[nRF52833] TIMER3 does not enter IRQ and keeps going
I am trying to use TIMER3 where it should count 1ms ticks for 15 seconds and then stop.
Tried the below code. However it never enters ISR.
Please let me know if I am configuring it incorrectly or something else.
As Channel 0 is being used by Timer 2 already, I have chosen channel 3.
Also tried setting priority to 3.
// Timer tick duration (1 ms = 16000 ticks at 16 MHz)
#define TIMER_TICK_1MS   16000
// Total duration (15 seconds = 15000 ms)
#define TIMER_DURATION_15S   (15000 * TIMER_TICK_1MS)
void hw_timer3_init(uint32_t tick_count)
    // Stop Timer 3 before configuring
    nrf_timer_task_trigger(NRF_TIMER3, NRF_TIMER_TASK_STOP);
    // Configure TIMER3 in Timer mode
    nrf_timer_mode_set(NRF_TIMER3, NRF_TIMER_MODE_TIMER);
    // Set frequency to 16 MHz
    nrf_timer_frequency_set(NRF_TIMER3, NRF_TIMER_FREQ_16MHz);
    // Set the timer to 32-bit mode
    nrf_timer_bit_width_set(NRF_TIMER3, NRF_TIMER_BIT_WIDTH_32);
    // Set the compare value (tick_count)
    nrf_timer_cc_write(NRF_TIMER3, NRF_TIMER_CC_CHANNEL3, tick_count);
    // Enable interrupt for compare event on channel 3
    nrf_timer_int_enable(NRF_TIMER3, NRF_TIMER_INT_COMPARE3_MASK);
    // Enable TIMER3 interrupt in NVIC
    NVIC_EnableIRQ(TIMER3_IRQn);
    // Configure the timer to auto-clear on compare match
    nrf_timer_shorts_enable(NRF_TIMER3, NRF_TIMER_SHORT_COMPARE3_CLEAR_MASK);
void TIMER3_IRQHandler(void)
    // Check for COMPARE3 event
    if (nrf_timer_event_check(NRF_TIMER3, NRF_TIMER_EVENT_COMPARE3))
        nrf_timer_event_clear(NRF_TIMER3, NRF_TIMER_EVENT_COMPARE3);  // Clear the event
        // Stop the timer
        // Set GPIO P1.03 high to indicate timer expiration
        nrf_gpio_pin_toggle(NRF_GPIO_PIN_MAP(1, PIN_P1_03));
Starting Timer 3 in main ()
    nrf_timer_task_trigger(NRF_TIMER3, NRF_TIMER_TASK_CLEAR);
    nrf_timer_task_trigger(NRF_TIMER3, NRF_TIMER_TASK_START);
  • Update:
    I have observed that if there is no processing or printing etc. in main() then the IRQ Handler is hit and if I had some logic like below in main loop,
    g_ticks = timer3_get_ticks();
    NRF_LOG_INFO("T3 g_ticks = %u ", g_ticks);
    then the Timer3 never goes into the IRQ handler and keeps on running.
    I also tried to implement single shot hardware timer using instance 1, channel 0 using PPI and GPIOTE.
    However the Timer continues to run even after the single shot period and never enters the ISR also.
    Tried both APIs
    rf_drv_timer_extended_compare()  and nrf_drv_timer_compare()
    The NRF_TIMER_SHORT_COMPARE0_STOP_MASK does not really stop the timer.
    The requirement is to use hardware timer for 30s or more and after it's expiry raise a GPIO
    #define TICKS_DURATION_30S             (30000 * TIMER_TICK_1MS)
    static void ppi_init(void)
        uint32_t err_code = NRF_SUCCESS;
        //Initialize the PPI driver
       // Allocate the first unused PPI channel
        err_code = nrf_drv_ppi_channel_alloc(&m_ppi_channel1);
        // Assigning task and event endpoints so that the PPI channel triggers the OUT task of the LED_1 GPIO pin on TIMER0 COMPARE[0] match.
        err_code = nrf_drv_ppi_channel_assign(m_ppi_channel1,
                                              nrf_drv_timer_event_address_get(&m_timer1, NRF_TIMER_EVENT_COMPARE0),
                                              nrf_drv_gpiote_out_task_addr_get(LED_1));
        // Enable the PPI channel
        err_code = nrf_drv_ppi_channel_enable(m_ppi_channel1);
    void timer1_event_handler(nrf_timer_event_t event_type, void * p_context)
        switch(event_type)
            case NRF_TIMER_EVENT_COMPARE0:
                nrf_drv_gpiote_out_task_trigger(LED_1);
                NRF_LOG_INFO("Toggle LED1 \r\n");
                // Do nothing.
    static void hw_timer1_init(void)
        ret_code_t err_code;
        // Configure the timer to use the default configuration set in sdk_config.h
        //Initializing the Timer driver
        err_code = nrf_drv_timer_init(&m_timer1, &timer_cfg, timer1_event_handler);
        /*Configure the timer to generate the COMPARE event after 200*1000UL ticks and enable the shortcut that triggers the CLEAR task on every COMPARE event. */
        // nrf_drv_timer_extended_compare(&m_timer1, NRF_TIMER_CC_CHANNEL0, TICKS_DURATION_30S, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK |NRF_TIMER_SHORT_COMPARE0_STOP_MASK, true); // Set last argument to false for Task 3
        nrf_drv_timer_compare(&m_timer1, NRF_TIMER_CC_CHANNEL0, TICKS_DURATION_30S, true);
        nrfx_timer_compare_int_enable(&m_timer1,NRF_TIMER_CC_CHANNEL0);
        // Turning on the Timer.
        nrf_drv_timer_enable(&m_timer1);
    static void gpiote_init(void)
        // Check wether the GPIOTE driver has been initialized before by any other module, e.g. app_button_init().
        if (!nrf_drv_gpiote_is_init())
            // Initialize the GPIOTE driver
        // Configure the GPIO pin so that its toggled every time the OUT task is triggerd
        nrf_drv_gpiote_out_config_t config = GPIOTE_CONFIG_OUT_TASK_TOGGLE(false);
        // Apply the configuration above to the LED_1 GPIO pin.
        err_code = nrf_drv_gpiote_out_init(LED_1, &config);
        // Enabling the OUT task for the LED_1 GPIO pin.
        nrf_drv_gpiote_out_task_enable(LED_1);
    int main()
        gpiote_init();  // Initialize GPIO
        ppi_init();     // Initialize PPI
        NRF_LOG_INFO("Init and Starting Timer 1");
        hw_timer1_init();
        for (;;)
            idle_state_handle();
            l_ticks = timer1_get_ticks();
            NRF_LOG_INFO(" l_ticks = %u", l_ticks);
            NRF_LOG_FLUSH();
            nrf_delay_ms(10000);
    I am not quite sure why it is not working, based on your snippets. Is it possible to upload the application?
    This doesn't make any sense to me. Do you mean "I have chosen Timer 3"? Each timer has it's own CC channels.
    Edvin
  • Initially was a bit unsure. Now I know that each Timer has own CC channel set.
    I can share the application in a private ticket.
    Thanks for your reply.
