location application run time error and warnings
Hi!
I have built a sample application "location," got some warnings, and got runtime errors. I have attached a zip file with code and images.
I just have reinstalled nRF Connect Desktop, nRF Command Line Tools and VSC extension, I think I have some problems with my setup
My setup:
Updated Windows 11, Spanish
SDK 2.6.1 and 2.8.0
Any hints would be greatly appreciated.
location.zip
    It looks like your adding more to the sample, based on the .zip flie you added. Could you please elaborate? I have no issues building nrf\samples\cellular\location for the sparkfun_thing_plus/nrf9160/ns in nRF Connect SDK v2.8.0.
    What warnings and errors are you seeing exactly? Did you try without altering the location sample?
    Øyvind
  • Hello, Øyvind!
        I got some warnings, I dont get build time error, but run time errors.
    This is the serial terminal output:
    *** Booting nRF Connect SDK v3.5.99-ncs1-1 ***
    [00:00:00.257,659] .[0m<inf> gnss_sample: Starting GNSS sample.[0m
    [00:00:00.451,477] .[1;31m<err> lte_lc: Could not send AT command, error: 65536.[0m
    [00:00:00.458,831] .[1;31m<err> lte_lc: Failed to set system mode and mode preference, err -14.[0m
    [00:00:00.471,160] .[1;31m<err> gnss_sample: Failed to set GNSS NMEA mask.[0m
    [00:00:00.477,966] .[1;31m<err> gnss_sample: Failed to initialize and start GNSS.[0m
    Aside from the standard "Add build configuration" and prj.conf "CONFIG_BOOTLOADER_MCUBOOT=y," I haven't contributed any further configurations or code.
    The SparkFun board requires the "app_update.bin" file, then I use "newtmgr -c serial image upload build/zephyr/app_update.bin" to program the board.
    Maybe I should upgrade the SparkFun board firmware? How can I view the firmware version, please?
    I believe I have a problem, probably with my settings; I made no changes because I need a working app!
    I've installed and uninstalled the software more than six times and can't figure out what's wrong; might it be that I have Spanish Windows 11 Pro? I also installed on a Windows 10 Pro; I'm desperate; I'm about to lose my job since I've been trying to make it work for so long.
    Why do you think I changed something in the application? It could be a hint; any hints would be greatly appreciated.
    Thank you!
    Best regrds
    Thank you!
    Best regrds
