In Nrf7002dk facing issue with TWT Powersave Mechanism
1. I was facing issue with my nordic device saying
[02:16:46.206,481] <err> net_pkt: Data buffer (1328) allocation failed.
[02:16:46.206,481] <wrn> net_conn: pkt cloning failed, pkt 0x2003a454 dropped
continuously , attached video below for your reference.
 2. I need to test TWT powersave using Nrf7002dk, what i was doing was
  • Initially turning on powersave using " wifi ps on "
  • Connecting wifi using " wifi connect SSID Password "
  • After successful connection starting ping to the nordic ip which i took from "net iface show" through my laptop which is in the same network and ping is happening.
  • Now entering " wifi twt setup 0 0 2 2 0 0 1 0 20000 3000000 " command and output occurred as uart:~$ wifi twt setup 0 0 2 2 0 0 1 0 20000 3000000
    TWT operation TWT setup with dg: 2, flow_id: 2 requested
    TWT response: TWT reject
    TWT Dialog token: 2
    TWT flow ID: 2
    TWT negotiation type: TWT individual negotiation
    TWT responder: true
    TWT implicit: true
    TWT announce: false
    TWT trigger: false
    TWT wake interval: 19968 us
    TWT interval: 3002000 us
But even after i have given wake interval it should go to sleep and should wake after the given wake interval time, but i was not happening in that way, it was continuously pinging or reachable without sleep.
3. When i was giving net tcp connect IP Port it was disconnecting with errors
uart:~$ net tcp connect 172.40.9.203 5001
Connecting from 172.40.9.248:0 to 172.40.9.203:5001
TCP connection failed (-116)
[00:13:28.327,423] <err> os: ***** BUS FAULT *****
[00:13:28.327,423] <err> os: Precise data bus error
[00:13:28.327,423] <err> os: BFAR Address: 0xc809
[00:13:28.327,453] <err> os: r0/a1: 0x00000000 r1/a2: 0x00000002 r2/a3: 0x0000c809
[00:13:28.327,453] <err> os: r3/a4: 0x20012e60 r12/ip: 0x200298f4 r14/lr: 0x0004d67f
[00:13:28.327,453] <err> os: xpsr: 0x21000000
[00:13:28.327,453] <err> os: Faulting instruction address (r15/pc): 0x000738a4
[00:13:28.327,484] <err> os: >>> ZEPHYR FATAL ERROR 25: Unknown error on CPU 0
[00:13:28.327,484] <err> os: Current thread: 0x20002af8 (tcp_work)
[00:13:28.390,502] <err> coredump: #CD:BEGIN#
[00:13:28.396,270] <err> coredump: #CD:5a4501000300050019000000
[00:13:28.403,594] <err> coredump: #CD:4102004400
[00:13:28.409,698] <err> coredump: #CD:000000000200000009c80000602e0120f49802207fd60400a438070000000021
[00:13:28.420,501] <err> coredump: #CD:98d4002000000000000000000000000000000000000000000000000000000000
[00:13:28.431,304] <err> coredump: #CD:00000000
[00:13:28.437,225] <err> coredump: #CD:4d0100f82a0020c02b0020
[00:13:28.444,366] <err> coredump: #CD:70230020a47d0020000000000080f20000000000000000000000000000000000
[00:13:28.455,169] <err> coredump: #CD:00000000000000000000000000000000a447002000000000ffffffffffffffff
[00:13:28.466,003] <err> coredump: #CD:00000000ffffffff000000000000000070d4002000000000502b0020502b0020
[00:13:28.476,806] <err> coredump: #CD:000100001dd70400f82a00200000000000000000903500207463705f776f726b
[00:13:28.487,609] <err> coredump: #CD:0000000000000000000000000000000000000000000000000000000020d10020
[00:13:28.498,413] <err> coredump: #CD:0004000000000000301600200000000000000000000000000000000000000000
[00:13:28.509,216] <err> coredump: #CD:0000000000000000
[00:13:28.515,838] <err> coredump: #CD:4d010020d1002020d50020
[00:13:28.522,979] <err> coredump: #CD:f0f0f0f0aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:13:28.533,782] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:13:28.544,586] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:13:28.555,419] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:13:28.566,223] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:13:28.577,026] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:13:28.587,829] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:13:28.598,632] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:13:28.609,436] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:13:28.620,239] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:13:28.631,042] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:13:28.641,845] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:13:28.652,648] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:13:28.663,452] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:13:28.674,255] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:13:28.685,058] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[00:13:28.695,861] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa7035002045db0400
[00:13:28.706,665] <err> coredump: #CD:e0330020887d0020f82a0020c1db0400fffffffff82a002080120020df320700
[00:13:28.717,498] <err> coredump: #CD:ffffffffffffffffffffffffed88002003000000ed88002000000000cf040600
[00:13:28.728,302] <err> coredump: #CD:70070020f4980220ed880020487e0700b8d30020030000000723060035230600
[00:13:28.739,105] <err> coredump: #CD:03000000d47207001b000000d2880020072306000d2b06000300000000000000
[00:13:28.749,908] <err> coredump: #CD:0000000000000000d0410000b03c0020f87d07000a000000a519090018000000
[00:13:28.760,711] <err> coredump: #CD:1b00000049260600f87d07008926060051260600c0d400201c000000ab5a0000
[00:13:28.771,514] <err> coredump: #CD:3ed400203b3307005029002051260600a6190900000000000000000005160200
[00:13:28.782,318] <err> coredump: #CD:48d40020a319090050010000181a002000000000d61d00007035002045db0400
[00:13:28.793,121] <err> coredump: #CD:e0330020887d0020f82a0020c1db0400fffffffff82a0020a4470020df320700
[00:13:28.803,955] <err> coredump: #CD:ffffffffffffffffffffffff2ddd04000000000000ed00e0887d002000000000
[00:13:28.814,758] <err> coredump: #CD:f4980220f1d40400a8bf000000000061f2ffffffa44700200000000002000000
[00:13:28.825,561] <err> coredump: #CD:09c80000602e0120f49802207fd60400a4380700000000210000000044930220
[00:13:28.836,364] <err> coredump: #CD:8cffffff156b0600449302208cfffffff82a0020d4930220b07d0020a1d70400
[00:13:28.847,167] <err> coredump: #CD:ffffffffffffffff00000000aaaaaaaaaaaaaaaa1dd704000000000000000000
[00:13:28.857,971] <err> coredump: #CD:0000000000000000000000000000000000000000ddfc050000000000aaaaaaaa
[00:13:28.868,743] <err> coredump: #CD:END#
[00:13:28.874,328] <err> fatal_error: Resetting system
I need help on both points, ASAP because it was stopping my testing.
  • iperf2 compatible client.
    can you explain how to do this, i have connected my nordic board to laptop which has iperf and iperf3 in it, do i need to run server in laptop on in nordic, if in nordic how to run it and which command do i need to give in my laptop ?
  • Feel free to do this by adjusting twt_interval parameter.
    i was not getting like how to adjust correctly, can you give the direct command so that i will adjust the timings in it
  • please check the attached sniffer onceTWT_checking.pcapng
    Also ran twt command with wake interval 20000us that means 20sec and twt interval as 60sec, but it was not waking after 20 sec
    This is 20 ms, not 20 seconds.
    This will make it wake up for 20 ms each 60 seconds.
    In general, I would recommend that you check the manual for the programs that you use, in this case, you can see more details if you open a terminal and write "man iperf".
    To setup iperf as a client, with TCP communication, here's an example:
    iperf -c <nrf-ip>
    Håkon
  • This will make it wake up for 20 ms each 60 seconds
    But this also not happening right? as per video i have attached
    iperf -c <nrf-ip>
    Not working
    Is there any possible to connect virtually regrading this issue?
