nrfutil device list command fails
I just freshly (Nov 25, 2024) installed the nrfutil 'core' exe and the nrfutil device command.
I try to list my nrf devices (a nrf52840 dongle is connected and another nrf52840 through jlink), but the command fails:
$ nrfutil device list
thread '<unnamed>' panicked at src\serialport\module\src\windows.rs:118:55:
called `Option::unwrap()` on a `None` value
note: run with `RUST_BACKTRACE=1` environment variable to display a backtrace
thread '<unnamed>' panicked at core\src\panicking.rs:221:5:
panic in a function that cannot unwind
stack backtrace:
0: 0x7ffcc9b646a1 - nrfdl_plugin_identifier
1: 0x7ffcc9b760d9 - nrfdl_plugin_identifier
2: 0x7ffcc9b62de7 - nrfdl_plugin_identifier
3: 0x7ffcc9b65ea9 - nrfdl_plugin_identifier
4: 0x7ffcc9b65a2c - nrfdl_plugin_identifier
5: 0x7ffcc9b66722 - nrfdl_plugin_identifier
6: 0x7ffcc9b665bf - nrfdl_plugin_identifier
7: 0x7ffcc9b64def - nrfdl_plugin_identifier
8: 0x7ffcc9b66206 - nrfdl_plugin_identifier
9: 0x7ffcc9b84e6d - nrfdl_plugin_identifier
10: 0x7ffcc9b84f13 - nrfdl_plugin_identifier
11: 0x7ffcc9b84fab - nrfdl_plugin_identifier
12: 0x7ffcc9a6dcab - nrfdl_plugin_enumerate
13: 0x7ffcf43b1060 - <unknown>
14: 0x7ffcf43b4d38 - is_exception_typeof
15: 0x7ffd491149c6 - RtlCaptureContext2
16: 0x7ffcc9a6d946 - nrfdl_plugin_enumerate
17: 0x7ffd0f02933a - <unknown>
18: 0x7ffd0f0268bd - <unknown>
19: 0x7ffd0f023e86 - <unknown>
20: 0x7ffd0f023b6f - <unknown>
21: 0x7ffd0f004553 - <unknown>
22: 0x7ffd0f024822 - <unknown>
23: 0x7ffd0f027e03 - <unknown>
24: 0x7ffd0f004e64 - <unknown>
25: 0x7ffd0f003918 - <unknown>
26: 0x7ffd1da229a9 - Concurrency::details::_Schedule_chore
27: 0x7ffd490d287a - RtlHashUnicodeString
28: 0x7ffd490a5e46 - RtlClearThreadWorkOnBehalfTicket
29: 0x7ffd46ee257d - BaseThreadInitThunk
30: 0x7ffd490caf08 - RtlUserThreadStart
thread caused non-unwinding panic. aborting.
Error: Subprocess C:\Users\ronaldh\.nrfutil\bin\nrfutil-device.exe failed with unexpected exit code Some(-1073740791)
Setting the RUST_BACKTRACE env-var produces the extra:
Stack backtrace:
0: git_odb_object_data
1: git_odb_object_data
2: git_midx_writer_new
3: <unknown>
4: <unknown>
5: <unknown>
6: <unknown>
7: git_odb_object_data
8: <unknown>
9: git_midx_writer_new
10: BaseThreadInitThunk
11: RtlUserThreadStart
Unplugging either or both connected nrf devices from USB doesn't change the behavior.
What gives?
NOTE: programming the nrf52840 dongle using the programmer tool in "nrf connect desktop" is just fine.
    Ronald Hoogenboom said:
    Not much, there is still:
    [2025-02-18T12:40:49.073Z] [27268] DEBUG - [serialport] No com name found for \\?\USB#VID_04E8&PID_6860&Modem#7&225ecf2a&0&0001#{86e0d1e0-8089-11d0-9ce4-08003e301f73}
    Can you provide more information about *No com name found*? What was your test setup in this case?
    I cooked up some demonstration code that uses the 'Device Parameters'.PortName to find the com name.
    usbserial.cpp
    Can you elaborate on what this sample (demo code) demonstrates?
    Dejan
  • My setup included the samsung phone on the USB bus. The line was copied from the 2251.nrfutil-device.log I attached earlier. The "No com name found" line is for the samsung phone, which has com3.
    The sample demo code shows how to get to the correct com name for devices like the samsung phone that don't put the com name in the FriendlyName property using the windows API. Using this method, the nrf-device.exe can be made more 'reliable', although it might be questionable if any serial devices that have drivers that don't put the com name in the FriendlyName will ever be "supported" by nrfutil.
    Indeed if you ask CoPilot how to get the com port name for usb attached serial devices in windows, he suggests to parse the FriendlyName property too at first, so I guess it is quite common practice to do that. Obviously, common practice doesn't always represent best practice.
    For now, just ignoring all serial devices that don't have a com name somewhere in the FriendlyName property instead of crashing if such a device is encountered is an acceptable improvement.
    Thank you for additional information and your feedback.
    Do you have any further questions? Can we consider your initial issue resolved?
    Dejan
  • yes, the initial issue is resolved. Just my suggestion for further improvement remains and it is up to you if you want to take that suggestion. I think I have provided enough information so that it is clear what that suggestion is exactly.
    Thank you for your feedback and suggestion for further improvement. I have forwarded your suggestion internally and relevant team will look into it.
    Dejan
