In Nrf7002dk facing issue with TWT Powersave Mechanism
1. I was facing issue with my nordic device saying
[02:16:46.206,481] <err> net_pkt: Data buffer (1328) allocation failed.
[02:16:46.206,481] <wrn> net_conn: pkt cloning failed, pkt 0x2003a454 dropped
continuously , attached video below for your reference.
 2. I need to test TWT powersave using Nrf7002dk, what i was doing was
  • Initially turning on powersave using " wifi ps on "
  • Connecting wifi using " wifi connect SSID Password "
  • After successful connection starting ping to the nordic ip which i took from "net iface show" through my laptop which is in the same network and ping is happening.
  • Now entering " wifi twt setup 0 0 2 2 0 0 1 0 20000 3000000 " command and output occurred as uart:~$ wifi twt setup 0 0 2 2 0 0 1 0 20000 3000000
    TWT operation TWT setup with dg: 2, flow_id: 2 requested
    TWT response: TWT reject
    TWT Dialog token: 2
    TWT flow ID: 2
    TWT negotiation type: TWT individual negotiation
    TWT responder: true
    TWT implicit: true
    TWT announce: false
    TWT trigger: false
    TWT wake interval: 19968 us
    TWT interval: 3002000 us
But even after i have given wake interval it should go to sleep and should wake after the given wake interval time, but i was not happening in that way, it was continuously pinging or reachable without sleep.
3. When i was giving net tcp connect IP Port it was disconnecting with errors
uart:~$ net tcp connect 172.40.9.203 5001
Connecting from 172.40.9.248:0 to 172.40.9.203:5001
TCP connection failed (-116)
[00:13:28.327,423] <err> os: ***** BUS FAULT *****
[00:13:28.327,423] <err> os: Precise data bus error
[00:13:28.327,423] <err> os: BFAR Address: 0xc809
[00:13:28.327,453] <err> os: r0/a1: 0x00000000 r1/a2: 0x00000002 r2/a3: 0x0000c809
[00:13:28.327,453] <err> os: r3/a4: 0x20012e60 r12/ip: 0x200298f4 r14/lr: 0x0004d67f
[00:13:28.327,453] <err> os: xpsr: 0x21000000
[00:13:28.327,453] <err> os: Faulting instruction address (r15/pc): 0x000738a4
[00:13:28.327,484] <err> os: >>> ZEPHYR FATAL ERROR 25: Unknown error on CPU 0
[00:13:28.327,484] <err> os: Current thread: 0x20002af8 (tcp_work)
[00:13:28.390,502] <err> coredump: #CD:BEGIN#
[00:13:28.396,270] <err> coredump: #CD:5a4501000300050019000000
[00:13:28.403,594] <err> coredump: #CD:4102004400
[00:13:28.409,698] <err> coredump: #CD:000000000200000009c80000602e0120f49802207fd60400a438070000000021
[00:13:28.420,501] <err> coredump: #CD:98d4002000000000000000000000000000000000000000000000000000000000
[00:13:28.431,304] <err> coredump: #CD:00000000
[00:13:28.437,225] <err> coredump: #CD:4d0100f82a0020c02b0020
[00:13:28.444,366] <err> coredump: #CD:70230020a47d0020000000000080f20000000000000000000000000000000000
[00:13:28.455,169] <err> coredump: #CD:00000000000000000000000000000000a447002000000000ffffffffffffffff
[00:13:28.466,003] <err> coredump: #CD:00000000ffffffff000000000000000070d4002000000000502b0020502b0020
[00:13:28.476,806] <err> coredump: #CD:000100001dd70400f82a00200000000000000000903500207463705f776f726b
[00:13:28.487,609] <err> coredump: #CD:0000000000000000000000000000000000000000000000000000000020d10020
[00:13:28.498,413] <err> coredump: #CD:0004000000000000301600200000000000000000000000000000000000000000
[00:13:28.509,216] <err> coredump: #CD:0000000000000000
[00:13:28.515,838] <err> coredump: #CD:4d010020d1002020d50020
[00:13:28.522,979] <err> coredump: #CD:f0f0f0f0aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:13:28.533,782] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:13:28.544,586] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:13:28.555,419] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:13:28.566,223] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:13:28.577,026] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:13:28.587,829] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:13:28.598,632] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:13:28.609,436] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:13:28.620,239] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:13:28.631,042] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:13:28.641,845] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:13:28.652,648] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:13:28.663,452] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:13:28.674,255] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:13:28.685,058] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:13:28.695,861] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa7035002045db0400
[00:13:28.706,665] <err> coredump: #CD:e0330020887d0020f82a0020c1db0400fffffffff82a002080120020df320700
[00:13:28.717,498] <err> coredump: #CD:ffffffffffffffffffffffffed88002003000000ed88002000000000cf040600
[00:13:28.728,302] <err> coredump: #CD:70070020f4980220ed880020487e0700b8d30020030000000723060035230600
[00:13:28.739,105] <err> coredump: #CD:03000000d47207001b000000d2880020072306000d2b06000300000000000000
[00:13:28.749,908] <err> coredump: #CD:0000000000000000d0410000b03c0020f87d07000a000000a519090018000000
[00:13:28.760,711] <err> coredump: #CD:1b00000049260600f87d07008926060051260600c0d400201c000000ab5a0000
[00:13:28.771,514] <err> coredump: #CD:3ed400203b3307005029002051260600a6190900000000000000000005160200
[00:13:28.782,318] <err> coredump: #CD:48d40020a319090050010000181a002000000000d61d00007035002045db0400
[00:13:28.793,121] <err> coredump: #CD:e0330020887d0020f82a0020c1db0400fffffffff82a0020a4470020df320700
[00:13:28.803,955] <err> coredump: #CD:ffffffffffffffffffffffff2ddd04000000000000ed00e0887d002000000000
[00:13:28.814,758] <err> coredump: #CD:f4980220f1d40400a8bf000000000061f2ffffffa44700200000000002000000
[00:13:28.825,561] <err> coredump: #CD:09c80000602e0120f49802207fd60400a4380700000000210000000044930220
[00:13:28.836,364] <err> coredump: #CD:8cffffff156b0600449302208cfffffff82a0020d4930220b07d0020a1d70400
[00:13:28.847,167] <err> coredump: #CD:ffffffffffffffff00000000aaaaaaaaaaaaaaaa1dd704000000000000000000
[00:13:28.857,971] <err> coredump: #CD:0000000000000000000000000000000000000000ddfc050000000000aaaaaaaa
[00:13:28.868,743] <err> coredump: #CD:END#
[00:13:28.874,328] <err> fatal_error: Resetting system
I need help on both points, ASAP because it was stopping my testing.
  • To for instance 65000
    Tried the same by limiting the time but even though we gave the sleep interval,client is continuously in wake state as you see in the ping and once after disconnected from wifi then only it went to offline saying host is unreachable
    It seems that you are now getting TWT accepted, and you are seeing a delay of up to 3 seconds via your ping, as expected with the TWT settings that you have (3s / 65ms active). The AP buffers the data to when the nRF7002 is awake.
    The latest video shows that it works as expected.
    Håkon
  • HI,
    but when i was running zperf download i was not receiving any buffer data in my sniffer capture,
  • I want to run in loop that means i device should go to sleep for every 10 sec and should be awake for 3 sec and should receive the buffer data in the awake period and this should continue until i give tear down command , need the exact command for the same.and should see this through wire shark capture .
    Please do the needful ASAP
    Jaswanth.
    You started listening on the nRF, ie. zperf server is running on that device. You then need to connect via a iperf2 compatible client.
    Feel free to do this by adjusting twt_interval parameter.
    Please see the documentation for wifi/shell TWT command in this list:
    https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/samples/wifi/shell/README.html#supported_cli_commands
    Please notice the intervals, especially the boundaries for twt_wake_interval.
    Håkon
