nrfutil device list command fails
I just freshly (Nov 25, 2024) installed the nrfutil 'core' exe and the nrfutil device command.
I try to list my nrf devices (a nrf52840 dongle is connected and another nrf52840 through jlink), but the command fails:
$ nrfutil device list
thread '<unnamed>' panicked at src\serialport\module\src\windows.rs:118:55:
called `Option::unwrap()` on a `None` value
note: run with `RUST_BACKTRACE=1` environment variable to display a backtrace
thread '<unnamed>' panicked at core\src\panicking.rs:221:5:
panic in a function that cannot unwind
stack backtrace:
0: 0x7ffcc9b646a1 - nrfdl_plugin_identifier
1: 0x7ffcc9b760d9 - nrfdl_plugin_identifier
2: 0x7ffcc9b62de7 - nrfdl_plugin_identifier
3: 0x7ffcc9b65ea9 - nrfdl_plugin_identifier
4: 0x7ffcc9b65a2c - nrfdl_plugin_identifier
5: 0x7ffcc9b66722 - nrfdl_plugin_identifier
6: 0x7ffcc9b665bf - nrfdl_plugin_identifier
7: 0x7ffcc9b64def - nrfdl_plugin_identifier
8: 0x7ffcc9b66206 - nrfdl_plugin_identifier
9: 0x7ffcc9b84e6d - nrfdl_plugin_identifier
10: 0x7ffcc9b84f13 - nrfdl_plugin_identifier
11: 0x7ffcc9b84fab - nrfdl_plugin_identifier
12: 0x7ffcc9a6dcab - nrfdl_plugin_enumerate
13: 0x7ffcf43b1060 - <unknown>
14: 0x7ffcf43b4d38 - is_exception_typeof
15: 0x7ffd491149c6 - RtlCaptureContext2
16: 0x7ffcc9a6d946 - nrfdl_plugin_enumerate
17: 0x7ffd0f02933a - <unknown>
18: 0x7ffd0f0268bd - <unknown>
19: 0x7ffd0f023e86 - <unknown>
20: 0x7ffd0f023b6f - <unknown>
21: 0x7ffd0f004553 - <unknown>
22: 0x7ffd0f024822 - <unknown>
23: 0x7ffd0f027e03 - <unknown>
24: 0x7ffd0f004e64 - <unknown>
25: 0x7ffd0f003918 - <unknown>
26: 0x7ffd1da229a9 - Concurrency::details::_Schedule_chore
27: 0x7ffd490d287a - RtlHashUnicodeString
28: 0x7ffd490a5e46 - RtlClearThreadWorkOnBehalfTicket
29: 0x7ffd46ee257d - BaseThreadInitThunk
30: 0x7ffd490caf08 - RtlUserThreadStart
thread caused non-unwinding panic. aborting.
Error: Subprocess C:\Users\ronaldh\.nrfutil\bin\nrfutil-device.exe failed with unexpected exit code Some(-1073740791)
Setting the RUST_BACKTRACE env-var produces the extra:
Stack backtrace:
0: git_odb_object_data
1: git_odb_object_data
2: git_midx_writer_new
3: <unknown>
4: <unknown>
5: <unknown>
6: <unknown>
7: git_odb_object_data
8: <unknown>
9: git_midx_writer_new
10: BaseThreadInitThunk
11: RtlUserThreadStart
Unplugging either or both connected nrf devices from USB doesn't change the behavior.
What gives?
NOTE: programming the nrf52840 dongle using the programmer tool in "nrf connect desktop" is just fine.
  • My system:
    $ uname minus a
    MINGW64_NT-10.0-22631 LT-GYW2LX3 3.4.10.x86_64 2023-12-22 10:06 UTC x86_64 Msys
    $ powershell -Command "Get-CimInstance -ClassName Win32_OperatingSystem | Select-Object Caption, Version, BuildNumber, OSArchitecture"
    Caption Version BuildNumber OSArchitecture
    Microsoft Windows 11 Business 10.0.22631 22631 64-bit
  • Sorry for the fragmented answer. I keep getting "An error occured" notifications and had to trial and error which parts of my answer are causing that.
    Thank you for additional information.
    Can you check if you get the same error when using nrfutil from this webpage?
    Dejan
  • I downloaded the nrfutil from your link and get EXACTLY the same binary as I got from curl. Same md5sum and everything.
    Maybe the strace of a run of nrfutil device list can help:
    --- Process 25596 created
    --- Process 25596 loaded C:\Windows\System32\ntdll.dll at 00007ffd49070000
    --- Process 25596 loaded C:\Windows\System32\kernel32.dll at 00007ffd46ed0000
    --- Process 25596 loaded C:\Windows\System32\KernelBase.dll at 00007ffd467d0000
    --- Process 25596 loaded C:\Windows\System32\bcryptprimitives.dll at 00007ffd46b90000
    --- Process 25596 thread 19832 created
    --- Process 25596 loaded C:\Windows\System32\advapi32.dll at 00007ffd47c40000
    --- Process 25596 loaded C:\Windows\System32\msvcrt.dll at 00007ffd471d0000
    --- Process 25596 loaded C:\Windows\System32\sechost.dll at 00007ffd47d00000
    --- Process 25596 loaded C:\Windows\System32\bcrypt.dll at 00007ffd46680000
    --- Process 25596 thread 17732 created
    --- Process 25596 loaded C:\Windows\System32\rpcrt4.dll at 00007ffd470b0000
    --- Process 25596 loaded C:\Windows\System32\ws2_32.dll at 00007ffd46dd0000
    --- Process 25596 loaded C:\Windows\System32\crypt32.dll at 00007ffd46510000
    --- Process 25596 loaded C:\Windows\System32\ucrtbase.dll at 00007ffd46c10000
    --- Process 25596 thread 31112 created
    --- Process 25596 loaded C:\Windows\System32\secur32.dll at 00007ffd45080000
    --- Process 25596 loaded C:\Windows\System32\shell32.dll at 00007ffd473a0000
    --- Process 25596 loaded C:\Windows\System32\msvcp_win.dll at 00007ffd46470000
    --- Process 25596 loaded C:\Windows\System32\user32.dll at 00007ffd486e0000
    --- Process 25596 loaded C:\Windows\System32\win32u.dll at 00007ffd46440000
    --- Process 25596 loaded C:\Windows\System32\gdi32.dll at 00007ffd46da0000
    --- Process 25596 loaded C:\Windows\System32\gdi32full.dll at 00007ffd466b0000
    --- Process 25596 loaded C:\Windows\System32\ole32.dll at 00007ffd47e10000
    --- Process 25596 loaded C:\Windows\System32\combase.dll at 00007ffd48980000
    --- Process 25596 loaded C:\Windows\System32\vcruntime140.dll at 00007ffcf43b0000
    --- Process 25596 loaded C:\Windows\System32\cryptbase.dll at 00007ffd45b20000
    --- Process 25596 loaded C:\Windows\System32\sspicli.dll at 00007ffd45640000
    --- Process 25596 loaded C:\Windows\System32\imm32.dll at 00007ffd47fc0000
    --- Process 14760 created
    --- Process 14760 loaded C:\Windows\System32\ntdll.dll at 00007ffd49070000
    --- Process 14760 loaded C:\Windows\System32\kernel32.dll at 00007ffd46ed0000
    --- Process 14760 loaded C:\Windows\System32\KernelBase.dll at 00007ffd467d0000
    --- Process 14760 loaded C:\Windows\System32\advapi32.dll at 00007ffd47c40000
    --- Process 14760 loaded C:\Windows\System32\msvcrt.dll at 00007ffd471d0000
    --- Process 14760 thread 19964 created
    --- Process 14760 loaded C:\Windows\System32\sechost.dll at 00007ffd47d00000
    --- Process 14760 loaded C:\Windows\System32\bcrypt.dll at 00007ffd46680000
    --- Process 14760 thread 32872 created
    --- Process 14760 loaded C:\Windows\System32\rpcrt4.dll at 00007ffd470b0000
    --- Process 14760 loaded C:\Windows\System32\user32.dll at 00007ffd486e0000
    --- Process 14760 loaded C:\Windows\System32\win32u.dll at 00007ffd46440000
    --- Process 14760 loaded C:\Windows\System32\gdi32.dll at 00007ffd46da0000
    --- Process 14760 loaded C:\Windows\System32\gdi32full.dll at 00007ffd466b0000
    --- Process 14760 loaded C:\Windows\System32\msvcp_win.dll at 00007ffd46470000
    --- Process 14760 loaded C:\Windows\System32\ucrtbase.dll at 00007ffd46c10000
    --- Process 14760 thread 30668 created
    --- Process 14760 loaded C:\Windows\System32\ole32.dll at 00007ffd47e10000
    --- Process 14760 loaded C:\Windows\System32\combase.dll at 00007ffd48980000
    --- Process 14760 loaded C:\Windows\System32\crypt32.dll at 00007ffd46510000
    --- Process 14760 loaded C:\Windows\System32\winhttp.dll at 00007ffd452c0000
    --- Process 14760 loaded C:\Windows\System32\ws2_32.dll at 00007ffd46dd0000
    --- Process 14760 loaded C:\Windows\System32\shell32.dll at 00007ffd473a0000
    --- Process 14760 loaded C:\Windows\System32\secur32.dll at 00007ffd45080000
    --- Process 14760 loaded C:\Windows\System32\vcruntime140.dll at 00007ffcf43b0000
    --- Process 14760 loaded C:\Windows\System32\cryptbase.dll at 00007ffd45b20000
    --- Process 14760 loaded C:\Windows\System32\sspicli.dll at 00007ffd45640000
    --- Process 14760 loaded C:\Windows\System32\imm32.dll at 00007ffd47fc0000
    --- Process 14760 loaded C:\Windows\System32\IPHLPAPI.DLL at 00007ffd44af0000
    --- Process 14760 loaded C:\Windows\System32\bcryptprimitives.dll at 00007ffd46b90000
    --- Process 35548 created
    --- Process 35548 loaded C:\Windows\System32\ntdll.dll at 00007ffd49070000
    --- Process 35548 loaded C:\Windows\System32\kernel32.dll at 00007ffd46ed0000
    --- Process 35548 loaded C:\Windows\System32\KernelBase.dll at 00007ffd467d0000
    --- Process 35548 loaded C:\Windows\System32\bcryptprimitives.dll at 00007ffd46b90000
    --- Process 35548 thread 7992 created
    --- Process 35548 loaded C:\Windows\System32\advapi32.dll at 00007ffd47c40000
    --- Process 35548 loaded C:\Windows\System32\msvcrt.dll at 00007ffd471d0000
    --- Process 35548 loaded C:\Windows\System32\sechost.dll at 00007ffd47d00000
    --- Process 35548 loaded C:\Windows\System32\bcrypt.dll at 00007ffd46680000
    --- Process 35548 thread 32412 created
    --- Process 35548 loaded C:\Windows\System32\rpcrt4.dll at 00007ffd470b0000
    --- Process 35548 loaded C:\Windows\System32\shell32.dll at 00007ffd473a0000
    --- Process 35548 loaded C:\Windows\System32\msvcp_win.dll at 00007ffd46470000
    --- Process 35548 loaded C:\Windows\System32\ucrtbase.dll at 00007ffd46c10000
    --- Process 35548 loaded C:\Windows\System32\user32.dll at 00007ffd486e0000
    --- Process 35548 loaded C:\Windows\System32\win32u.dll at 00007ffd46440000
    --- Process 35548 loaded C:\Windows\System32\gdi32.dll at 00007ffd46da0000
    --- Process 35548 loaded C:\Windows\System32\gdi32full.dll at 00007ffd466b0000
    --- Process 35548 thread 33568 created
    --- Process 35548 loaded C:\Windows\System32\ole32.dll at 00007ffd47e10000
    --- Process 35548 loaded C:\Windows\System32\combase.dll at 00007ffd48980000
    --- Process 35548 loaded C:\Windows\System32\vcruntime140.dll at 00007ffcf43b0000
    --- Process 35548 loaded C:\Users\ronaldh\.nrfutil\lib\nrfutil-device\nrfdl.dll at 00007ffccb0d0000
    --- Process 35548 loaded C:\Windows\System32\cryptbase.dll at 00007ffd45b20000
    --- Process 35548 loaded C:\Windows\System32\setupapi.dll at 00007ffd48180000
    --- Process 35548 loaded C:\Windows\System32\oleaut32.dll at 00007ffd48600000
    --- Process 35548 loaded C:\Users\ronaldh\.nrfutil\lib\nrfutil-device\spdlog.dll at 00007ffd1e440000
    --- Process 35548 loaded C:\Windows\System32\cfgmgr32.dll at 00007ffd45f80000
    --- Process 35548 loaded C:\Users\ronaldh\.nrfutil\lib\nrfutil-device\fmt.dll at 00007ffd1ef30000
    --- Process 35548 loaded C:\Windows\System32\msvcp140.dll at 00007ffd1da10000
    --- Process 35548 loaded C:\Windows\System32\vcruntime140_1.dll at 00007ffd2aae0000
    --- Process 35548 loaded C:\Windows\System32\vcruntime140_1.dll at 0000025a16960000
    --- Process 35548 unloaded DLL at 0000025a16960000
    --- Process 35548 loaded C:\Windows\System32\imm32.dll at 00007ffd47fc0000
    --- Process 35548 thread 18056 created
    --- Process 35548 thread 34628 created
    --- Process 35548 thread 27488 created
    --- Process 35548 thread 27104 created
    --- Process 35548 thread 25172 created
    --- Process 35548 thread 33248 created
    --- Process 35548 thread 35580 created
    --- Process 35548 thread 20388 created
    --- Process 35548 thread 14140 created
    --- Process 35548 thread 34868 created
    --- Process 35548 thread 17476 created
    --- Process 35548 thread 368 created
    --- Process 35548 thread 28956 created
    --- Process 35548 thread 32788 created
    --- Process 35548 loaded C:\Windows\System32\kernel.appcore.dll at 00007ffd452a0000
    --- Process 35548 loaded C:\Users\ronaldh\.nrfutil\lib\nrfutil-device\01-nrfdl-devkit-plugin.nrfdl at 00007ffcc1570000
    --- Process 35548 loaded C:\Users\ronaldh\.nrfutil\lib\nrfutil-device\05-nrfdl-probe-plugin.nrfdl at 00007ffcbbef0000
    --- Process 35548 loaded C:\Users\ronaldh\.nrfutil\lib\nrfutil-device\10-nrfdl-jlink-plugin.nrfdl at 00007ffcf8d10000
    --- Process 35548 loaded C:\Users\ronaldh\.nrfutil\lib\nrfutil-device\nrfjprog.dll at 00007ffcba9e0000
    --- Process 35548 loaded C:\Windows\System32\ws2_32.dll at 00007ffd46dd0000
    --- Process 35548 loaded C:\Users\ronaldh\.nrfutil\lib\nrfutil-device\11-nrfdl-boardcontroller-plugin.nrfdl at 00007ffcd6460000
    --- Process 35548 loaded C:\Users\ronaldh\.nrfutil\lib\nrfutil-device\12-nrfdl-serialport-plugin.nrfdl at 00007ffcbd320000
    --- Process 35548 loaded C:\Users\ronaldh\.nrfutil\lib\nrfutil-device\13-nrfdl-sdfu-plugin.nrfdl at 00007ffd03f60000
    --- Process 35548 loaded C:\Users\ronaldh\.nrfutil\lib\nrfutil-device\zip.dll at 00007ffd3a0d0000
    --- Process 35548 loaded C:\Windows\System32\winusb.dll at 00007ffd43cf0000
    --- Process 35548 loaded C:\Users\ronaldh\.nrfutil\lib\nrfutil-device\zlib1.dll at 00007ffd3a040000
    --- Process 35548 loaded C:\Users\ronaldh\.nrfutil\lib\nrfutil-device\bz2.dll at 00007ffd0e3f0000
    --- Process 35548 loaded C:\Users\ronaldh\.nrfutil\lib\nrfutil-device\14-nrfdl-mcuboot-plugin.nrfdl at 00007ffcd31b0000
    --- Process 35548 loaded C:\Users\ronaldh\.nrfutil\lib\nrfutil-device\98-nrfdl-broken-plugin.nrfdl at 00007ffd04860000
    --- Process 35548 thread 29404 created
    --- Process 35548 loaded C:\Windows\System32\uxtheme.dll at 00007ffd42e20000
    --- Process 35548 loaded C:\Program Files\SEGGER\JLink\JLink_x64.dll at 00007ffc95540000
    --- Process 35548 loaded C:\Windows\System32\IPHLPAPI.DLL at 00007ffd44af0000
    --- Process 35548 loaded C:\Windows\System32\hid.dll at 00007ffd448d0000
    --- Process 35548 loaded C:\Windows\System32\winmm.dll at 00007ffd439a0000
    --- Process 35548 thread 35272 created
    --- Process 35548 thread 21048 created
    --- Process 35548 thread 3940 created
    --- Process 30532 created
    --- Process 30532 loaded C:\Windows\System32\ntdll.dll at 00007ffd49070000
    --- Process 30532 loaded C:\Windows\System32\kernel32.dll at 00007ffd46ed0000
    --- Process 30532 loaded C:\Windows\System32\KernelBase.dll at 00007ffd467d0000
    --- Process 13888 created
    --- Process 13888 loaded C:\Windows\System32\ntdll.dll at 00007ffd49070000
    --- Process 13888 loaded C:\Windows\System32\kernel32.dll at 00007ffd46ed0000
    --- Process 13888 loaded C:\Windows\System32\KernelBase.dll at 00007ffd467d0000
    --- Process 13888 loaded C:\Windows\System32\msvcp_win.dll at 00007ffd46470000
    --- Process 13888 loaded C:\Windows\System32\ucrtbase.dll at 00007ffd46c10000
    --- Process 13888 thread 15832 created
    --- Process 13888 thread 28216 created
    --- Process 13888 loaded C:\Windows\System32\advapi32.dll at 00007ffd47c40000
    --- Process 13888 loaded C:\Windows\System32\msvcrt.dll at 00007ffd471d0000
    --- Process 13888 loaded C:\Windows\System32\sechost.dll at 00007ffd47d00000
    --- Process 13888 loaded C:\Windows\System32\bcrypt.dll at 00007ffd46680000
    --- Process 13888 loaded C:\Windows\System32\rpcrt4.dll at 00007ffd470b0000
    --- Process 13888 loaded C:\Windows\System32\combase.dll at 00007ffd48980000
    --- Process 13888 loaded C:\Windows\System32\user32.dll at 00007ffd486e0000
    --- Process 13888 loaded C:\Windows\System32\win32u.dll at 00007ffd46440000
    --- Process 13888 loaded C:\Windows\System32\gdi32.dll at 00007ffd46da0000
    --- Process 13888 loaded C:\Windows\System32\gdi32full.dll at 00007ffd466b0000
    --- Process 13888 loaded C:\Windows\System32\imm32.dll at 00007ffd47fc0000
    --- Process 13888 thread 31164 created
    --- Process 13888 thread 15832 exited with status 0x0
    --- Process 13888 thread 28216 exited with status 0x0
    --- Process 13888 thread 14468 exited with status 0x0
    --- Process 13888 loaded C:\Windows\System32\shell32.dll at 00007ffd473a0000
    --- Process 13888 thread 32856 created
    --- Process 13888 loaded C:\Windows\System32\uxtheme.dll at 00007ffd42e20000
    --- Process 13888 thread 19600 created
    --- Process 30532 loaded C:\Windows\System32\ws2_32.dll at 00007ffd46dd0000
    --- Process 30532 loaded C:\Windows\System32\rpcrt4.dll at 00007ffd470b0000
    --- Process 30532 thread 20852 created
    --- Process 30532 thread 35484 created
    --- Process 30532 thread 28380 created
    --- Process 30532 loaded C:\Windows\System32\bcrypt.dll at 00007ffd46680000
    --- Process 30532 loaded C:\Windows\System32\advapi32.dll at 00007ffd47c40000
    --- Process 30532 loaded C:\Windows\System32\cfgmgr32.dll at 00007ffd45f80000
    --- Process 30532 loaded C:\Windows\System32\msvcrt.dll at 00007ffd471d0000
    --- Process 30532 loaded C:\Windows\System32\ucrtbase.dll at 00007ffd46c10000
    --- Process 30532 loaded C:\Windows\System32\sechost.dll at 00007ffd47d00000
    --- Process 30532 loaded C:\Windows\System32\ole32.dll at 00007ffd47e10000
    --- Process 30532 loaded C:\Windows\System32\msvcp_win.dll at 00007ffd46470000
    --- Process 30532 loaded C:\Windows\System32\gdi32.dll at 00007ffd46da0000
    --- Process 30532 loaded C:\Windows\System32\win32u.dll at 00007ffd46440000
    --- Process 30532 loaded C:\Windows\System32\gdi32full.dll at 00007ffd466b0000
    --- Process 30532 loaded C:\Windows\System32\user32.dll at 00007ffd486e0000
    --- Process 30532 loaded C:\Windows\System32\combase.dll at 00007ffd48980000
    --- Process 30532 loaded C:\Windows\System32\oleaut32.dll at 00007ffd48600000
    --- Process 30532 loaded C:\Windows\System32\vcruntime140_1.dll at 00007ffd2aae0000
    --- Process 30532 loaded C:\Windows\System32\msvcp140.dll at 00007ffd1da10000
    --- Process 30532 loaded C:\Windows\System32\vcruntime140.dll at 0000024bc2080000
    --- Process 30532 loaded C:\Windows\System32\vcruntime140.dll at 00007ffcf43b0000
    --- Process 30532 unloaded DLL at 0000024bc2080000
    --- Process 30532 loaded C:\Windows\System32\imm32.dll at 00007ffd47fc0000
    --- Process 30532 thread 12448 created
    --- Process 30532 loaded C:\Windows\System32\kernel.appcore.dll at 00007ffd452a0000
    --- Process 30532 thread 14896 created
    --- Process 30532 loaded C:\Program Files\SEGGER\JLink\JLink_x64.dll at 00007ffc95540000
    --- Process 30532 loaded C:\Windows\System32\shell32.dll at 00007ffd473a0000
    --- Process 30532 loaded C:\Windows\System32\setupapi.dll at 00007ffd48180000
    --- Process 30532 loaded C:\Windows\System32\IPHLPAPI.DLL at 00007ffd44af0000
    --- Process 30532 loaded C:\Windows\System32\hid.dll at 00007ffd448d0000
    --- Process 30532 loaded C:\Windows\System32\winmm.dll at 00007ffd439a0000
    --- Process 30532 unloaded DLL at 00007ffd439a0000
    --- Process 30532 loaded C:\Windows\System32\shlwapi.dll at 00007ffd47db0000
    --- Process 30532 unloaded DLL at 00007ffd47db0000
    --- Process 30532 unloaded DLL at 00007ffd473a0000
    --- Process 30532 unloaded DLL at 00007ffd48180000
    --- Process 30532 unloaded DLL at 00007ffd448d0000
    --- Process 30532 unloaded DLL at 00007ffd44af0000
    --- Process 30532 unloaded DLL at 00007ffc95540000
    --- Process 30532 thread 12448 exited with status 0x0
    --- Process 30532 thread 14896 exited with status 0x0
    --- Process 30532, exception e06d7363 at 00007ffd4682fe4c
    --- Process 30532 thread 28380 exited with status 0x0
    --- Process 30532 thread 35484 exited with status 0x0
    --- Process 30532 thread 20852 exited with status 0x0
    --- Process 30532 exited with status 0x0
    --- Process 13888 thread 32856 exited with status 0x0
    --- Process 13888 thread 19600 exited with status 0x0
    --- Process 35548 thread 3940 exited with status 0x0
    --- Process 13888 exited with status 0x0
    --- Process 35548 thread 21048 exited with status 0x0
    --- Process 35548 thread 35272 exited with status 0x0
    --- Process 35548 thread 21916 created
    --- Process 35548 loaded C:\Windows\System32\devobj.dll at 00007ffd45f50000
    --- Process 35548 loaded C:\Windows\System32\wintrust.dll at 00007ffd46d30000
    --- Process 35548 loaded C:\Windows\System32\crypt32.dll at 00007ffd46510000
    --- Process 35548 loaded C:\Windows\System32\msasn1.dll at 00007ffd45b90000
    --- Process 35548 thread 4472 created
    --- Process 35548 thread 29292 created
    --- Process 35548 thread 30312 created
    --- Process 30028 created
    --- Process 30028 loaded C:\Windows\System32\ntdll.dll at 00007ffd49070000
    --- Process 30028 loaded C:\Windows\System32\kernel32.dll at 00007ffd46ed0000
    --- Process 30028 loaded C:\Windows\System32\KernelBase.dll at 00007ffd467d0000
    --- Process 30732 created
    --- Process 30732 loaded C:\Windows\System32\ntdll.dll at 00007ffd49070000
    --- Process 30732 loaded C:\Windows\System32\kernel32.dll at 00007ffd46ed0000
    --- Process 30732 loaded C:\Windows\System32\KernelBase.dll at 00007ffd467d0000
    --- Process 30732 loaded C:\Windows\System32\msvcp_win.dll at 00007ffd46470000
    --- Process 30732 loaded C:\Windows\System32\ucrtbase.dll at 00007ffd46c10000
    --- Process 30732 thread 30776 created
    --- Process 30732 thread 34956 created
    --- Process 30732 loaded C:\Windows\System32\advapi32.dll at 00007ffd47c40000
    --- Process 30732 loaded C:\Windows\System32\msvcrt.dll at 00007ffd471d0000
    --- Process 30732 loaded C:\Windows\System32\sechost.dll at 00007ffd47d00000
    --- Process 30732 loaded C:\Windows\System32\bcrypt.dll at 00007ffd46680000
    --- Process 30732 loaded C:\Windows\System32\rpcrt4.dll at 00007ffd470b0000
    --- Process 30732 loaded C:\Windows\System32\combase.dll at 00007ffd48980000
    --- Process 30732 loaded C:\Windows\System32\user32.dll at 00007ffd486e0000
    --- Process 30732 loaded C:\Windows\System32\win32u.dll at 00007ffd46440000
    --- Process 30732 loaded C:\Windows\System32\gdi32.dll at 00007ffd46da0000
    --- Process 30732 loaded C:\Windows\System32\gdi32full.dll at 00007ffd466b0000
    --- Process 30732 loaded C:\Windows\System32\imm32.dll at 00007ffd47fc0000
    --- Process 30732 thread 34224 created
    --- Process 30732 thread 34956 exited with status 0x0
    --- Process 30732 thread 30776 exited with status 0x0
    --- Process 30732 thread 22548 exited with status 0x0
    --- Process 30732 loaded C:\Windows\System32\shell32.dll at 00007ffd473a0000
    --- Process 30732 thread 20036 created
    --- Process 30732 loaded C:\Windows\System32\uxtheme.dll at 00007ffd42e20000
    --- Process 30732 thread 33012 created
    --- Process 30028 loaded C:\Windows\System32\ws2_32.dll at 00007ffd46dd0000
    --- Process 30028 loaded C:\Windows\System32\rpcrt4.dll at 00007ffd470b0000
    --- Process 30028 thread 30208 created
    --- Process 30028 thread 35416 created
    --- Process 30028 loaded C:\Windows\System32\bcrypt.dll at 00007ffd46680000
    --- Process 30028 loaded C:\Windows\System32\advapi32.dll at 00007ffd47c40000
    --- Process 30028 loaded C:\Windows\System32\cfgmgr32.dll at 00007ffd45f80000
    --- Process 30028 loaded C:\Windows\System32\msvcrt.dll at 00007ffd471d0000
    --- Process 30028 loaded C:\Windows\System32\ucrtbase.dll at 00007ffd46c10000
    --- Process 30028 thread 35752 created
    --- Process 30028 loaded C:\Windows\System32\sechost.dll at 00007ffd47d00000
    --- Process 30028 loaded C:\Windows\System32\ole32.dll at 00007ffd47e10000
    --- Process 30028 loaded C:\Windows\System32\msvcp_win.dll at 00007ffd46470000
    --- Process 30028 loaded C:\Windows\System32\gdi32.dll at 00007ffd46da0000
    --- Process 30028 loaded C:\Windows\System32\win32u.dll at 00007ffd46440000
    --- Process 30028 loaded C:\Windows\System32\gdi32full.dll at 00007ffd466b0000
    --- Process 30028 loaded C:\Windows\System32\user32.dll at 00007ffd486e0000
    --- Process 30028 loaded C:\Windows\System32\combase.dll at 00007ffd48980000
    --- Process 30028 loaded C:\Windows\System32\oleaut32.dll at 00007ffd48600000
    --- Process 30028 loaded C:\Windows\System32\vcruntime140.dll at 00007ffcf43b0000
    --- Process 30028 loaded C:\Windows\System32\vcruntime140_1.dll at 00007ffd2aae0000
    --- Process 30028 loaded C:\Windows\System32\msvcp140.dll at 00007ffd1da10000
    --- Process 30028 loaded C:\Windows\System32\imm32.dll at 00007ffd47fc0000
    --- Process 30028 thread 10332 created
    --- Process 30028 loaded C:\Windows\System32\kernel.appcore.dll at 00007ffd452a0000
    --- Process 30028 thread 27172 created
    --- Process 30028 loaded C:\Program Files\SEGGER\JLink\JLink_x64.dll at 00007ffc95540000
    --- Process 30028 loaded C:\Windows\System32\shell32.dll at 00007ffd473a0000
    --- Process 30028 loaded C:\Windows\System32\setupapi.dll at 00007ffd48180000
    --- Process 30028 loaded C:\Windows\System32\hid.dll at 00007ffd448d0000
    --- Process 30028 loaded C:\Windows\System32\IPHLPAPI.DLL at 00007ffd44af0000
    --- Process 30028 loaded C:\Windows\System32\winmm.dll at 00007ffd439a0000
    --- Process 30028 loaded C:\Windows\System32\devobj.dll at 00007ffd45f50000
    --- Process 30028 loaded C:\Windows\System32\wintrust.dll at 00007ffd46d30000
    --- Process 30028 loaded C:\Windows\System32\crypt32.dll at 00007ffd46510000
    --- Process 30028 loaded C:\Windows\System32\msasn1.dll at 00007ffd45b90000
    --- Process 30028 loaded C:\Windows\System32\winusb.dll at 00007ffd43cf0000
    --- Process 30028 unloaded DLL at 00007ffd439a0000
    --- Process 30028 loaded C:\Windows\System32\shlwapi.dll at 00007ffd47db0000
    --- Prthread '<unnamed>' panicked at src\serialport\module\src\windows.rs:118:55:
    stack backtrace:
       0:     0x7ffcbd4246a1 - nrfdl_plugin_identifier
       1:     0x7ffcbd4360d9 - nrfdl_plugin_identifier
       2:     0x7ffcbd422de7 - nrfdl_plugin_identifier
       3:     0x7ffcbd425ea9 - nrfdl_plugin_identifier
       4:     0x7ffcbd425a2c - nrfdl_plugin_identifier
       5:     0x7ffcbd426722 - nrfdl_plugin_identifier
       6:     0x7ffcbd4265bf - nrfdl_plugin_identifier
       7:     0x7ffcbd424def - nrfdl_plugin_identifier
       8:     0x7ffcbd426206 - nrfdl_plugin_identifier
       9:     0x7ffcbd444e6d - nrfdl_plugin_identifier
      10:     0x7ffcbd444f13 - nrfdl_plugin_identifier
      11:     0x7ffcbd444fab - nrfdl_plugin_identifier
      12:     0x7ffcbd32dcab - nrfdl_plugin_enumerate
      16:     0x7ffcbd32d946 - nrfdl_plugin_enumerate
      17:     0x7ffccb20933a - <unknown>
      18:     0x7ffccb2068bd - <unknown>
      19:     0x7ffccb203e86 - <unknown>
      20:     0x7ffccb203b6f - <unknown>
      21:     0x7ffccb1e4553 - <unknown>
      22:     0x7ffccb204822 - <unknown>
      23:     0x7ffccb207e03 - <unknown>
      24:     0x7ffccb1e4e64 - <unknown>
      25:     0x7ffccb1e3918 - <unknown>
    ocess 30028 unloaded DLL at 00007ffd47db0000
    --- Process 30028 unloaded DLL at 00007ffd473a0000
    --- Process 30028 unloaded DLL at 00007ffd48180000
    --- Process 30028 unloaded DLL at 00007ffd448d0000
    --- Process 30028 unloaded DLL at 00007ffd44af0000
    --- Process 30028 unloaded DLL at 00007ffc95540000
    --- Process 30028 thread 10332 exited with status 0x0
    --- Process 30028 thread 27172 exited with status 0x0
    --- Process 30028, exception e06d7363 at 00007ffd4682fe4c
    --- Process 30028 thread 35752 exited with status 0x0
    --- Process 30028 thread 35416 exited with status 0x0
    --- Process 30028 thread 30208 exited with status 0x0
    --- Process 30028 exited with status 0x0
    --- Process 35548 thread 30312 exited with status 0x0
    --- Process 30732 thread 33012 exited with status 0x0
    --- Process 30732 thread 20036 exited with status 0x0
    --- Process 30732 exited with status 0x0
    --- Process 35548 thread 29292 exited with status 0x0
    --- Process 35548 thread 4472 exited with status 0x0
    --- Process 35548 thread 19620 created
    --- Process 35548 thread 19620 exited with status 0x0
    --- Process 35548, exception e06d7363 at 00007ffd4682fe4c
    --- Process 35548 loaded C:\Windows\System32\dbghelp.dll at 00007ffd436e0000
    --- Process 35548 thread 21916 exited with status 0xc0000409
    --- Process 35548 thread 17476 exited with status 0xc0000409
    --- Process 35548 thread 35580 exited with status 0xc0000409
    --- Process 35548 thread 27488 exited with status 0xc0000409
    --- Process 35548 thread 11372 exited with status 0xc0000409
    --- Process 35548 thread 33568 exited with status 0xc0000409
    --- Process 35548 thread 32412 exited with status 0xc0000409
    --- Process 35548 thread 25172 exited with status 0xc0000409
    --- Process 35548 thread 7992 exited with status 0xc0000409
    --- Process 35548 thread 34628 exited with status 0xc0000409
    --- Process 35548 thread 34868 exited with status 0xc0000409
    --- Process 35548 thread 14140 exited with status 0xc0000409
    --- Process 35548 thread 32788 exited with status 0xc0000409
    --- Process 35548 thread 20388 exited with status 0xc0000409
    --- Process 35548 thread 18056 exited with status 0xc0000409
    --- Process 35548 thread 27104 exited with status 0xc0000409
    --- Process 35548 thread 28956 exited with status 0xc0000409
    --- Process 35548 thread 33248 exited with status 0xc0000409
    --- Process 35548 thread 368 exited with status 0xc0000409
    --- Process 35548 exited with status 0xc0000409
    --- Process 14760 loaded C:\Windows\System32\kernel.appcore.dll at 00007ffd452a0000
    --- Process 14760 thread 30668 exited with status 0x1
    --- Process 14760 thread 32872 exited with status 0x1
    --- Process 14760 thread 19964 exited with status 0x1
    --- Process 14760 exited with status 0x1
    --- Process 25596 thread 17732 exited with status 0x1
    --- Process 25596 thread 19832 exited with status 0x1
    --- Process 25596 thread 31112 exited with status 0x1
    --- Process 25596 exited with status 0x1
    Could you please try to run WinObj which is available here and send a screenshot of all COM devices - Nordic and non-Nordic - which are listed in the Global?? namespace as shown below?
    Dejan
