NCS 2.8.0: path length problem during build under Windows
I know that this issue comes up from time to time.  I'm raising it again, because to my opinion there have to be a solution for this.  Perhaps there is, that's the other reason I'm asking...
Since upgrade from NCS 2.7.0 to 2.8.0 we are facing the problem with path names exceeding some toolchain limit under Windows (Windows is already setup to use long names).
During build, the compiler complains that it cannot open a dependency file:
C:/u/src/BlueConnect_NordicApplication-Zephyr/submodules/BlueConnect_Core/ApplServ/RePAc/FieldDevice/Connector/CDeviceRemoteParamAccessConnectorBase.cpp:267:1: fatal error: opening dependency file submodules\BlueConnect_Core\build-config\Zephyr\CMakeFiles\blueconnect-core.dir\__\__\ApplServ\RePAc\FieldDevice\Connector\CDeviceRemoteParamAccessConnectorBase.cpp.obj.d: No such file or directory
The file actually resides in "C:\u\src\BlueConnect_NordicApplication-Zephyr\submodules\BlueConnect_Core\ApplServ\RePAc\FieldDevice\Connector\CDeviceRemoteParamAccessConnectorBase.cpp". These are 152 characters, actually not too much.
But the build system adds "some" extra information and creates a path "C:\u\src\BlueConnect_NordicApplication-Zephyr\_build\BlueConnect_NordicApplication-Zephyr\submodules\BlueConnect_Core\build-config\Zephyr\CMakeFiles\blueconnect-core.dir\__\__\ApplServ\RePAc\FieldDevice\ConnectorX\CDeviceRemoteParamAccessConnectorBase.cpp.obj.d" which has 261 characters, which exceeds some magic toolchain (and Windows) limit.
I guess that cmake actually is capable of avoiding those limits by exchanging parts of a long path with some hash.  I can observe those hashes somewhere in the build directory structure, but the directories below are empty (I guess that the build process crashed before filling them).
So I'm looking desperately for a solution of this issue.
And no: restructuring everything is not an option, because this is an existing code base.  One will run into this problem sooner or later due to different project root directories ("hey user, don't forget to unpack the repository into your drive root!").  And if one is unlucky, then the CI pipelines will give the rest to the efforts taken to make the paths shorter.
Thanks for response & regards
Hardy
