nRF5340 Low frequency Clock configuration when external clock is used
I have the following scenario:
  • nrf5340
  • SDK 2.1.1
  • HFCLK: 32Mhz crystal
  • LFCLK: square wave of 32768 Hz from an external RTC, range [0 - 1.8] Volts
  • square wave applied to XL1 pin
  • XL2 pin left unconnected
According to the Product Specification v1.5, the following register need to be configured for the LFCLK to work with the above scenario (paragraph 4.12.3):
  • OSCILLATORS.XOSC32KI.BYPASS=Enabled.
  • LFCLKSRC.SRC=LFXO
Questions
  1. By activating the BYPASS, what is really bypassed (see picture below)?
  2. I suppose i dont need to use any capacitor in this configuration. Is it correct to set the XOSC32KI.INTCAP as by default ?
  3. Looking in the Zephyr Kconfig parameters, i cannot find a way to enable the BYPASS. I read that this is not even yet possible in SDK 2.8.0 but it is in the nrfx3.6.0 (see this link).
    1. Can I have your feedback about it ?
    2. In case it is not possible through Kconfig, can i set the bypass if the LFCLK is already running ? Or do i need to stop it, reconfigure it and start it again ?
    3. Can you eventually provide a recommended way of doing it ?
  4. So far, I have run the above scenario WITHOUT enabling the BYPASS. The device seems to work anyhow. Is that expected ?
  5.  In case the external source is removed or fails, what is the behaviour of the clock peripheral ? any fall-back behaviour ?
Thanks in advance for your kind availability !
Regards
Riccardo
