Facing issue with Dynamic payload of Ack NRF24l01
Hi I am working on a project where I am trying to implement Bi-directional communication between 2 nrf modules connected to stm32f411ve dev boards.
I am facing issue with adding a dynamic payload along with my ack message
below is nrf driver code for the receiver side and also the spi code.
I am unable to understand how and where should I call the W_TX_PAYLOAD command
 * SPI.c
 *  Created on: Nov 10, 2024
 *      Author: Asus
#include"SPI.h"
#include"stdio.h"
#define AF05  (0x05)
void SPI_INIT(){
	//enable clock for GPIOA
	RCC->AHB1ENR|=RCC_AHB1ENR_GPIOAEN;
	//set PA5, PA6 and PA7 to alternate function mode
	GPIOA->MODER|=GPIO_MODER_MODE5_1|GPIO_MODER_MODE6_1|GPIO_MODER_MODE7_1;
	//set which type of alternate function is
	GPIOA->AFR[0]|=(AF05<<20)|(AF05<<24)|(AF05<<28);
	//enable clock access to SPI1
	RCC->APB2ENR|=RCC_APB2ENR_SPI1EN;
	//set software slave managment
	SPI1->CR1|=SPI_CR1_SSM|SPI_CR1_SSI;
	//set SPI in master mode
	MODIFY_FIELD(SPI1->CR1, SPI_CR1_MSTR, 1);
	MODIFY_FIELD(SPI1->CR1, SPI_CR1_BR,  3);
	MODIFY_FIELD(SPI1->CR1, SPI_CR1_CPHA, 0);
	MODIFY_FIELD(SPI1->CR1, SPI_CR1_CPOL, 0);
	//MODIFY_FIELD(SPI1->CR1, SPI_CR1_LSBFIRST, 1);
	SPI1->CR2 |= 0x4;
	SPI1->CR1 |= 0x40; // Enabling SPI SPI periph
	MODIFY_FIELD(SPI1->CR1, SPI_CR1_SPE, 1);
//send multiple bytes in case size>1
void SPI_TX_MULTI(uint8_t *data_ptr,int size){
int i=0;
uint8_t temp;
while(i<size){
	while(!(SPI1->SR & (SPI_SR_TXE))){}
	SPI1->DR = data_ptr[i];
	i++;
/*Wait until TXE is set*/
/*Wait for BUSY flag to reset*/
while((SPI1->SR & (SPI_SR_BSY))){}
/*Clear OVR flag*/
temp = SPI1->DR;
temp = SPI1->SR;
void SPI_READ_MULTI(uint8_t *data_ptr,int size){
	while(size)
		/*Send dummy data*/
		SPI1->DR =0;
		/*Wait for RXNE flag to be set*/
		while(!(SPI1->SR & (SPI_SR_RXNE))){}
		/*Read data from data register*/
		*data_ptr++ = (SPI1->DR);
		size--;
	 * NRF_DRIVER.c
	 *      Author: Asus
	#include"NRF_DRIVER.h"
	#include"delay.h"
	#include"SPI.h"
	#include"utilities.h"
#include<stdio.h>
void init_CSN_CE_PINS(){
	MODIFY_FIELD(GPIOA->MODER, GPIO_MODER_MODER4, ESF_GPIO_MODER_OUTPUT); // NSS pin for now4 as outpu
	MODIFY_FIELD(GPIOA->MODER, GPIO_MODER_MODER0, ESF_GPIO_MODER_OUTPUT); // NSS pin for now4 as outpu
	void CSN_SELECT_NRF(){
		  GPIOA->BSRR |= GPIO_BSRR_BR_4; //pull low to enable nrf
	void CSN_UNSELECT_NRF(){
		  GPIOA->BSRR |= GPIO_BSRR_BS_4; //make high to disable
	void NRF_ENABLE(){
		GPIOA->BSRR |= GPIO_BSRR_BS_0;
	void NRF_DISABLE(){
		GPIOA->BSRR |= GPIO_BSRR_BR_0;
	void NRF_WRITE_REGISTER(uint8_t REG_ADDRESS,uint8_t data){
		uint8_t trans_buff[2];
		trans_buff[0]=REG_ADDRESS|W_REGISTER;
		trans_buff[1]=data;
		CSN_SELECT_NRF();
		SPI_TX_MULTI(trans_buff,2);
		CSN_UNSELECT_NRF();
	void NRF_WRITE_REG_MULTI_BYTES(uint8_t REG_ADDRESS,uint8_t* data_trans,int size_trans){
		CSN_SELECT_NRF();
		SPI_TX_MULTI(trans_buff,1);
		SPI_TX_MULTI(data_trans,size_trans);
		CSN_UNSELECT_NRF();
	uint8_t NRF_READ_REGISTER(uint8_t REG_ADDRESS){
		uint8_t data_returned=0;
		CSN_SELECT_NRF();
		SPI_TX_MULTI(&REG_ADDRESS,1);
		SPI_READ_MULTI(&data_returned,1);
		CSN_UNSELECT_NRF();
		return data_returned;
	void NRF_READ_REGISTER_MULTI(uint8_t REG_ADDRESS,uint8_t *RECV_BUFFER,int RECV_BUFFER_SIZE){
		CSN_SELECT_NRF();
		SPI_READ_MULTI(RECV_BUFFER,RECV_BUFFER_SIZE);
		CSN_UNSELECT_NRF();
	void NRF_PTX_CONFIG(uint8_t *Address, uint8_t channel){
		NRF_DISABLE();
		NRF_WRITE_REGISTER(RF_CH,channel); //select channel
		NRF_WRITE_REG_MULTI_BYTES(TX_ADDR,Address,5); //set address
		// un comment belowo code to setup for auto ack
		uint8_t current_pipe_status=NRF_READ_REGISTER(EN_RXADDR);
		current_pipe_status=current_pipe_status|(1<<0);//enable pipe 1
		NRF_WRITE_REGISTER(EN_RXADDR,current_pipe_status);
		NRF_WRITE_REG_MULTI_BYTES(RX_ADDR_P0,Address,5); //pipe address
		NRF_WRITE_REGISTER(CONFIG,0x0a); //powwr on device and keep in tx mode
		delay(5);
		//NRF_ENABLE();
	void NRF_PRX_CONFIG(uint8_t *Address, uint8_t channel){
		NRF_DISABLE();
		current_pipe_status=current_pipe_status|(1<<1);//enable pipe 1
		NRF_WRITE_REG_MULTI_BYTES(RX_ADDR_P1,Address,5); //pipe address
		//since we have dynamic payload we dont need thus below
		//NRF_WRITE_REGISTER(RX_PW_P1,32); //data 32 bytes width
		NRF_WRITE_REGISTER(CONFIG,0x0b); //powwr on device and keep in tx mode
		NRF_ENABLE();
	void nrf24_reset(uint8_t REG)
		if (REG == STATUS)
			NRF_WRITE_REGISTER(STATUS, 0x00);
		else if (REG == FIFO_STATUS)
			NRF_WRITE_REGISTER(FIFO_STATUS, 0x11);
		else {
		NRF_WRITE_REGISTER(CONFIG, 0x08);
		NRF_WRITE_REGISTER(EN_AA, 0x3F);
		NRF_WRITE_REGISTER(EN_RXADDR, 0x03);
		NRF_WRITE_REGISTER(SETUP_AW, 0x03);
		NRF_WRITE_REGISTER(SETUP_RETR, 0x03);
		NRF_WRITE_REGISTER(RF_CH, 0x02);
		NRF_WRITE_REGISTER(RF_SETUP, 0x0E);
		NRF_WRITE_REGISTER(OBSERVE_TX, 0x00);
		NRF_WRITE_REGISTER(CD, 0x00);
		uint8_t rx_addr_p0_def[5] = {0xE7, 0xE7, 0xE7, 0xE7, 0xE7};
		NRF_WRITE_REG_MULTI_BYTES(RX_ADDR_P0, rx_addr_p0_def, 5);
		uint8_t rx_addr_p1_def[5] = {0xC2, 0xC2, 0xC2, 0xC2, 0xC2};
		NRF_WRITE_REG_MULTI_BYTES(RX_ADDR_P1, rx_addr_p1_def, 5);
		NRF_WRITE_REGISTER(RX_ADDR_P2, 0xC3);
		NRF_WRITE_REGISTER(RX_ADDR_P3, 0xC4);
		NRF_WRITE_REGISTER(RX_ADDR_P4, 0xC5);
		NRF_WRITE_REGISTER(RX_ADDR_P5, 0xC6);
		uint8_t tx_addr_def[5] = {0xE7, 0xE7, 0xE7, 0xE7, 0xE7};
		NRF_WRITE_REG_MULTI_BYTES(TX_ADDR, tx_addr_def, 5);
		NRF_WRITE_REGISTER(RX_PW_P0, 0);
		NRF_WRITE_REGISTER(RX_PW_P1, 0);
		NRF_WRITE_REGISTER(RX_PW_P2, 0);
		NRF_WRITE_REGISTER(RX_PW_P3, 0);
		NRF_WRITE_REGISTER(RX_PW_P4, 0);
		NRF_WRITE_REGISTER(RX_PW_P5, 0);
		NRF_WRITE_REGISTER(DYNPD, 0);
		NRF_WRITE_REGISTER(FEATURE, 0);
	void NRF_INIT(){
		SPI_INIT(); //initalize spi comms
		init_CSN_CE_PINS();
		NRF_DISABLE();
		nrf24_reset(0);
		NRF_WRITE_REGISTER(CONFIG, 0);  // will be configured later
		//NRF_WRITE_REGISTER(EN_AA, 0x00);  // No Auto ACK
		/*uncomment below code to enable auto ack stuff*/
		//NRF_WRITE_REGISTER(EN_AA, 0x3f);  // No Auto ACK
		//NRF_WRITE_REGISTER(SETUP_RETR, 0x03); // 15 retries, 500µs delay
		NRF_WRITE_REGISTER (EN_RXADDR, 0);  // Not Enabling any data pipe right now
		NRF_WRITE_REGISTER (SETUP_AW, 0x03);  // 5 Bytes for the TX/RX address
		//NRF_WRITE_REGISTER (SETUP_RETR, 0x00);   // No retransmission
		NRF_WRITE_REGISTER (RF_CH, 0);  // will be setup during Tx or RX
		//enable dynamic payloads on all pipes
		//for DYNP I require EN_AA and Requires EN_DPL and ENAA_P0
		NRF_WRITE_REGISTER (DYNPD, 0x3f);  // will be setup during Tx or RX
		NRF_WRITE_REGISTER (FEATURE, 0x6);  // enable dynamic payload length
		NRF_WRITE_REGISTER(SETUP_RETR, 0xff); // 15 retries, 500µs delay
		NRF_WRITE_REGISTER (RF_SETUP, 0x0e);   // Power= 0db, data rate = 2Mbps
		//NRF_ENABLE();
	void NRD_SEND_CMD (uint8_t cmd)
		// Pull the CS Pin LOW to select the device
		CSN_SELECT_NRF();
		SPI_TX_MULTI(&cmd, 1);
		// Pull the CS HIGH to release the device
		CSN_UNSELECT_NRF();
	uint8_t NRF_TX_DATA(uint8_t *data_ptr){
		uint8_t tx_fifo_stat;
		uint8_t status_reg;
		CSN_SELECT_NRF();
	  uint8_t cmd = W_TX_PAYLOAD;
	  SPI_TX_MULTI( &cmd, 1);
		SPI_TX_MULTI(data_ptr,32);//send payload
		CSN_UNSELECT_NRF();
		NRF_ENABLE();
		delay(10);
		NRF_DISABLE();
		tx_fifo_stat=NRF_READ_REGISTER(FIFO_STATUS);
		status_reg=NRF_READ_REGISTER(STATUS);
		printf("tx_fifo_stat is - %d",tx_fifo_stat);
		printf("status register- %d",status_reg);
		if ((tx_fifo_stat&(1<<4)) && (!(tx_fifo_stat&(1<<3)))){
			cmd=FLUSH_TX;
			NRD_SEND_CMD(cmd);
			NRF_WRITE_REGISTER(FIFO_STATUS, 0x11); //reset fifo
			return 1;
		if(status_reg &(1<<4)){
			printf("max number of retransmission \n \r %d \n \r",status_reg);
			status_reg=status_reg|(1<<4);
			NRF_WRITE_REGISTER(STATUS,status_reg);
			printf("after clearing flag? %d \n \r",status_reg);
			cmd=FLUSH_TX;
		 NRD_SEND_CMD(cmd);
		return 0;
uint8_t is_data_on_pipe(uint8_t pipenum){
uint8_t status_reg=NRF_READ_REGISTER(STATUS);
//if 6 th bit is set and respective data pipe is set
//printf("reciever status %d \n \r",status_reg);
if((status_reg & (1<<6))&& status_reg &(1<<pipenum)){
//clear rx_dr
	NRF_WRITE_REGISTER(STATUS,(1<<6));
	return 1; //data recieved
return 0;
//uint8_t NRF_SEND_PAYLOAD_WIDTH_READ(uint8_t cmd){
//	uint8_t temp;
//	while(!(SPI1->SR & (SPI_SR_TXE))){}
//	SPI1->DR = cmd;
//	temp = SPI1->DR;
//	temp = SPI1->SR;
//	while (!(SPI1->SR & SPI_SR_RXNE)) {}
//	return (uint8_t)(SPI1->DR);
//this code needs to  be modefied for dyanmic first we will send
//R_RX_PL_WID first and then R_RX_PAYLOAD
void NRF_RECV_DATA(uint8_t *data_ptr_RECV){
	CSN_SELECT_NRF();
	uint8_t cmd=W_ACK_PAYLOAD|0;
	uint8_t ack_payLoad[]={0x56};
	SPI_TX_MULTI(ack_payLoad, sizeof(ack_payLoad));
	CSN_UNSELECT_NRF();
	delay(10);
	uint8_t tx_fifo_stat=NRF_READ_REGISTER(FIFO_STATUS);
	delay(10);
	 cmd = R_RX_PL_WID;
	uint8_t payLoad_width=0;
	CSN_SELECT_NRF();
	//payLoad_width=NRF_SEND_PAYLOAD_WIDTH_READ(cmd);
	//next comand to read payload
	SPI_READ_MULTI(&payLoad_width,1);//recieve width
	printf("\n \r  payloadWidth %d \n \r",payLoad_width);
	CSN_UNSELECT_NRF();
	delay(10);
	printf("status_reg %d \n \r",status_reg);
	printf("tx_fifo_stat %d \n \r",tx_fifo_stat);
	CSN_SELECT_NRF();
	cmd=R_RX_PAYLOAD;
	SPI_READ_MULTI(data_ptr_RECV,payLoad_width);//recieve data
	CSN_UNSELECT_NRF();
	cmd=FLUSH_RX;
	delay(20);
	NRD_SEND_CMD(cmd); //flush rx fifo
	delay(10);
	if(tx_fifo_stat&(1<<5)){
	 cmd=FLUSH_TX;
     NRD_SEND_CMD(cmd);
Thanks
