As the subject, when i connect to the Windows with the cable connected with VDD side, it will not show up Jlink in Windows.
What should I do to reset the Nrf5340 dk
Could you try using another USB cable? Some USB cables only provide power and don't support data transfer. Also, what is the response from the DK? Does the LED start glowing, or is it flickering?
If you're using a USB hub, I recommend connecting the device directly to the USB port to see if this resolves the issue. Additionally, try connecting the DK to another PC to check if there are any issues with the PC drivers.
Abhijith
