WiFi scan while connected
Does the NCS stack + nRF7002 support scanning while connected? I would expect it could, to support handoff, but getting errors.
Using nRF7002-DK and NCS 2.8.0.
Compile the wifi/shell example for nrf7002dk/nrf5340/cpuapp, no other changes.
*** Booting nRF Connect SDK v2.8.0-a2386bfc8401 ***
*** Using Zephyr OS v3.7.99-0bc3393fb112 ***
Starting nrf7002dk with CPU frequency: 128 MHz
[00:00:00.532,226] <inf> wifi_supplicant: wpa_supplicant initialized
uart:~$ wifi connect -s Hizzulon <my AP credentials>
Connection requested
Connected
[00:00:19.725,433] <inf> wpa_supp: MBO: Disable MBO/OCE due to misbehaving AP not having enabled PMF
[00:00:19.726,226] <inf> wpa_supp: wlan0: SME: Trying to authenticate with fc:34:97:af:71:54 (SSID='Hizzulon' freq=5220 MHz)
[00:00:20.086,120] <inf> wpa_supp: wlan0: Trying to associate with fc:34:97:af:71:54 (SSID='Hizzulon' freq=5220 MHz)
[00:00:20.102,874] <inf> wpa_supp: wlan0: Associated with fc:34:97:af:71:54
[00:00:20.103,027] <inf> wpa_supp: MBO: Disable MBO/OCE due to misbehaving AP not having enabled PMF
[00:00:20.103,118] <inf> wpa_supp: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
[00:00:20.122,253] <inf> wpa_supp: wlan0: WPA: Key negotiation completed with fc:34:97:af:71:54 [PTK=CCMP GTK=CCMP]
[00:00:20.122,467] <inf> wpa_supp: wlan0: CTRL-EVENT-CONNECTED - Connection to fc:34:97:af:71:54 completed [id=0 id_str=]
[00:00:20.137,420] <inf> net_dhcpv4: Received: 192.168.1.203
uart:~$ wifi status
Status: successful
State: COMPLETED
Interface Mode: STATION
Link Mode: WIFI 6 (802.11ax/HE)
SSID: Hizzulon
BSSID: FC:34:97:AF:71:54
Band: 5GHz
Channel: 44
Security: WPA2-PSK
MFP: Optional
RSSI: -34
Beacon Interval: 100
DTIM: 1
TWT: Supported
Current PHY rate : 26000
uart:~$ wifi scan
Scan requested
[wait ~30 seconds]
Scan request failed (-116)
[wait another ~30 seconds]
[00:01:33.363,311] <err> wifi_nrf: nrf_wifi_fmac_chg_vif_state: RPU is unresponsive for 10 sec
[00:01:33.363,342] <err> wifi_nrf: nrf_wifi_if_stop_zep: nrf_wifi_fmac_chg_vif_state failed
[00:01:33.364,013] <inf> wifi_supplicant: Network interface 1 (0x200013c0) down
[00:01:33.375,396] <inf> wpa_supp: wlan0: CTRL-EVENT-DSCP-POLICY clear_all
[00:01:33.375,854] <inf> wpa_supp: wlan0: CTRL-EVENT-DSCP-POLICY clear_all
[00:01:35.533,050] <inf> wifi_supplicant: Network interface 1 (0x200013c0) up
uart:~$ wifi status
Status: successful
State: DISCONNECTED
uart:~$
So the scan fails, but later there's another error that looks like the low-level nRF7002 driver failing and recovering (CONFIG_NRF_WIFI_RPU_RECOVERY is enabled by default).
If scan while connected isn't a supported feature, I would expect it to error immediately, not get into a state where it drops the connection?
A probably related issue: if I issue "wifi connect" with invalid credentials, wifi status is "SCANNING" forever (certainly much longer than the 30 second scan timeout), and later connect requests fail with:
uart:~$ wifi connect <credentials>
[00:01:58.298,828] <inf> wpa_supp: wlan0: CTRL-EVENT-DSCP-POLICY clear_all
[00:01:58.302,124] <inf> wpa_supp: wlan0: Reject scan trigger since one is already pending
[00:01:58.302,246] <wrn> wpa_supp: wlan0: Failed to initiate AP scan
[00:01:58.304,992] <inf> wpa_supp: wlan0: Reject scan trigger since one is already pending
[00:01:58.305,114] <wrn> wpa_supp: wlan0: Failed to initiate AP scan
I need to explicitly do "wifi disconnect" before it will stop scanning and allow another connection. Normally, issuing a connect command while already connected disconnects automatically then initiates the new connection.
  • For the new "zephyr (1).hex" file, same behavior as before, fails scan on channel 165.
    Not including full log here, just the Zephyr header so you can confirm I'm running the expected image, and the command I'm executing:
    *** Booting nRF Connect SDK v2.8.0-caf9929fbaeb ***
    *** Using Zephyr OS v3.7.99-6c5454b22eea ***
    [00:00:00.499,359] <inf> wifi_supplicant: wpa_supplicant initialized
    uart:~$ wifi connect -s Hizzulon <credentials>
    ... connects successfully to a 5GHz AP
    uart:~$ wifi scan -b 5 -c 5:44
    ... successful scan
    uart:~$ wifi scan -b 5 -c 5:165
    ... fails scan
    For "zephyr_with_logs_enabled.hex", also same behavior. Here are the logs - there are some dropped messages (including the Zephyr boot banner), though no drops around the scanning. I waited between commands for some of the background periodic wpa_supp messages to appear.
    uart:~$
    --- 5 messages dropped ---
    [00:00:00.512,847] <dbg> wpa_supp: wpa_printf_impl: wpa_supplicant v2.11-devel
    --- 11 messages dropped ---
    [00:00:00.513,397] <inf> wifi_supplicant: wpa_supplicant initialized
    [00:00:00.514,007] <dbg> wifi_supplicant: add_interface: Adding interface wlan0 [1] (0x200013c0)
    [00:00:00.514,068] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: interface_add, argc: 5
    [00:00:00.514,099] <dbg> wpa_supp: wpa_printf_impl: argv[0]: interface_add
    [00:00:00.514,160] <dbg> wpa_supp: wpa_printf_impl: argv[1]: wlan0
    [00:00:00.514,190] <dbg> wpa_supp: wpa_printf_impl: argv[2]: zephyr
    [00:00:00.514,221] <dbg> wpa_supp: wpa_printf_impl: argv[3]: zephyr
    [00:00:00.514,251] <dbg> wpa_supp: wpa_printf_impl: argv[4]: zephyr
    [00:00:00.525,848] <dbg> wpa_supp: wpa_printf_impl: _wpa_drv_zep_set_key: priv:0x20002f08 alg 0 addr 0 key_idx 3 set_tx 0 seq 0 seq_len 0 key 0 key_len 0 key_flag 10
    [00:00:00.528,900] <dbg> wpa_supp: wpa_printf_impl: _wpa_drv_zep_set_key: priv:0x20002f08 alg 0 addr 0 key_idx 4 set_tx 0 seq 0 seq_len 0 key 0 key_len 0 key_flag 10
    [00:00:00.530,548] <dbg> wpa_supp: wpa_printf_impl: _wpa_drv_zep_set_key: priv:0x20002f08 alg 0 addr 0 key_idx 5 set_tx 0 seq 0 seq_len 0 key 0 key_len 0 key_flag 10
    [00:00:00.532,196] <dbg> wpa_supp: wpa_printf_impl: wlan0: RSN: flushing PMKID list in the driver
    [00:00:00.532,287] <dbg> wpa_supp: wpa_printf_impl: wlan0: State: DISCONNECTED -> INACTIVE
    [00:00:00.532,897] <dbg> wpa_supp: wpa_printf_impl: MBO: Update non-preferred channels, non_pref_chan=N/A
    [00:00:00.533,081] <dbg> wpa_supp: wpa_printf_impl: wlan0: Added interface wlan0
    [00:00:00.533,172] <dbg> wpa_supp: wpa_printf_impl: wlan0: State: INACTIVE -> DISCONNECTED
    --- 87 messages dropped ---
    [00:00:09.294,036] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: ENABLE_NETWORK id=0
    --- 4 messages dropped ---
    [00:00:09.294,128] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 0.000000 sec
    [00:00:09.294,342] <dbg> wpa_supp: wpa_printf_impl: wlan0: State: DISCONNECTED -> SCANNING
    [00:00:09.294,433] <dbg> wpa_supp: wpa_printf_impl: Scan SSID - hexdump_ascii(len=8):
    [00:00:09.294,464] <dbg> wpa_supp: _wpa_hexdump_ascii:
    48 69 7a 7a 75 6c 6f 6e |Hizzulon
    [00:00:09.294,525] <dbg> wpa_supp: wpa_printf_impl: wlan0: Include wildcard SSID in the scan request
    [00:00:09.294,738] <dbg> wpa_supp: wpa_printf_impl: wlan0: Add radio work 'scan'@0x200329a0
    [00:00:09.295,776] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
    [00:00:09.304,046] <dbg> wpa_supp: wpa_printf_impl: wpa_drv_zep_scan2: Scan requested - scan timeout 35 seconds
    [00:00:09.305,175] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SELECT_NETWORK 0'
    [00:00:09.305,236] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SELECT_NETWORK id=0
    [00:00:09.305,328] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 0.000000 sec
    [00:00:09.305,541] <dbg> wpa_supp: wpa_printf_impl: wlan0: Already scanning - Reschedule the incoming scan req
    [00:00:09.305,633] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 1.000000 sec
    [00:00:09.305,847] <dbg> wifi_supplicant: event_socket_handler: Passing message 47 to wpa_supplicant
    [00:00:09.305,938] <dbg> wpa_supp: wpa_printf_impl: wlan0: Event SCAN_STARTED (47) received
    [00:00:09.306,060] <dbg> wpa_supp: wpa_printf_impl: wlan0: Own scan request started a scan in 0.001801 seconds
    [00:00:09.306,304] <dbg> wpa_supp: wpa_printf_impl: Received len: 24, msg_len:24 - CTRL-EVENT-SCAN-STARTED ->END
    [00:00:10.305,847] <dbg> wpa_supp: wpa_printf_impl: wlan0: Already scanning - Reschedule the incoming scan req
    [00:00:10.305,969] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 1.000000 sec
    [00:00:11.306,213] <dbg> wpa_supp: wpa_printf_impl: wlan0: Already scanning - Reschedule the incoming scan req
    [00:00:11.306,304] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 1.000000 sec
    [00:00:12.306,518] <dbg> wpa_supp: wpa_printf_impl: wlan0: Already scanning - Reschedule the incoming scan req
    [00:00:12.306,640] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 1.000000 sec
    --- 44 messages dropped ---
    [00:00:13.929,321] <dbg> wpa_supp: wpa_printf_impl: WPA: Set own WPA IE default - hexdump(len=22): 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 02 80 00
    [00:00:13.929,412] <dbg> wpa_supp: wpa_printf_impl: RSN: Set own RSNXE default - hexdump(len=0):��
    [00:00:13.929,473] <dbg> wpa_supp: wpa_printf_impl: PSK (set in config) - hexdump(len=32): [REMOVED]
    [00:00:13.929,534] <dbg> wpa_supp: wpa_printf_impl: WPA: Set PMK based on external data - hexdump(len=32): [REMOVED]
    [00:00:13.929,595] <dbg> wpa_supp: wpa_printf_impl: RRM: Determining whether RRM can be used - device support: 0x50
    [00:00:13.929,656] <dbg> wpa_supp: wpa_printf_impl: RRM: Adding RRM IE to Association Request
    [00:00:13.930,206] <dbg> wpa_supp: wpa_printf_impl: Added supported operating classes IE - hexdump(len=10): 3b 08 80 51 52 73 76 79 7c 7d
    [00:00:13.930,328] <dbg> wpa_supp: wpa_printf_impl: wlan0: Cancelling scan request
    [00:00:13.930,511] <inf> wpa_supp: wlan0: SME: Trying to authenticate with fc:34:97:af:71:34 (SSID='Hizzulon' freq=5220 MHz)
    [00:00:13.930,633] <dbg> wpa_supp: wpa_printf_impl: wlan0: State: SCANNING -> AUTHENTICATING
    [00:00:13.934,783] <dbg> wpa_supp: wpa_printf_impl: Received len: 40, msg_len:40 - CTRL-EVENT-BSS-ADDED 0 fc:34:97:af:71:34->END
    [00:00:13.934,936] <dbg> wpa_supp: wpa_printf_impl: Received len: 24, msg_len:24 - CTRL-EVENT-SCAN-RESULTS ->END
    [00:00:13.935,119] <dbg> wpa_supp: wpa_printf_impl: Received len: 82, msg_len:82 - SME: Trying to authenticate with fc:34:97:af:71:34 (SSID='Hizzulon' freq=5220 MHz)->END
    --- 2 messages dropped ---
    [00:00:14.291,900] <dbg> wpa_supp: wpa_printf_impl: wlan0: SME: Authentication response: peer=fc:34:97:af:71:34 auth_type=0 auth_transaction=2 status_code=0
    --- 90 messages dropped ---
    [00:00:14.292,083] <dbg> wpa_supp: wpa_printf_impl: SME: Authentication response IEs - hexdump(len=11): dd 09 00 10 18 02 07 00 9c 00 00
    [00:00:14.292,510] <dbg> wpa_supp: wpa_printf_impl: SME: Association Request IEs - hexdump(len=52): 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 02 80 00 7f 0b 00 00 0a 02 00 40 40 00 00 00 20 46 05 70 00 00 00 00 3b 08 80 51 52 73 76 79 7c 7d
    [00:00:14.292,694] <inf> wpa_supp: wlan0: Trying to associate with fc:34:97:af:71:34 (SSID='Hizzulon' freq=5220 MHz)
    [00:00:14.337,249] <dbg> wpa_supp: wpa_printf_impl: WPA: KCK - hexdump(len=16): [REMOVED]
    [00:00:14.346,069] <dbg> wpa_supp: wpa_printf_impl: wlan0: Cancelling authentication timeout
    [00:00:14.346,191] <dbg> wpa_supp: wpa_printf_impl: wlan0: State: GROUP_HANDSHAKE -> COMPLETED
    [00:00:14.346,343] <dbg> wpa_supp: wpa_printf_impl: wlan0: Radio work 'sme-connect'@0x200329a0 done in 0.419311 seconds
    [00:00:14.346,496] <dbg> wpa_supp: wpa_printf_impl: wlan0: radio_work_free('sme-connect'@0x200329a0): num_active_works --> 0
    [00:00:14.346,710] <inf> wpa_supp: wlan0: CTRL-EVENT-CONNECTED - Connection to fc:34:97:af:71:34 completed [id=0 id_str=]
    [00:00:14.349,853] <dbg> wpa_supp: wpa_printf_impl: Received len: 73, msg_len:73 - WPA: Key negotiation completed with fc:34:97:af:71:34 [PTK=CCMP GTK=CCMP]->END
    [00:00:14.350,006] <dbg> wpa_supp: wpa_printf_impl: Received len: 79, msg_len:79 - CTRL-EVENT-CONNECTED - Connection to fc:34:97:af:71:34 completed [id=0 id_str=]->END
    [00:00:14.357,330] <inf> net_dhcpv4: Received: 192.168.1.203
    Connected
    uart:~$ wifi status
    Status: successful
    State: COMPLETED
    SSID: Hizzulon
    BSSID: FC:34:97:AF:71:34
    Band: 5GHz
    Channel: 44
    Security: WPA2-PSK
    MFP: Optional
    RSSI: -55
    DTIM: 1
    TWT: Supported
    Current PHY rate : 34400
    [00:00:25.801,727] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SIGNAL_POLL'
    [00:00:26.446,777] <dbg> wpa_supp: wpa_printf_impl: wpa_supp: Frame event
    [00:00:26.446,929] <dbg> wifi_supplicant: event_socket_handler: Passing message 18 to wpa_supplicant
    [00:00:26.446,990] <dbg> wpa_supp: wpa_printf_impl: wlan0: Event RX_MGMT (18) received
    [00:00:26.447,204] <dbg> wpa_supp: wpa_printf_impl: wlan0: Received Action frame: SA=fc:34:97:af:71:34 Category=5 DataLen=40 freq=5220 MHz
    [00:00:26.447,265] <dbg> wpa_supp: wpa_printf_impl: Measurement request type 5 token 144
    [00:00:26.447,326] <dbg> wpa_supp: wpa_printf_impl: Beacon request: invalid operating class 0
    [00:00:26.447,357] <dbg> wpa_supp: wpa_printf_impl: Beacon request: No valid channels
    [00:00:26.447,479] <dbg> wpa_supp: wpa_printf_impl: wpa_supp: Send Action frame (freq=5220 MHz wait=0 ms no_cck=0)
    [00:00:26.450,073] <dbg> wpa_supp: wpa_printf_impl: wpa_supp: Frame TX status event
    [00:00:26.450,225] <dbg> wifi_supplicant: event_socket_handler: Passing message 16 to wpa_supplicant
    Scan requested
    Num | SSID (len) | Chan (Band) | RSSI | Security | BSSID | MFP
    1 | Hizzulon 8 | 44 (5GHz ) | -56 | WPA2-PSK | FC:34:97:AF:71:34 | Disable
    Scan request done
    [00:00:26.450,317] <dbg> wpa_supp: wpa_printf_impl: wlan0: Event TX_STATUS (16) received
    [00:00:26.450,469] <dbg> wpa_supp: wpa_printf_impl: wlan0: EVENT_TX_STATUS dst=fc:34:97:af:71:34 type=0 stype=13
    [00:00:53.480,773] <dbg> wpa_supp: wpa_printf_impl: wpa_supp: Frame event
    [00:00:53.480,926] <dbg> wifi_supplicant: event_socket_handler: Passing message 18 to wpa_supplicant
    [00:00:53.481,018] <dbg> wpa_supp: wpa_printf_impl: wlan0: Event RX_MGMT (18) received
    [00:00:53.481,201] <dbg> wpa_supp: wpa_printf_impl: wlan0: Received Action frame: SA=fc:34:97:af:71:34 Category=5 DataLen=40 freq=5220 MHz
    [00:00:53.481,262] <dbg> wpa_supp: wpa_printf_impl: Measurement request type 5 token 150
    [00:00:53.481,323] <dbg> wpa_supp: wpa_printf_impl: Beacon request: invalid operating class 0
    [00:00:53.481,384] <dbg> wpa_supp: wpa_printf_impl: Beacon request: No valid channels
    [00:00:53.481,475] <dbg> wpa_supp: wpa_printf_impl: wpa_supp: Send Action frame (freq=5220 MHz wait=0 ms no_cck=0)
    [00:00:53.484,069] <dbg> wpa_supp: wpa_printf_impl: wpa_supp: Frame TX status event
    [00:00:53.484,222] <dbg> wifi_supplicant: event_socket_handler: Passing message 16 to wpa_supplicant
    [00:00:53.484,313] <dbg> wpa_supp: wpa_printf_impl: wlan0: Event TX_STATUS (16) received
    [00:00:53.484,466] <dbg> wpa_supp: wpa_printf_impl: wlan0: EVENT_TX_STATUS dst=fc:34:97:af:71:34 type=0 stype=13
    [00:01:09.455,535] <dbg> wpa_supp: wpa_printf_impl: wpa_supp: Frame event
    [00:01:09.455,688] <dbg> wifi_supplicant: event_socket_handler: Passing message 18 to wpa_supplicant
    [00:01:09.455,749] <dbg> wpa_supp: wpa_printf_impl: wlan0: Event RX_MGMT (18) received
    [00:01:09.455,963] <dbg> wpa_supp: wpa_printf_impl: wlan0: Received Action frame: SA=fc:34:97:af:71:34 Category=5 DataLen=40 freq=5220 MHz
    [00:01:09.456,024] <dbg> wpa_supp: wpa_printf_impl: Measurement request type 5 token 154
    [00:01:09.456,085] <dbg> wpa_supp: wpa_printf_impl: Beacon request: invalid operating class 0
    [00:01:09.456,115] <dbg> wpa_supp: wpa_printf_impl: Beacon request: No valid channels
    [00:01:09.456,207] <dbg> wpa_supp: wpa_printf_impl: wpa_supp: Send Action frame (freq=5220 MHz wait=0 ms no_cck=0)
    [00:01:09.458,831] <dbg> wpa_supp: wpa_printf_impl: wpa_supp: Frame TX status event
    [00:01:09.458,984] <dbg> wifi_supplicant: event_socket_handler: Passing message 16 to wpa_supplicant
    [00:01:09.459,075] <dbg> wpa_supp: wpa_printf_impl: wlan0: Event TX_STATUS (16) received
    [00:01:09.459,228] <dbg> wpa_supp: wpa_printf_impl: wlan0: EVENT_TX_STATUS dst=fc:34:97:af:71:34 type=0 stype=13
    Scan requested
    --- 15 messages dropped ---
    [00:02:15.691,192] <dbg> wpa_supp: wpa_printf_impl: wlan0: Removing interface wlan0
    [00:02:15.691,436] <dbg> wpa_supp: wpa_printf_impl: wlan0: Request to deauthenticate - bssid=00:00:00:00:00:00 pending_bssid=00:00:00:00:00:00 reason=3 (DEAUTH_LEAVING) state=INTERFACE_DISABLED
    [00:02:15.691,528] <dbg> wpa_supp: wpa_printf_impl: QM: Clear all active DSCP policies
    [00:02:15.691,589] <inf> wpa_supp: wlan0: CTRL-EVENT-DSCP-POLICY clear_all
    [00:02:15.691,741] <dbg> wpa_supp: wpa_printf_impl: wlan0: WPA: Clear old PMK and PTK
    [00:02:15.691,955] <dbg> wpa_supp: wpa_printf_impl: wlan0: BSS: Remove id 0 BSSID fc:34:97:af:71:34 SSID 'Hizzulon' due to wpa_bss_flush
    [00:02:15.692,138] <dbg> wpa_supp: wpa_printf_impl: wlan0: Cancelling scan request
    [00:02:15.692,230] <dbg> wpa_supp: wpa_printf_impl: wlan0: Cancelling authentication timeout
    [00:02:15.692,382] <dbg> wpa_supp: wpa_printf_impl: QM: Clear all active DSCP policies
    [00:02:15.692,443] <inf> wpa_supp: wlan0: CTRL-EVENT-DSCP-POLICY clear_all
    [00:02:15.692,504] <dbg> wpa_supp: wpa_printf_impl: Remove interface wlan0 from radio
    [00:02:15.692,535] <dbg> wpa_supp: wpa_printf_impl: Remove radio
    [00:02:17.848,602] <inf> wifi_supplicant: Network interface 1 (0x200013c0) up
    [00:02:17.848,632] <dbg> wifi_supplicant: add_interface: Adding interface wlan0 [1] (0x200013c0)
    [00:02:17.848,693] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: interface_add, argc: 5
    [00:02:17.848,724] <dbg> wpa_supp: wpa_printf_impl: argv[0]: interface_add
    [00:02:17.848,785] <dbg> wpa_supp: wpa_printf_impl: argv[1]: wlan0
    [00:02:17.848,815] <dbg> wpa_supp: wpa_printf_impl: argv[2]: zephyr
    [00:02:17.848,846] <dbg> wpa_supp: wpa_printf_impl: argv[3]: zephyr
    [00:02:17.848,876] <dbg> wpa_supp: wpa_printf_impl: argv[4]: zephyr
    [00:02:17.851,959] <dbg> wpa_supp: wpa_printf_impl: RX global ctrl_iface - hexdump_ascii(len=71):
    [00:02:17.857,635] <dbg> wpa_supp: wpa_printf_impl: wpa_supp: Added 802.11b mode based on 802.11g information
    [00:02:17.863,098] <dbg> wpa_supp: wpa_printf_impl: _wpa_drv_zep_set_key: priv:0x20002f08 alg 0 addr 0 key_idx 3 set_tx 0 seq 0 seq_len 0 key 0 key_len 0 key_flag 10
    [00:02:17.866,058] <dbg> wpa_supp: wpa_printf_impl: _wpa_drv_zep_set_key: priv:0x20002f08 alg 0 addr 0 key_idx 4 set_tx 0 seq 0 seq_len 0 key 0 key_len 0 key_flag 10
    [00:02:17.867,706] <dbg> wpa_supp: wpa_printf_impl: _wpa_drv_zep_set_key: priv:0x20002f08 alg 0 addr 0 key_idx 5 set_tx 0 seq 0 seq_len 0 key 0 key_len 0 key_flag 10
    [00:02:17.869,323] <dbg> wpa_supp: wpa_printf_impl: wlan0: RSN: flushing PMKID list in the driver
    [00:02:17.869,415] <dbg> wpa_supp: wpa_printf_impl: wlan0: State: DISCONNECTED -> INACTIVE
    [00:02:17.870,025] <dbg> wpa_supp: wpa_printf_impl: MBO: Update non-preferred channels, non_pref_chan=N/A
    [00:02:17.870,208] <dbg> wpa_supp: wpa_printf_impl: wlan0: Added interface wlan0
    [00:02:17.870,300] <dbg> wpa_supp: wpa_printf_impl: wlan0: State: INACTIVE -> DISCONNECTED
    uart:~$
    For the 2.4GHz connection failure, here are the logs, in case they help:
    uart:~$ wifi connect -s Hizzulon2 -p H1zzul0n -k 1
    [00:00:08.492,462] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: ENABLE_NETWORK id=0
    [00:00:08.492,553] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 0.000000 sec
    [00:00:08.492,797] <dbg> wpa_supp: wpa_printf_impl: wlan0: State: DISCONNECTED -> SCANNING
    [00:00:08.492,858] <dbg> wpa_supp: wpa_printf_impl: Scan SSID - hexdump_ascii(len=9):
    [00:00:08.492,889] <dbg> wpa_supp: _wpa_hexdump_ascii:
    48 69 7a 7a 75 6c 6f 6e 32 |Hizzulon 2
    [00:00:08.492,980] <dbg> wpa_supp: wpa_printf_impl: wlan0: Include wildcard SSID in the scan request
    [00:00:08.493,194] <dbg> wpa_supp: wpa_printf_impl: wlan0: Add radio work 'scan'@0x200329a0
    [00:00:08.494,232] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
    [00:00:08.503,051] <dbg> wpa_supp: wpa_printf_impl: wpa_drv_zep_scan2: Scan requested - scan timeout 35 seconds
    [00:00:08.504,150] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SELECT_NETWORK 0'
    [00:00:08.504,241] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SELECT_NETWORK id=0
    [00:00:08.504,333] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 0.000000 sec
    [00:00:08.504,547] <dbg> wpa_supp: wpa_printf_impl: wlan0: Already scanning - Reschedule the incoming scan req
    [00:00:08.504,638] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 1.000000 sec
    [00:00:08.504,852] <dbg> wifi_supplicant: event_socket_handler: Passing message 47 to wpa_supplicant
    [00:00:08.504,943] <dbg> wpa_supp: wpa_printf_impl: wlan0: Event SCAN_STARTED (47) received
    [00:00:08.505,065] <dbg> wpa_supp: wpa_printf_impl: wlan0: Own scan request started a scan in 0.001801 seconds
    [00:00:08.505,310] <dbg> wpa_supp: wpa_printf_impl: Received len: 24, msg_len:24 - CTRL-EVENT-SCAN-STARTED ->END
    [00:00:09.504,882] <dbg> wpa_supp: wpa_printf_impl: wlan0: Already scanning - Reschedule the incoming scan req
    [00:00:09.505,004] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 1.000000 sec
    [00:00:10.505,218] <dbg> wpa_supp: wpa_printf_impl: wlan0: Already scanning - Reschedule the incoming scan req
    [00:00:10.505,340] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 1.000000 sec
    [00:00:11.505,523] <dbg> wpa_supp: wpa_printf_impl: wlan0: Already scanning - Reschedule the incoming scan req
    [00:00:11.505,645] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 1.000000 sec
    [00:00:12.505,859] <dbg> wpa_supp: wpa_printf_impl: wlan0: Already scanning - Reschedule the incoming scan req
    [00:00:12.505,981] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 1.000000 sec
    [00:00:13.506,164] <dbg> wpa_supp: wpa_printf_impl: wlan0: Already scanning - Reschedule the incoming scan req
    [00:00:13.506,286] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 1.000000 sec
    [00:00:14.506,500] <dbg> wpa_supp: wpa_printf_impl: wlan0: Already scanning - Reschedule the incoming scan req
    [00:00:14.506,622] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 1.000000 sec
    [00:00:15.506,805] <dbg> wpa_supp: wpa_printf_impl: wlan0: Already scanning - Reschedule the incoming scan req
    [00:00:15.506,927] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 1.000000 sec
    [00:00:16.507,141] <dbg> wpa_supp: wpa_printf_impl: wlan0: Already scanning - Reschedule the incoming scan req
    [00:00:16.507,263] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 1.000000 sec
    [00:00:17.507,446] <dbg> wpa_supp: wpa_printf_impl: wlan0: Already scanning - Reschedule the incoming scan req
    [00:00:17.507,568] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 1.000000 sec
    [00:00:18.507,751] <dbg> wpa_supp: wpa_printf_impl: wlan0: Already scanning - Reschedule the incoming scan req
    [00:00:18.507,873] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 1.000000 sec
    [00:00:19.508,056] <dbg> wpa_supp: wpa_printf_impl: wlan0: Already scanning - Reschedule the incoming scan req
    [00:00:19.508,178] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 1.000000 sec
    [00:00:20.508,392] <dbg> wpa_supp: wpa_printf_impl: wlan0: Already scanning - Reschedule the incoming scan req
    [00:00:20.508,514] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 1.000000 sec
    [00:00:21.508,697] <dbg> wpa_supp: wpa_printf_impl: wlan0: Already scanning - Reschedule the incoming scan req
    [00:00:21.508,819] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 1.000000 sec
    [00:00:22.509,033] <dbg> wpa_supp: wpa_printf_impl: wlan0: Already scanning - Reschedule the incoming scan req
    [00:00:22.509,155] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 1.000000 sec
    [00:00:23.509,338] <dbg> wpa_supp: wpa_printf_impl: wlan0: Already scanning - Reschedule the incoming scan req
    [00:00:23.509,460] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 1.000000 sec
    [00:00:24.509,643] <dbg> wpa_supp: wpa_printf_impl: wlan0: Already scanning - Reschedule the incoming scan req
    [00:00:24.509,765] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 1.000000 sec
    [00:00:25.510,009] <dbg> wpa_supp: wpa_printf_impl: wlan0: Already scanning - Reschedule the incoming scan req
    [00:00:25.510,101] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 1.000000 sec
    [00:00:26.510,284] <dbg> wpa_supp: wpa_printf_impl: wlan0: Already scanning - Reschedule the incoming scan req
    [00:00:26.510,406] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 1.000000 sec
    [00:00:27.510,650] <dbg> wpa_supp: wpa_printf_impl: wlan0: Already scanning - Reschedule the incoming scan req
    [00:00:27.510,772] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 1.000000 sec
    [00:00:28.510,986] <dbg> wpa_supp: wpa_printf_impl: wlan0: Already scanning - Reschedule the incoming scan req
    [00:00:28.511,108] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 1.000000 sec
    [00:00:29.511,291] <dbg> wpa_supp: wpa_printf_impl: wlan0: Already scanning - Reschedule the incoming scan req
    [00:00:29.511,413] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 1.000000 sec
    [00:00:30.511,627] <dbg> wpa_supp: wpa_printf_impl: wlan0: Already scanning - Reschedule the incoming scan req
    [00:00:30.511,749] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 1.000000 sec
    [00:00:31.511,932] <dbg> wpa_supp: wpa_printf_impl: wlan0: Already scanning - Reschedule the incoming scan req
    [00:00:31.512,054] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 1.000000 sec
    [00:00:32.512,237] <dbg> wpa_supp: wpa_printf_impl: wlan0: Already scanning - Reschedule the incoming scan req
    [00:00:32.512,359] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 1.000000 sec
    [00:00:33.512,603] <dbg> wpa_supp: wpa_printf_impl: wlan0: Already scanning - Reschedule the incoming scan req
    [00:00:33.512,695] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 1.000000 sec
    [00:00:34.512,878] <dbg> wpa_supp: wpa_printf_impl: wlan0: Already scanning - Reschedule the incoming scan req
    [00:00:34.513,000] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 1.000000 sec
    [00:00:35.513,244] <dbg> wpa_supp: wpa_printf_impl: wlan0: Already scanning - Reschedule the incoming scan req
    [00:00:35.513,366] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 1.000000 sec
    [00:00:36.513,580] <dbg> wpa_supp: wpa_printf_impl: wlan0: Already scanning - Reschedule the incoming scan req
    [00:00:36.513,702] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 1.000000 sec
    --- 43 messages dropped ---
    [00:00:38.514,984] <dbg> wpa_supp: wpa_printf_impl: WPA: Set own WPA IE default - hexdump(len=22): 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 02 80 00
    [00:00:38.515,075] <dbg> wpa_supp: wpa_printf_impl: RSN: Set own RSNXE default - hexdump(len=0):(�
    [00:00:38.515,136] <dbg> wpa_supp: wpa_printf_impl: PSK (set in config) - hexdump(len=32): [REMOVED]
    [00:00:38.515,197] <dbg> wpa_supp: wpa_printf_impl: WPA: Set PMK based on external data - hexdump(len=32): [REMOVED]
    [00:00:38.515,258] <dbg> wpa_supp: wpa_printf_impl: RRM: Determining whether RRM can be used - device support: 0x50
    [00:00:38.515,319] <dbg> wpa_supp: wpa_printf_impl: RRM: Adding RRM IE to Association Request
    [00:00:38.515,838] <dbg> wpa_supp: wpa_printf_impl: Added supported operating classes IE - hexdump(len=10): 3b 08 51 51 52 73 76 79 7c 7d
    [00:00:38.515,960] <dbg> wpa_supp: wpa_printf_impl: wlan0: Cancelling scan request
    [00:00:38.516,174] <inf> wpa_supp: wlan0: SME: Trying to authenticate with fc:34:97:af:71:30 (SSID='Hizzulon2' freq=2442 MHz)
    [00:00:38.516,296] <dbg> wpa_supp: wpa_printf_impl: wlan0: State: SCANNING -> AUTHENTICATING
    [00:00:38.520,446] <dbg> wpa_supp: wpa_printf_impl: Received len: 40, msg_len:40 - CTRL-EVENT-BSS-ADDED 0 fc:34:97:af:71:30->END
    [00:00:38.520,599] <dbg> wpa_supp: wpa_printf_impl: Received len: 24, msg_len:24 - CTRL-EVENT-SCAN-RESULTS ->END
    [00:00:38.520,751] <dbg> wpa_supp: wpa_printf_impl: Received len: 83, msg_len:83 - SME: Trying to authenticate with fc:34:97:af:71:30 (SSID='Hizzulon2' freq=2442 MHz)->END
    [00:00:43.522,491] <dbg> wpa_supp: wpa_printf_impl: wlan0: radio_work_free('sme-connect'@0x200329a0): num_active_works --> 0
    [00:00:43.522,583] <dbg> wpa_supp: wpa_printf_impl: Added BSSID fc:34:97:af:71:30 into ignore list, ignoring for 10 seconds
    [00:00:43.522,705] <dbg> wpa_supp: wpa_printf_impl: wlan0: Consecutive connection failures: 1 --> request scan in 100 ms
    [00:00:43.522,827] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 0.100000 sec
    [00:00:43.522,949] <dbg> wpa_supp: wpa_printf_impl: wlan0: State: AUTHENTICATING -> DISCONNECTED
    [00:00:43.623,016] <dbg> wpa_supp: wpa_printf_impl: wlan0: State: DISCONNECTED -> SCANNING
    [00:00:43.623,107] <dbg> wpa_supp: wpa_printf_impl: wlan0: Starting AP scan for wildcard SSID
    [00:00:43.623,321] <dbg> wpa_supp: wpa_printf_impl: wlan0: Add radio work 'scan'@0x20032348
    [00:00:43.623,474] <dbg> wpa_supp: wpa_printf_impl: wlan0: First radio work item in the queue - schedule start immediately
    [00:00:43.623,718] <dbg> wpa_supp: wpa_printf_impl: wlan0: Starting radio work 'scan'@0x20032348 after 0.000214 second wait
    [00:00:43.626,159] <dbg> wpa_supp: wpa_printf_impl: wpa_drv_zep_scan2: Scan requested - scan timeout 35 seconds
    [00:00:46.530,639] <dbg> wifi_supplicant: event_socket_handler: Passing message 11 to wpa_supplicant
    [00:00:46.530,731] <dbg> wpa_supp: wpa_printf_impl: wlan0: Event DEAUTH (11) received
    [00:00:46.530,822] <dbg> wpa_supp: wpa_printf_impl: wlan0: Deauthentication notification
    [00:00:46.530,914] <dbg> wpa_supp: wpa_printf_impl: wlan0: * reason 3 (DEAUTH_LEAVING)
    [00:00:46.531,036] <dbg> wpa_supp: wpa_printf_impl: wlan0: * address f4:ce:36:00:23:2c
    [00:00:46.531,097] <dbg> wpa_supp: wpa_printf_impl: Deauthentication frame IE(s) - hexdump(len=0): [NULL]
    [00:00:46.531,219] <dbg> wpa_supp: wpa_printf_impl: wlan0: Auto connect enabled: try to reconnect (wps=0/0 wpa_state=3)
    [00:00:46.531,311] <dbg> wpa_supp: wpa_printf_impl: wlan0: Do not request new immediate scan
    [00:00:46.531,402] <dbg> wpa_supp: wpa_printf_impl: wlan0: WPA: Clear old PMK and PTK
    [00:00:46.531,524] <dbg> wpa_supp: wpa_printf_impl: wlan0: Disconnect event - remove keys
    [00:00:46.531,646] <dbg> wpa_supp: wpa_printf_impl: wlan0: State: SCANNING -> DISCONNECTED
    --- 3 messages dropped ---
    [00:01:13.628,845] <dbg> wpa_supp: wpa_printf_impl: 00:00:00:00:00:00 freq=0 qual=0 noise=-89 level=0 flags=0x7 age=0 est=0
    [00:01:13.628,906] <dbg> wpa_supp: wpa_printf_impl: wlan0: BSS: Start scan result update 2
    [00:01:13.629,058] <dbg> wpa_supp: wpa_printf_impl: wlan0: BSS: No SSID IE included for 00:00:00:00:00:00
    [00:01:13.629,119] <dbg> wpa_supp: wpa_printf_impl: BSS: last_scan_res_used=0/32
    [00:01:13.629,211] <dbg> wpa_supp: wpa_printf_impl: wlan0: New scan results available (own=0 ext=0)
    [00:01:13.629,425] <dbg> wpa_supp: wpa_printf_impl: wlan0: Radio work 'scan'@0x20032348 done in 30.005706 seconds
    [00:01:13.629,577] <dbg> wpa_supp: wpa_printf_impl: wlan0: radio_work_free('scan'@0x20032348): num_active_works --> 0
    [00:01:13.629,669] <dbg> wpa_supp: wpa_printf_impl: wlan0: No suitable network found
    [00:01:13.629,760] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 5.000000 sec
    [00:01:13.630,035] <dbg> wpa_supp: wpa_printf_impl: Received len: 24, msg_len:24 - CTRL-EVENT-SCAN-RESULTS ->END
    [00:01:13.630,187] <dbg> wpa_supp: wpa_printf_impl: Received len: 29, msg_len:29 - CTRL-EVENT-NETWORK-NOT-FOUND ->END
    [00:01:18.629,974] <dbg> wpa_supp: wpa_printf_impl: wlan0: State: DISCONNECTED -> SCANNING
    [00:01:18.630,065] <dbg> wpa_supp: wpa_printf_impl: Scan SSID - hexdump_ascii(len=9):
    [00:01:18.630,065] <dbg> wpa_supp: _wpa_hexdump_ascii:
    [00:01:18.630,157] <dbg> wpa_supp: wpa_printf_impl: wlan0: Include wildcard SSID in the scan request
    [00:01:18.630,371] <dbg> wpa_supp: wpa_printf_impl: wlan0: Add radio work 'scan'@0x20032c88
    [00:01:18.630,493] <dbg> wpa_supp: wpa_printf_impl: wlan0: First radio work item in the queue - schedule start immediately
    [00:01:18.630,737] <dbg> wpa_supp: wpa_printf_impl: wlan0: Starting radio work 'scan'@0x20032c88 after 0.000214 second wait
    [00:01:18.633,605] <dbg> wpa_supp: wpa_printf_impl: wpa_drv_zep_scan2: Scan requested - scan timeout 35 seconds
    uart:~$
  • It sounds like you have not been able to reproduce this locally. I'm attaching an exported configuration from my Asus ZenMax WiFi XT8 (AX6600) (running current latest firmware 3.0.0.4.388_24688-gf94212b) in case that helps.
    I haven't tried loading an external config, but if you connect to the web interface, Administration, Restore/Save/Upload Setting tab, there is a button to upload a configuration.
    If it works, there will be a 2.4GHz network "Hizzulon2" and a 5GHz network "Hizzulon". I didn't export the passwords so you will probably have to set those.
    There are also some mesh configs, but it should be fine if there's no mesh to connect to.
    Settings_ZenWiFi AX.CFG
  • Indeed, we have not been able to reproduce it locally yet. I'm sorry the potential fix didn't help. The investigation continues then. Again, thank you for your thorough responses. They're much appreciated.
    I'll get back to you with any further suggestions from our end.
    Simon
  • Hi
    From the logs and since we can't reproduce this using your configurations in the lab, the problem looks to be due to the environment and not AP configuration. Can you try out this .hex file as well and get the log from it? We've added a few more debug flags to get a better idea of what's going on.
     zephyr_logs_v2.hex
    Simon
  • Here are the logs from zephyr_logs_v2.hex
    uart:~$
    [00:00:00.523,864] <dbg> wpa_supp: wpa_printf_impl: wpa_supplicant v2.11-devel
    [00:00:00.524,414] <inf> wifi_supplicant: wpa_supplicant initialized
    [00:00:00.525,024] <dbg> wifi_supplicant: add_interface: Adding interface wlan0 [1] (0x200013c0)
    [00:00:00.525,085] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: interface_add, argc: 5
    [00:00:00.525,146] <dbg> wpa_supp: wpa_printf_impl: argv[0]: interface_add
    [00:00:00.525,177] <dbg> wpa_supp: wpa_printf_impl: argv[1]: wlan0
    [00:00:00.525,207] <dbg> wpa_supp: wpa_printf_impl: argv[2]: zephyr
    [00:00:00.525,238] <dbg> wpa_supp: wpa_printf_impl: argv[3]: zephyr
    [00:00:00.525,299] <dbg> wpa_supp: wpa_printf_impl: argv[4]: zephyr
    [00:00:00.536,834] <dbg> wpa_supp: wpa_printf_impl: _wpa_drv_zep_set_key: priv:0x20002f08 alg 0 addr 0 key_idx 3 set_tx 0 seq 0 seq_len 0 key 0 key_len 0 key_flag 10
    [00:00:00.539,825] <dbg> wpa_supp: wpa_printf_impl: _wpa_drv_zep_set_key: priv:0x20002f08 alg 0 addr 0 key_idx 4 set_tx 0 seq 0 seq_len 0 key 0 key_len 0 key_flag 10
    [00:00:00.541,473] <dbg> wpa_supp: wpa_printf_impl: _wpa_drv_zep_set_key: priv:0x20002f08 alg 0 addr 0 key_idx 5 set_tx 0 seq 0 seq_len 0 key 0 key_len 0 key_flag 10
    [00:00:00.543,090] <dbg> wpa_supp: wpa_printf_impl: wlan0: RSN: flushing PMKID list in the driver
    [00:00:00.543,182] <dbg> wpa_supp: wpa_printf_impl: wlan0: State: DISCONNECTED -> INACTIVE
    [00:00:00.543,792] <dbg> wpa_supp: wpa_printf_impl: MBO: Update non-preferred channels, non_pref_chan=N/A
    [00:00:00.543,975] <dbg> wpa_supp: wpa_printf_impl: wlan0: Added interface wlan0
    [00:00:00.544,067] <dbg> wpa_supp: wpa_printf_impl: wlan0: State: INACTIVE -> DISCONNECTED
    uart:~$ wifi scan
    Scan requested
    uart:~$ debug event 1122  0000  0000
    debug event 1127  0001  0000
    debug event 1127  0002  0000
    debug event 1127  0003  0000
    debug event 1127  0004  0000
    debug event 1127  0005  0000
    debug event 1127  0006  0000
    debug event 1127  0007  0000
    debug event 1127  0008  0000
    debug event 1127  0009  0000
    debug event 1127  000a  0000
    debug event 1127  000b  0000
    debug event 1127  000c  0000
    debug event 1127  000d  0000
    debug event 1127  000e  0000
    debug event 1124  0000  0000
    debug event 113000  0000  0000
    debug event 113001  0000  0000
    debug event 1127  0024  0000
    debug event 1127  0028  0000
    debug event 1127  002c  0000
    debug event 1127  0030  0000
    debug event 1127  0034  0000
    debug event 1127  0038  0000
    debug event 1127  003c  0000
    debug event 1127  0040  0000
    debug event 1127  0064  0000
    debug event 1127  0068  0000
    debug event 1127  006c  0000
    debug event 1127  0070  0000
    debug event 1127  0074  0000
    debug event 1127  0078  0000
    debug event 1127  007c  0000
    debug event 1127  0080  0000
    debug event 1127  0084  0000
    debug event 1127  0088  0000
    debug event 1127  008c  0000
    debug event 1127  0090  0000
    debug event 1127  0095  0000
    debug event 1127  0099  0000
    debug event 1127  009d  0000
    debug event 1127  00a1  0000
    debug event 1127  00a5  0000
    debug event 1127  00a9  0000
    debug event 1127  00ad  0000
    debug event 1127  00b1  0000
    1    |                                  0     | 161  (5GHz  ) | -57  | WPA2-PSK        | BA:34:97:AF:71:3D | Disable
    2    |                                  0     | 161  (5GHz  ) | -57  | WPA2-PSK        | FC:34:97:AF:71:38 | Disable
    3    | Hizzulon                         8     | 44   (5GHz  ) | -57  | WPA2-PSK        | FC:34:97:AF:71:34 | Disable
    4    | Hizzulon2                        9     | 7    (2.4GHz) | -62  | WPA2-PSK        | FC:34:97:AF:71:30 | Disable
    5    |                                  0     | 44   (5GHz  ) | -76  | WPA2-PSK        | 22:EF:BD:34:5E:DF | Disable
    6    | Padres19                         8     | 10   (2.4GHz) | -80  | WPA2-PSK        | BC:9A:8E:33:9A:74 | Optional
    7    | ATT5ffDcTA                       10    | 2    (2.4GHz) | -81  | WPA2-PSK        | 74:8A:0D:86:7F:D0 | Optional
    8    | Cycle                            5     | 5    (2.4GHz) | -89  | WPA2-PSK        | F0:2F:74:C5:75:F8 | Disable
    9    | ATTkuv7HS2_Guest                 16    | 1    (2.4GHz) | -90  | WPA2-PSK        | 5A:60:D8:7C:DD:31 | Optional
    10   |                                  0     | 10   (2.4GHz) | -91  | WPA2-PSK        | 3C:A3:08:9E:D7:11 | Disable
    Scan request done
    [00:00:22.130,767] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: ENABLE_NETWORK id=0
    [00:00:22.130,889] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 0.000000 sec
    [00:00:22.131,103] <dbg> wpa_supp: wpa_printf_impl: wlan0: State: DISCONNECTED -> SCANNING
    [00:00:22.131,164] <dbg> wpa_supp: wpa_printf_impl: Scan SSID - hexdump_ascii(len=8):
    [00:00:22.131,195] <dbg> wpa_supp: _wpa_hexdump_ascii:
    [00:00:22.131,286] <dbg> wpa_supp: wpa_printf_impl: wlan0: Include wildcard SSID in the scan request
    [00:00:22.131,500] <dbg> wpa_supp: wpa_printf_impl: wlan0: Add radio work 'scan'@0x20032158
    [00:00:22.132,537] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
    [00:00:22.141,052] <dbg> wpa_supp: wpa_printf_impl: wpa_drv_zep_scan2: Scan requested - scan timeout 35 seconds
    [00:00:22.142,730] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SELECT_NETWORK 0'
    [00:00:22.142,822] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SELECT_NETWORK id=0
    [00:00:22.142,913] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 0.000000 sec
    [00:00:22.143,127] <dbg> wpa_supp: wpa_printf_impl: wlan0: Already scanning - Reschedule the incoming scan req
    [00:00:22.143,218] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 1.000000 sec
    [00:00:22.148,773] <dbg> wifi_supplicant: event_socket_handler: Passing message 47 to wpa_supplicant
    [00:00:22.148,864] <dbg> wpa_supp: wpa_printf_impl: wlan0: Event SCAN_STARTED (47) received
    [00:00:22.148,986] <dbg> wpa_supp: wpa_printf_impl: wlan0: Own scan request started a scan in 0.007691 seconds
    [00:00:22.149,230] <dbg> wpa_supp: wpa_printf_impl: Received len: 24, msg_len:24 - CTRL-EVENT-SCAN-STARTED ->END
    uart:~$ debug event 1127  0002  0000
    [00:00:23.143,402] <dbg> wpa_supp: wpa_printf_impl: wlan0: Already scanning - Reschedule the incoming scan req
    [00:00:23.143,524] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 1.000000 sec
    uart:~$ debug event 1127  0068  0000
    [00:00:24.143,768] <dbg> wpa_supp: wpa_printf_impl: wlan0: Already scanning - Reschedule the incoming scan req
    [00:00:24.143,890] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 1.000000 sec
    uart:~$ debug event 1127  0088  0000
    [00:00:25.144,073] <dbg> wpa_supp: wpa_printf_impl: wlan0: Already scanning - Reschedule the incoming scan req
    [00:00:25.144,195] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 1.000000 sec
    uart:~$ debug event 1127  00a9  0000
    [00:00:26.618,164] <dbg> wpa_supp: wpa_printf_impl: WPA: Set own WPA IE default - hexdump(len=22): 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 02 80 00
    [00:00:26.618,225] <dbg> wpa_supp: wpa_printf_impl: RSN: Set own RSNXE default - hexdump(len=0):
    [00:00:26.618,286] <dbg> wpa_supp: wpa_printf_impl: PSK (set in config) - hexdump(len=32): [REMOVED]
    [00:00:26.618,377] <dbg> wpa_supp: wpa_printf_impl: WPA: Set PMK based on external data - hexdump(len=32): [REMOVED]
    [00:00:26.618,438] <dbg> wpa_supp: wpa_printf_impl: RRM: Determining whether RRM can be used - device support: 0x50
    [00:00:26.618,499] <dbg> wpa_supp: wpa_printf_impl: RRM: Adding RRM IE to Association Request
    [00:00:26.619,018] <dbg> wpa_supp: wpa_printf_impl: Added supported operating classes IE - hexdump(len=10): 3b 08 80 51 52 73 76 79 7c 7d
    [00:00:26.619,171] <dbg> wpa_supp: wpa_printf_impl: wlan0: Cancelling scan request
    [00:00:26.619,354] <inf> wpa_supp: wlan0: SME: Trying to authenticate with fc:34:97:af:71:34 (SSID='Hizzulon' freq=5220 MHz)
    [00:00:26.619,476] <dbg> wpa_supp: wpa_printf_impl: wlan0: State: SCANNING -> AUTHENTICATING
    [00:00:26.623,596] <dbg> wpa_supp: wpa_printf_impl: Received len: 40, msg_len:40 - CTRL-EVENT-BSS-ADDED 0 fc:34:97:af:71:34->END
    [00:00:26.623,779] <dbg> wpa_supp: wpa_printf_impl: Received len: 24, msg_len:24 - CTRL-EVENT-SCAN-RESULTS ->END
    [00:00:26.623,931] <dbg> wpa_supp: wpa_printf_impl: Received len: 82, msg_len:82 - SME: Trying to authenticate with fc:34:97:af:71:34 (SSID='Hizzulon' freq=5220 MHz)->END
    [00:00:26.980,926] <dbg> wpa_supp: wpa_printf_impl: wlan0: SME: Authentication response: peer=fc:34:97:af:71:34 auth_type=0 auth_transaction=2 status_code=0
    [00:00:26.981,079] <dbg> wpa_supp: wpa_printf_impl: SME: Authentication response IEs - hexdump(len=11): dd 09 00 10 18 02 07 00 9c 00 00
    [00:00:26.981,567] <dbg> wpa_supp: wpa_printf_impl: SME: Association Request IEs - hexdump(len=52): 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 02 80 00 7f 0b 00 00 0a 02 00 40 40 00 00 00 20 46 05 70 00 00 00 00 3b 08 80 51 52 73 76 79 7c 7d
    [00:00:26.981,750] <inf> wpa_supp: wlan0: Trying to associate with fc:34:97:af:71:34 (SSID='Hizzulon' freq=5220 MHz)
    [00:00:27.026,245] <dbg> wpa_supp: wpa_printf_impl: WPA: KCK - hexdump(len=16): [REMOVED]
    [00:00:27.035,064] <dbg> wpa_supp: wpa_printf_impl: wlan0: Cancelling authentication timeout
    [00:00:27.035,186] <dbg> wpa_supp: wpa_printf_impl: wlan0: State: GROUP_HANDSHAKE -> COMPLETED
    [00:00:27.035,339] <dbg> wpa_supp: wpa_printf_impl: wlan0: Radio work 'sme-connect'@0x20032ca8 done in 0.419464 seconds
    [00:00:27.035,491] <dbg> wpa_supp: wpa_printf_impl: wlan0: radio_work_free('sme-connect'@0x20032ca8): num_active_works --> 0
    [00:00:27.035,675] <inf> wpa_supp: wlan0: CTRL-EVENT-CONNECTED - Connection to fc:34:97:af:71:34 completed [id=0 id_str=]
    [00:00:27.038,818] <dbg> wpa_supp: wpa_printf_impl: Received len: 73, msg_len:73 - WPA: Key negotiation completed with fc:34:97:af:71:34 [PTK=CCMP GTK=CCMP]->END
    [00:00:27.038,970] <dbg> wpa_supp: wpa_printf_impl: Received len: 79, msg_len:79 - CTRL-EVENT-CONNECTED - Connection to fc:34:97:af:71:34 completed [id=0 id_str=]->END
    [00:00:27.045,471] <inf> net_dhcpv4: Received: 192.168.1.203
    Connected
    uart:~$ wifi status
    Status: successful
    State: COMPLETED
    SSID: Hizzulon
    Band: 5GHz
    Channel: 44
    Security: WPA2-PSK
    MFP: Optional
    RSSI: -57
    DTIM: 1
    TWT: Supported
    uart:~$ debug event 214000  0008  0004
    [00:00:31.353,851] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SIGNAL_POLL'
    [00:00:38.840,667] <dbg> wpa_supp: wpa_printf_impl: wpa_supp: Frame event
    [00:00:38.840,820] <dbg> wifi_supplicant: event_socket_handler: Passing message 18 to wpa_supplicant
    [00:00:38.840,881] <dbg> wpa_supp: wpa_printf_impl: wlan0: Event RX_MGMT (18) received
    [00:00:38.841,064] <dbg> wpa_supp: wpa_printf_impl: wlan0: Received Action frame: SA=fc:34:97:af:71:34 Category=5 DataLen=40 freq=5220 MHz
    [00:00:38.841,156] <dbg> wpa_supp: wpa_printf_impl: Measurement request type 5 token 208
    [00:00:38.841,217] <dbg> wpa_supp: wpa_printf_impl: Beacon request: invalid operating class 0
    [00:00:38.841,247] <dbg> wpa_supp: wpa_printf_impl: Beacon request: No valid channels
    [00:00:38.841,339] <dbg> wpa_supp: wpa_printf_impl: wpa_supp: Send Action frame (freq=5220 MHz wait=0 ms no_cck=0)
    [00:00:38.843,902] <dbg> wpa_supp: wpa_printf_impl: wpa_supp: Frame TX status event
    [00:00:38.844,055] <dbg> wifi_supplicant: event_socket_handler: Passing message 16 to wpa_supplicant
    [00:00:38.844,146] <dbg> wpa_supp: wpa_printf_impl: wlan0: Event TX_STATUS (16) received
    [00:00:38.844,299] <dbg> wpa_supp: wpa_printf_impl: wlan0: EVENT_TX_STATUS dst=fc:34:97:af:71:34 type=0 stype=13
    Scan requested
    debug event 112500  0000  0000
    debug event 112501  0000  0000
    debug event 112502  0000  0000
    1    | Hizzulon                         8     | 44   (5GHz  ) | -55  | WPA2-PSK        | FC:34:97:AF:71:34 | Disable
    Scan request done
    Scan requested
    debug event 214000  0008  0002
    Scan request done
    [00:01:09.765,838] <dbg> wpa_supp: wpa_printf_impl: wpa_supp: Frame event
    [00:01:09.766,021] <dbg> wifi_supplicant: event_socket_handler: Passing message 18 to wpa_supplicant
    [00:01:09.766,082] <dbg> wpa_supp: wpa_printf_impl: wlan0: Event RX_MGMT (18) received
    [00:01:09.766,296] <dbg> wpa_supp: wpa_printf_impl: wlan0: Received Action frame: SA=fc:34:97:af:71:34 Category=5 DataLen=40 freq=5220 MHz
    [00:01:09.766,357] <dbg> wpa_supp: wpa_printf_impl: Measurement request type 5 token 212
    [00:01:09.766,418] <dbg> wpa_supp: wpa_printf_impl: Beacon request: invalid operating class 0
    [00:01:09.766,448] <dbg> wpa_supp: wpa_printf_impl: Beacon request: No valid channels
    [00:01:09.766,540] <dbg> wpa_supp: wpa_printf_impl: wpa_supp: Send Action frame (freq=5220 MHz wait=0 ms no_cck=0)
    [00:01:09.769,104] <dbg> wpa_supp: wpa_printf_impl: wpa_supp: Frame TX status event
    [00:01:09.769,256] <dbg> wifi_supplicant: event_socket_handler: Passing message 16 to wpa_supplicant
    [00:01:09.769,348] <dbg> wpa_supp: wpa_printf_impl: wlan0: Event TX_STATUS (16) received
    [00:01:09.769,500] <dbg> wpa_supp: wpa_printf_impl: wlan0: EVENT_TX_STATUS dst=fc:34:97:af:71:34 type=0 stype=13
    Scan requested
    ... last line repeats forever
    It fails the same as before on channel 165.
    One new behavior, which is probably just random chance rather than a difference in this image, is that the first scan on channel 165 in this log completed. But when I scanned the same channel immediately afterwards, it didn't finish. I did multiple runs and could never get it to complete again, so seems a small chance.
