ncs 2.8.0 fails to build zephyr's bluetooth ISO_CENTRAL and ISO_PERIPHERAL samples on 52840DK
HW: 52840DK PCA10056 3.0.1 2023.16
NCS SDK: v2.8.0
I want to test Zephyr's BLE controller instead of the default SoftDevice controller, and the `prj.conf` of ISO_CENTRAL sample is configured as follows:
CONFIG_BT=y
CONFIG_LOG=y
CONFIG_BT_ISO_CENTRAL=y
CONFIG_BT_LL_SW_SPLIT=y
During the build there is an error `undefined reference to `__device_dts_ord_134`. Check the `build/iso_central/zephyr/include/generated/zephyr/devicetree_generated.h` file the ORD 134 corresponds to `/soc/radio@40001000/bt_hci_sdc`, which is SoftDevice controller. The SoftDevice controller should be disable when `CONFIG_BT_LL_SW_SPLIT=y` is set. Please help me clarify the underlying cause and resolve the issue.
Following is the build log
[231/236] Linking C executable zephyr/zephyr_pre0.elf
FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map /home/os-chiyuehlin/VSCodeProjects/iso_central/build/iso_central/zephyr/zephyr_pre0.map
: && ccache /home/os-chiyuehlin/ncs/toolchains/b81a7cd864/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -Os -DNDEBUG -gdwarf-4 zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr/zephyr_pre0.elf  zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj  -fuse-ld=bfd  -T  zephyr/linker_zephyr_pre0.cmd  -Wl,-Map=/home/os-chiyuehlin/VSCodeProjects/iso_central/build/iso_central/zephyr/zephyr_pre0.map  -Wl,--whole-archive  app/libapp.a  zephyr/libzephyr.a  zephyr/arch/common/libarch__common.a  zephyr/arch/arch/arm/core/libarch__arm__core.a  zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a  zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a  zephyr/lib/libc/picolibc/liblib__libc__picolibc.a  zephyr/lib/libc/common/liblib__libc__common.a  zephyr/lib/net_buf/liblib__net_buf.a  zephyr/soc/soc/nrf52840/libsoc__nordic.a  zephyr/subsys/random/libsubsys__random.a  zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a  zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a  zephyr/subsys/bluetooth/controller/libsubsys__bluetooth__controller.a  zephyr/subsys/bluetooth/controller/ll_sw/nordic/libsubsys__bluetooth__controller__ll_sw__nordic.a  zephyr/drivers/clock_control/libdrivers__clock_control.a  zephyr/drivers/console/libdrivers__console.a  zephyr/drivers/entropy/libdrivers__entropy.a  zephyr/drivers/gpio/libdrivers__gpio.a  zephyr/drivers/pinctrl/libdrivers__pinctrl.a  zephyr/drivers/serial/libdrivers__serial.a  zephyr/drivers/timer/libdrivers__timer.a  modules/nrf/drivers/hw_cc3xx/lib..__nrf__drivers__hw_cc3xx.a  modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a  modules/segger/libmodules__segger.a  -Wl,--no-whole-archive  zephyr/kernel/libkernel.a  -L"/home/os-chiyuehlin/ncs/toolchains/b81a7cd864/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/thumb/v7e-m/nofp"  -L/home/os-chiyuehlin/VSCodeProjects/iso_central/build/iso_central/zephyr  -lgcc  zephyr/arch/common/libisr_tables.a  -mcpu=cortex-m4  -mthumb  -mabi=aapcs  -mfp16-format=ieee  -mtp=soft  -Wl,--gc-sections  -Wl,--build-id=none  -Wl,--sort-common=descending  -Wl,--sort-section=alignment  -Wl,-u,_OffsetAbsSyms  -Wl,-u,_ConfigAbsSyms  -nostdlib  -static  -Wl,-X  -Wl,-N  -Wl,--orphan-handling=warn  -Wl,-no-pie  -DPICOLIBC_LONG_LONG_PRINTF_SCANF  /home/os-chiyuehlin/ncs/v2.8.0/nrfxlib/crypto/nrf_cc310_platform/lib/cortex-m4/soft-float/no-interrupts/libnrf_cc310_platform_0.9.19.a  --specs=picolibc.specs  -lc  -lgcc && cd /home/os-chiyuehlin/VSCodeProjects/iso_central/build/iso_central/zephyr && /home/os-chiyuehlin/ncs/toolchains/b81a7cd864/usr/local/bin/cmake -E true
/home/os-chiyuehlin/ncs/toolchains/b81a7cd864/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_core.c.obj):(.data.bt_dev+0x184): undefined reference to `__device_dts_ord_134'
collect2: error: ld returned 1 exit status
FAILED: _sysbuild/sysbuild/images/iso_central-prefix/src/iso_central-stamp/iso_central-build /home/os-chiyuehlin/VSCodeProjects/iso_central/build/_sysbuild/sysbuild/images/iso_central-prefix/src/iso_central-stamp/iso_central-build
cd /home/os-chiyuehlin/VSCodeProjects/iso_central/build/iso_central && /home/os-chiyuehlin/ncs/toolchains/b81a7cd864/usr/local/bin/cmake --build .
FATAL ERROR: command exited with status 1: /home/os-chiyuehlin/ncs/toolchains/b81a7cd864/usr/local/bin/cmake --build /home/os-chiyuehlin/VSCodeProjects/iso_central/build
    That does indeed look like a bug. I see from the devicetree_generated.h that 133 refers to bt_hci_controller, which I assume should be used instead.
    Please note that we do not certify the Zephyr Bluetooth Controller, so it will be a lot harder to certify a product using this (and quite a lot more costly). So I don't really see any good reasons to use this BLE controller in the first place.
    However, that doesn't mean it shouldn't build. I will report this back to our SDK team.
    Edvin
  • Ok, after discussing with our developers, it seems like it is not a bug. From 2.8.0 you need to  build using the snippet "bt-ll-sw-split" in order to build with the Zephyr Bluetooth LE Controller. In some samples, such as the ISO_central sample, you also need to add the .conf file: overlay-bt_ll_sw_split.conf (if they are present).
    How you include these are dependent on how you are setting up your build configuration. If you are using the VS Code plugin, there are drop down menus when creating your build configuration. In that case, you should select the "Extra Kconfig fragments", and select the overlay-bt_ll_sw_split.conf. Similarly, under "Snippets", click "add snippet", and select the bt-ll-sw-split. In both cases, remember to click "ok", for it to actually be included.
    If you are using command line directly to build, you can add these arguments:
    -DSNIPPET="bt-ll-sw-split" -DEXTRA_CONF_FILE=overlay-bt_ll_sw_split.conf
    Edvin
  • Thanks for your and SDK Team's timely response! After pull the latest sdk-zephyr code and modify some codes. Now both ISO_CENTRAL and ISO_PERIPHERAL sample codes can be successfully compiled. The code I modified is `sample.yaml`, I added nrf52840dk/nrf52840 to platform_allow: and integration_platforms: sections, otherwise there's no bt-ll-sw-split snippet for board nrf52840dk/nrf52840 in the build configuration.
  • The snippets are found in ncs\zephyr\snippets, or probably zephyr\snippets if you are using zephyr directly. Are you using nRF Connect for Visual Studio? Or are you building using command line directly?
    Were you able to build using the snippet? If not, were you not able to select it? Did it cause a build error? If so, can you please share the build log?
    But again, we at Nordic don't recommend using the zephyr BLE controller. In fact, it is not officially supported on our HW.
    Edvin
  • I'm using nRF Connect for Visual Studio.  By default board target `nrf52840dk/nrf52840` has no `bt-ll-sw-split` option in `Add Snippet`, only `nrf52833dk/nrf52833` has. I had tried several setups:
    1. board target `nrf52840dk/nrf52840`:
    "Extra Kconfig fragments",: `overlay-bt_ll_sw_split.conf`
    "Snippets": empty
    => the undefined reference to `__device_dts_ord_134' issue persists.
    2. board target `nrf52833dk/nrf52833`:
    "Extra Kconfig fragments" `overlay-bt_ll_sw_split.conf`
    "Snippets" `bt-ll-sw-split`
    => build successfully and the program can be flashed to my nrf52840dk.
    It took me a while to realize why nrf52833dk has `bt-ll-sw-split` option, and then I modified `sample.yaml` accordingly so the Snippet `bt-ll-sw-split` finally shown up in `Add Snippet` for board nrf52840dk. With this change the build is successful for my nrf52840dk.
    Also thanks for your recommendation on the BLE controller, we use Zephyr BLE controller just for educational purpose.
    Best regards
