There was no problem when the current version of ccache was 4.6.1. However, the current version of ccache, 4.10.2, behaves differently with the --specs option. It will do nothing at all with NCS. To correct this, I make this change
diff --git a/cmake/modules/ccache.cmake b/cmake/modules/ccache.cmake
index c1d41d6b9e4..14b9b683519 100644
--- a/cmake/modules/ccache.cmake
+++ b/cmake/modules/ccache.cmake
@@ -9,7 +9,7 @@ if(USE_CCACHE STREQUAL "0")
else()
find_program(CCACHE_FOUND ccache)
if(CCACHE_FOUND)
- set_property(GLOBAL PROPERTY RULE_LAUNCH_COMPILE ccache)
+ set_property(GLOBAL PROPERTY RULE_LAUNCH_COMPILE "ccache ignore_options=--specs=picolibc.specs")
set_property(GLOBAL PROPERTY RULE_LAUNCH_LINK ccache)
endif()
endif()
Thank you for any possible correction. I guess in the Linux case you include ccache in the Zephyr toolchain and it is a version that works.
Burt Silverman
