Adding NVS in zigbee sample
We are making ZigBee product. The base we have took is from nrf connect sdk samples light_switch and coordniator example. everything works fine but we need to keep some information stored in NVS/flash.
Mainly for device list in network so that we can relate mac and short address and update it when rejoins. so that when coordinator  restarts it has network device list.
Issue we are facing is that when we add nvs sample code it gives error
*** Booting nRF Connect SDK v3.5.99-ncs1-1 ***
[00:00:00.020,416] <err> flash_nrf: invalid address: 0x00100ff8:8
[00:00:00.037,841] <inf> fs_nvs: 3 Sectors of 4096 bytes
[00:00:00.038,604] <inf> fs_nvs: alloc wra: 0, fe8
[00:00:00.039,306] <inf> fs_nvs: data wra: 0, 0
[00:00:00.040,039] <err> flash_nrf: invalid address: 0x00100ff8:8
No address found, adding 192.168.1.1 at id 1
[00:00:00.041,351] <err> flash_nrf: invalid address: 0x00100ff8:8
[00:00:00.042,236] <err> flash_nrf: invalid address: 0x00100ff8:8
No key found, adding it at id 2
After research found its due to multi build
The nRF Connect SDK build system enables sysbuild by default, while Zephyr build system does not. You can select the build system default or choose to explicitly use --sysbuild or --no-sysbuild for your build configuration.
I am not sure how to fix it still
Any suggestion idea will be helpful!
    Can you share how you are reproducing this issue?
    When altering the partition layout, it is important that you re-generate the build (ie. delete the build folder, then re-configure) - this is to ensure that the partitions are generated within the address space of the chosen device.
    Your address space seems to be out-of-bounds.
    Håkon
  • Hi Hakon
    I am not sure where to alter partition layout
    in nvs example it used to be mentioned in device tree but if have used zigbee samples
    not able to find where to add nvs partition or if it has then how to modify it
    The layout is generated based on the configuration.
    Can you please share how to recreate this scenario?
    Håkon
    I tried to reproduce with sample you can use coordniator example with below prj.conf
    # Copyright (c) 2020 Nordic Semiconductor ASA
    CONFIG_NCS_SAMPLES_DEFAULTS=y
    CONFIG_SERIAL=y
    CONFIG_GPIO=y
    # Make sure printk is not printing to the UART console
    CONFIG_CONSOLE=y
    CONFIG_UART_CONSOLE=y
    CONFIG_HEAP_MEM_POOL_SIZE=2048
    CONFIG_MAIN_THREAD_PRIORITY=7
    CONFIG_ZIGBEE=y
    CONFIG_ZIGBEE_APP_UTILS=y
    CONFIG_ZIGBEE_ROLE_COORDINATOR=y
    # Enable DK LED and Buttons library
    CONFIG_DK_LIBRARY=y
    # This example requires more workqueue stack
    # Enable nRF ECB driver
    CONFIG_CRYPTO=y
    CONFIG_CRYPTO_NRF_ECB=y
    CONFIG_CRYPTO_INIT_PRIORITY=80
    # Networking
    CONFIG_NET_IPV6=n
    CONFIG_NET_IP_ADDR_CHECK=n
    CONFIG_NET_UDP=n
    CONFIG_NO_OPTIMIZATIONS=y
    CONFIG_UART_INTERRUPT_DRIVEN=n
    CONFIG_SERIAL=y
    CONFIG_UART_ASYNC_API=y
    CONFIG_UART_1_ASYNC=y
    CONFIG_GPIO=y
    CONFIG_CONSOLE=y
    CONFIG_ZIGBEE=y
    CONFIG_DK_LIBRARY=y
    # Enable API for powering down unused RAM parts
    CONFIG_RAM_POWER_DOWN_LIBRARY=y
    # Networking
    CONFIG_NET_IPV6=n
    CONFIG_NET_UDP=n
    #CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC=y
    CONFIG_ZIGBEE_SCENES=y
    CONFIG_LOG_MODE_IMMEDIATE=y
    CONFIG_ZIGBEE_CHANNEL=15
    CONFIG_FLASH=y
    CONFIG_FLASH_PAGE_LAYOUT=y
    CONFIG_NVS=y
    CONFIG_LOG=y
    CONFIG_NVS_LOG_LEVEL_DBG=y
    CONFIG_REBOOT=y
    CONFIG_MPU_ALLOW_FLASH_WRITE=y
    # choose RTT console
    CONFIG_UART_CONSOLE=n
    CONFIG_USE_SEGGER_RTT=y
    CONFIG_RTT_CONSOLE=y
    CONFIG_MAIN_STACK_SIZE=4096
    and main function from nvs sample with required variables and #defines
    #include <zephyr/drivers/flash.h>
    #include <zephyr/storage/flash_map.h>
    #include <zephyr/fs/nvs.h>
    static struct nvs_fs fs;
    #define NVS_PARTITION       storage_partition
    #define NVS_PARTITION_DEVICE    FIXED_PARTITION_DEVICE(NVS_PARTITION)
    #define NVS_PARTITION_OFFSET    FIXED_PARTITION_OFFSET(NVS_PARTITION)
    /* 1000 msec = 1 sec */
    #define SLEEP_TIME      100
    /* maximum reboot counts, make high enough to trigger sector change (buffer */
    /* rotation). */
    #define MAX_REBOOT 400
    #define ADDRESS_ID 1
    #define KEY_ID 2
    #define RBT_CNT_ID 3
    #define STRING_ID 4
    #define LONG_ID 5
        int rc = 0, cnt = 0, cnt_his = 0;
        char buf[16];
        uint8_t key[8], longarray[128];
        uint32_t reboot_counter = 0U, reboot_counter_his;
        struct flash_pages_info info;
        /* define the nvs file system by settings with:
         *  sector_size equal to the pagesize,
         *  3 sectors
         *  starting at NVS_PARTITION_OFFSET
        fs.flash_device = NVS_PARTITION_DEVICE;
        if (!device_is_ready(fs.flash_device)) {
            printk("Flash device %s is not ready\n", fs.flash_device->name);
            return 0;
        fs.offset = NVS_PARTITION_OFFSET;
        rc = flash_get_page_info_by_offs(fs.flash_device, fs.offset, &info);
        if (rc) {
            printk("Unable to get page info\n");
            return 0;
        fs.sector_size = info.size;
        fs.sector_count = 3U;
        rc = nvs_mount(&fs);
        if (rc) {
            printk("Flash Init failed\n");
            return 0;
        /* ADDRESS_ID is used to store an address, lets see if we can
         * read it from flash, since we don't know the size read the
         * maximum possible
        rc = nvs_read(&fs, ADDRESS_ID, &buf, sizeof(buf));
        if (rc > 0) { /* item was found, show it */
            printk("Id: %d, Address: %s\n", ADDRESS_ID, buf);
        } else   {/* item was not found, add it */
            strcpy(buf, "192.168.1.1");
            printk("No address found, adding %s at id %d\n", buf,
                   ADDRESS_ID);
            (void)nvs_write(&fs, ADDRESS_ID, &buf, strlen(buf)+1);
        /* KEY_ID is used to store a key, lets see if we can read it from flash
        rc = nvs_read(&fs, KEY_ID, &key, sizeof(key));
            printk("Id: %d, Key: ", KEY_ID);
            for (int n = 0; n < 8; n++) {
                printk("%x ", key[n]);
            printk("\n");
            printk("No key found, adding it at id %d\n", KEY_ID);
            key[0] = 0xFF;
            key[1] = 0xFE;
            key[2] = 0xFD;
            key[3] = 0xFC;
            key[4] = 0xFB;
            key[5] = 0xFA;
            key[6] = 0xF9;
            key[7] = 0xF8;
            (void)nvs_write(&fs, KEY_ID, &key, sizeof(key));
        /* RBT_CNT_ID is used to store the reboot counter, lets see
         * if we can read it from flash
        rc = nvs_read(&fs, RBT_CNT_ID, &reboot_counter, sizeof(reboot_counter));
            printk("Id: %d, Reboot_counter: %d\n",
                RBT_CNT_ID, reboot_counter);
            printk("No Reboot counter found, adding it at id %d\n",
                   RBT_CNT_ID);
            (void)nvs_write(&fs, RBT_CNT_ID, &reboot_counter,
        /* STRING_ID is used to store data that will be deleted,lets see
         * if we can read it from flash, since we don't know the size read the
         * maximum possible
        rc = nvs_read(&fs, STRING_ID, &buf, sizeof(buf));
        if (rc > 0) {
            printk("Id: %d, Data: %s\n",
                STRING_ID, buf);
            /* remove the item if reboot_counter = 10 */
            if (reboot_counter == 10U) {
                (void)nvs_delete(&fs, STRING_ID);
        } else   {
            /* entry was not found, add it if reboot_counter = 0*/
            if (reboot_counter == 0U) {
                printk("Id: %d not found, adding it\n",
                STRING_ID);
                strcpy(buf, "DATA");
                (void)nvs_write(&fs, STRING_ID, &buf, strlen(buf) + 1);
        /* LONG_ID is used to store a larger dataset ,lets see if we can read
         * it from flash
        rc = nvs_read(&fs, LONG_ID, &longarray, sizeof(longarray));
        if (rc > 0) {
            printk("Id: %d, Longarray: ", LONG_ID);
            for (int n = 0; n < sizeof(longarray); n++) {
                printk("%x ", longarray[n]);
            printk("\n");
        } else   {
                printk("Longarray not found, adding it as id %d\n",
                       LONG_ID);
                    longarray[n] = n;
                (void)nvs_write(
        cnt = 5;
        while (1) {
            k_msleep(SLEEP_TIME);
            if (reboot_counter < MAX_REBOOT) {
                if (cnt == 5) {
                    /* print some history information about
                     * the reboot counter
                     * Check the counter history in flash
                    printk("Reboot counter history: ");
                    while (1) {
                        rc = nvs_read_hist(
                            &fs, RBT_CNT_ID,
                            &reboot_counter_his,
                            sizeof(reboot_counter_his),
                            cnt_his);
                        if (rc < 0) {
                        printk("...%d", reboot_counter_his);
                        cnt_his++;
                    if (cnt_his == 0) {
                        printk("\n Error, no Reboot counter");
                    } else {
                        printk("\nOldest reboot counter: %d",
                    printk("\nRebooting in ");
                printk("...%d", cnt);
                cnt--;
                if (cnt == 0) {
                    printk("\n");
                    reboot_counter++;
                    (void)nvs_write(
                    if (reboot_counter == MAX_REBOOT) {
                        printk("Doing last reboot...\n");
                    sys_reboot(0);
            } else {
                printk("Reboot counter reached max value.\n");
                printk("Reset to 0 and exit test.\n");
                reboot_counter = 0U;
        return 0;
    I found if I comment
     it works fine
    but I will need that so how can I fix it any idea?
