WiFi scan while connected
Does the NCS stack + nRF7002 support scanning while connected? I would expect it could, to support handoff, but getting errors.
Using nRF7002-DK and NCS 2.8.0.
Compile the wifi/shell example for nrf7002dk/nrf5340/cpuapp, no other changes.
*** Booting nRF Connect SDK v2.8.0-a2386bfc8401 ***
*** Using Zephyr OS v3.7.99-0bc3393fb112 ***
Starting nrf7002dk with CPU frequency: 128 MHz
[00:00:00.532,226] <inf> wifi_supplicant: wpa_supplicant initialized
uart:~$ wifi connect -s Hizzulon <my AP credentials>
Connection requested
Connected
[00:00:19.725,433] <inf> wpa_supp: MBO: Disable MBO/OCE due to misbehaving AP not having enabled PMF
[00:00:19.726,226] <inf> wpa_supp: wlan0: SME: Trying to authenticate with fc:34:97:af:71:54 (SSID='Hizzulon' freq=5220 MHz)
[00:00:20.086,120] <inf> wpa_supp: wlan0: Trying to associate with fc:34:97:af:71:54 (SSID='Hizzulon' freq=5220 MHz)
[00:00:20.102,874] <inf> wpa_supp: wlan0: Associated with fc:34:97:af:71:54
[00:00:20.103,027] <inf> wpa_supp: MBO: Disable MBO/OCE due to misbehaving AP not having enabled PMF
[00:00:20.103,118] <inf> wpa_supp: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
[00:00:20.122,253] <inf> wpa_supp: wlan0: WPA: Key negotiation completed with fc:34:97:af:71:54 [PTK=CCMP GTK=CCMP]
[00:00:20.122,467] <inf> wpa_supp: wlan0: CTRL-EVENT-CONNECTED - Connection to fc:34:97:af:71:54 completed [id=0 id_str=]
[00:00:20.137,420] <inf> net_dhcpv4: Received: 192.168.1.203
uart:~$ wifi status
Status: successful
State: COMPLETED
Interface Mode: STATION
Link Mode: WIFI 6 (802.11ax/HE)
SSID: Hizzulon
BSSID: FC:34:97:AF:71:54
Band: 5GHz
Channel: 44
Security: WPA2-PSK
MFP: Optional
RSSI: -34
Beacon Interval: 100
DTIM: 1
TWT: Supported
Current PHY rate : 26000
uart:~$ wifi scan
Scan requested
[wait ~30 seconds]
Scan request failed (-116)
[wait another ~30 seconds]
[00:01:33.363,311] <err> wifi_nrf: nrf_wifi_fmac_chg_vif_state: RPU is unresponsive for 10 sec
[00:01:33.363,342] <err> wifi_nrf: nrf_wifi_if_stop_zep: nrf_wifi_fmac_chg_vif_state failed
[00:01:33.364,013] <inf> wifi_supplicant: Network interface 1 (0x200013c0) down
[00:01:33.375,396] <inf> wpa_supp: wlan0: CTRL-EVENT-DSCP-POLICY clear_all
[00:01:33.375,854] <inf> wpa_supp: wlan0: CTRL-EVENT-DSCP-POLICY clear_all
[00:01:35.533,050] <inf> wifi_supplicant: Network interface 1 (0x200013c0) up
uart:~$ wifi status
Status: successful
State: DISCONNECTED
uart:~$
So the scan fails, but later there's another error that looks like the low-level nRF7002 driver failing and recovering (CONFIG_NRF_WIFI_RPU_RECOVERY is enabled by default).
If scan while connected isn't a supported feature, I would expect it to error immediately, not get into a state where it drops the connection?
A probably related issue: if I issue "wifi connect" with invalid credentials, wifi status is "SCANNING" forever (certainly much longer than the 30 second scan timeout), and later connect requests fail with:
uart:~$ wifi connect <credentials>
[00:01:58.298,828] <inf> wpa_supp: wlan0: CTRL-EVENT-DSCP-POLICY clear_all
[00:01:58.302,124] <inf> wpa_supp: wlan0: Reject scan trigger since one is already pending
[00:01:58.302,246] <wrn> wpa_supp: wlan0: Failed to initiate AP scan
[00:01:58.304,992] <inf> wpa_supp: wlan0: Reject scan trigger since one is already pending
[00:01:58.305,114] <wrn> wpa_supp: wlan0: Failed to initiate AP scan
I need to explicitly do "wifi disconnect" before it will stop scanning and allow another connection. Normally, issuing a connect command while already connected disconnects automatically then initiates the new connection.
  • 4010.zephyr_logs_v4.hex
    Hi again
    After analyzing the captures we see that channel 161 is clean, and that the RSSI in this channel is close to the expected noise floor. But in channel 165 there's a tonal pick up at ~5833 MHz. The RSSI measured on this capture is ~-56dBm, while the CCA threshold is -62dBm. So he high RSSI can lead to the CCA remaining asserted and thus the DUT isn't able to win the channel contention. Attached is a .hex file that contains a fix for this issue. Please try it out to confirm whether it fixes your issue or not. We will provide a patch on top of NCS 2.8.0 without the logging if this resolves the issue on your end.
    Simon
  • This appears to fix the issue!
    A full scan now works while connected, and a directed scan just on channel 165 works as well, when connected to either 2.4 or 5GHz.
    The issue I was having with not being able to connect to 2.4GHz unless I specify the band explicitly also seems to have been resolved with this image. That was always unpredictable, so I can't rule out random chance, but it is encouraging.
    The source of the 5833MHz jammer remains a mystery. I'm a few miles from a military airfield, so maybe radar? That's not something I need to solve.
    We will likely be upgrading to NCS 2.9 in a few weeks, so you can add this to the next NCS 2.9.x if that's easier.
    Thanks for all your help!
  • Hi Remi
    That is great news! I'll forward the info to the devs so they can handle it accordingly. I'm sure we can add the fix to a 2.9.x patch as well.
    Best of luck going forward, and don't hesitate to make a new ticket if you run into further issues.
    Simon
  • Hi again Remi
    Here are the firmware bins for the NCS 2.9.x release with the fixes to this issue. You should replace the binaries in nrfxlib/nrf_wifi/bin/ncs in 2.9.x with the ones uploaded here.
    3515.ncs.zip
    Simon
