Test existing nRF Connect project with nRF9151
Dear Nordic Support
We have an existing Project that uses the nRF9160 SoC and builds with toolchain v2.4.4 and SDK v2.4.4.
The project basically runs with the nRF9160 DK board (we derived a custom board with few changes and aliases).
Now I would like to evaluate our solution using the new nRF9151 DK Board. However, this undertaking is more difficult than originally assumed.
I tried to take the board definition of the nrf9151dk from the SDK v2.8.0 and add it to our existing custom boards. This seems not to work, as the board is not visible in the custom boards list in the board configuration dialog (when I switch the Toolchain and SDK version to v2.8.0 it appears).
Is there an easy approach to use the nrf9151dk board within the SDK v2.4.4 environment? (that would be the simplest solution for my purpose) (I also tried to migrate the project to SDK v2.8.0 but, so far, failed miserably)
I'm looking forward for your response. Thanks in advance for your support.
Kind Regards,
Stefan
  • Ok... please ignore the two posts before (I coudn't post because I had cmd<dot>exe in the text, which apeard to be refused by the portal)...
  • Here's my full response...
    Ok, after some other priorities I'm back...
    Once I figured out which environment variables to set, I could build the existing project (still using the nRF9160 SoC) via powershell CLI.
    Starting from this base I now try to build using the nRF9151DK board:
    cmd<dot>exe /d /s /c "west build --build-dir c:/work/YMR/ESW_BluePt_2/applications/productsw/comm_uc/build3 c:/work/YMR/ESW_BluePt_2/applications/productsw/comm_uc --pristine --board nrf9151dk_nrf9151_ns -- -DNCS_TOOLCHAIN_VERSION=NONE -DBOARD_ROOT=c:/work/ymr/esw_bluept_2/platforms/ele_test_hw_01/hal/nrf9160;c:/work/ymr/esw_bluept_2/platforms/ele_test_hw_01/hal/nrf9151"
    returns error
    C:/work/YMR/ESW_BluePt_2/platforms/ele_test_hw_01/hal/nrf9160/boards/arm/nrf9151dk/nrf9151dk_nrf9151_ns.dts:8:10: fatal error: nordic/nrf9151ns_laca.dtsi: No such file or directory
        8 | #include <nordic/nrf9151ns_laca.dtsi>
    compilation terminated.
    Then I copied the following files from SDK v2.8.0 to v2.4.4:
        nrf9151_laca.dtsi
        nrf9151ns_laca.dtsi
    Now the build returns:
    C:/work/YMR/ESW_BluePt_2/platforms/ele_test_hw_01/hal/nrf9160/boards/arm/nrf9151dk/nrf9151dk_nrf9151_common.dtsi:217:10: fatal error: common/nordic/nrf91xx_partition.dtsi: No such file or directory
      217 | #include <common/nordic/nrf91xx_partition.dtsi>
    The common/nordic folder doesn't even exist in v2.4.4. Still I created it and copied the file which lead to further errors.
    I doubt that this journey leads to success (as it's a hack and I don't really know what I'm doing... maybe Santa knows Nerd). Obviously the v2.4.4 SDK is missing some dependencies that are needed for the nRF9151DK board (and maybe some files that are there have been changed meanwhile).
    May you have more detailed info on what must be done to integrate the board? (otherwise I'll probably have to migrate our project to the latest SDK... trying an iterative approach based on a standard project)
    Can you show full structure of your project folder?
        nrf9151_laca.dtsi
        nrf9151ns_laca.dtsi
    Where did you copy these files from and where to?
    Dejan
  • Hi Dejan
    Meanwhile I have started to port the project to SDK v2.8.0 (we probably anyway would have to do this sooner or later).
    I already have a baseline including all our sources, that builds. However I hit another roadblock. It's something that doesn't fit anymore into this support case. I'll open a new request, and close this one.
    Thanks & BR,
    Stefan
  • Hi Stefan,
    Thank for the status update.
    Dejan
