Update to NCS3.0.0 broke wifi WPA2-PSK connect?
Custom PCB with nrf5340/nrf7002. Currently was using NCS2.9.0, with WPA2-PSK connection to the wifi.
While trying to enable use of WPA2-Enterprise, I updated to NCS3.0.0 (to see if the increased flash requirement of around 45kB! was perhaps less). This turned out to be WAY worse (another 49kB on top for identical prj.conf), but also broke the WP2-PSK connection it seems?
Previous it would connect fine, but now it times out and I see these logs:
[00:02:21.108,764] <err> wpa_supp: Error in pbkdf2_sha1()
[00:02:21.110,382] <err> wpa_supp: Line 0: invalid key_mgmt 'SAE'
Any idea what these mean? I previously had the SAE log from time to time : I assumed this is for WPA3 with SAE key exchange which I wasn't using (WPA2-PSK) and it didn't block the connection.
If anyone has any ideas about how to trim down the wifi stack usage also I'd be interested too as it no longer fits in the flash on my nrf5340 (and yes, I already have the nrf70 fw and all other mcyboot slots in a external flash...)
  • Hi Bryan,
    I am sorry to hear that. It's true that these Wi-Fi features are currently very memory hungry. Are you saying that Enterprise did work for you in 2.9?
    Elfving
  • I haven't been able to try the enterprise wifi connection yet. My question here concerns WPA2-PSK on NCS3.0.0 vs NCS2.9.0: this works on 2.9 but fails to connect on 3.0. (application code is identical)
    On 2.9 I get the SAE error (can you explain what this refers to?)
    On 3.0 I get the SAE error but also the pbkdf2_sha1 error, which seems to be related to it not managing to connect?
    So on NCS 3.0 not even WPA2-PSK is working for me...
    Note: For the memory usage, in NCS2.9.0 a rom_report tells me that around 350kB is required to use IP networking over wifi with WPA2-PSK  (between wifi drivers, TCP/IP, mbedtls, wpa_supp etc) - without adding 'enterprise' and WPA3 support. And this does not include the 79kB of nrf70 fw code that is stored in external flash).
    This is 35% of the nrf5340's internal flash, just to be able to connect a MQTT client... I can see no way to reduce this overhead currently.
  • I see someone else has experience the same issue on NCS 3.0.1, something about the mbedtls heap?
    what has changed from 2.9.0?
    Ah okay, seems I just misunderstood you for a second there.
    Hmm, this a surprise to me at least. I can check. You are seeing this on your custom application, right? Are you seeing this with a sample as well? Could you get me the exact build command that was used?
    Elfving
  • This is my custom application, which is now at 970kB (the absolute limit to fix in the 1Mb flash with mcuboot as well)
    If you build just wifi-sta sample with WPA2 enterprise (and not even an MQTT or HTTP client in that sample) you will find the application size is over 350kB....
    To return to the problem :
    what does this signify?
    and
    which seems to be the problem stopping WPA2-PSK working in NCS 3.0.0.
    I now think that this is because the libc heap is at 0 in the NCS3.0 build (as the networking code is using its own sysheap my code then uses the system sysheap, so k_malloc() instead of malloc().) And because
    CONFIG_MBEDTLS_ENABLE_HEAP=y
    by default, but the heap is size 0, the mbedtls fn fails.
    So, either I set CONFIG_MBEDTLS_ENABLE_HEAP=n, or I leave the libc heap in place I guess?
