPERF is not set
    # end of Network additional services
    # CONFIG_NET_CONNECTION_MANAGER is not set
    # end of Networking
    # Power Management
    # end of Power Management
    # Portability
    # end of Portability
    # Random Number Generators
    # CONFIG_TEST_RANDOM_GENERATOR is not set
    CONFIG_TIMER_RANDOM_INITIAL_STATE=123456789
    CONFIG_ENTROPY_DEVICE_RANDOM_GENERATOR=y
    # CONFIG_XOSHIRO_RANDOM_GENERATOR is not set
    CONFIG_CSPRNG_ENABLED=y
    CONFIG_HARDWARE_DEVICE_CS_GENERATOR=y
    # CONFIG_CTR_DRBG_CSPRNG_GENERATOR is not set
    # end of Random Number Generators
    # CONFIG_RTIO is not set
    # SD
    # CONFIG_MMC_STACK is not set
    # CONFIG_SDMMC_STACK is not set
    # CONFIG_SDIO_STACK is not set
    # end of SD
    # CONFIG_SETTINGS is not set
    # CONFIG_SHELL is not set
    # CONFIG_STATS is not set
    # Storage
    # CONFIG_STREAM_FLASH is not set
    # end of Storage
    # CONFIG_TASK_WDT is not set
    # Testing
    # CONFIG_ZTEST is not set
    # CONFIG_ZTEST_MOCKING is not set
    # CONFIG_ZTRESS is not set
    # CONFIG_TEST is not set
    CONFIG_COVERAGE_GCOV_HEAP_SIZE=16384
    # CONFIG_FORCE_COVERAGE is not set
    # CONFIG_TEST_USERSPACE is not set
    # end of Testing
    CONFIG_TIMING_FUNCTIONS=y
    # CONFIG_TRACING is not set
    # CONFIG_USB_DEVICE_STACK is not set
    # CONFIG_USB_DEVICE_STACK_NEXT is not set
    # CONFIG_USB_HOST_STACK is not set
    # CONFIG_USBC_STACK is not set
    # CONFIG_ZBUS is not set
    # CONFIG_MODULES is not set
    # end of Subsystems and OS Services
    CONFIG_TOOLCHAIN_ZEPHYR_0_16=y
    CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE=y
    # Build and Link Features
    # Linker Options
    # CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
    CONFIG_LINKER_ORPHAN_SECTION_WARN=y
    # CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
    CONFIG_ROM_END_OFFSET=0
    CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y
    CONFIG_LD_LINKER_TEMPLATE=y
    # CONFIG_CMAKE_LINKER_GENERATOR is not set
    # CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
    CONFIG_LINKER_SORT_BY_ALIGNMENT=y
    # Linker Sections
    # CONFIG_LINKER_USE_BOOT_SECTION is not set
    # CONFIG_LINKER_USE_PINNED_SECTION is not set
    CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y
    CONFIG_LINKER_LAST_SECTION_ID=y
    CONFIG_LINKER_LAST_SECTION_ID_PATTERN=0xE015E015
    CONFIG_LINKER_USE_RELAX=y
    # end of Linker Sections
    CONFIG_LINKER_ITERABLE_SUBALIGN=4
    CONFIG_LINKER_DEVNULL_SUPPORT=y
    # CONFIG_LINKER_DEVNULL_MEMORY is not set
    # end of Linker Options
    # Compiler Options
    # CONFIG_STD_C90 is not set
    CONFIG_STD_C99=y
    # CONFIG_STD_C11 is not set
    # CONFIG_STD_C17 is not set
    # CONFIG_STD_C23 is not set
    CONFIG_TOOLCHAIN_SUPPORTS_GNU_EXTENSIONS=y
    # CONFIG_GNU_C_EXTENSIONS is not set
    # CONFIG_CODING_GUIDELINE_CHECK is not set
    # CONFIG_COMPILER_FREESTANDING is not set
    CONFIG_SIZE_OPTIMIZATIONS=y
    # CONFIG_SPEED_OPTIMIZATIONS is not set
    # CONFIG_DEBUG_OPTIMIZATIONS is not set
    # CONFIG_NO_OPTIMIZATIONS is not set
    # CONFIG_COMPILER_WARNINGS_AS_ERRORS is not set
    # CONFIG_COMPILER_SAVE_TEMPS is not set
    CONFIG_COMPILER_TRACK_MACRO_EXPANSION=y
    CONFIG_COMPILER_COLOR_DIAGNOSTICS=y
    # CONFIG_FORTIFY_SOURCE_NONE is not set
    CONFIG_FORTIFY_SOURCE_COMPILE_TIME=y
    # CONFIG_FORTIFY_SOURCE_RUN_TIME is not set
    CONFIG_COMPILER_OPT=""
    # CONFIG_MISRA_SANE is not set
    # end of Compiler Options
    # CONFIG_ASSERT_ON_ERRORS is not set
    # CONFIG_NO_RUNTIME_CHECKS is not set
    CONFIG_RUNTIME_ERROR_CHECKS=y
    # Build Options
    CONFIG_KERNEL_BIN_NAME="zephyr"
    CONFIG_OUTPUT_STAT=y
    # CONFIG_OUTPUT_SYMBOLS is not set
    # CONFIG_OUTPUT_DISASSEMBLY is not set
    CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
    # CONFIG_CLEANUP_INTERMEDIATE_FILES is not set
    # CONFIG_BUILD_NO_GAP_FILL is not set
    # CONFIG_BUILD_OUTPUT_EXE is not set
    # CONFIG_BUILD_OUTPUT_S19 is not set
    # CONFIG_BUILD_OUTPUT_UF2 is not set
    # CONFIG_BUILD_OUTPUT_STRIPPED is not set
    # CONFIG_BUILD_OUTPUT_COMPRESS_DEBUG_SECTIONS is not set
    # CONFIG_BUILD_ALIGN_LMA is not set
    # CONFIG_APPLICATION_DEFINED_SYSCALL is not set
    # CONFIG_MAKEFILE_EXPORTS is not set
    # CONFIG_BUILD_OUTPUT_META is not set
    CONFIG_BUILD_OUTPUT_STRIP_PATHS=y
    CONFIG_CHECK_INIT_PRIORITIES=y
    # CONFIG_EMIT_ALL_SYSCALLS is not set
    # end of Build Options
    CONFIG_WARN_DEPRECATED=y
    CONFIG_ENFORCE_ZEPHYR_STDINT=y
    # end of Build and Link Features
    # Boot Options
    # CONFIG_IS_BOOTLOADER is not set
    # CONFIG_BOOTLOADER_BOSSA is not set
    # end of Boot Options
    # Nordic Sta sample
    CONFIG_CONNECTION_IDLE_TIMEOUT=30
    CONFIG_STA_SAMPLE_SSID="algorigo_tp5G"
    # CONFIG_STA_KEY_MGMT_NONE is not set
    CONFIG_STA_KEY_MGMT_WPA2=y
    # CONFIG_STA_KEY_MGMT_WPA2_256 is not set
    # CONFIG_STA_KEY_MGMT_WPA3 is not set
    CONFIG_STA_SAMPLE_PASSWORD="dkfrhflrh24223#"
    CONFIG_STA_CONN_TIMEOUT_SEC=70
    # end of Nordic Sta sample
    And I would like to know where I can do the setting that is not set in the image below.
    1.
    2.
    3.
    4.
  • Your .config file shows that MBOX is enabled on line 151.
    Your configured board is this:
    This means that there is a board defined as "SC50" somewhere in your sources. These typically have board definitions, such as kconfig entries specific to that board, similar to this:
    https://github.com/nrfconnect/sdk-zephyr/blob/main/boards/nordic/nrf5340dk/Kconfig.defconfig
    Could you share those specific defconfig's for your board?
    Håkon
  • Open the "Kconfig.defconfig" file in the custom board directory and open the "C:\n" filecs\v2.7.0\zephyr\boards\nordic\nI built it with the missing parts compared to the rf5340dk\Kconfig.defconfig" file and it was built normally.
    Is there a way to modify it in vscode's project instead of directly opening the file as above?
    Is the file regarding "Could you share these specific defconfig's for your board?" attached below correct?
    # nRF5340 DK nRF5340 board configuration
    # Copyright (c) 2019-2020 Nordic Semiconductor ASA
    if  BOARD_NRF5340DK_NRF5340_CPUAPP || BOARD_NRF5340DK_NRF5340_CPUAPP_NS
    # Code Partition:
    # For the secure version of the board the firmware is linked at the beginning
    # of the flash, or into the code-partition defined in DT if it is intended to
    # be loaded by MCUboot. If the secure firmware is to be combined with a non-
    # secure image (TRUSTED_EXECUTION_SECURE=y), the secure FW image shall always
    # be restricted to the size of its code partition.
    # For the non-secure version of the board, the firmware
    # must be linked into the code-partition (non-secure) defined in DT, regardless.
    # Apply this configuration below by setting the Kconfig symbols used by
    # the linker according to the information extracted from DT partitions.
    # SRAM Partition:
    # If the secure firmware is to be combined with a non-secure image
    # (TRUSTED_EXECUTION_SECURE=y), the secure FW image SRAM shall always
    # be restricted to the secure image SRAM partition (sram-secure-partition).
    # Otherwise (if TRUSTED_EXECUTION_SECURE is not set) the whole zephyr,sram
    # may be used by the image.
    # For the non-secure version of the board, the firmware image SRAM is
    # always restricted to the allocated non-secure SRAM partition.
    # Workaround for not being able to have commas in macro arguments
    DT_CHOSEN_Z_CODE_PARTITION := zephyr,code-partition
    DT_CHOSEN_Z_SRAM_PARTITION := zephyr,sram-secure-partition
    if BOARD_NRF5340DK_NRF5340_CPUAPP && TRUSTED_EXECUTION_SECURE
    config FLASH_LOAD_SIZE
    	default $(dt_chosen_reg_size_hex,$(DT_CHOSEN_Z_CODE_PARTITION))
    config SRAM_SIZE
    	default $(dt_chosen_reg_size_int,$(DT_CHOSEN_Z_SRAM_PARTITION),0,K)
    endif # BOARD_NRF5340DK_NRF5340_CPUAPP && TRUSTED_EXECUTION_SECURE
    if BOARD_NRF5340DK_NRF5340_CPUAPP_NS
    config FLASH_LOAD_OFFSET
    	default $(dt_chosen_reg_addr_hex,$(DT_CHOSEN_Z_CODE_PARTITION))
    endif # BOARD_NRF5340DK_NRF5340_CPUAPP_NS
    endif # BOARD_NRF5340DK_NRF5340_CPUAPP || BOARD_NRF5340DK_NRF5340_CPUAPP_NS
    config MBOX_NRFX_IPC
    	default MBOX
    choice BT_HCI_BUS_TYPE
    	default BT_HCI_IPC if BT
    endchoice
    config HEAP_MEM_POOL_ADD_SIZE_BOARD
    	int
    	default 4096 if BT_HCI_IPC
    if BOARD_NRF5340DK_NRF5340_CPUNET
    config BT_CTLR
    	default y if BT
    endif # BOARD_NRF5340DK_NRF5340_CPUNET
    I am not sure which parts were modified here, but if you found which entries fixed the issues, I would recommend you diff this against your board files and see what needs to be altered in your board (ie. the SC50/nrf5340 board files).
    Can you share a .diff showing what changes that you did?
    Håkon
