nrfCloud Rest API provisioning is not working
Hello
I have a custom board based on nrf9160 and I cannot claim and make REST API and JWT auth work for it.
These are the steps I followed
1. https://github.com/nRFCloud/utils/blob/master/python/modem-firmware-1.3%2B/README.md#create-ca-cert
2. https://github.com/nRFCloud/utils/blob/master/python/modem-firmware-1.3%2B/README.md#device-credentials-installer
3. https://github.com/nRFCloud/utils/blob/master/python/modem-firmware-1.3%2B/README.md#nrf-cloud-device-onboarding
4. https://github.com/nRFCloud/utils/blob/master/python/modem-firmware-1.3%2B/README.md#gather-attestation-tokens
5. https://github.com/nRFCloud/utils/blob/master/python/modem-firmware-1.3%2B/README.md#claim-devices
Everything is successful apart from 5. which I report the Output
$ python3 ./claim_devices.py -v --provisioning_tags "nrf-cloud-onboarding" --api_key $MY_KEY
OS detect: Linux=True, MacOS=False, Windows=False
Provisioning API URL: https://api.provisioning.nrfcloud.com/v1/
1. Claiming 350457791967688, 50485839-3435-4caf-80d7-1d049684e467, 2024-11-26T17:16:39.152310+00:00, 2dn3hQFQUEhYOTQ1TK-A1x0EloTkZwNQPpJvddMbSFKzlIwT9ai7blDTMmHNBxvjUolijpM73NcO.0oRDoQEmoQRBIfZYQOpXius-sP2w5pr2wBHwhxIhStJzamC8zIPE6rTAaDpTuFnMkI5t1CNdFsIP0vbl5h1X_GjtUbnSWQFDJddAq1Y, with tags: "nrf-cloud-onboarding"
Claim payload:
"2dn3hQFQUEhYOTQ1TK-A1x0EloTkZwNQPpJvddMbSFKzlIwT9ai7blDTMmHNBxvjUolijpM73NcO.0oRDoQEmoQRBIfZYQOpXius-sP2w5pr2wBHwhxIhStJzamC8zIPE6rTAaDpTuFnMkI5t1CNdFsIP0vbl5h1X_GjtUbnSWQFDJddAq1Y","nrf-cloud-onboarding"
--> Accepted; claimed 0:
Done. 0 of 1 devices claimed.
As far as I know to make it work I could also go to nrfCloud->Security Services -> Claimed Device enter the attestation token and so on.
However when I enter the attestation token I get "
Error claiming device: Device is not supported.
What am I doing wrong?
Thank you very much
Alessandro
  • The Secure identity is not supported for nRF9160 devices which rules out the nRF Cloud Security services. This is due the Secure identity keys collection started during nRF9160 manufacturing, so we cannot promise all are available.
    It is possible to enable the Secure identity usage if you want to tryout that.
    To onboard the device, you need to upload the certificate with POST api.nrfcloud.com/.../devices Docs in: https://api.nrfcloud.com/v1/#tag/IP-Devices/operation/OnboardDevices)
    Create a CSV file with deviceId,[subType],[tags],[fwTypes],"certPem". Below is example where the optional [subType],[tags],[fwTypes] are empty.
    50363953-3234-4e14-8023-052421c8645c,,,,"-----BEGIN CERTIFICATE----- MIIBQDCB5qADAgECAgYBkyS1WOswCgYIKoZIzj0EAwIwHzEdMBsGA1UECgwUTm9y ZGljIFNlbWljb25kdWN0b3IwHhcNMjQxMTEzMDg0ODA0WhcNMzkxMTEwMDg0ODA0 WjAvMS0wKwYDVQQDDCQ1MDM2Mzk1My0zMjM0LTRlMTQtODAyMy0wNTI0MjFjODY0 NWMwWTATBgcqhkjOPQIBBggqhkjOPQMBBwNCAARLVrCgC0UHShEhAVnlE44GLX4y XXyR5z8pq09LNNEEnahe/3jZvAQA7cVpFIL1Tr97IPq43QPDU+n1RAyqKemgMAoG CCqGSM49BAMCA0kAMEYCIQD4NSG5jJ9CloL+nndgnTRP4LGJVG/9Yoo8r8XdpWay 0AIhAO4v4RKUFOrzEpaAGb8SuUwIxwQr6r0Jaccueg995qMG -----END CERTIFICATE-----
    Remember to have the line feeds in the certificate. curl -X POST api.nrfcloud.com/.../devices \ --data-binary @[your csv file].csv \ -H "Content-Type: text/csv" \ -H "Authorization: Bearer [API-Key]"
  • Thank you Tuomas,
    I have tried your solution and I am getting the same results. I am realizing the issue should be somewhere else.
    If you read my original post I think in theory just 1. 2. and 3. (3. is the same as your suggestion) are required to provision the device for MQTT, CoAP and REST API.
    I any cases the device appears on the nrfCloud portal, so they should be fine.
    My issue is to make the cell location example work for our custom board (based on nrf9160).
    At the moment this is the output when enabling A-GNSS and I have assumed the issue was because the wrong provisioning
    [00:00:12.395,324] <err> nrf_cloud_codec_internal: REST error msg: Invalid JWT
    [00:00:12.403,320] <err> nrf_cloud_rest: nRF Cloud REST error code: 40100
    [00:00:12.411,987] <err> location: nRF Cloud A-GNSS request failed, error: -77
    Note: the same code is working on the nrf9151DK
    I also manually erased the nrfcloud certificates and I get the same results.
    I also provisioned the same device to another nrfCloud account and I get the same results
    I also have tried to download AGNSS and authenticate to the enpoint through "curl" and JWT generated as described here. But authentication fails
    Can you assist me?
    Thank you
  • I tried the curl and jwt.io example and tried to reproduce "Invalid JWT". If you forgot the line feed from the end, it creates JWT but it is not valid in nRF CLoud.
    The line feed is part part of the certificate format. The jwt.io still says "signature verified".
    But why it works this way in device. Did you create the certs also for the real device with the scripts and then with AT commands provisioned the certs?
    Make sure you have the needed line feeds "\n" in the cert. You can use for example https://www.samltool.com/format_x509cert.php
    (In other words, copy pasting certs from files need attention that the needed line feeds are in place. In device, the line feeds need to be "\n"). See example AT command below
    at AT%CMNG=0,16842753,1,"-----BEGIN CERTIFICATE-----\nMIIBPzCB5qADAgECAgYBkyP6rbowCgYIKoZIzj0EAwIwHzEdMBsGA1UECgwUTm9y\nZGljIFNlbWljb25kdWN0b3IwHhcNMjQxMTEzMDUyNDExWhcNMzkxMTEwMDUyNDEx\nWjAvMS0wKwYDVQQDDCQ1MDM2Mzk1My0zMjM0LTRlNzItODBlMC0wOTBlZjk2ZTQ4\nYjUwWTATBgcqhkjOPQIBBggqhkjOPQMBBwNCAAR7lZkMaln11PS8yHmj+8C/bgUu\n9yyF+LPfuwezI2joeEOjoVtWKfm6ykVfV7FnON6uJce9zOQhWNymagzE/6DGMAoG\nCCqGSM49BAMCA0gAMEUCIQC6Lx5JG+DgzHIM/6Ci39yltYhIvZCxz6ueGpzv4iAt\njwIgUbzA7BuaC43NZK/T98IxJu7IDhk8ZldsREHFJqFAkhI=\n-----END CERTIFICATE-----\n"
    Also, one possibility is to create the certs in the device. This way the device side is for sure OK. Instructions in docs.nordicsemi.com/.../Credentials.html
  • Hello Tuomas,
    I have solved the issue, basically I needed to add to my .conf file
    CONFIG_NRF_CLOUD_CLIENT_ID_SRC_INTERNAL_UUID=y
    Now everything is working well.
    Thank you for your support!
    Alessandro
