HI ALL,
v2.8.0, nrf54l15, using the "periphral_uart" demo without any modifications
I downloaded nrf52840 using v2.8.0 and it runs normally, but nrf54l15 has issues.
The steps are as follows:
1.build
2.flash
3.Then
Thanks
HI ALL,
1.build
2.flash
3.Then
Thanks
Thanks a lot!!!
Hello, I've put nrfutil in the tolchains folder. Now I get this error. I type in device install but its says nrtutil command not found. VS on M4 mac 2.9SDK 54l15 DK
Flashing build54DK to 54L15 DK1
west flash -d /Users/rafal/Documents/Nordic_Boards/Apps/build54DK --skip-rebuild --dev-id 1057731392
-- west flash: using runner nrfutil
-- runners.nrfutil: reset after flashing requested
-- runners.nrfutil: Flashing file: /Users/rafal/Documents/Nordic_Boards/Apps/build54DK/merged.hex
Error: nrfutil command `device` not found. See `nrfutil list` for full list of installed commands, `nrfutil search` for installable commands, and `nrfutil install` for installation of new commands.
Caused by:
Subcommand nrfutil-device not found
-- runners.nrfutil: Board with serial number 1057731392 flashed successfully.
* Terminal will be reused by tasks, press any key to close it.
Please try to install the "device" command by running nrfutil install device.
Knut
I get thus when i type it:
rafal@Rafals-MacBook-Pro-M4 Apps % nrfutil install device zsh: command not found: nrfutil rafal@Rafals-MacBook-Pro-M4 Apps %
Note that there are additional steps after downloading nrfutil:
"After downloading the nrfutil executable, it is recommended to move it to a folder that is in the system's PATH. On macOS and Linux, the downloaded file will also need to be given execute permission by typing chmod +x nrfutil or by doing this in a file browser (this is typically a checkbox found under file properties)."
Knut
