Reduce nRF7002dk image size
Hello, I'm in the development stage of a product and currently evaluating the nRF5340 as our main processor and nRF7002 as a companion IC for WiFi. Our application can be used in a wide variety of connectivity environments, so we require a WiFi interface, Ethernet interface, a cellular/GPS modem, and BLE. Also, we want to make MQTTS/HTTPS connections to our cloud provider. I've gotten a lot of these individual components to work individually by building our app to run on a nRF7002dk; however, I'm running into issues with the size of the image being too big when I try to include all of the necessary config variables in my build. Is what I'm attempting to do infeasible? My current build is overflowing RAM by 71,272 bytes and Flash is overflowed by 10,160 bytes. I can share my board overlays and configuration files. To be clear, I'm using NCS version 2.8.0, and building an application with nrf/7002dk/nrf5340/cpuapp/ns board as the target.
4336.prj.conf sysbuild.conf 3731.nrf7002dk_nrf5340_cpuapp_ns.conf nrf7002dk_nrf5340_cpuapp_ns.overlay
  • So I'm able to get the app to fit with MCUBoot as long as there's an external flash and no BLE enabled. I'm using the mx25r64 devicetree node as the external flash. My next thought was use the cpunet core to run all of the BLE stack (mentioned here https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/samples/bluetooth/rpc_host/README.html#ble-rpc-host). However, that's making my app even bigger. Is that expected? What's the point of running the network stack on another CPU?
  • Hi Ethan,
    Nicely spotted, I didn't think that was an option. You'd typically just have the SDC on the network core which would save flash space and CPU, though I see that with this sample you can keep the entire stack there. Though you still need the communication between the Host and the SDC binary that uses RPC libraries and architecture, and now in addition to that you need the communication between the netcore and appcore, which also requires RPC etc.
    So it would make sense if the space you need is a bit more than what just the application takes up. Though I would expect this to still take up less flash than what it would've with some of the BLE stack there as well. Are you saying that moving the entire stack to the netcore made your app bigger than it was with app+host? If so could you try generating a memory report.
    I should also mention that this sample is currently supported for development only and does not support all Bluetooth Host APIs.
    Elfving
  • although I have come to the conclusion that it would be VERY useful to be able to put the entire wifi WPA_SUPP code into XiP as its a BIG chunk of code (especially if you want WPA2/3 Enterprise functionality - even just EAP-TLS). And as its just used during the wifi connection phase, it might not be a problem that XiP execution is slower....
    I asked about this as a build option in the end of this thread :  Update to NCS3.0.0 broke wifi WPA2-PSK connect?
    hopefully at some point this will be possible...
  • Gotcha that checks out. If I try to host the SDC on the netcore and BLE host on the cpuapp core, I still have issues. I may just have to try a different module that has all of the WiFi stack hosted on it
