WiFi scan while connected
Does the NCS stack + nRF7002 support scanning while connected? I would expect it could, to support handoff, but getting errors.
Using nRF7002-DK and NCS 2.8.0.
Compile the wifi/shell example for nrf7002dk/nrf5340/cpuapp, no other changes.
*** Booting nRF Connect SDK v2.8.0-a2386bfc8401 ***
*** Using Zephyr OS v3.7.99-0bc3393fb112 ***
Starting nrf7002dk with CPU frequency: 128 MHz
[00:00:00.532,226] <inf> wifi_supplicant: wpa_supplicant initialized
uart:~$ wifi connect -s Hizzulon <my AP credentials>
Connection requested
Connected
[00:00:19.725,433] <inf> wpa_supp: MBO: Disable MBO/OCE due to misbehaving AP not having enabled PMF
[00:00:19.726,226] <inf> wpa_supp: wlan0: SME: Trying to authenticate with fc:34:97:af:71:54 (SSID='Hizzulon' freq=5220 MHz)
[00:00:20.086,120] <inf> wpa_supp: wlan0: Trying to associate with fc:34:97:af:71:54 (SSID='Hizzulon' freq=5220 MHz)
[00:00:20.102,874] <inf> wpa_supp: wlan0: Associated with fc:34:97:af:71:54
[00:00:20.103,027] <inf> wpa_supp: MBO: Disable MBO/OCE due to misbehaving AP not having enabled PMF
[00:00:20.103,118] <inf> wpa_supp: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
[00:00:20.122,253] <inf> wpa_supp: wlan0: WPA: Key negotiation completed with fc:34:97:af:71:54 [PTK=CCMP GTK=CCMP]
[00:00:20.122,467] <inf> wpa_supp: wlan0: CTRL-EVENT-CONNECTED - Connection to fc:34:97:af:71:54 completed [id=0 id_str=]
[00:00:20.137,420] <inf> net_dhcpv4: Received: 192.168.1.203
uart:~$ wifi status
Status: successful
State: COMPLETED
Interface Mode: STATION
Link Mode: WIFI 6 (802.11ax/HE)
SSID: Hizzulon
BSSID: FC:34:97:AF:71:54
Band: 5GHz
Channel: 44
Security: WPA2-PSK
MFP: Optional
RSSI: -34
Beacon Interval: 100
DTIM: 1
TWT: Supported
Current PHY rate : 26000
uart:~$ wifi scan
Scan requested
[wait ~30 seconds]
Scan request failed (-116)
[wait another ~30 seconds]
[00:01:33.363,311] <err> wifi_nrf: nrf_wifi_fmac_chg_vif_state: RPU is unresponsive for 10 sec
[00:01:33.363,342] <err> wifi_nrf: nrf_wifi_if_stop_zep: nrf_wifi_fmac_chg_vif_state failed
[00:01:33.364,013] <inf> wifi_supplicant: Network interface 1 (0x200013c0) down
[00:01:33.375,396] <inf> wpa_supp: wlan0: CTRL-EVENT-DSCP-POLICY clear_all
[00:01:33.375,854] <inf> wpa_supp: wlan0: CTRL-EVENT-DSCP-POLICY clear_all
[00:01:35.533,050] <inf> wifi_supplicant: Network interface 1 (0x200013c0) up
uart:~$ wifi status
Status: successful
State: DISCONNECTED
uart:~$
So the scan fails, but later there's another error that looks like the low-level nRF7002 driver failing and recovering (CONFIG_NRF_WIFI_RPU_RECOVERY is enabled by default).
If scan while connected isn't a supported feature, I would expect it to error immediately, not get into a state where it drops the connection?
A probably related issue: if I issue "wifi connect" with invalid credentials, wifi status is "SCANNING" forever (certainly much longer than the 30 second scan timeout), and later connect requests fail with:
uart:~$ wifi connect <credentials>
[00:01:58.298,828] <inf> wpa_supp: wlan0: CTRL-EVENT-DSCP-POLICY clear_all
[00:01:58.302,124] <inf> wpa_supp: wlan0: Reject scan trigger since one is already pending
[00:01:58.302,246] <wrn> wpa_supp: wlan0: Failed to initiate AP scan
[00:01:58.304,992] <inf> wpa_supp: wlan0: Reject scan trigger since one is already pending
[00:01:58.305,114] <wrn> wpa_supp: wlan0: Failed to initiate AP scan
I need to explicitly do "wifi disconnect" before it will stop scanning and allow another connection. Normally, issuing a connect command while already connected disconnects automatically then initiates the new connection.
  • Hi Remi
    Another week and another patch you can try. Mainly to get more logs:zephyr_logs_v3.hex
    Can you also confirm if this is something you only see on one specific board or if you see this behavior on multiple DKs/boards?
    Simon
  • Here are the logs:
    [00:00:00.516,052] <inf> fs_nvs: 2 Sectors of 4096 bytes
    [00:00:00.516,082] <inf> fs_nvs: alloc wra: 0, fe8
    [00:00:00.516,082] <inf> fs_nvs: data wra: 0, 0
    *** Booting nRF Connect SDK v2.8.0-1d192a274cd7 ***
    *** Using Zephyr OS v3.7.99-cbd75f256cc9 ***
    [00:00:00.518,066] <inf> wifi_supplicant: wpa_supplicant initialized
    uart:~$ wifi scan
    Scan requested
    uart:~$ debug event 00001122  00000000  00000000  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00112700  00000000  00000001  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00112700  00000000  00000002  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00112700  00000000  00000003  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00112700  00000000  00000004  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00112700  00000000  00000005  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00112700  00000000  00000006  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00112700  00000000  00000007  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00112700  00000000  00000008  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00112700  00000000  00000009  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00112700  00000000  0000000a  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00112700  00000000  0000000b  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00112700  00000000  0000000c  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00112700  00000000  0000000d  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00112700  00000000  0000000e  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00001124  00000000  00000000  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00113000  00000000  00000000  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00113001  00000000  00000000  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00112700  00000000  00000024  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00112700  00000000  00000028  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00112700  00000000  0000002c  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00112700  00000000  00000030  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00112700  00000000  00000034  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00112700  00000000  00000038  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00112700  00000000  0000003c  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00112700  00000000  00000040  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00112700  00000000  00000064  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00112700  00000000  00000068  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00112700  00000000  0000006c  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00112700  00000000  00000070  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00112700  00000000  00000074  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00112700  00000000  00000078  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00112700  00000000  0000007c  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00112700  00000000  00000080  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00112700  00000000  00000084  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00112700  00000000  00000088  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00112700  00000000  0000008c  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00112700  00000000  00000090  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00112700  00000000  00000095  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00112700  00000000  00000099  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00112700  00000000  0000009d  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00112700  00000000  000000a1  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00112700  00000000  000000a5  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00112700  00000000  000000a9  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00112700  00000000  000000ad  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00112700  00000000  000000b1  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    Num  | SSID                             (len) | Chan (Band)   | RSSI | Security        | BSSID             | MFP
    1    | Hizzulon2                        9     | 7    (2.4GHz) | -51  | WPA2-PSK        | FC:34:97:AF:71:30 | Disable
    2    | Hizzulon                         8     | 48   (5GHz  ) | -62  | WPA2-PSK        | FC:34:97:AF:71:34 | Disable
    3    |                                  0     | 161  (5GHz  ) | -66  | WPA2-PSK        | BA:34:97:AF:71:3D | Disable
    4    |                                  0     | 161  (5GHz  ) | -66  | WPA2-PSK        | FC:34:97:AF:71:38 | Disable
    5    |                                  0     | 48   (5GHz  ) | -82  | WPA2-PSK        | 22:EF:BD:34:5E:DF | Disable
    6    | ATT5cs7fRv_Guest                 16    | 10   (2.4GHz) | -82  | WPA2-PSK        | C2:BD:13:3B:A3:2A | Optional
    7    | CocktailClub                     12    | 10   (2.4GHz) | -84  | WPA2-PSK        | A0:2D:13:3B:A3:29 | Disable
    8    |                                  0     | 149  (5GHz  ) | -86  | WPA2-PSK        | BC:9A:8E:33:9A:7F | Optional
    9    | Padres19                         8     | 149  (5GHz  ) | -86  | WPA2-PSK        | BC:9A:8E:33:9A:7C | Optional
    10   | MySpectrumWiFiD9-2G              19    | 11   (2.4GHz) | -86  | WPA2-PSK        | C8:B4:22:2A:13:D7 | Disable
    11   |                                  0     | 1    (2.4GHz) | -87  | WPA2-PSK        | 7A:83:C2:03:48:A8 | Disable
    12   | CocktailClub                     12    | 11   (2.4GHz) | -89  | WPA2-PSK        | A0:2D:13:64:CC:E5 | Disable
    13   | c67a96cd                         8     | 1    (2.4GHz) | -91  | WPA2-PSK        | 50:2C:C6:7A:96:CD | Disable
    Scan request done
    uart:~$ wifi connect -s Hizzulon <credentials>
    uart:~$ debug event 00112700  00000000  00000002  00000000  00000000  00000000  00000000  00000000  00000000  00000000
    debug event 00214002  00000008  00000020  00400000  0000034f  00000008  00000000  00000000  00000002  00000003
    Connected
    [00:00:26.614,074] <inf> wpa_supp: wlan0: SME: Trying to authenticate with fc:34:97:af:71:34 (SSID='Hizzulon' freq=5240 MHz)
    [00:00:26.974,029] <inf> wpa_supp: wlan0: Trying to associate with fc:34:97:af:71:34 (SSID='Hizzulon' freq=5240 MHz)
    [00:00:26.990,783] <inf> wpa_supp: wlan0: Associated with fc:34:97:af:71:34
    [00:00:26.990,966] <inf> wpa_supp: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
    [00:00:27.018,798] <inf> wpa_supp: wlan0: WPA: Key negotiation completed with fc:34:97:af:71:34 [PTK=CCMP GTK=CCMP]
    [00:00:27.019,012] <inf> wpa_supp: wlan0: CTRL-EVENT-CONNECTED - Connection to fc:34:97:af:71:34 completed [id=0 id_str=]
    [00:00:27.032,592] <inf> net_dhcpv4: Received: 192.168.1.203
    uart:~$ debug event 00214002  00000008  00000020  00400000  0000000c  00000000  00000000  00000000  00000002  800402e8
    uart:~$ wifi status
    Status: successful
    State: COMPLETED
    SSID: Hizzulon
    BSSID: FC:34:97:AF:71:34
    Band: 5GHz
    Channel: 48
    Security: WPA2-PSK
    MFP: Optional
    RSSI: -59
    DTIM: 1
    TWT: Supported
    Current PHY rate : 0
    uart:~$ wifi scan -b 5 -c 5:48
    Scan requested
    debug event 00113000  00000000  00000000  00000000  00000000  00000000  ffffffff  00000005  00000000  00000000
    debug event 00113001  00000000  00000000  00000000  00000000  00000000  ffffffff  00000005  00000000  00000000
    1    | Hizzulon                         8     | 48   (5GHz  ) | -58  | WPA2-PSK        | FC:34:97:AF:71:34 | Disable
    Scan request done
    uart:~$ wifi scan -b 5 -c 5:44
    Scan requested
    Scan request done
    uart:~$ wifi scan -b 5 -c 5:165
    Scan requested
    debug event 00214002  00000008  00000004  00400040  00000006  00000000  00000000  00000000  00000000  00000000
    ... many repeats of last line
    [00:01:16.191,864] <err> wifi_nrf: zep_shim_llist_node_alloc: Unable to allocate memory for linked list node
    [00:01:16.191,894] <err> wifi_nrf: nrf_wifi_utils_list_add_tail: Unable to allocate list node
    [00:01:16.191,925] <err> wifi_nrf: hal_rpu_event_get: Unable to queue event
    [00:01:16.191,955] <err> wifi_nrf: hal_rpu_event_get_all: Failed to queue event
    uart:~$ debug event 00214002  00000008  00000004  00400040  00000006  00000000  00000000  00000000  00000000  00000000
    ... last line repeats forever (more than 30 seconds)
    The "unable to allocate" messages in the bad scan are new. I also sometimes see
    [00:01:27.330,322] <err> wifi_nrf: hal_rpu_event_get: Unable to alloc HAL msg for event (84 bytes)
    Those may be due to the new logging.
    I have two nRF7002-DK boards, both marked PCA10143 1.0.2 2023.25. Both have the same behavior. Our own board using nRF7002 also behaves the same.
    I connected to the Asus AP, a Pixel8, and an iPhone SE. All show the same scan failure on channel 165. Disabled the other APs so they wouldn't interfere. I don't have a Faraday cage, but I used some metal to isolate to just the DK and a phone hotspot to eliminate the possibility that farther APs were interfering, same result.
  • Thanks again Remi
    We see that CCA is continuously busy on this channel for some reason and suspect some non-Wi-Fi interference on that channel is causing this. So the next step would be to capture raw data on this channel for further analyze. Can you try using the attached radio test hex file and get captures of what's going on here with an nRF7002 DK:
    Config 1: Repeat the below commands 5 times and get terminal logs for analysis. Note that 16k samples will be logged to the terminal every run, indicating the channel state:
    wifi_radio_test init 165
    wifi_radio_test rx_lna_gain 0
    wifi_radio_test rx_bb_gain 25
    wifi_radio_test rx_capture_length 16000
    wifi_radio_test rx_cap 0
    Config 2: Repeat the below commands 5times and get terminal logs for analysis. note that 16k samples will be logged to the terminal for every run, indicating the channel state.
    wifi_radio_test rx_bb_gain 10
    Simon
    radio_test.hex
  • Here are the logs. All runs for a configuration in the same file, separated by boot message. I reset the DK between each run.
    radio_test_chan_165_bb_gain_25.txt : the first experiment
    radio_test_chan_165_bb_gain_10.txt: the second experiment
    For comparison, I also did a single run with gains 25 and 10 on channel 161, which does not have the scanning issue:
    radio_test_chan_161.txt
    On channel 165 with 25 gain, I see a lot of 800 and 7FC in the data, which looks like saturation? Gain 10 seems to be in range.
    Channel 161 is much lower magnitude.
    So there may be a jammer at 165? I turned off all the wireless I could find, used some metal shielding, and even tried connecting the DK to a different laptop in case there was PC noise coupling through USB. Same results. That implies the noise may be coming from the nRF7002-DK itself? It also happens on our own board (I didn't run radio test, but scan fails), maybe due to similar RF design? I don't have a 5GHZ spectrum analyzer, unfortunately. Or is it possible that there's a tuning issue when the firmware accesses channel 165?
    I could try buying another nRF7002-DK to see if it behaves differently. Is there a newer version of HW after v1.0.2? The product page doesn't specify.
    Independent of whatever is jamming channel 165, this is still a scanning firmware issue, right? A jammed channel shouldn't be able to hang the device.
  • Again, thank you for your thorough feedback Remi. I agree that this sounds very strange, and find it hard to believe it's something on the DK, as we can't see this behavior when testing on our end on a DK with the same revision.
    The developers are reviewing your logs now. I hope they have some more insight to share on this soon. I'll get back to you.
    Simon
