Set as required
Not sure if there's a problem here
Write data, it fails
If I block out CONFIG_FLASH_MAP=y
Can write successfully, but many errors
Set as required
Your settings partition and custom NVS partitions are probably overlapping in addresses.
You need to statically declare then in either a pm_static or in your .dts depending on which version of nRF Connect SDK you're using.
Andreas
Thank you for your reply. I am using nRF connect SDK 2.6.0. How can I set up NVS partition and custom partition?
You can for instance see this sample https://docs.nordicsemi.com/bundle/ncs-2.6.0/page/zephyr/samples/subsys/nvs/README.html
Andreas
