Need to disable pairing with Windows 10
Greetings,
I've searched the forum, but haven't found a particular answer. I need to configure the project to not pair with Windows 10 PC because it blocks other software that needs to send commands to the device. This is critical. Tried to pair it with Android, but it rejects the pairing. Where can I disable this pairing?
The project is based on a merged hex from:
  1. secure_bootloader_ble_s132_pca10040.hex
  2. s132_nrf52_7.2.0_softdevice.hex
  3. dfu (ble_app_uart_pca10040_s132.hex)
  • Ok, I started with that example. So far, I tweaked the peer_manager_init function. This seems to disable access Windows 10 connecting with the devkit, but connect with the phone, which is what I need. Now I want to integrate that function in my project and add peer_manager.c with its' dependencies. I'm stuck on that part with Segger. How do I add that with the dependencies? I have peer_manager.c in the components folder of the project.
  • Update:
    I have implemented a timeout after 13 seconds, so it disconnects a device if it is connected longer than 13 seconds. The issue is when it is paired with Windows 10, it blocks the timer somehow and it can't disconnect. Any suggestions?
    **@brief Function for handling BLE events.
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                uart_init();
                NRF_LOG_INFO("Connected");
                //err_code = bsp_indication_set(BSP_INDICATE_CONNECTED);
                //APP_ERROR_CHECK(err_code);
                // Start the inactivity timer
                err_code = app_timer_start(m_inactivity_timer_id, APP_TIMER_TICKS(13000), NULL);
                // Stop the inactivity timer
                err_code = app_timer_stop(m_inactivity_timer_id);
                // Wait for UART to finish
                while(app_uart_tx_done());
                app_uart_close();
                NRF_LOG_INFO("Disconnected");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
                // Pairing not supported
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
  • Ok, so it seems I fixed it somehow. I had issues with importing files in the SEGGER Embedded Studio with dependencies. It seems that if you don't include the headers that are connected to peer_manager.c (or other files that you might use) in the main.c file, it won't show the dependencies as imported. Also clean & build seems to fix it. Had to manually adjust some things in the component folder due to issues with the sdk_config file, mainly in the IF part because the sdk_config didn't have those definitions to enable/disable them. I imported the peer manager and added the following code, which blocks peering with PC Windows 10 devices.
    // PASSKEY
    #define PASSKEY_TXT                     "Passkey:"                                  /**< Message to be displayed together with the pass-key. */
    #define PASSKEY_TXT_LENGTH              8                                           /**< Length of message to be displayed together with the pass-key. */
    #define PASSKEY_LENGTH                  6                                           /**< Length of pass-key received by the stack for display. */
    #define SEC_PARAM_BOND                  1                                           /**< Perform bonding. */
    #define SEC_PARAM_MITM                  1                                           /**< Man In The Middle protection required (applicable when display module is detected). */
    #define SEC_PARAM_LESC                  1                                           /**< LE Secure Connections enabled. */
    #define SEC_PARAM_KEYPRESS              0                                           /**< Keypress notifications not enabled. */
    #define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_DISPLAY_ONLY                /**< Display I/O capabilities. */
    #define SEC_PARAM_OOB                   0                                           /**< Out Of Band data not available. */
    #define SEC_PARAM_MIN_KEY_SIZE          7                                           /**< Minimum encryption key size. */
    #define SEC_PARAM_MAX_KEY_SIZE          16                                          /**< Maximum encryption key size. */
    /**@brief Function for the Peer Manager initialization.
    static void peer_manager_init(void)
        ret_code_t           err_code;
        err_code = pm_init();
        sec_param.bond           = SEC_PARAM_BOND;
        sec_param.mitm           = SEC_PARAM_MITM;
        sec_param.lesc           = SEC_PARAM_LESC;
        sec_param.keypress       = SEC_PARAM_KEYPRESS;
        sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
        sec_param.oob            = SEC_PARAM_OOB;
        sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
        sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
        sec_param.kdist_own.enc  = 1;
        sec_param.kdist_own.id   = 1;
        sec_param.kdist_peer.enc = 1;
        sec_param.kdist_peer.id  = 1;
