KNX IoT build from VS Code
Hello.
I have two nRF5340 DK boards that I want to use to replicate the demo on https://github.com/NordicPlayground/nrf-knx-iot.
I am using Ubuntu 22.04.
I cloned the repo and checked out 0.3.0 tag and did all the necessary updates from the documentation. I also installed VS code and nRF Connect VS code extension and all the associated tools such as SDK toolchain Manager v2.8.0. I opened the extension in VS Code and opened the application light_switch_sensor from the repo's sample folder. All seemed ok until now and I also did the steps to install the Zephyr SDK from https://docs.zephyrproject.org/latest/develop/toolchains/zephyr_sdk.html#toolchain-zephyr-sdk-install
After opening the application in VS code, I can trigger a build all configurations and this leads me to the following error in the output tab:
ude -isystem /home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/lib/cpp/minimal/include -isystem /home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/examples/platforms -Wall -Wextra -Wshadow -Wno-c++14-compat -fno-exceptions -fno-strict-aliasing -Os -fcheck-new -std=c++11 -fno-rtti -imacros /home/mihai/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_sensor/build/zephyr/include/generated/zephyr/autoconf.h -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee -mtp=soft --sysroot=/home/mihai/ncs/toolchains/b81a7cd864/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros /home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -fno-pic -fno-pie -fno-asynchronous-unwind-tables -ftls-model=local-exec -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=/home/mihai/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_sensor=CMAKE_SOURCE_DIR -fmacro-prefix-map=/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/home/mihai/Documents/KNX_testing/nrf-knx-iot=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=picolibc.specs -D_POSIX_THREADS -nostdinc++ -fno-builtin -imacros /home/mihai/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_sensor/build/zephyr/include/generated/zephyr/autoconf.h -std=c++11 -MD -MT modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/instance_api.cpp.obj -MF modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/instance_api.cpp.obj.d -o modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/instance_api.cpp.obj -c /home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/src/core/api/instance_api.cpp
In file included from /home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/src/core/instance/instance.hpp:118,
                 from /home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/src/core/common/locator_getters.hpp:42,
                 from /home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/src/core/api/instance_api.cpp:40:
/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/src/core/thread/mlr_manager.hpp:42:2: error: #error "Thread 1.2 or higher version is required for OPENTHREAD_CONFIG_MLR_ENABLE"
   42 | #error "Thread 1.2 or higher version is required for OPENTHREAD_CONFIG_MLR_ENABLE"
/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/src/core/thread/mlr_manager.hpp:101:44: error: 'BackboneRouter' has not been declared
  101 |     void HandleBackboneRouterPrimaryUpdate(BackboneRouter::Leader::State aState, const BackboneRouter::Config &aConfig);
/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/src/core/thread/mlr_manager.hpp:101:74: error: expected ',' or '...' before 'aState'
/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/src/core/thread/mlr_manager.hpp:149:53: error: 'Ip6AddressesTlv' was not declared in this scope
  149 |     class AddressArray : public Array<Ip6::Address, Ip6AddressesTlv::kMaxAddresses>
/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/src/core/thread/mlr_manager.hpp:149:83: error: template argument 2 is invalid
/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/src/core/thread/mlr_manager.hpp:149:83: error: template argument 3 is invalid
/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/src/core/thread/mlr_manager.hpp: In member function 'bool ot::MlrManager::AddressArray::IsEmptyOrContains(const ot::Ip6::Address&) const':
/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/src/core/thread/mlr_manager.hpp:152:77: error: 'IsEmpty' was not declared in this scope
  152 |         bool IsEmptyOrContains(const Ip6::Address &aAddress) const { return IsEmpty() || Contains(aAddress); }
/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/src/core/thread/mlr_manager.hpp:152:90: error: 'Contains' was not declared in this scope
[8/626] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/dns_server_api.cpp.obj
FAILED: modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/dns_server_api.cpp.obj
ccache /home/mihai/ncs/toolchains/b81a7cd864/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-g++ -DKERNEL -DK_HEAP_MEM_POOL_SIZE=4096 -DMBEDTLS_CONFIG_FILE=\"config-tls-generic.h\" -DMBEDTLS_SSL_EXPORT_KEYS -DNRF5340_XXAA_APPLICATION -DNRF_802154_ACK_TIMEOUT_ENABLED=1 -DNRF_802154_CARRIER_FUNCTIONS_ENABLED=0 -DNRF_802154_CCA_CORR_LIMIT_DEFAULT=2 -DNRF_802154_CCA_CORR_THRESHOLD_DEFAULT=45 -DNRF_802154_CCA_ED_THRESHOLD_DEFAULT=45 -DNRF_802154_CCA_MODE_DEFAULT=NRF_RADIO_CCA_MODE_ED -DNRF_802154_ENCRYPTION_ENABLED=0 -DNRF_802154_IE_WRITER_ENABLED=0 -DNRF_802154_INTERNAL_RADIO_IRQ_HANDLING=0 -DNRF_802154_PENDING_EXTENDED_ADDRESSES=16 -DNRF_802154_PENDING_SHORT_ADDRESSES=16 -DNRF_802154_PLATFORM_ASSERT_INCLUDE=\"nrf_802154_assert_zephyr.h\" -DNRF_802154_RX_BUFFERS=16 -DNRF_802154_SECURITY_KEY_STORAGE_SIZE=3 -DNRF_802154_SECURITY_WRITER_ENABLED=0 -DNRF_802154_SERIALIZATION_HOST=1 -DNRF_802154_TX_STARTED_NOTIFY_ENABLED=1 -DNRF_802154_USE_RAW_API=1 -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DOPENTHREAD_CONFIG_ASSERT_ENABLE=0 -DOPENTHREAD_CONFIG_BACKBONE_ROUTER_DUA_NDPROXYING_ENABLE=0 -DOPENTHREAD_CONFIG_BACKBONE_ROUTER_ENABLE=0 -DOPENTHREAD_CONFIG_BACKBONE_ROUTER_MULTICAST_ROUTING_ENABLE=0 -DOPENTHREAD_CONFIG_BLE_TCAT_ENABLE=0 -DOPENTHREAD_CONFIG_BORDER_AGENT_ENABLE=0 -DOPENTHREAD_CONFIG_BORDER_AGENT_EPHEMERAL_KEY_ENABLE=0 -DOPENTHREAD_CONFIG_BORDER_AGENT_ID_ENABLE=0 -DOPENTHREAD_CONFIG_BORDER_ROUTER_ENABLE=0 -DOPENTHREAD_CONFIG_BORDER_ROUTING_DHCP6_PD_ENABLE=0 -DOPENTHREAD_CONFIG_BORDER_ROUTING_ENABLE=0 -DOPENTHREAD_CONFIG_CHANNEL_MANAGER_CSL_CHANNEL_SELECT_ENABLE=0 -DOPENTHREAD_CONFIG_CHANNEL_MANAGER_ENABLE=0 -DOPENTHREAD_CONFIG_CHANNEL_MONITOR_ENABLE=0 -DOPENTHREAD_CONFIG_COAP_API_ENABLE=0 -DOPENTHREAD_CONFIG_COAP_BLOCKWISE_TRANSFER_ENABLE=0 -DOPENTHREAD_CONFIG_COAP_OBSERVE_API_ENABLE=0 -DOPENTHREAD_CONFIG_COAP_SECURE_API_ENABLE=0 -DOPENTHREAD_CONFIG_COMMISSIONER_ENABLE=0 -DOPENTHREAD_CONFIG_DATASET_UPDATER_ENABLE=0 -DOPENTHREAD_CONFIG_DEVICE_POWER_SUPPLY=OT_POWER_SUPPLY_EXTERNAL -DOPENTHREAD_CONFIG_DHCP6_CLIENT_ENABLE=0 -DOPENTHREAD_CONFIG_DHCP6_SERVER_ENABLE=0 -DOPENTHREAD_CONFIG_DIAG_ENABLE=0 -DOPENTHREAD_CONFIG_DNSSD_DISCOVERY_PROXY_ENABLE=0 -DOPENTHREAD_CONFIG_DNSSD_SERVER_ENABLE=0 -DOPENTHREAD_CONFIG_DNS_CLIENT_ENABLE=0 -DOPENTHREAD_CONFIG_DNS_CLIENT_OVER_TCP_ENABLE=0 -DOPENTHREAD_CONFIG_DNS_DSO_ENABLE=0 -DOPENTHREAD_CONFIG_DNS_UPSTREAM_QUERY_ENABLE=0 -DOPENTHREAD_CONFIG_DUA_ENABLE=0 -DOPENTHREAD_CONFIG_DYNAMIC_STORE_FRAME_AHEAD_COUNTER_ENABLE=0 -DOPENTHREAD_CONFIG_ECDSA_ENABLE=0 -DOPENTHREAD_CONFIG_ENABLE_BUILTIN_MBEDTLS=0 -DOPENTHREAD_CONFIG_ENABLE_BUILTIN_MBEDTLS_MANAGEMENT=0 -DOPENTHREAD_CONFIG_HEAP_EXTERNAL_ENABLE=0 -DOPENTHREAD_CONFIG_HISTORY_TRACKER_ENABLE=0 -DOPENTHREAD_CONFIG_IP6_BR_COUNTERS_ENABLE=0 -DOPENTHREAD_CONFIG_IP6_FRAGMENTATION_ENABLE=0 -DOPENTHREAD_CONFIG_IP6_SLAAC_ENABLE=0 -DOPENTHREAD_CONFIG_JAM_DETECTION_ENABLE=0 -DOPENTHREAD_CONFIG_JOINER_ENABLE=0 -DOPENTHREAD_CONFIG_LINK_METRICS_MANAGER_ENABLE=0 -DOPENTHREAD_CONFIG_LINK_RAW_ENABLE=0 -DOPENTHREAD_CONFIG_LOG_LEVEL=0 -DOPENTHREAD_CONFIG_LOG_LEVEL_DYNAMIC_ENABLE=0 -DOPENTHREAD_CONFIG_MAC_CSL_AUTO_SYNC_ENABLE=0 -DOPENTHREAD_CONFIG_MAC_CSL_DEBUG_ENABLE=0 -DOPENTHREAD_CONFIG_MAC_CSL_RECEIVER_ENABLE=0 -DOPENTHREAD_CONFIG_MAC_CSL_RECEIVER_LOCAL_TIME_SYNC=0 -DOPENTHREAD_CONFIG_MAC_FILTER_ENABLE=0 -DOPENTHREAD_CONFIG_MAC_OUTGOING_BEACON_PAYLOAD_ENABLE=0 -DOPENTHREAD_CONFIG_MESH_DIAG_ENABLE=0 -DOPENTHREAD_CONFIG_MESSAGE_USE_HEAP_ENABLE=0 -DOPENTHREAD_CONFIG_MLE_DEVICE_PROPERTY_LEADER_WEIGHT_ENABLE=0 -DOPENTHREAD_CONFIG_MLE_LINK_METRICS_INITIATOR_ENABLE=0 -DOPENTHREAD_CONFIG_MLE_LINK_METRICS_SUBJECT_ENABLE=0 -DOPENTHREAD_CONFIG_MLE_LONG_ROUTES_ENABLE=0 -DOPENTHREAD_CONFIG_MLR_ENABLE=1 -DOPENTHREAD_CONFIG_MULTICAST_DNS_ENABLE=0 -DOPENTHREAD_CONFIG_MULTIPAN_RCP_ENABLE=0 -DOPENTHREAD_CONFIG_MULTIPLE_INSTANCE_ENABLE=0 -DOPENTHREAD_CONFIG_NAT64_BORDER_ROUTING_ENABLE=0 -DOPENTHREAD_CONFIG_NAT64_TRANSLATOR_ENABLE=0 -DOPENTHREAD_CONFIG_NCP_HDLC_ENABLE=1 -DOPENTHREAD_CONFIG_NCP_INFRA_IF_ENABLE=0 -DOPENTHREAD_CONFIG_NEIGHBOR_DISCOVERY_AGENT_ENABLE=0 -DOPENTHREAD_CONFIG_NETDATA_PUBLISHER_ENABLE=0 -DOPENTHREAD_CONFIG_NET_DIAG_VENDOR_INFO_SET_API_ENABLE=0 -DOPENTHREAD_CONFIG_OPERATIONAL_DATASET_AUTO_INIT=1 -DOPENTHREAD_CONFIG_OTNS_ENABLE=0 -DOPENTHREAD_CONFIG_PING_SENDER_ENABLE=0 -DOPENTHREAD_CONFIG_PLATFORM_BOOTLOADER_MODE_ENABLE=0 -DOPENTHREAD_CONFIG_PLATFORM_KEY_REFERENCES_ENABLE=0 -DOPENTHREAD_CONFIG_PLATFORM_LOG_CRASH_DUMP_ENABLE=0 -DOPENTHREAD_CONFIG_PLATFORM_NETIF_ENABLE=0 -DOPENTHREAD_CONFIG_PLATFORM_POWER_CALIBRATION_ENABLE=0 -DOPENTHREAD_CONFIG_PLATFORM_UDP_ENABLE=0 -DOPENTHREAD_CONFIG_RADIO_LINK_IEEE_802_15_4_ENABLE=1 -DOPENTHREAD_CONFIG_RADIO_LINK_TREL_ENABLE=0 -DOPENTHREAD_CONFIG_REFERENCE_DEVICE_ENABLE=0 -DOPENTHREAD_CONFIG_SNTP_CLIENT_ENABLE=0 -DOPENTHREAD_CONFIG_SRP_CLIENT_ENABLE=0 -DOPENTHREAD_CONFIG_SRP_SERVER_ADVERTISING_PROXY_ENABLE=0 -DOPENTHREAD_CONFIG_SRP_SERVER_ENABLE=0 -DOPENTHREAD_CONFIG_TCP_ENABLE=0 -DOPENTHREAD_CONFIG_THREAD_VERSION=OT_THREAD_VERSION_1_1 -DOPENTHREAD_CONFIG_TIME_SYNC_ENABLE=0 -DOPENTHREAD_CONFIG_TMF_ANYCAST_LOCATOR_ENABLE=0 -DOPENTHREAD_CONFIG_TMF_NETDATA_SERVICE_ENABLE=0 -DOPENTHREAD_CONFIG_TMF_NETDIAG_CLIENT_ENABLE=0 -DOPENTHREAD_CONFIG_TX_QUEUE_STATISTICS_ENABLE=0 -DOPENTHREAD_CONFIG_UDP_FORWARD_ENABLE=0 -DOPENTHREAD_CONFIG_UPTIME_ENABLE=1 -DOPENTHREAD_CONFIG_VERHOEFF_CHECKSUM_ENABLE=0 -DOPENTHREAD_FTD=1 -DOPENTHREAD_MTD=0 -DOPENTHREAD_POSIX_CONFIG_FIREWALL_ENABLE=0 -DOPENTHREAD_PROJECT_CORE_CONFIG_FILE=\"openthread-core-zephyr-config.h\" -DOPENTHREAD_RADIO=0 -DOPENTHREAD_SETTINGS_RAM=0 -DPACKAGE_NAME=\"OPENTHREAD\" -DPICOLIBC_LONG_LONG_PRINTF_SCANF -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR__=1 -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_sensor/build/modules/openthread/build/etc/cmake -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/etc/cmake -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/src/core -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/crypto/mbedtls/include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/modules/mbedtls/configs -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/modules/mbedtls/include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/src -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/examples/platforms/zephyr -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_sensor/build/zephyr/include/generated/zephyr -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_sensor/build/zephyr/include/generated -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/soc/nordic -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/lib/posix/options/getopt -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/soc/nordic/nrf53/. -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/soc/nordic/common/. -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/subsys/settings/include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/subsys/shell/modules/kernel_service/thread/.. -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/hal/cmsis/CMSIS/Core/Include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/modules/cmsis/. -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/hal/nordic/nrfx -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/hal/nordic/nrfx/drivers/include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/hal/nordic/nrfx/mdk -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/modules/hal_nordic/nrfx/. -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/modules/openthread/platform/. -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/hal/nordic/drivers/nrf_802154/serialization/include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/hal/nordic/drivers/nrf_802154/serialization/include/platform -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/hal/nordic/drivers/nrf_802154/serialization/include/serialization -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/hal/nordic/drivers/nrf_802154/common/include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/modules/hal_nordic/nrf_802154/include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/third_party/tcplp/bsdtcp -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/third_party/tcplp/lib -isystem /home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/include -isystem /home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/lib/libc/common/include -isystem /home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/lib/cpp/minimal/include -isystem /home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/examples/platforms -Wall -Wextra -Wshadow -Wno-c++14-compat -fno-exceptions -fno-strict-aliasing -Os -fcheck-new -std=c++11 -fno-rtti -imacros /home/mihai/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_sensor/build/zephyr/include/generated/zephyr/autoconf.h -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee -mtp=soft --sysroot=/home/mihai/ncs/toolchains/b81a7cd864/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros /home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -fno-pic -fno-pie -fno-asynchronous-unwind-tables -ftls-model=local-exec -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=/home/mihai/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_sensor=CMAKE_SOURCE_DIR -fmacro-prefix-map=/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/home/mihai/Documents/KNX_testing/nrf-knx-iot=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=picolibc.specs -D_POSIX_THREADS -nostdinc++ -fno-builtin -imacros /home/mihai/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_sensor/build/zephyr/include/generated/zephyr/autoconf.h -std=c++11 -MD -MT modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/dns_server_api.cpp.obj -MF modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/dns_server_api.cpp.obj.d -o modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/dns_server_api.cpp.obj -c /home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/src/core/api/dns_server_api.cpp
                 from /home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/src/core/api/dns_server_api.cpp:36:
[9/626] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/dns_api.cpp.obj
FAILED: modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/dns_api.cpp.obj
ccache /home/mihai/ncs/toolchains/b81a7cd864/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-g++ -DKERNEL -DK_HEAP_MEM_POOL_SIZE=4096 -DMBEDTLS_CONFIG_FILE=\"config-tls-generic.h\" -DMBEDTLS_SSL_EXPORT_KEYS -DNRF5340_XXAA_APPLICATION -DNRF_802154_ACK_TIMEOUT_ENABLED=1 -DNRF_802154_CARRIER_FUNCTIONS_ENABLED=0 -DNRF_802154_CCA_CORR_LIMIT_DEFAULT=2 -DNRF_802154_CCA_CORR_THRESHOLD_DEFAULT=45 -DNRF_802154_CCA_ED_THRESHOLD_DEFAULT=45 -DNRF_802154_CCA_MODE_DEFAULT=NRF_RADIO_CCA_MODE_ED -DNRF_802154_ENCRYPTION_ENABLED=0 -DNRF_802154_IE_WRITER_ENABLED=0 -DNRF_802154_INTERNAL_RADIO_IRQ_HANDLING=0 -DNRF_802154_PENDING_EXTENDED_ADDRESSES=16 -DNRF_802154_PENDING_SHORT_ADDRESSES=16 -DNRF_802154_PLATFORM_ASSERT_INCLUDE=\"nrf_802154_assert_zephyr.h\" -DNRF_802154_RX_BUFFERS=16 -DNRF_802154_SECURITY_KEY_STORAGE_SIZE=3 -DNRF_802154_SECURITY_WRITER_ENABLED=0 -DNRF_802154_SERIALIZATION_HOST=1 -DNRF_802154_TX_STARTED_NOTIFY_ENABLED=1 -DNRF_802154_USE_RAW_API=1 -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DOPENTHREAD_CONFIG_ASSERT_ENABLE=0 -DOPENTHREAD_CONFIG_BACKBONE_ROUTER_DUA_NDPROXYING_ENABLE=0 -DOPENTHREAD_CONFIG_BACKBONE_ROUTER_ENABLE=0 -DOPENTHREAD_CONFIG_BACKBONE_ROUTER_MULTICAST_ROUTING_ENABLE=0 -DOPENTHREAD_CONFIG_BLE_TCAT_ENABLE=0 -DOPENTHREAD_CONFIG_BORDER_AGENT_ENABLE=0 -DOPENTHREAD_CONFIG_BORDER_AGENT_EPHEMERAL_KEY_ENABLE=0 -DOPENTHREAD_CONFIG_BORDER_AGENT_ID_ENABLE=0 -DOPENTHREAD_CONFIG_BORDER_ROUTER_ENABLE=0 -DOPENTHREAD_CONFIG_BORDER_ROUTING_DHCP6_PD_ENABLE=0 -DOPENTHREAD_CONFIG_BORDER_ROUTING_ENABLE=0 -DOPENTHREAD_CONFIG_CHANNEL_MANAGER_CSL_CHANNEL_SELECT_ENABLE=0 -DOPENTHREAD_CONFIG_CHANNEL_MANAGER_ENABLE=0 -DOPENTHREAD_CONFIG_CHANNEL_MONITOR_ENABLE=0 -DOPENTHREAD_CONFIG_COAP_API_ENABLE=0 -DOPENTHREAD_CONFIG_COAP_BLOCKWISE_TRANSFER_ENABLE=0 -DOPENTHREAD_CONFIG_COAP_OBSERVE_API_ENABLE=0 -DOPENTHREAD_CONFIG_COAP_SECURE_API_ENABLE=0 -DOPENTHREAD_CONFIG_COMMISSIONER_ENABLE=0 -DOPENTHREAD_CONFIG_DATASET_UPDATER_ENABLE=0 -DOPENTHREAD_CONFIG_DEVICE_POWER_SUPPLY=OT_POWER_SUPPLY_EXTERNAL -DOPENTHREAD_CONFIG_DHCP6_CLIENT_ENABLE=0 -DOPENTHREAD_CONFIG_DHCP6_SERVER_ENABLE=0 -DOPENTHREAD_CONFIG_DIAG_ENABLE=0 -DOPENTHREAD_CONFIG_DNSSD_DISCOVERY_PROXY_ENABLE=0 -DOPENTHREAD_CONFIG_DNSSD_SERVER_ENABLE=0 -DOPENTHREAD_CONFIG_DNS_CLIENT_ENABLE=0 -DOPENTHREAD_CONFIG_DNS_CLIENT_OVER_TCP_ENABLE=0 -DOPENTHREAD_CONFIG_DNS_DSO_ENABLE=0 -DOPENTHREAD_CONFIG_DNS_UPSTREAM_QUERY_ENABLE=0 -DOPENTHREAD_CONFIG_DUA_ENABLE=0 -DOPENTHREAD_CONFIG_DYNAMIC_STORE_FRAME_AHEAD_COUNTER_ENABLE=0 -DOPENTHREAD_CONFIG_ECDSA_ENABLE=0 -DOPENTHREAD_CONFIG_ENABLE_BUILTIN_MBEDTLS=0 -DOPENTHREAD_CONFIG_ENABLE_BUILTIN_MBEDTLS_MANAGEMENT=0 -DOPENTHREAD_CONFIG_HEAP_EXTERNAL_ENABLE=0 -DOPENTHREAD_CONFIG_HISTORY_TRACKER_ENABLE=0 -DOPENTHREAD_CONFIG_IP6_BR_COUNTERS_ENABLE=0 -DOPENTHREAD_CONFIG_IP6_FRAGMENTATION_ENABLE=0 -DOPENTHREAD_CONFIG_IP6_SLAAC_ENABLE=0 -DOPENTHREAD_CONFIG_JAM_DETECTION_ENABLE=0 -DOPENTHREAD_CONFIG_JOINER_ENABLE=0 -DOPENTHREAD_CONFIG_LINK_METRICS_MANAGER_ENABLE=0 -DOPENTHREAD_CONFIG_LINK_RAW_ENABLE=0 -DOPENTHREAD_CONFIG_LOG_LEVEL=0 -DOPENTHREAD_CONFIG_LOG_LEVEL_DYNAMIC_ENABLE=0 -DOPENTHREAD_CONFIG_MAC_CSL_AUTO_SYNC_ENABLE=0 -DOPENTHREAD_CONFIG_MAC_CSL_DEBUG_ENABLE=0 -DOPENTHREAD_CONFIG_MAC_CSL_RECEIVER_ENABLE=0 -DOPENTHREAD_CONFIG_MAC_CSL_RECEIVER_LOCAL_TIME_SYNC=0 -DOPENTHREAD_CONFIG_MAC_FILTER_ENABLE=0 -DOPENTHREAD_CONFIG_MAC_OUTGOING_BEACON_PAYLOAD_ENABLE=0 -DOPENTHREAD_CONFIG_MESH_DIAG_ENABLE=0 -DOPENTHREAD_CONFIG_MESSAGE_USE_HEAP_ENABLE=0 -DOPENTHREAD_CONFIG_MLE_DEVICE_PROPERTY_LEADER_WEIGHT_ENABLE=0 -DOPENTHREAD_CONFIG_MLE_LINK_METRICS_INITIATOR_ENABLE=0 -DOPENTHREAD_CONFIG_MLE_LINK_METRICS_SUBJECT_ENABLE=0 -DOPENTHREAD_CONFIG_MLE_LONG_ROUTES_ENABLE=0 -DOPENTHREAD_CONFIG_MLR_ENABLE=1 -DOPENTHREAD_CONFIG_MULTICAST_DNS_ENABLE=0 -DOPENTHREAD_CONFIG_MULTIPAN_RCP_ENABLE=0 -DOPENTHREAD_CONFIG_MULTIPLE_INSTANCE_ENABLE=0 -DOPENTHREAD_CONFIG_NAT64_BORDER_ROUTING_ENABLE=0 -DOPENTHREAD_CONFIG_NAT64_TRANSLATOR_ENABLE=0 -DOPENTHREAD_CONFIG_NCP_HDLC_ENABLE=1 -DOPENTHREAD_CONFIG_NCP_INFRA_IF_ENABLE=0 -DOPENTHREAD_CONFIG_NEIGHBOR_DISCOVERY_AGENT_ENABLE=0 -DOPENTHREAD_CONFIG_NETDATA_PUBLISHER_ENABLE=0 -DOPENTHREAD_CONFIG_NET_DIAG_VENDOR_INFO_SET_API_ENABLE=0 -DOPENTHREAD_CONFIG_OPERATIONAL_DATASET_AUTO_INIT=1 -DOPENTHREAD_CONFIG_OTNS_ENABLE=0 -DOPENTHREAD_CONFIG_PING_SENDER_ENABLE=0 -DOPENTHREAD_CONFIG_PLATFORM_BOOTLOADER_MODE_ENABLE=0 -DOPENTHREAD_CONFIG_PLATFORM_KEY_REFERENCES_ENABLE=0 -DOPENTHREAD_CONFIG_PLATFORM_LOG_CRASH_DUMP_ENABLE=0 -DOPENTHREAD_CONFIG_PLATFORM_NETIF_ENABLE=0 -DOPENTHREAD_CONFIG_PLATFORM_POWER_CALIBRATION_ENABLE=0 -DOPENTHREAD_CONFIG_PLATFORM_UDP_ENABLE=0 -DOPENTHREAD_CONFIG_RADIO_LINK_IEEE_802_15_4_ENABLE=1 -DOPENTHREAD_CONFIG_RADIO_LINK_TREL_ENABLE=0 -DOPENTHREAD_CONFIG_REFERENCE_DEVICE_ENABLE=0 -DOPENTHREAD_CONFIG_SNTP_CLIENT_ENABLE=0 -DOPENTHREAD_CONFIG_SRP_CLIENT_ENABLE=0 -DOPENTHREAD_CONFIG_SRP_SERVER_ADVERTISING_PROXY_ENABLE=0 -DOPENTHREAD_CONFIG_SRP_SERVER_ENABLE=0 -DOPENTHREAD_CONFIG_TCP_ENABLE=0 -DOPENTHREAD_CONFIG_THREAD_VERSION=OT_THREAD_VERSION_1_1 -DOPENTHREAD_CONFIG_TIME_SYNC_ENABLE=0 -DOPENTHREAD_CONFIG_TMF_ANYCAST_LOCATOR_ENABLE=0 -DOPENTHREAD_CONFIG_TMF_NETDATA_SERVICE_ENABLE=0 -DOPENTHREAD_CONFIG_TMF_NETDIAG_CLIENT_ENABLE=0 -DOPENTHREAD_CONFIG_TX_QUEUE_STATISTICS_ENABLE=0 -DOPENTHREAD_CONFIG_UDP_FORWARD_ENABLE=0 -DOPENTHREAD_CONFIG_UPTIME_ENABLE=1 -DOPENTHREAD_CONFIG_VERHOEFF_CHECKSUM_ENABLE=0 -DOPENTHREAD_FTD=1 -DOPENTHREAD_MTD=0 -DOPENTHREAD_POSIX_CONFIG_FIREWALL_ENABLE=0 -DOPENTHREAD_PROJECT_CORE_CONFIG_FILE=\"openthread-core-zephyr-config.h\" -DOPENTHREAD_RADIO=0 -DOPENTHREAD_SETTINGS_RAM=0 -DPACKAGE_NAME=\"OPENTHREAD\" -DPICOLIBC_LONG_LONG_PRINTF_SCANF -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR__=1 -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_sensor/build/modules/openthread/build/etc/cmake -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/etc/cmake -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/src/core -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/crypto/mbedtls/include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/modules/mbedtls/configs -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/modules/mbedtls/include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/src -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/examples/platforms/zephyr -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_sensor/build/zephyr/include/generated/zephyr -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_sensor/build/zephyr/include/generated -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/soc/nordic -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/lib/posix/options/getopt -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/soc/nordic/nrf53/. -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/soc/nordic/common/. -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/subsys/settings/include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/subsys/shell/modules/kernel_service/thread/.. -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/hal/cmsis/CMSIS/Core/Include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/modules/cmsis/. -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/hal/nordic/nrfx -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/hal/nordic/nrfx/drivers/include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/hal/nordic/nrfx/mdk -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/modules/hal_nordic/nrfx/. -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/modules/openthread/platform/. -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/hal/nordic/drivers/nrf_802154/serialization/include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/hal/nordic/drivers/nrf_802154/serialization/include/platform -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/hal/nordic/drivers/nrf_802154/serialization/include/serialization -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/hal/nordic/drivers/nrf_802154/common/include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/modules/hal_nordic/nrf_802154/include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/third_party/tcplp/bsdtcp -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/third_party/tcplp/lib -isystem /home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/include -isystem /home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/lib/libc/common/include -isystem /home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/lib/cpp/minimal/include -isystem /home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/examples/platforms -Wall -Wextra -Wshadow -Wno-c++14-compat -fno-exceptions -fno-strict-aliasing -Os -fcheck-new -std=c++11 -fno-rtti -imacros /home/mihai/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_sensor/build/zephyr/include/generated/zephyr/autoconf.h -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee -mtp=soft --sysroot=/home/mihai/ncs/toolchains/b81a7cd864/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros /home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -fno-pic -fno-pie -fno-asynchronous-unwind-tables -ftls-model=local-exec -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=/home/mihai/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_sensor=CMAKE_SOURCE_DIR -fmacro-prefix-map=/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/home/mihai/Documents/KNX_testing/nrf-knx-iot=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=picolibc.specs -D_POSIX_THREADS -nostdinc++ -fno-builtin -imacros /home/mihai/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_sensor/build/zephyr/include/generated/zephyr/autoconf.h -std=c++11 -MD -MT modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/dns_api.cpp.obj -MF modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/dns_api.cpp.obj.d -o modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/dns_api.cpp.obj -c /home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/src/core/api/dns_api.cpp
                 from /home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/src/core/api/dns_api.cpp:38:
[10/626] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/crypto_api.cpp.obj
FAILED: modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/crypto_api.cpp.obj
ccache /home/mihai/ncs/toolchains/b81a7cd864/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-g++ -DKERNEL -DK_HEAP_MEM_POOL_SIZE=4096 -DMBEDTLS_CONFIG_FILE=\"config-tls-generic.h\" -DMBEDTLS_SSL_EXPORT_KEYS -DNRF5340_XXAA_APPLICATION -DNRF_802154_ACK_TIMEOUT_ENABLED=1 -DNRF_802154_CARRIER_FUNCTIONS_ENABLED=0 -DNRF_802154_CCA_CORR_LIMIT_DEFAULT=2 -DNRF_802154_CCA_CORR_THRESHOLD_DEFAULT=45 -DNRF_802154_CCA_ED_THRESHOLD_DEFAULT=45 -DNRF_802154_CCA_MODE_DEFAULT=NRF_RADIO_CCA_MODE_ED -DNRF_802154_ENCRYPTION_ENABLED=0 -DNRF_802154_IE_WRITER_ENABLED=0 -DNRF_802154_INTERNAL_RADIO_IRQ_HANDLING=0 -DNRF_802154_PENDING_EXTENDED_ADDRESSES=16 -DNRF_802154_PENDING_SHORT_ADDRESSES=16 -DNRF_802154_PLATFORM_ASSERT_INCLUDE=\"nrf_802154_assert_zephyr.h\" -DNRF_802154_RX_BUFFERS=16 -DNRF_802154_SECURITY_KEY_STORAGE_SIZE=3 -DNRF_802154_SECURITY_WRITER_ENABLED=0 -DNRF_802154_SERIALIZATION_HOST=1 -DNRF_802154_TX_STARTED_NOTIFY_ENABLED=1 -DNRF_802154_USE_RAW_API=1 -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DOPENTHREAD_CONFIG_ASSERT_ENABLE=0 -DOPENTHREAD_CONFIG_BACKBONE_ROUTER_DUA_NDPROXYING_ENABLE=0 -DOPENTHREAD_CONFIG_BACKBONE_ROUTER_ENABLE=0 -DOPENTHREAD_CONFIG_BACKBONE_ROUTER_MULTICAST_ROUTING_ENABLE=0 -DOPENTHREAD_CONFIG_BLE_TCAT_ENABLE=0 -DOPENTHREAD_CONFIG_BORDER_AGENT_ENABLE=0 -DOPENTHREAD_CONFIG_BORDER_AGENT_EPHEMERAL_KEY_ENABLE=0 -DOPENTHREAD_CONFIG_BORDER_AGENT_ID_ENABLE=0 -DOPENTHREAD_CONFIG_BORDER_ROUTER_ENABLE=0 -DOPENTHREAD_CONFIG_BORDER_ROUTING_DHCP6_PD_ENABLE=0 -DOPENTHREAD_CONFIG_BORDER_ROUTING_ENABLE=0 -DOPENTHREAD_CONFIG_CHANNEL_MANAGER_CSL_CHANNEL_SELECT_ENABLE=0 -DOPENTHREAD_CONFIG_CHANNEL_MANAGER_ENABLE=0 -DOPENTHREAD_CONFIG_CHANNEL_MONITOR_ENABLE=0 -DOPENTHREAD_CONFIG_COAP_API_ENABLE=0 -DOPENTHREAD_CONFIG_COAP_BLOCKWISE_TRANSFER_ENABLE=0 -DOPENTHREAD_CONFIG_COAP_OBSERVE_API_ENABLE=0 -DOPENTHREAD_CONFIG_COAP_SECURE_API_ENABLE=0 -DOPENTHREAD_CONFIG_COMMISSIONER_ENABLE=0 -DOPENTHREAD_CONFIG_DATASET_UPDATER_ENABLE=0 -DOPENTHREAD_CONFIG_DEVICE_POWER_SUPPLY=OT_POWER_SUPPLY_EXTERNAL -DOPENTHREAD_CONFIG_DHCP6_CLIENT_ENABLE=0 -DOPENTHREAD_CONFIG_DHCP6_SERVER_ENABLE=0 -DOPENTHREAD_CONFIG_DIAG_ENABLE=0 -DOPENTHREAD_CONFIG_DNSSD_DISCOVERY_PROXY_ENABLE=0 -DOPENTHREAD_CONFIG_DNSSD_SERVER_ENABLE=0 -DOPENTHREAD_CONFIG_DNS_CLIENT_ENABLE=0 -DOPENTHREAD_CONFIG_DNS_CLIENT_OVER_TCP_ENABLE=0 -DOPENTHREAD_CONFIG_DNS_DSO_ENABLE=0 -DOPENTHREAD_CONFIG_DNS_UPSTREAM_QUERY_ENABLE=0 -DOPENTHREAD_CONFIG_DUA_ENABLE=0 -DOPENTHREAD_CONFIG_DYNAMIC_STORE_FRAME_AHEAD_COUNTER_ENABLE=0 -DOPENTHREAD_CONFIG_ECDSA_ENABLE=0 -DOPENTHREAD_CONFIG_ENABLE_BUILTIN_MBEDTLS=0 -DOPENTHREAD_CONFIG_ENABLE_BUILTIN_MBEDTLS_MANAGEMENT=0 -DOPENTHREAD_CONFIG_HEAP_EXTERNAL_ENABLE=0 -DOPENTHREAD_CONFIG_HISTORY_TRACKER_ENABLE=0 -DOPENTHREAD_CONFIG_IP6_BR_COUNTERS_ENABLE=0 -DOPENTHREAD_CONFIG_IP6_FRAGMENTATION_ENABLE=0 -DOPENTHREAD_CONFIG_IP6_SLAAC_ENABLE=0 -DOPENTHREAD_CONFIG_JAM_DETECTION_ENABLE=0 -DOPENTHREAD_CONFIG_JOINER_ENABLE=0 -DOPENTHREAD_CONFIG_LINK_METRICS_MANAGER_ENABLE=0 -DOPENTHREAD_CONFIG_LINK_RAW_ENABLE=0 -DOPENTHREAD_CONFIG_LOG_LEVEL=0 -DOPENTHREAD_CONFIG_LOG_LEVEL_DYNAMIC_ENABLE=0 -DOPENTHREAD_CONFIG_MAC_CSL_AUTO_SYNC_ENABLE=0 -DOPENTHREAD_CONFIG_MAC_CSL_DEBUG_ENABLE=0 -DOPENTHREAD_CONFIG_MAC_CSL_RECEIVER_ENABLE=0 -DOPENTHREAD_CONFIG_MAC_CSL_RECEIVER_LOCAL_TIME_SYNC=0 -DOPENTHREAD_CONFIG_MAC_FILTER_ENABLE=0 -DOPENTHREAD_CONFIG_MAC_OUTGOING_BEACON_PAYLOAD_ENABLE=0 -DOPENTHREAD_CONFIG_MESH_DIAG_ENABLE=0 -DOPENTHREAD_CONFIG_MESSAGE_USE_HEAP_ENABLE=0 -DOPENTHREAD_CONFIG_MLE_DEVICE_PROPERTY_LEADER_WEIGHT_ENABLE=0 -DOPENTHREAD_CONFIG_MLE_LINK_METRICS_INITIATOR_ENABLE=0 -DOPENTHREAD_CONFIG_MLE_LINK_METRICS_SUBJECT_ENABLE=0 -DOPENTHREAD_CONFIG_MLE_LONG_ROUTES_ENABLE=0 -DOPENTHREAD_CONFIG_MLR_ENABLE=1 -DOPENTHREAD_CONFIG_MULTICAST_DNS_ENABLE=0 -DOPENTHREAD_CONFIG_MULTIPAN_RCP_ENABLE=0 -DOPENTHREAD_CONFIG_MULTIPLE_INSTANCE_ENABLE=0 -DOPENTHREAD_CONFIG_NAT64_BORDER_ROUTING_ENABLE=0 -DOPENTHREAD_CONFIG_NAT64_TRANSLATOR_ENABLE=0 -DOPENTHREAD_CONFIG_NCP_HDLC_ENABLE=1 -DOPENTHREAD_CONFIG_NCP_INFRA_IF_ENABLE=0 -DOPENTHREAD_CONFIG_NEIGHBOR_DISCOVERY_AGENT_ENABLE=0 -DOPENTHREAD_CONFIG_NETDATA_PUBLISHER_ENABLE=0 -DOPENTHREAD_CONFIG_NET_DIAG_VENDOR_INFO_SET_API_ENABLE=0 -DOPENTHREAD_CONFIG_OPERATIONAL_DATASET_AUTO_INIT=1 -DOPENTHREAD_CONFIG_OTNS_ENABLE=0 -DOPENTHREAD_CONFIG_PING_SENDER_ENABLE=0 -DOPENTHREAD_CONFIG_PLATFORM_BOOTLOADER_MODE_ENABLE=0 -DOPENTHREAD_CONFIG_PLATFORM_KEY_REFERENCES_ENABLE=0 -DOPENTHREAD_CONFIG_PLATFORM_LOG_CRASH_DUMP_ENABLE=0 -DOPENTHREAD_CONFIG_PLATFORM_NETIF_ENABLE=0 -DOPENTHREAD_CONFIG_PLATFORM_POWER_CALIBRATION_ENABLE=0 -DOPENTHREAD_CONFIG_PLATFORM_UDP_ENABLE=0 -DOPENTHREAD_CONFIG_RADIO_LINK_IEEE_802_15_4_ENABLE=1 -DOPENTHREAD_CONFIG_RADIO_LINK_TREL_ENABLE=0 -DOPENTHREAD_CONFIG_REFERENCE_DEVICE_ENABLE=0 -DOPENTHREAD_CONFIG_SNTP_CLIENT_ENABLE=0 -DOPENTHREAD_CONFIG_SRP_CLIENT_ENABLE=0 -DOPENTHREAD_CONFIG_SRP_SERVER_ADVERTISING_PROXY_ENABLE=0 -DOPENTHREAD_CONFIG_SRP_SERVER_ENABLE=0 -DOPENTHREAD_CONFIG_TCP_ENABLE=0 -DOPENTHREAD_CONFIG_THREAD_VERSION=OT_THREAD_VERSION_1_1 -DOPENTHREAD_CONFIG_TIME_SYNC_ENABLE=0 -DOPENTHREAD_CONFIG_TMF_ANYCAST_LOCATOR_ENABLE=0 -DOPENTHREAD_CONFIG_TMF_NETDATA_SERVICE_ENABLE=0 -DOPENTHREAD_CONFIG_TMF_NETDIAG_CLIENT_ENABLE=0 -DOPENTHREAD_CONFIG_TX_QUEUE_STATISTICS_ENABLE=0 -DOPENTHREAD_CONFIG_UDP_FORWARD_ENABLE=0 -DOPENTHREAD_CONFIG_UPTIME_ENABLE=1 -DOPENTHREAD_CONFIG_VERHOEFF_CHECKSUM_ENABLE=0 -DOPENTHREAD_FTD=1 -DOPENTHREAD_MTD=0 -DOPENTHREAD_POSIX_CONFIG_FIREWALL_ENABLE=0 -DOPENTHREAD_PROJECT_CORE_CONFIG_FILE=\"openthread-core-zephyr-config.h\" -DOPENTHREAD_RADIO=0 -DOPENTHREAD_SETTINGS_RAM=0 -DPACKAGE_NAME=\"OPENTHREAD\" -DPICOLIBC_LONG_LONG_PRINTF_SCANF -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR__=1 -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_sensor/build/modules/openthread/build/etc/cmake -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/etc/cmake -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/src/core -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/crypto/mbedtls/include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/modules/mbedtls/configs -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/modules/mbedtls/include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/src -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/examples/platforms/zephyr -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_sensor/build/zephyr/include/generated/zephyr -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_sensor/build/zephyr/include/generated -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/soc/nordic -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/lib/posix/options/getopt -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/soc/nordic/nrf53/. -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/soc/nordic/common/. -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/subsys/settings/include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/subsys/shell/modules/kernel_service/thread/.. -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/hal/cmsis/CMSIS/Core/Include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/modules/cmsis/. -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/hal/nordic/nrfx -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/hal/nordic/nrfx/drivers/include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/hal/nordic/nrfx/mdk -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/modules/hal_nordic/nrfx/. -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/modules/openthread/platform/. -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/hal/nordic/drivers/nrf_802154/serialization/include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/hal/nordic/drivers/nrf_802154/serialization/include/platform -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/hal/nordic/drivers/nrf_802154/serialization/include/serialization -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/hal/nordic/drivers/nrf_802154/common/include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/modules/hal_nordic/nrf_802154/include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/third_party/tcplp/bsdtcp -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/third_party/tcplp/lib -isystem /home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/include -isystem /home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/lib/libc/common/include -isystem /home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/lib/cpp/minimal/include -isystem /home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/examples/platforms -Wall -Wextra -Wshadow -Wno-c++14-compat -fno-exceptions -fno-strict-aliasing -Os -fcheck-new -std=c++11 -fno-rtti -imacros /home/mihai/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_sensor/build/zephyr/include/generated/zephyr/autoconf.h -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee -mtp=soft --sysroot=/home/mihai/ncs/toolchains/b81a7cd864/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros /home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -fno-pic -fno-pie -fno-asynchronous-unwind-tables -ftls-model=local-exec -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=/home/mihai/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_sensor=CMAKE_SOURCE_DIR -fmacro-prefix-map=/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/home/mihai/Documents/KNX_testing/nrf-knx-iot=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=picolibc.specs -D_POSIX_THREADS -nostdinc++ -fno-builtin -imacros /home/mihai/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_sensor/build/zephyr/include/generated/zephyr/autoconf.h -std=c++11 -MD -MT modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/crypto_api.cpp.obj -MF modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/crypto_api.cpp.obj.d -o modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/crypto_api.cpp.obj -c /home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/src/core/api/crypto_api.cpp
                 from /home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/src/core/api/crypto_api.cpp:42:
[11/626] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/ip6_api.cpp.obj
FAILED: modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/ip6_api.cpp.obj
ccache /home/mihai/ncs/toolchains/b81a7cd864/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-g++ -DKERNEL -DK_HEAP_MEM_POOL_SIZE=4096 -DMBEDTLS_CONFIG_FILE=\"config-tls-generic.h\" -DMBEDTLS_SSL_EXPORT_KEYS -DNRF5340_XXAA_APPLICATION -DNRF_802154_ACK_TIMEOUT_ENABLED=1 -DNRF_802154_CARRIER_FUNCTIONS_ENABLED=0 -DNRF_802154_CCA_CORR_LIMIT_DEFAULT=2 -DNRF_802154_CCA_CORR_THRESHOLD_DEFAULT=45 -DNRF_802154_CCA_ED_THRESHOLD_DEFAULT=45 -DNRF_802154_CCA_MODE_DEFAULT=NRF_RADIO_CCA_MODE_ED -DNRF_802154_ENCRYPTION_ENABLED=0 -DNRF_802154_IE_WRITER_ENABLED=0 -DNRF_802154_INTERNAL_RADIO_IRQ_HANDLING=0 -DNRF_802154_PENDING_EXTENDED_ADDRESSES=16 -DNRF_802154_PENDING_SHORT_ADDRESSES=16 -DNRF_802154_PLATFORM_ASSERT_INCLUDE=\"nrf_802154_assert_zephyr.h\" -DNRF_802154_RX_BUFFERS=16 -DNRF_802154_SECURITY_KEY_STORAGE_SIZE=3 -DNRF_802154_SECURITY_WRITER_ENABLED=0 -DNRF_802154_SERIALIZATION_HOST=1 -DNRF_802154_TX_STARTED_NOTIFY_ENABLED=1 -DNRF_802154_USE_RAW_API=1 -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DOPENTHREAD_CONFIG_ASSERT_ENABLE=0 -DOPENTHREAD_CONFIG_BACKBONE_ROUTER_DUA_NDPROXYING_ENABLE=0 -DOPENTHREAD_CONFIG_BACKBONE_ROUTER_ENABLE=0 -DOPENTHREAD_CONFIG_BACKBONE_ROUTER_MULTICAST_ROUTING_ENABLE=0 -DOPENTHREAD_CONFIG_BLE_TCAT_ENABLE=0 -DOPENTHREAD_CONFIG_BORDER_AGENT_ENABLE=0 -DOPENTHREAD_CONFIG_BORDER_AGENT_EPHEMERAL_KEY_ENABLE=0 -DOPENTHREAD_CONFIG_BORDER_AGENT_ID_ENABLE=0 -DOPENTHREAD_CONFIG_BORDER_ROUTER_ENABLE=0 -DOPENTHREAD_CONFIG_BORDER_ROUTING_DHCP6_PD_ENABLE=0 -DOPENTHREAD_CONFIG_BORDER_ROUTING_ENABLE=0 -DOPENTHREAD_CONFIG_CHANNEL_MANAGER_CSL_CHANNEL_SELECT_ENABLE=0 -DOPENTHREAD_CONFIG_CHANNEL_MANAGER_ENABLE=0 -DOPENTHREAD_CONFIG_CHANNEL_MONITOR_ENABLE=0 -DOPENTHREAD_CONFIG_COAP_API_ENABLE=0 -DOPENTHREAD_CONFIG_COAP_BLOCKWISE_TRANSFER_ENABLE=0 -DOPENTHREAD_CONFIG_COAP_OBSERVE_API_ENABLE=0 -DOPENTHREAD_CONFIG_COAP_SECURE_API_ENABLE=0 -DOPENTHREAD_CONFIG_COMMISSIONER_ENABLE=0 -DOPENTHREAD_CONFIG_DATASET_UPDATER_ENABLE=0 -DOPENTHREAD_CONFIG_DEVICE_POWER_SUPPLY=OT_POWER_SUPPLY_EXTERNAL -DOPENTHREAD_CONFIG_DHCP6_CLIENT_ENABLE=0 -DOPENTHREAD_CONFIG_DHCP6_SERVER_ENABLE=0 -DOPENTHREAD_CONFIG_DIAG_ENABLE=0 -DOPENTHREAD_CONFIG_DNSSD_DISCOVERY_PROXY_ENABLE=0 -DOPENTHREAD_CONFIG_DNSSD_SERVER_ENABLE=0 -DOPENTHREAD_CONFIG_DNS_CLIENT_ENABLE=0 -DOPENTHREAD_CONFIG_DNS_CLIENT_OVER_TCP_ENABLE=0 -DOPENTHREAD_CONFIG_DNS_DSO_ENABLE=0 -DOPENTHREAD_CONFIG_DNS_UPSTREAM_QUERY_ENABLE=0 -DOPENTHREAD_CONFIG_DUA_ENABLE=0 -DOPENTHREAD_CONFIG_DYNAMIC_STORE_FRAME_AHEAD_COUNTER_ENABLE=0 -DOPENTHREAD_CONFIG_ECDSA_ENABLE=0 -DOPENTHREAD_CONFIG_ENABLE_BUILTIN_MBEDTLS=0 -DOPENTHREAD_CONFIG_ENABLE_BUILTIN_MBEDTLS_MANAGEMENT=0 -DOPENTHREAD_CONFIG_HEAP_EXTERNAL_ENABLE=0 -DOPENTHREAD_CONFIG_HISTORY_TRACKER_ENABLE=0 -DOPENTHREAD_CONFIG_IP6_BR_COUNTERS_ENABLE=0 -DOPENTHREAD_CONFIG_IP6_FRAGMENTATION_ENABLE=0 -DOPENTHREAD_CONFIG_IP6_SLAAC_ENABLE=0 -DOPENTHREAD_CONFIG_JAM_DETECTION_ENABLE=0 -DOPENTHREAD_CONFIG_JOINER_ENABLE=0 -DOPENTHREAD_CONFIG_LINK_METRICS_MANAGER_ENABLE=0 -DOPENTHREAD_CONFIG_LINK_RAW_ENABLE=0 -DOPENTHREAD_CONFIG_LOG_LEVEL=0 -DOPENTHREAD_CONFIG_LOG_LEVEL_DYNAMIC_ENABLE=0 -DOPENTHREAD_CONFIG_MAC_CSL_AUTO_SYNC_ENABLE=0 -DOPENTHREAD_CONFIG_MAC_CSL_DEBUG_ENABLE=0 -DOPENTHREAD_CONFIG_MAC_CSL_RECEIVER_ENABLE=0 -DOPENTHREAD_CONFIG_MAC_CSL_RECEIVER_LOCAL_TIME_SYNC=0 -DOPENTHREAD_CONFIG_MAC_FILTER_ENABLE=0 -DOPENTHREAD_CONFIG_MAC_OUTGOING_BEACON_PAYLOAD_ENABLE=0 -DOPENTHREAD_CONFIG_MESH_DIAG_ENABLE=0 -DOPENTHREAD_CONFIG_MESSAGE_USE_HEAP_ENABLE=0 -DOPENTHREAD_CONFIG_MLE_DEVICE_PROPERTY_LEADER_WEIGHT_ENABLE=0 -DOPENTHREAD_CONFIG_MLE_LINK_METRICS_INITIATOR_ENABLE=0 -DOPENTHREAD_CONFIG_MLE_LINK_METRICS_SUBJECT_ENABLE=0 -DOPENTHREAD_CONFIG_MLE_LONG_ROUTES_ENABLE=0 -DOPENTHREAD_CONFIG_MLR_ENABLE=1 -DOPENTHREAD_CONFIG_MULTICAST_DNS_ENABLE=0 -DOPENTHREAD_CONFIG_MULTIPAN_RCP_ENABLE=0 -DOPENTHREAD_CONFIG_MULTIPLE_INSTANCE_ENABLE=0 -DOPENTHREAD_CONFIG_NAT64_BORDER_ROUTING_ENABLE=0 -DOPENTHREAD_CONFIG_NAT64_TRANSLATOR_ENABLE=0 -DOPENTHREAD_CONFIG_NCP_HDLC_ENABLE=1 -DOPENTHREAD_CONFIG_NCP_INFRA_IF_ENABLE=0 -DOPENTHREAD_CONFIG_NEIGHBOR_DISCOVERY_AGENT_ENABLE=0 -DOPENTHREAD_CONFIG_NETDATA_PUBLISHER_ENABLE=0 -DOPENTHREAD_CONFIG_NET_DIAG_VENDOR_INFO_SET_API_ENABLE=0 -DOPENTHREAD_CONFIG_OPERATIONAL_DATASET_AUTO_INIT=1 -DOPENTHREAD_CONFIG_OTNS_ENABLE=0 -DOPENTHREAD_CONFIG_PING_SENDER_ENABLE=0 -DOPENTHREAD_CONFIG_PLATFORM_BOOTLOADER_MODE_ENABLE=0 -DOPENTHREAD_CONFIG_PLATFORM_KEY_REFERENCES_ENABLE=0 -DOPENTHREAD_CONFIG_PLATFORM_LOG_CRASH_DUMP_ENABLE=0 -DOPENTHREAD_CONFIG_PLATFORM_NETIF_ENABLE=0 -DOPENTHREAD_CONFIG_PLATFORM_POWER_CALIBRATION_ENABLE=0 -DOPENTHREAD_CONFIG_PLATFORM_UDP_ENABLE=0 -DOPENTHREAD_CONFIG_RADIO_LINK_IEEE_802_15_4_ENABLE=1 -DOPENTHREAD_CONFIG_RADIO_LINK_TREL_ENABLE=0 -DOPENTHREAD_CONFIG_REFERENCE_DEVICE_ENABLE=0 -DOPENTHREAD_CONFIG_SNTP_CLIENT_ENABLE=0 -DOPENTHREAD_CONFIG_SRP_CLIENT_ENABLE=0 -DOPENTHREAD_CONFIG_SRP_SERVER_ADVERTISING_PROXY_ENABLE=0 -DOPENTHREAD_CONFIG_SRP_SERVER_ENABLE=0 -DOPENTHREAD_CONFIG_TCP_ENABLE=0 -DOPENTHREAD_CONFIG_THREAD_VERSION=OT_THREAD_VERSION_1_1 -DOPENTHREAD_CONFIG_TIME_SYNC_ENABLE=0 -DOPENTHREAD_CONFIG_TMF_ANYCAST_LOCATOR_ENABLE=0 -DOPENTHREAD_CONFIG_TMF_NETDATA_SERVICE_ENABLE=0 -DOPENTHREAD_CONFIG_TMF_NETDIAG_CLIENT_ENABLE=0 -DOPENTHREAD_CONFIG_TX_QUEUE_STATISTICS_ENABLE=0 -DOPENTHREAD_CONFIG_UDP_FORWARD_ENABLE=0 -DOPENTHREAD_CONFIG_UPTIME_ENABLE=1 -DOPENTHREAD_CONFIG_VERHOEFF_CHECKSUM_ENABLE=0 -DOPENTHREAD_FTD=1 -DOPENTHREAD_MTD=0 -DOPENTHREAD_POSIX_CONFIG_FIREWALL_ENABLE=0 -DOPENTHREAD_PROJECT_CORE_CONFIG_FILE=\"openthread-core-zephyr-config.h\" -DOPENTHREAD_RADIO=0 -DOPENTHREAD_SETTINGS_RAM=0 -DPACKAGE_NAME=\"OPENTHREAD\" -DPICOLIBC_LONG_LONG_PRINTF_SCANF -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR__=1 -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_sensor/build/modules/openthread/build/etc/cmake -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/etc/cmake -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/src/core -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/crypto/mbedtls/include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/modules/mbedtls/configs -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/modules/mbedtls/include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/src -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/examples/platforms/zephyr -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_sensor/build/zephyr/include/generated/zephyr -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_sensor/build/zephyr/include/generated -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/soc/nordic -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/lib/posix/options/getopt -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/soc/nordic/nrf53/. -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/soc/nordic/common/. -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/subsys/settings/include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/subsys/shell/modules/kernel_service/thread/.. -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/hal/cmsis/CMSIS/Core/Include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/modules/cmsis/. -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/hal/nordic/nrfx -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/hal/nordic/nrfx/drivers/include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/hal/nordic/nrfx/mdk -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/modules/hal_nordic/nrfx/. -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/modules/openthread/platform/. -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/hal/nordic/drivers/nrf_802154/serialization/include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/hal/nordic/drivers/nrf_802154/serialization/include/platform -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/hal/nordic/drivers/nrf_802154/serialization/include/serialization -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/hal/nordic/drivers/nrf_802154/common/include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/modules/hal_nordic/nrf_802154/include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/third_party/tcplp/bsdtcp -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/third_party/tcplp/lib -isystem /home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/include -isystem /home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/lib/libc/common/include -isystem /home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/lib/cpp/minimal/include -isystem /home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/examples/platforms -Wall -Wextra -Wshadow -Wno-c++14-compat -fno-exceptions -fno-strict-aliasing -Os -fcheck-new -std=c++11 -fno-rtti -imacros /home/mihai/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_sensor/build/zephyr/include/generated/zephyr/autoconf.h -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee -mtp=soft --sysroot=/home/mihai/ncs/toolchains/b81a7cd864/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros /home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -fno-pic -fno-pie -fno-asynchronous-unwind-tables -ftls-model=local-exec -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=/home/mihai/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_sensor=CMAKE_SOURCE_DIR -fmacro-prefix-map=/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/home/mihai/Documents/KNX_testing/nrf-knx-iot=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=picolibc.specs -D_POSIX_THREADS -nostdinc++ -fno-builtin -imacros /home/mihai/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_sensor/build/zephyr/include/generated/zephyr/autoconf.h -std=c++11 -MD -MT modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/ip6_api.cpp.obj -MF modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/ip6_api.cpp.obj.d -o modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/ip6_api.cpp.obj -c /home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/src/core/api/ip6_api.cpp
                 from /home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/src/core/api/ip6_api.cpp:39:
[12/626] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/link_api.cpp.obj
FAILED: modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/link_api.cpp.obj
ccache /home/mihai/ncs/toolchains/b81a7cd864/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-g++ -DKERNEL -DK_HEAP_MEM_POOL_SIZE=4096 -DMBEDTLS_CONFIG_FILE=\"config-tls-generic.h\" -DMBEDTLS_SSL_EXPORT_KEYS -DNRF5340_XXAA_APPLICATION -DNRF_802154_ACK_TIMEOUT_ENABLED=1 -DNRF_802154_CARRIER_FUNCTIONS_ENABLED=0 -DNRF_802154_CCA_CORR_LIMIT_DEFAULT=2 -DNRF_802154_CCA_CORR_THRESHOLD_DEFAULT=45 -DNRF_802154_CCA_ED_THRESHOLD_DEFAULT=45 -DNRF_802154_CCA_MODE_DEFAULT=NRF_RADIO_CCA_MODE_ED -DNRF_802154_ENCRYPTION_ENABLED=0 -DNRF_802154_IE_WRITER_ENABLED=0 -DNRF_802154_INTERNAL_RADIO_IRQ_HANDLING=0 -DNRF_802154_PENDING_EXTENDED_ADDRESSES=16 -DNRF_802154_PENDING_SHORT_ADDRESSES=16 -DNRF_802154_PLATFORM_ASSERT_INCLUDE=\"nrf_802154_assert_zephyr.h\" -DNRF_802154_RX_BUFFERS=16 -DNRF_802154_SECURITY_KEY_STORAGE_SIZE=3 -DNRF_802154_SECURITY_WRITER_ENABLED=0 -DNRF_802154_SERIALIZATION_HOST=1 -DNRF_802154_TX_STARTED_NOTIFY_ENABLED=1 -DNRF_802154_USE_RAW_API=1 -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DOPENTHREAD_CONFIG_ASSERT_ENABLE=0 -DOPENTHREAD_CONFIG_BACKBONE_ROUTER_DUA_NDPROXYING_ENABLE=0 -DOPENTHREAD_CONFIG_BACKBONE_ROUTER_ENABLE=0 -DOPENTHREAD_CONFIG_BACKBONE_ROUTER_MULTICAST_ROUTING_ENABLE=0 -DOPENTHREAD_CONFIG_BLE_TCAT_ENABLE=0 -DOPENTHREAD_CONFIG_BORDER_AGENT_ENABLE=0 -DOPENTHREAD_CONFIG_BORDER_AGENT_EPHEMERAL_KEY_ENABLE=0 -DOPENTHREAD_CONFIG_BORDER_AGENT_ID_ENABLE=0 -DOPENTHREAD_CONFIG_BORDER_ROUTER_ENABLE=0 -DOPENTHREAD_CONFIG_BORDER_ROUTING_DHCP6_PD_ENABLE=0 -DOPENTHREAD_CONFIG_BORDER_ROUTING_ENABLE=0 -DOPENTHREAD_CONFIG_CHANNEL_MANAGER_CSL_CHANNEL_SELECT_ENABLE=0 -DOPENTHREAD_CONFIG_CHANNEL_MANAGER_ENABLE=0 -DOPENTHREAD_CONFIG_CHANNEL_MONITOR_ENABLE=0 -DOPENTHREAD_CONFIG_COAP_API_ENABLE=0 -DOPENTHREAD_CONFIG_COAP_BLOCKWISE_TRANSFER_ENABLE=0 -DOPENTHREAD_CONFIG_COAP_OBSERVE_API_ENABLE=0 -DOPENTHREAD_CONFIG_COAP_SECURE_API_ENABLE=0 -DOPENTHREAD_CONFIG_COMMISSIONER_ENABLE=0 -DOPENTHREAD_CONFIG_DATASET_UPDATER_ENABLE=0 -DOPENTHREAD_CONFIG_DEVICE_POWER_SUPPLY=OT_POWER_SUPPLY_EXTERNAL -DOPENTHREAD_CONFIG_DHCP6_CLIENT_ENABLE=0 -DOPENTHREAD_CONFIG_DHCP6_SERVER_ENABLE=0 -DOPENTHREAD_CONFIG_DIAG_ENABLE=0 -DOPENTHREAD_CONFIG_DNSSD_DISCOVERY_PROXY_ENABLE=0 -DOPENTHREAD_CONFIG_DNSSD_SERVER_ENABLE=0 -DOPENTHREAD_CONFIG_DNS_CLIENT_ENABLE=0 -DOPENTHREAD_CONFIG_DNS_CLIENT_OVER_TCP_ENABLE=0 -DOPENTHREAD_CONFIG_DNS_DSO_ENABLE=0 -DOPENTHREAD_CONFIG_DNS_UPSTREAM_QUERY_ENABLE=0 -DOPENTHREAD_CONFIG_DUA_ENABLE=0 -DOPENTHREAD_CONFIG_DYNAMIC_STORE_FRAME_AHEAD_COUNTER_ENABLE=0 -DOPENTHREAD_CONFIG_ECDSA_ENABLE=0 -DOPENTHREAD_CONFIG_ENABLE_BUILTIN_MBEDTLS=0 -DOPENTHREAD_CONFIG_ENABLE_BUILTIN_MBEDTLS_MANAGEMENT=0 -DOPENTHREAD_CONFIG_HEAP_EXTERNAL_ENABLE=0 -DOPENTHREAD_CONFIG_HISTORY_TRACKER_ENABLE=0 -DOPENTHREAD_CONFIG_IP6_BR_COUNTERS_ENABLE=0 -DOPENTHREAD_CONFIG_IP6_FRAGMENTATION_ENABLE=0 -DOPENTHREAD_CONFIG_IP6_SLAAC_ENABLE=0 -DOPENTHREAD_CONFIG_JAM_DETECTION_ENABLE=0 -DOPENTHREAD_CONFIG_JOINER_ENABLE=0 -DOPENTHREAD_CONFIG_LINK_METRICS_MANAGER_ENABLE=0 -DOPENTHREAD_CONFIG_LINK_RAW_ENABLE=0 -DOPENTHREAD_CONFIG_LOG_LEVEL=0 -DOPENTHREAD_CONFIG_LOG_LEVEL_DYNAMIC_ENABLE=0 -DOPENTHREAD_CONFIG_MAC_CSL_AUTO_SYNC_ENABLE=0 -DOPENTHREAD_CONFIG_MAC_CSL_DEBUG_ENABLE=0 -DOPENTHREAD_CONFIG_MAC_CSL_RECEIVER_ENABLE=0 -DOPENTHREAD_CONFIG_MAC_CSL_RECEIVER_LOCAL_TIME_SYNC=0 -DOPENTHREAD_CONFIG_MAC_FILTER_ENABLE=0 -DOPENTHREAD_CONFIG_MAC_OUTGOING_BEACON_PAYLOAD_ENABLE=0 -DOPENTHREAD_CONFIG_MESH_DIAG_ENABLE=0 -DOPENTHREAD_CONFIG_MESSAGE_USE_HEAP_ENABLE=0 -DOPENTHREAD_CONFIG_MLE_DEVICE_PROPERTY_LEADER_WEIGHT_ENABLE=0 -DOPENTHREAD_CONFIG_MLE_LINK_METRICS_INITIATOR_ENABLE=0 -DOPENTHREAD_CONFIG_MLE_LINK_METRICS_SUBJECT_ENABLE=0 -DOPENTHREAD_CONFIG_MLE_LONG_ROUTES_ENABLE=0 -DOPENTHREAD_CONFIG_MLR_ENABLE=1 -DOPENTHREAD_CONFIG_MULTICAST_DNS_ENABLE=0 -DOPENTHREAD_CONFIG_MULTIPAN_RCP_ENABLE=0 -DOPENTHREAD_CONFIG_MULTIPLE_INSTANCE_ENABLE=0 -DOPENTHREAD_CONFIG_NAT64_BORDER_ROUTING_ENABLE=0 -DOPENTHREAD_CONFIG_NAT64_TRANSLATOR_ENABLE=0 -DOPENTHREAD_CONFIG_NCP_HDLC_ENABLE=1 -DOPENTHREAD_CONFIG_NCP_INFRA_IF_ENABLE=0 -DOPENTHREAD_CONFIG_NEIGHBOR_DISCOVERY_AGENT_ENABLE=0 -DOPENTHREAD_CONFIG_NETDATA_PUBLISHER_ENABLE=0 -DOPENTHREAD_CONFIG_NET_DIAG_VENDOR_INFO_SET_API_ENABLE=0 -DOPENTHREAD_CONFIG_OPERATIONAL_DATASET_AUTO_INIT=1 -DOPENTHREAD_CONFIG_OTNS_ENABLE=0 -DOPENTHREAD_CONFIG_PING_SENDER_ENABLE=0 -DOPENTHREAD_CONFIG_PLATFORM_BOOTLOADER_MODE_ENABLE=0 -DOPENTHREAD_CONFIG_PLATFORM_KEY_REFERENCES_ENABLE=0 -DOPENTHREAD_CONFIG_PLATFORM_LOG_CRASH_DUMP_ENABLE=0 -DOPENTHREAD_CONFIG_PLATFORM_NETIF_ENABLE=0 -DOPENTHREAD_CONFIG_PLATFORM_POWER_CALIBRATION_ENABLE=0 -DOPENTHREAD_CONFIG_PLATFORM_UDP_ENABLE=0 -DOPENTHREAD_CONFIG_RADIO_LINK_IEEE_802_15_4_ENABLE=1 -DOPENTHREAD_CONFIG_RADIO_LINK_TREL_ENABLE=0 -DOPENTHREAD_CONFIG_REFERENCE_DEVICE_ENABLE=0 -DOPENTHREAD_CONFIG_SNTP_CLIENT_ENABLE=0 -DOPENTHREAD_CONFIG_SRP_CLIENT_ENABLE=0 -DOPENTHREAD_CONFIG_SRP_SERVER_ADVERTISING_PROXY_ENABLE=0 -DOPENTHREAD_CONFIG_SRP_SERVER_ENABLE=0 -DOPENTHREAD_CONFIG_TCP_ENABLE=0 -DOPENTHREAD_CONFIG_THREAD_VERSION=OT_THREAD_VERSION_1_1 -DOPENTHREAD_CONFIG_TIME_SYNC_ENABLE=0 -DOPENTHREAD_CONFIG_TMF_ANYCAST_LOCATOR_ENABLE=0 -DOPENTHREAD_CONFIG_TMF_NETDATA_SERVICE_ENABLE=0 -DOPENTHREAD_CONFIG_TMF_NETDIAG_CLIENT_ENABLE=0 -DOPENTHREAD_CONFIG_TX_QUEUE_STATISTICS_ENABLE=0 -DOPENTHREAD_CONFIG_UDP_FORWARD_ENABLE=0 -DOPENTHREAD_CONFIG_UPTIME_ENABLE=1 -DOPENTHREAD_CONFIG_VERHOEFF_CHECKSUM_ENABLE=0 -DOPENTHREAD_FTD=1 -DOPENTHREAD_MTD=0 -DOPENTHREAD_POSIX_CONFIG_FIREWALL_ENABLE=0 -DOPENTHREAD_PROJECT_CORE_CONFIG_FILE=\"openthread-core-zephyr-config.h\" -DOPENTHREAD_RADIO=0 -DOPENTHREAD_SETTINGS_RAM=0 -DPACKAGE_NAME=\"OPENTHREAD\" -DPICOLIBC_LONG_LONG_PRINTF_SCANF -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR__=1 -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_sensor/build/modules/openthread/build/etc/cmake -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/etc/cmake -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/src/core -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/crypto/mbedtls/include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/modules/mbedtls/configs -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/modules/mbedtls/include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/src -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/examples/platforms/zephyr -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_sensor/build/zephyr/include/generated/zephyr -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_sensor/build/zephyr/include/generated -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/soc/nordic -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/lib/posix/options/getopt -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/soc/nordic/nrf53/. -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/soc/nordic/common/. -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/subsys/settings/include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/subsys/shell/modules/kernel_service/thread/.. -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/hal/cmsis/CMSIS/Core/Include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/modules/cmsis/. -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/hal/nordic/nrfx -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/hal/nordic/nrfx/drivers/include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/hal/nordic/nrfx/mdk -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/modules/hal_nordic/nrfx/. -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/modules/openthread/platform/. -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/hal/nordic/drivers/nrf_802154/serialization/include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/hal/nordic/drivers/nrf_802154/serialization/include/platform -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/hal/nordic/drivers/nrf_802154/serialization/include/serialization -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/hal/nordic/drivers/nrf_802154/common/include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/modules/hal_nordic/nrf_802154/include -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/third_party/tcplp/bsdtcp -I/home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/third_party/tcplp/lib -isystem /home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/include -isystem /home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/lib/libc/common/include -isystem /home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/lib/cpp/minimal/include -isystem /home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/examples/platforms -Wall -Wextra -Wshadow -Wno-c++14-compat -fno-exceptions -fno-strict-aliasing -Os -fcheck-new -std=c++11 -fno-rtti -imacros /home/mihai/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_sensor/build/zephyr/include/generated/zephyr/autoconf.h -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee -mtp=soft --sysroot=/home/mihai/ncs/toolchains/b81a7cd864/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros /home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -fno-pic -fno-pie -fno-asynchronous-unwind-tables -ftls-model=local-exec -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=/home/mihai/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_sensor=CMAKE_SOURCE_DIR -fmacro-prefix-map=/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/home/mihai/Documents/KNX_testing/nrf-knx-iot=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=picolibc.specs -D_POSIX_THREADS -nostdinc++ -fno-builtin -imacros /home/mihai/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_sensor/build/zephyr/include/generated/zephyr/autoconf.h -std=c++11 -MD -MT modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/link_api.cpp.obj -MF modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/link_api.cpp.obj.d -o modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/link_api.cpp.obj -c /home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/src/core/api/link_api.cpp
                 from /home/mihai/Documents/KNX_testing/nrf-knx-iot/modules/lib/openthread/src/core/api/link_api.cpp:39:
FATAL ERROR: command exited with status 1: /home/mihai/ncs/toolchains/b81a7cd864/usr/local/bin/cmake --build /home/mihai/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_sensor/build
 *  The terminal process terminated with exit code: 1.
 *  Terminal will be reused by tasks, press any key to close it.
Can you please advise what I am doing wrong?
Thanks.
Mihai
  • From the looks of it, it would seem that build command is not taking the openthread version correctly.
    The supported version is currently fixed on NCS v2.5.0. We haven't tested with v2.8.0.
    Is it possible to use west to build the application?
    Are you able to build some other OpenThread application (CLI) with VS code without issues?
    Amanda H.
  • Hello, Amanda.
    From the CLI, using west, I get the following error:
    ~/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_actuator$ west build -b nrf5340dk_nrf5340_cpuapp --force
    Loading Zephyr default modules (Zephyr base (cached)).
    -- Application: /home/mihai/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_actuator
    -- CMake version: 3.22.1
    -- Cache files will be written to: /home/mihai/.cache/zephyr
    -- Zephyr version: 4.0.99 (/home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr)
    -- Found west (found suitable version "1.0.0", minimum required is "0.14.0")
    CMake Warning at /home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/cmake/modules/boards.cmake:110 (message):
      Deprecated BOARD=nrf5340dk_nrf5340_cpuapp specified, board automatically
      changed to: nrf5340dk/nrf5340/cpuapp.
      /home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/cmake/modules/zephyr_default.cmake:133 (include)
      /home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
      /home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:97 (include_boilerplate)
      CMakeLists.txt:8 (find_package)
    -- Board: nrf5340dk, qualifiers: nrf5340/cpuapp
    CMake Error at /home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/cmake/modules/FindZephyr-sdk.cmake:80 (find_package):
      Could not find a package configuration file provided by "Zephyr-sdk"
      (requested version 0.16) with any of the following names:
        Zephyr-sdkConfig.cmake
        zephyr-sdk-config.cmake
      Add the installation prefix of "Zephyr-sdk" to CMAKE_PREFIX_PATH or set
      "Zephyr-sdk_DIR" to a directory containing one of the above files.  If
      "Zephyr-sdk" provides a separate development package or SDK, be sure it has
      been installed.
      /home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/cmake/modules/FindHostTools.cmake:53 (find_package)
      /home/mihai/Documents/KNX_testing/nrf-knx-iot/zephyr/cmake/modules/dts.cmake:9 (find_package)
    FATAL ERROR: command exited with status 1: /usr/bin/cmake -DWEST_PYTHON=/usr/bin/python3 -B/home/mihai/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_actuator/build -GNinja -S/home/mihai/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_actuator
    BR,
    Mihai
  • For the west build from CLI, I have the following errors:
    (.venv) (v2.5.0) mihai@mihai-Latitude-5410:~/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_sensor$ ls
    boards	build  CMakeLists.txt  Kconfig	prj.conf  src
    (.venv) (v2.5.0) mihai@mihai-Latitude-5410:~/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_sensor$ rm -rf build/
    (.venv) (v2.5.0) mihai@mihai-Latitude-5410:~/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_sensor$ west build -b nrf5340dk/nrf5340/cpuapp
    -- Application: /home/mihai/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_sensor
    -- CMake version: 3.20.5
    -- Using NCS Toolchain 2.5.20231017.513615545433 for building. (/home/mihai/ncs/toolchains/7795df4459/cmake)
    CMake Deprecation Warning at /home/mihai/Documents/v2.5.0/zephyr/cmake/modules/FindDeprecated.cmake:121 (message):
      'PYTHON_PREFER' variable is deprecated.  Please use Python3_EXECUTABLE
      instead.
      /home/mihai/Documents/v2.5.0/zephyr/cmake/modules/python.cmake:16 (find_package)
      /home/mihai/Documents/v2.5.0/zephyr/cmake/modules/zephyr_default.cmake:129 (include)
      /home/mihai/Documents/v2.5.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
      /home/mihai/Documents/v2.5.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
    -- Found Python3: /home/mihai/ncs/toolchains/7795df4459/usr/local/bin/python3 (found suitable version "3.8.2", minimum required is "3.8") found components: Interpreter
    -- Zephyr version: 3.4.99 (/home/mihai/Documents/v2.5.0/zephyr)
    -- Found west (found suitable version "1.1.0", minimum required is "0.14.0")
    -- Board: nrf5340dk/nrf5340/cpuapp
    No board named 'nrf5340dk/nrf5340/cpuapp' found.
    Please choose one of the following boards:
    arm:
      96b_aerocore2
      96b_argonkey
      96b_avenger96
      96b_carbon
      96b_carbon_nrf51
      96b_meerkat96
      96b_neonkey
      96b_nitrogen
      96b_stm32_sensor_mez
      96b_wistrio
      acn52832
      actinius_icarus
      actinius_icarus_bee
      actinius_icarus_bee_ns
      actinius_icarus_ns
      actinius_icarus_som
      actinius_icarus_som_dk
      actinius_icarus_som_dk_ns
      actinius_icarus_som_ns
      adafruit_feather_m0_basic_proto
      adafruit_feather_m0_lora
      adafruit_feather_nrf52840
      adafruit_feather_stm32f405
      adafruit_itsybitsy_m4_express
      adafruit_itsybitsy_nrf52840
      adafruit_kb2040
      adafruit_trinket_m0
      am62x_m4_phyboard_lyra
      am62x_m4_sk
      apollo4p_evb
      arduino_due
      arduino_giga_r1_m4
      arduino_giga_r1_m7
      arduino_mkrzero
      arduino_nano_33_ble
      arduino_nano_33_ble_sense
      arduino_nano_33_iot
      arduino_nicla_sense_me
      arduino_portenta_h7_m4
      arduino_portenta_h7_m7
      arduino_zero
      arty_a7_arm_designstart_m1
      arty_a7_arm_designstart_m3
      ast1030_evb
      atsamc21n_xpro
      atsamd20_xpro
      atsamd21_xpro
      atsame54_xpro
      atsaml21_xpro
      atsamr21_xpro
      atsamr34_xpro
      az3166_iotdevkit
      b_g474e_dpow1
      b_l072z_lrwan1
      b_l4s5i_iot01a
      b_u585i_iot02a
      b_u585i_iot02a_ns
      bbc_microbit
      bbc_microbit_v2
      bcm958401m2
      bcm958402m2_m7
      beagleconnect_freedom
      bl5340_dvk_cpuapp
      bl5340_dvk_cpuapp_ns
      bl5340_dvk_cpunet
      bl652_dvk
      bl653_dvk
      bl654_dvk
      bl654_sensor_board
      bl654_usb
      black_f407ve
      black_f407zg_pro
      blackpill_f401cc
      blackpill_f401ce
      blackpill_f411ce
      blueclover_plt_demo_v2_nrf52832
      bt510
      bt610
      cc1352p1_launchxl
      cc1352r1_launchxl
      cc1352r_sensortag
      cc26x2r1_launchxl
      cc3220sf_launchxl
      cc3235sf_launchxl
      circuitdojo_feather_nrf9160
      circuitdojo_feather_nrf9160_ns
      colibri_imx7d_m4
      contextualelectronics_abc
      cy8ckit_062_ble_m0
      cy8ckit_062_ble_m4
      cy8ckit_062_wifi_bt_m0
      cy8ckit_062_wifi_bt_m4
      cy8ckit_062s4_m4
      cy8cproto_062_4343w
      cy8cproto_063_ble
      cyclonev_socdk
      da1469x_dk_pro
      decawave_dwm1001_dev
      degu_evk
      disco_l475_iot1
      dragino_lsn50
      dragino_nbsn95
      ebyte_e73_tbb_nrf52832
      efm32gg_sltb009a
      efm32gg_slwstk6121a
      efm32gg_stk3701a
      efm32hg_slstk3400a
      efm32pg_stk3401a
      efm32pg_stk3402a
      efm32pg_stk3402a_jg
      efm32wg_stk3800
      efr32_radio_brd4104a
      efr32_radio_brd4180a
      efr32_radio_brd4187c
      efr32_radio_brd4250b
      efr32_radio_brd4255a
      efr32bg22_brd4184a
      efr32bg22_brd4184b
      efr32bg27_brd2602a
      efr32mg_sltb004a
      efr32xg24_dk2601b
      ev11l78a
      faze
      frdm_k22f
      frdm_k64f
      frdm_k82f
      frdm_kl25z
      frdm_kw41z
      fvp_baser_aemv8r_aarch32
      gd32a503v_eval
      gd32e103v_eval
      gd32e507v_start
      gd32e507z_eval
      gd32f350r_eval
      gd32f403z_eval
      gd32f407v_start
      gd32f450i_eval
      gd32f450v_start
      gd32f450z_eval
      gd32f470i_eval
      gd32l233r_eval
      google_dragonclaw
      google_kukui
      google_twinkie_v2
      hexiwear_k64
      hexiwear_kw40z
      holyiot_yj16019
      ip_k66f
      kv260_r5
      legend
      lora_e5_dev_board
      lpcxpresso11u68
      lpcxpresso51u68
      lpcxpresso54114_m0
      lpcxpresso54114_m4
      lpcxpresso55s06
      lpcxpresso55s16
      lpcxpresso55s28
      lpcxpresso55s36
      lpcxpresso55s69_cpu0
      lpcxpresso55s69_cpu1
      lpcxpresso55s69_ns
      mec1501modular_assy6885
      mec15xxevb_assy6853
      mec172xevb_assy6906
      mec172xmodular_assy6930
      mercury_xu
      mg100
      mikroe_clicker_2
      mikroe_mini_m4_for_stm32
      mimx8mm_evk
      mimx8mm_phyboard_polis
      mimx8mp_evk_ddr
      mimx8mp_evk_itcm
      mimx8mp_phyboard_pollux
      mimx8mq_evk_cm4
      mimxrt1010_evk
      mimxrt1015_evk
      mimxrt1020_evk
      mimxrt1024_evk
      mimxrt1040_evk
      mimxrt1050_evk
      mimxrt1050_evk_qspi
      mimxrt1060_evk
      mimxrt1060_evk_hyperflash
      mimxrt1060_evkb
      mimxrt1062_fmurt6
      mimxrt1064_evk
      mimxrt1160_evk_cm4
      mimxrt1160_evk_cm7
      mimxrt1170_evk_cm4
      mimxrt1170_evk_cm7
      mimxrt1170_evkb_cm4
      mimxrt1170_evkb_cm7
      mimxrt595_evk_cm33
      mimxrt685_evk_cm33
      mm_feather
      mm_swiftio
      mps2_an385
      mps2_an521
      mps2_an521_ns
      mps2_an521_remote
      mps3_an547
      mps3_an547_ns
      mr_canhubk3
      msp_exp432p401r_launchxl
      npcx7m6fb_evb
      npcx9m6f_evb
      nrf21540dk_nrf52840
      nrf51_ble400
      nrf51_blenano
      nrf51_vbluno51
      nrf51dk_nrf51422
      nrf51dongle_nrf51422
      nrf52810dmouse_nrf52810
      nrf52820dongle_nrf52820
      nrf52832_mdk
      nrf52833dk_nrf52820
      nrf52833dk_nrf52833
      nrf52833dongle_nrf52833
      nrf52840_blip
      nrf52840_mdk
      nrf52840_mdk_usb_dongle
      nrf52840_papyr
      nrf52840dk_nrf52811
      nrf52840dk_nrf52840
      nrf52840dongle_nrf52840
      nrf52840gmouse_nrf52840
      nrf52_adafruit_feather
      nrf52_blenano2
      nrf52_sparkfun
      nrf52_vbluno52
      nrf52dk_nrf52805
      nrf52dk_nrf52810
      nrf52dk_nrf52832
      nrf52dmouse_nrf52832
      nrf52kbd_nrf52832
      nrf5340_audio_dk_nrf5340_cpuapp
      nrf5340_audio_dk_nrf5340_cpuapp_ns
      nrf5340_audio_dk_nrf5340_cpunet
      nrf5340dk_nrf5340_cpuapp_ns
      nrf5340dk_nrf5340_cpunet
      nrf7002dk_nrf5340_cpuapp
      nrf7002dk_nrf5340_cpuapp_ns
      nrf7002dk_nrf5340_cpunet
      nrf7002dk_nrf7001_nrf5340_cpuapp
      nrf7002dk_nrf7001_nrf5340_cpuapp_ns
      nrf7002dk_nrf7001_nrf5340_cpunet
      nrf9160_innblue21
      nrf9160_innblue21_ns
      nrf9160_innblue22
      nrf9160_innblue22_ns
      nrf9160dk_nrf52840
      nrf9160dk_nrf9160
      nrf9160dk_nrf9160_ns
      nrf9161dk_nrf9161
      nrf9161dk_nrf9161_ns
      nucleo_c031c6
      nucleo_f030r8
      nucleo_f031k6
      nucleo_f042k6
      nucleo_f070rb
      nucleo_f091rc
      nucleo_f103rb
      nucleo_f207zg
      nucleo_f302r8
      nucleo_f303k8
      nucleo_f303re
      nucleo_f334r8
      nucleo_f401re
      nucleo_f410rb
      nucleo_f411re
      nucleo_f412zg
      nucleo_f413zh
      nucleo_f429zi
      nucleo_f446re
      nucleo_f446ze
      nucleo_f746zg
      nucleo_f756zg
      nucleo_f767zi
      nucleo_g031k8
      nucleo_g070rb
      nucleo_g071rb
      nucleo_g0b1re
      nucleo_g431rb
      nucleo_g474re
      nucleo_h563zi
      nucleo_h723zg
      nucleo_h743zi
      nucleo_h745zi_q_m4
      nucleo_h745zi_q_m7
      nucleo_h753zi
      nucleo_h7a3zi_q
      nucleo_l011k4
      nucleo_l031k6
      nucleo_l053r8
      nucleo_l073rz
      nucleo_l152re
      nucleo_l412rb_p
      nucleo_l432kc
      nucleo_l433rc_p
      nucleo_l452re
      nucleo_l452re_p
      nucleo_l476rg
      nucleo_l496zg
      nucleo_l4a6zg
      nucleo_l4r5zi
      nucleo_l552ze_q
      nucleo_l552ze_q_ns
      nucleo_u575zi_q
      nucleo_wb55rg
      nucleo_wba52cg
      nucleo_wl55jc
      numaker_pfm_m467
      nuvoton_pfm_m487
      olimex_lora_stm32wl_devkit
      olimex_stm32_e407
      olimex_stm32_h103
      olimex_stm32_h405
      olimex_stm32_h407
      olimex_stm32_p405
      olimexino_stm32
      pan1770_evb
      pan1780_evb
      pan1781_evb
      pan1782_evb
      pandora_stm32l475
      particle_argon
      particle_boron
      particle_xenon
      pico_pi_m4
      pinetime_devkit0
      pinnacle_100_dvk
      qemu_cortex_a9
      qemu_cortex_m0
      qemu_cortex_m3
      qemu_cortex_r5
      qomu
      quick_feather
      rak4631_nrf52840
      rak5010_nrf52840
      raytac_mdbt50q_db_33_nrf52833
      raytac_mdbt50q_db_40_nrf52840
      rcar_h3_salvatorx_cr7
      rcar_h3ulcb_cr7
      rddrone_fmuk66
      reel_board
      reel_board_v2
      rm1xx_dvk
      ronoth_lodev
      rpi_pico
      rpi_pico_w
      ruuvi_ruuvitag
      s32z270dc2_rtu0_r52
      s32z270dc2_rtu1_r52
      sam4e_xpro
      sam4l_ek
      sam4s_xplained
      sam_e70_xplained
      sam_e70b_xplained
      sam_v71_xult
      sam_v71b_xult
      scobc_module1
      seeeduino_xiao
      segger_trb_stm32f407
      sensortile_box
      serpente
      sparkfun_pro_micro_rp2040
      sparkfun_thing_plus_nrf9160
      sparkfun_thing_plus_nrf9160_ns
      steval_fcu001v1
      stm3210c_eval
      stm32373c_eval
      stm32_min_dev_black
      stm32_min_dev_blue
      stm32f030_demo
      stm32f072_eval
      stm32f072b_disco
      stm32f0_disco
      stm32f103_mini
      stm32f3_disco
      stm32f3_seco_d23
      stm32f401_mini
      stm32f411e_disco
      stm32f412g_disco
      stm32f429i_disc1
      stm32f469i_disco
      stm32f4_disco
      stm32f723e_disco
      stm32f746g_disco
      stm32f7508_dk
      stm32f769i_disco
      stm32g0316_disco
      stm32g071b_disco
      stm32g081b_eval
      stm32h573i_dk
      stm32h735g_disco
      stm32h747i_disco_m4
      stm32h747i_disco_m7
      stm32h7b3i_dk
      stm32l1_disco
      stm32l476g_disco
      stm32l496g_disco
      stm32l562e_dk
      stm32l562e_dk_ns
      stm32mp157c_dk2
      stm32vl_disco
      swan_r5
      tdk_robokit1
      teensy40
      teensy41
      thingy52_nrf52832
      thingy53_nrf5340_cpuapp
      thingy53_nrf5340_cpuapp_ns
      thingy53_nrf5340_cpunet
      thingy91_nrf52840
      thingy91_nrf9160
      thingy91_nrf9160_ns
      twr_ke18f
      twr_kv58f220m
      ubx_bmd300eval_nrf52832
      ubx_bmd330eval_nrf52810
      ubx_bmd340eval_nrf52840
      ubx_bmd345eval_nrf52840
      ubx_bmd360eval_nrf52811
      ubx_bmd380eval_nrf52840
      ubx_evkannab1_nrf52832
      ubx_evkninab1_nrf52832
      ubx_evkninab3_nrf52840
      ubx_evkninab4_nrf52833
      udoo_neo_full_m4
      usb_kw24d512
      v2m_beetle
      v2m_musca_b1
      v2m_musca_b1_ns
      v2m_musca_s1
      v2m_musca_s1_ns
      vmu_rt1170
      warp7_m4
      waveshare_open103z
      we_ophelia1ev_nrf52805
      we_proteus2ev_nrf52832
      we_proteus3ev_nrf52840
      wio_terminal
      xiao_ble
      xiao_ble_sense
      xmc45_relax_kit
      xmc47_relax_kit
      zybo
    arc:
      em_starterkit
      em_starterkit_em11d
      em_starterkit_em7d
      em_starterkit_em7d_v22
      emsdp
      emsdp_em4
      emsdp_em5d
      emsdp_em6
      emsdp_em7d
      emsdp_em7d_esp
      emsdp_em9d
      hsdk
      hsdk4xd
      hsdk_2cores
      iotdk
      nsim_em
      nsim_em11d
      nsim_em7d_v22
      nsim_hs
      nsim_hs3x_hostlink
      nsim_hs5x
      nsim_hs5x_smp
      nsim_hs6x
      nsim_hs6x_smp
      nsim_hs_flash_xip
      nsim_hs_mpuv6
      nsim_hs_smp
      nsim_hs_sram
      nsim_sem
      nsim_sem_mpu_stack_guard
      nsim_vpx5
      qemu_arc_em
      qemu_arc_hs
      qemu_arc_hs5x
      qemu_arc_hs6x
      qemu_arc_hs_xip
    arm64:
      bcm958402m2_a72
      fvp_base_revc_2xaemv8a
      fvp_base_revc_2xaemv8a_smp_ns
      fvp_baser_aemv8r
      fvp_baser_aemv8r_smp
      intel_socfpga_agilex5_socdk
      intel_socfpga_agilex_socdk
      khadas_edgev
      mimx8mm_evk_a53
      mimx8mm_evk_a53_smp
      mimx8mn_evk_a53
      mimx8mn_evk_a53_smp
      mimx8mp_evk_a53
      mimx8mp_evk_a53_smp
      mimx93_evk_a55
      mimx93_evk_a55_sof
      nxp_ls1046ardb
      nxp_ls1046ardb_smp_2cores
      nxp_ls1046ardb_smp_4cores
      phycore_am62x_a53
      qemu_cortex_a53
      qemu_cortex_a53_smp
      qemu_cortex_a53_xip
      qemu_kvm_arm64
      rcar_h3ulcb_ca57
      rcar_salvator_xs_m3
      xenvm
      xenvm_gicv3
    mips:
      qemu_malta
      qemu_malta_be
    nios2:
      altera_max10
      qemu_nios2
    posix:
      native_posix
      native_posix_64
      native_sim
      native_sim_64
      nrf52_bsim
    riscv:
      adp_xc7k_ae350
      esp32c3_devkitm
      gd32vf103c_starter
      gd32vf103v_eval
      hifive1
      hifive1_revb
      hifive_unleashed
      hifive_unmatched
      icev_wireless
      it82xx2_evb
      it8xxx2_evb
      litex_vexriscv
      longan_nano
      longan_nano_lite
      m2gl025_miv
      mpfs_icicle
      neorv32
      niosv_g
      niosv_m
      opentitan_earlgrey
      qemu_riscv32
      qemu_riscv32_smp
      qemu_riscv32_xip
      qemu_riscv32e
      qemu_riscv64
      qemu_riscv64_smp
      rv32m1_vega_ri5cy
      rv32m1_vega_zero_riscy
      sparkfun_red_v_things_plus
      stamp_c3
      titanium_ti60_f225
      tlsr9518adk80d
      xiao_esp32c3
    sparc:
      generic_leon3
      gr716a_mini
      qemu_leon3
    x86:
      acrn
      acrn_ehl_crb
      intel_adl_crb
      intel_adl_rvp
      intel_ehl_crb
      intel_ehl_crb_sbl
      intel_ish_5_4_1
      intel_ish_5_6_0
      intel_ish_5_8_0
      intel_rpl_s_crb
      qemu_x86
      qemu_x86_64
      qemu_x86_64_nokpti
      qemu_x86_lakemont
      qemu_x86_nokpti
      qemu_x86_nommu
      qemu_x86_nopae
      qemu_x86_tiny
      qemu_x86_virt
      qemu_x86_xip
      up_squared
    xtensa:
      esp32_devkitc_wroom
      esp32_devkitc_wrover
      esp32_ethernet_kit
      esp32_net
      esp32s2_franzininho
      esp32s2_saola
      esp32s3_devkitm
      esp32s3_luatos_core
      esp32s3_luatos_core_usb
      esp_wrover_kit
      heltec_wifi_lora32_v2
      intel_adsp_ace15_mtpm
      intel_adsp_ace20_lnl
      intel_adsp_cavs25
      intel_adsp_cavs25_tgph
      m5stickc_plus
      nxp_adsp_imx8
      nxp_adsp_imx8m
      nxp_adsp_imx8x
      odroid_go
      olimex_esp32_evb
      qemu_xtensa
      qemu_xtensa_dc233c
      xiao_esp32s3
      xt-sim
      yd_esp32
    CMake Error at /home/mihai/Documents/v2.5.0/zephyr/cmake/modules/boards.cmake:167 (message):
      Invalid BOARD; see above.
    FATAL ERROR: command exited with status 1: /home/mihai/ncs/toolchains/7795df4459/usr/local/bin/cmake -DWEST_PYTHON=/home/mihai/ncs/toolchains/7795df4459/usr/local/bin/python3.8 -B/home/mihai/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_sensor/build -GNinja -DBOARD=nrf5340dk/nrf5340/cpuapp -S/home/mihai/Documents/KNX_testing/nrf-knx-iot/samples/light_switch_sensor
    It would seem that I can't find the right board combo, although I did see as supported nrf5340dk/nrf5340/cpuapp.
    BR,
    Mihai
  • Please select nRF5340DK by nrf5340dk_nrf5340_cpuapp for NCS v2.5.0.
