Hi, I am working on a project that collects data from various sensors and transmits it to a Mobile application via BLE.
Can I use Isochronous Streaming for it? Can I set up Isochronous channel between a board and a Mobile?
Thank you
Regards
Pallavi
Thank you
Regards
Pallavi
Hi!
The LE isochronous channels support as of today is centered around LE Audio and Audio use-cases. So I would recommend using it for general senor data.
Hi
Can you elaborate? I can set up an Isochronous channel for sensor data streaming or no?
How is the isochronous channel setup between a board and a mobile app?
Since Iso is a BLE feature, will the board connect only to the mobile app that has BLE?
I am confused. Also it was told in one of the discussions that NUS example can be used for data streaming
Stream generic data directly to PC via BLE/Bluetooth?
How do I remove the UART part from this and make it solely for streaming between board and app only?
LE Isochronous Channels was first introduced in BLE 5.2, and for Audio use-cases. https://www.bluetooth.com/blog/10-frequently-asked-questions-on-le-isochronous-channels/
Use normal GATT notifications for sending sensor data to the mobile phone.
