No bluetooth advertisement is found
Hi Community,
I made a custom board based on thingy53.
the custom board can be flashed with nRF5340-DK, I see the "merged_domains.hex" is flashed.
Also tried with nRF connect for desktop to flash the "dfu_application.zip", the result is the same.
the appliaction seems no problem, the output from the console looks same as on Thingy53:
[00:00:00.005,187] <inf> Custom_MYMO: Starting Custom
[00:00:00.011,138] <inf> fs_nvs: 8 Sectors of 4096 bytes
[00:00:00.011,138] <inf> fs_nvs: alloc wra: 0, fd0
[00:00:00.011,138] <inf> fs_nvs: data wra: 0, 1c
[00:00:00.036,437] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
[00:00:00.036,468] <inf> bt_hci_core: HW Variant: nRF53x (0x0003)
[00:00:00.036,468] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 54.58864 Build 1214809870
[00:00:00.038,757] <inf> bt_hci_core: No ID address. App must call settings_load()
[00:00:00.041,198] <inf> bt_hci_core: Identity: E6:0B:3C:01:47:D0 (random)
[00:00:00.041,229] <inf> bt_hci_core: HCI: version 5.4 (0x0d) revision 0x218f, manufacturer 0x0059
[00:00:00.041,259] <inf> bt_hci_core: LMP: version 5.4 (0x0d) subver 0x218f
return of bt_services_init:0
[00:00:00.044,982] <inf> Custom_MYMO: test print---0
[00:00:00.044,982] <inf> Custom_MYMO: Bluetooth initialized
[00:00:00.044,982] <inf> Custom_MYMO: test print---1
[00:00:00.050,628] <inf> Custom_MYMO: test print---2
[00:00:00.050,628] <inf> Custom_MYMO: Advertising successfully started
MCUBOOT_IMAGE_VERSION:0.0.3
switch LED
switch LED
switch LED
switch LED
switch LED
As you can see "Advertising successfully started" , that means no issue for this function in main:
err = bt_le_adv_start(BT_LE_ADV_CONN, ad, ARRAY_SIZE(ad), sd, ARRAY_SIZE(sd));
    if (err) {
        LOG_ERR("Advertising failed to start (err %d)\n", err);
        return err;
the problem is I can not find the bluetooth advertisement with mobile phone. how can I verify if the network core works correctly? or any other idea?
Best regards
Danny
    Thank you. We have looked at your design and are giving some feedback on that in the private ticket.
    Regarding the issue of no advertising,  given that all looks good in the log and advertising is started, I susepct issues with the HFXO. Could it be that it is not properly starting or is oscillatign with wrong frequency?
    If you have a spectrum analyzer, you can use the radio test sample and set up a constant carrier. Is the carrier located in the correct channel/frequency?. If you do not have a spectrum analyzer, you can also use the nRF Connect for Dekstop RSSI viewer app to see which channel there is traffic. The outcome of this test woul be if we see any radio TX at all, and if so, if we see it at the right frequency.
    If there is no radio Tx acticity, perhaps you can measure on the crystal with an oscilliscope when doing advertising or similar? That will affect the crystal making the frequency off, but we can see if the XO is starting or not.
