Hi
What is the best way to read cluster attributes periodically in zigbee network coordnicator?
any sample code available for one time request or subscription for value change or periodic subscription ?
Hi
Hi AHaug
I am sure the on/off is working and happending as its smart plug I used to send uart command to on or off and it reflects on plug.
Hi Ahaug
I am using this method to on/off target device
Could you do a Zigbee sniffer trace and see if your nodes actually does send attribute reports or not when the state changes?
Andreas
Hi I dont have sniffer right now
but I am confused as well that all standard zigbee device will have attributing supported or not
Here's a pointer to where to get started with this: https://www.nordicsemi.com/Products/Development-tools/nRF-Sniffer-for-802154
Dhaval Dalvadi said:but I am confused as well that all standard zigbee device will have attributing supported or not
It should be supported. What I want you to investigate with the sniffer is to see if you're actually sending the signal so we can look closer into why it does not report anything.
Andreas
