Hi, I'm having trouble running the samples/net/aws_iot sample on nRF9160-based board.
Configuration:
- nCS: v2.6.0
- modem version: nrf9160_1.3.6
When running the sample with default settings for a nRF9160-based custom board using provided overlay for nrf9160dk_nrf9160_ns board, I get the following logs:
[Sec Thread] Secure image initializing!
Booting TF-M v2.0.0
*** Booting nRF Connect SDK v3.5.99-ncs1 ***
[00:00:00.253,417] <inf> aws_iot_sample: The AWS IoT sample started, version: v1.0.0
[00:00:00.253,448] <inf> aws_iot_sample: Bringing network interface up and connecting to the network
+CEREG: 2,"CE98","01F62E11",7
+CSCON: 1
+CGEV: ME PDN ACT 0,0
+CNEC_ESM: 50,0
+CEREG: 5,"CE98","01F62E11",7,,,"11100000","11100000"
[00:00:04.385,437] <inf> aws_iot_sample: Network connectivity established
[00:00:09.385,620] <inf> aws_iot_sample: Connecting to AWS IoT
[00:00:13.273,986] <inf> aws_iot_sample: AWS_IOT_EVT_CONNECTED
[00:00:13.274,963] <inf> aws_iot_sample: Publishing message: {"state":{"reported":{"uptime":13274,"app_version":"v1.0.0","modem_version":"nrf9160_1.3.6"}}} to AWS IoT shadow
[00:00:13.352,478] <inf> aws_iot_sample: AWS_IOT_EVT_PUBACK, message ID: 37504
[00:00:13.523,895] <err> mqtt_helper: Socket error: POLLERR
[00:00:13.523,925] <err> mqtt_helper: Connection was unexpectedly closed
[00:00:13.524,475] <inf> aws_iot_sample: AWS_IOT_EVT_DISCONNECTED
[00:00:18.524,658] <inf> aws_iot_sample: Connecting to AWS IoT
[00:00:22.614,288] <inf> aws_iot_sample: AWS_IOT_EVT_CONNECTED
[00:00:22.615,264] <inf> aws_iot_sample: Publishing message: {"state":{"reported":{"uptime":22614,"app_version":"v1.0.0","modem_version":"nrf9160_1.3.6"}}} to AWS IoT shadow
[00:00:22.692,749] <inf> aws_iot_sample: AWS_IOT_EVT_PUBACK, message ID: 16827
[00:00:22.874,816] <err> mqtt_helper: Socket error: POLLERR
[00:00:22.874,847] <err> mqtt_helper: Connection was unexpectedly closed
[00:00:22.875,610] <inf> aws_iot_sample: AWS_IOT_EVT_DISCONNECTED
In the AWS I see that the device connects, shadow is updated with the message sent by the device, then the device disconnects with the following log:
"clientId": <hidden_id>,
"timestamp": 1732104741853,
"eventType": "disconnected",
"clientInitiatedDisconnect": false,
"sessionIdentifier": <hidden_identifier>,
"principalIdentifier": <hidden_identifier>,
"disconnectReason": "CONNECTION_LOST",
"versionNumber": 924
Config overlay is as follows (almost no difference between nrf9160dk_nrf9160_ns.conf file):
# General CONFIG_HW_STACK_PROTECTION=y CONFIG_HW_ID_LIBRARY_SOURCE_IMEI=y CONFIG_PICOLIBC=y # Modem related configurations CONFIG_MODEM_INFO=y CONFIG_AT_HOST_LIBRARY=y CONFIG_NRF_MODEM_LIB_ON_FAULT_APPLICATION_SPECIFIC=y # Modem trace CONFIG_SERIAL=y CONFIG_UART_ASYNC_API=y # Disable Duplicate Address Detection (DAD) # due to not being properly implemented for offloaded interfaces. CONFIG_NET_IPV6_NBR_CACHE=n CONFIG_NET_IPV6_MLD=n # Zephyr NET Connection Manager and Connectivity layer. CONFIG_NET_CONNECTION_MANAGER_MONITOR_STACK_SIZE=1024 CONFIG_NRF_MODEM_LIB_NET_IF=y # Bootloader and FOTA related configurations # MCUBOOT CONFIG_BOOTLOADER_MCUBOOT=y CONFIG_MCUBOOT_IMG_MANAGER=y # Image manager CONFIG_IMG_MANAGER=y CONFIG_STREAM_FLASH=y CONFIG_FLASH_MAP=y CONFIG_FLASH=y CONFIG_IMG_ERASE_PROGRESSIVELY=y # AWS FOTA CONFIG_AWS_FOTA=y CONFIG_FOTA_DOWNLOAD=y CONFIG_DFU_TARGET=y # Download client (needed by AWS FOTA) CONFIG_DOWNLOAD_CLIENT=y CONFIG_DOWNLOAD_CLIENT_STACK_SIZE=4096 # AWS IoT library CONFIG_AWS_IOT_BROKER_HOST_NAME=<hidden_host_name> # MQTT helper library CONFIG_MQTT_HELPER_SEC_TAG=2
Do you know what may cause such error? Are you able to reproduce it? Thanks in advance.
