Secure Boot - boot time
Hi
For a low power product, I need the nRF54L15 to wake up periodically with very low consumption in between. In the deepest sleep mode there is no RAM retained and so the bootloader will rerun on every wake up I guess. Therefor the critical question for me is, how fast can secure boot be.
I have tried the bootloader example, but it results in 400ms boot time after reset is released. Probably that's not the way to test it.
Do you know what boot times are achivable or can you give me some hints how I should test it?
Kind regards
Samuel
    You refer to both "secure boot" and "bootloader". Are any of these referring to NSIB or MCUboot?
    The 400ms you're seeing is higher than what I would expect from MCUboot validating the app image(s), but it might be due to writing over some sort of serial, for instance UART logging. Have you disabled this? If not, do you see the same speed if you've disabled all writes?
    Andreas
  • Hey
    Thank you! After disabling logging from mcuboot and aplication the boot time decreases to 78ms:
    It seems that the hash verification happens in the first third. I am wondering what happens afterwards. The application (zephyr boot to system off) itself needs a few milliseconds only. Do you see possibilities to further reduce that time?
    I am using the NCS mainline with mcuboot. I have modified the system off example, so that it uses mcuboot. The build is done using --sysbuild and configured via sysbuild.conf / sysbuild/mcuboot.conf.
    Kind regards
    Samuel
  • Hi Samuel,
    To be honest I'm not too familiar with the details in the boot to system off procedure, so to conclude with anything would require some experimentation and in line debugging to see which calls are being used throughout the procedure so you can eliminate which you might be able to optimize w.r.t. speed. Other than this, I'm not sure I won't be able to help you narrow down the scope, unfortunately
    There might be someone in a zephyr discord or git forums that have discussed this already, so that might be another angle/platform where you can discuss with other potential developers who's dived into this topic earlier.
    Andreas
